Long climbs GC/SC ?
Long climbs GC/SC ?
Postby Crawf » Wed Dec 13, 2017 1:25 pm
Preferably quiet out of the way climbs, sealed, with a steady gradient, without too much traffic that are 20mins+, good for repeats?
Excluding the normal nebo/glorious/mee.
Any suggestions? Post some routes/Strava links if you have them?
- RonK
Re: Long climbs GC/SC ?
Postby RonK » Wed Dec 13, 2017 4:06 pm
GC
Nerang to Binna Burra
Canungra to O'Reillys
Currumbin Valley - Tomewin - Murwillumbah loop.
SC
Landsborough to Montville
Palmwoods to Montville
Nambour to Montville
Buderim 9 Challenge route.
- MichaelB
Postby MichaelB » Thu Dec 14, 2017 8:11 am
Binna Burra is good, but not the smoothest, but better than O’Reillys.
Have to look up the other loop from the GC recommended.
- RonK
Postby RonK » Thu Dec 14, 2017 11:49 am
Currumbin - Tomewin- Murwillumbah LoopMichaelB wrote:Have to look up the other loop from the GC recommended.
- MichaelB
Postby MichaelB » Thu Dec 14, 2017 1:17 pm
I presume Springbrook rd is still closed ?
Postby TheWall » Thu Dec 14, 2017 9:28 pm
Look up Postmans track as the hardest road on the coast followed by Obi Obi (so hard they named it twice) Rd. Obi Obi is hard to get to though as it is dirt on the way down as the road is split.
As mentioned Buderim Hills if you need to stay close to the beach and are up for repeats...Somerset Rd is the real challenge on Buderim - too hard for the Buderim9 event mentioned by RonK.
- singlespeedscott
Postby singlespeedscott » Fri Dec 15, 2017 12:17 am
Campbells Pocket Rd - steep pinches but a flatter reprieves in between - https://www.strava.com/segments/897475
Bellthorpe Range Rd - steepish steady climb with some nice little switch backs - https://www.strava.com/segments/8567369
Oceanview Rd, via Mt Mee Rd - nice and steady start, steep section at the start of Oceanview and then some ups and downs towards the top - https://www.strava.com/segments/16649743
Postby bwdftp » Fri Dec 15, 2017 9:33 am
Still closed, but apparently there is a well worn path around the rockslides - ie rideable.MichaelB wrote:Ta. Already have a route based from where I am staying taking in the 1st climb. Thanks
Postby Crawf » Fri Dec 15, 2017 3:48 pm
- MichaelB
Postby MichaelB » Fri Dec 15, 2017 5:40 pm
Any 1st hand data rather than 2nd hand ?bwdftp wrote:Still closed, but apparently there is a well worn path around the rockslides - ie rideable.MichaelB wrote:Ta. Already have a route based from where I am staying taking in the 1st climb. Thanks
Will prob do a Beechmont loop tomorrow for a starter
- MichaelB
Postby MichaelB » Sun Dec 17, 2017 3:44 pm
The hire bike is std crank with 11-28 cassette, so any sustained climb over 10% is a bit of an issue for a non mountain goat like me. Beechmont is ok, but the really steep pitches over 15% are an issue.
Any feedback on the three hills in this route ?
Ta
- A_P
- MichaelB
Postby MichaelB » Mon Dec 18, 2017 11:47 am
4hrs total ride time for me, so happy with that, given the humidity is a killer for me.
Ta
Postby bwdftp » Tue Dec 19, 2017 3:13 pm
A reasonable number of people are riding it - check results by month:MichaelB wrote:Any 1st hand data rather than 2nd hand ?bwdftp wrote:Still closed, but apparently there is a well worn path around the rockslides - ie rideable.MichaelB wrote:Ta. Already have a route based from where I am staying taking in the 1st climb. Thanks
https://www.strava.com/segments/1160977
- MichaelB
Postby MichaelB » Tue Dec 19, 2017 3:57 pm
- MichaelB
Postby MichaelB » Wed Dec 20, 2017 4:06 pm
So many leaves and bark covering the road, was a bit eerie, but would be a great descent.
Thanks for he tips
Postby doyouevenbike » Fri May 25, 2018 2:09 pm
- MichaelB
Postby MichaelB » Tue Aug 14, 2018 12:49 pm
Here are some routes and comments from rides/routes I've done in the past, so if you can offer some others or alterations, that'd be great. Don't mind some decent climbs, but someone in the area seems to love making roads with some REALLY steep pitches, and that gets tiring at the end of a ride - so happy to avoid them if possible ....
