Chain cleaning
- Aushiker
Chain cleaning
Postby Aushiker » Fri Jun 15, 2007 11:18 pm
I have taken a look at a couple of the suggested bike maintenance websites and both suggest using a citrus based de-greaser for cleaning chains.
Is such a beast available here Australia or preferably WA? I was in Bunnings today and they just had Diggers brand. Would this be okay?
Other suggestions?
Regards
Aushiker.com
- europa
- sogood
Postby sogood » Sat Jun 16, 2007 7:07 am
Don't worry about Sheldon's April Fools dig. Just for light reading.
Postby twowheels » Sat Jun 16, 2007 1:12 pm
- sogood
- gururug
Postby gururug » Sun Jun 17, 2007 10:34 am
It takes about 10 spin cycles through the chain cleaner (refilling each time) to get the majority of the crap off an the rest I do with a rag.
1x1ltr bottle ($5 from memory) will do about 6-8 cleans.
- Aushiker
Postby Aushiker » Sun Jun 17, 2007 4:38 pm
Dropped into TBE (LBS) today and they had a citrus degreaser (orange can) selling for $32.00 for 600 ml. Seems expensive. Does it sound right?
Torpedo7 have a product called BLUBIKE Bio Chain Cleaner selling for $8.00 for 250 ml which is quite a bit cheaper than TBE. Anyone tried this?
Regards
Aushiker.com
- Aushiker
Postby Aushiker » Sun Jun 17, 2007 5:01 pm
Thanks, yeah I considered the postage and thought if it was good I would include it another order. Of course I placed a order last night didn't Irider06 wrote:bear in mind the postage - $9.00 and its not so cheap. does a good job though - i got it in a package with blubike lube & chain cleaner a fair while ago.
Regards
Aushiker.com
Postby twowheels » Sun Jun 17, 2007 5:43 pm
that is why i saidAushiker wrote:G'day
Regards
... get along to Repco Auto and pick up Lightning Tuff cleaner/degreaser citrus base, 750ml non-aerosol spray pack, really great result, can remove the top and pour into a chain cleaner or other container or use as a spray on. About $10 from memory.
- Aushiker
Postby Aushiker » Mon Jun 18, 2007 3:06 pm
I have a Repco nearby (but not on a good riding road) so will check it out.
Aushiker.com
- tallywhacker
Postby tallywhacker » Mon