Up Springbrook & down Beechmont
Great rides as Springbrook was still closed. Happy to do again, but open to different ways back.
Over the Border
Some of the routing I did took me over some interesting bits heading out of Currumbin, and the flat bit on the NSW side before climbing back was a bit boring. Starting to run out of water before I found a servo around Bilambil
Up to O'Reillys from Canungra
Nice climb, but the road is bloody rough. Need 32c tyres or suspension for this, so probably won't do that again.
Binna Burra & return
Great views at end and really challenging last km, but also some crappy roads. Will do again.
Up Beechmont & back via Canungra & Clagiraba
Beechmont climb is great, but lack of water available along the way made it hard (set out a bit late), and being on a hire bike with 39/28 low gear made it a bit hard. Probably underfuelled as well.
Snapper Rocks Recovery ride
Nice coastal ride with some great places to have brekky halfway.
Happy to try some other routes, even if it has a (short) drive to get there.
Let me know your favourite routes !!!
- A_P
Postby A_P » Tue Aug 14, 2018 1:20 pm
couldn't pay me enough money to ride the nerang/beaudesert road.
Springbrook / Numinbah Valley / Tomewin (aka Big loop) best day out on a bike on the GC IMO
edit, Urliup Rd , has a couple of K of gravel , but easily rideable.
- MichaelB
Postby MichaelB » Tue Aug 14, 2018 1:52 pm
Be interesting to ride it then and see what the traffic is like, and maybe do the loop in reverse.A_P wrote: Springbrook road is planned to open again in October,
Is that the bit along Canungra/Caligiraba ? Wasn't brilliant, but didn't have any issues. Presume it's the traffic and speed that's the issue ?A_P wrote:couldn't pay me enough money to ride the nerang/beaudesert road.
Guess that means making a single route of the front half of Springbrook route & 2nd half Border Raid route. Cool, wioll see what that looks likeA_P wrote:Springbrook / Numinbah Valley / Tomewin (aka Big loop) best day out on a bike on the GC IMO
EDIT : OK, so looking at the map, You go from top of Springbrook, right onto Pine Creek Rd, then Left onto Nerang-Murwillumbah Rd to Numinbah, then down Tomewin (the bit where I went up on the Border Raid route), down into Currumbin and back to Benowa ?
Edit #2 : Seems like RWGPS won't let me follow Gold Coast Springbrook Rd from just after Polly's Country Kitchen as the road is still 'closed'. Will do it by just drawing lines, but will re-visit when the time is right.
OK, may try that. Planning on having 28c tyres on for the Qld trip, so that will hlp a bitA_P wrote:edit, Urliup Rd , has a couple of K of gravel , but easily rideable.
- MichaelB
Postby MichaelB » Tue Aug 14, 2018 2:22 pm
Is this what you mean ?A_P wrote:Springbrook / Numinbah Valley / Tomewin (aka Big loop) best day out on a bike on the GC IMO
Talk about a solid day out - 137km and 2,000m of elevation
- RonK
Postby RonK » Tue Aug 14, 2018 4:19 pm
It would be a bit less climbing to go via Advancetown and to the west of Hinze Dam to Numinbah.MichaelB wrote:Is this what you mean ?A_P wrote:Springbrook / Numinbah Valley / Tomewin (aka Big loop) best day out on a bike on the GC IMO
- MichaelB
Postby MichaelB » Wed Aug 15, 2018 12:23 pm
Different, but not by much.RonK wrote: It would be a bit less climbing to go via Advancetown and to the west of Hinze Dam to Numinbah.
I guess this is what you meant ? A bit shorter (124km vs 137km) and a tad less climbing (1,850m vs 2,050m).
To be honest, I'd rather climb Springbrook, as the route around the dam can have lots of traffic and high speed (OK to descend down there), and Springbrook is a nice climb. Either way, nice rides and big days out !!
Standing by for any other suggestions
Postby adam0bmx0 » Wed Aug 15, 2018 6:06 pm
https://www.strava.com/activities/1249757334
- MichaelB
Postby MichaelB » Mon Aug 20, 2018 8:58 am
Cheers, will have a closer look and give it a go. Thanksadam0bmx0 wrote:A nice scenic and quiet recovery roll is Currumbin Valley out and back, dead end road so not much traffic at all;
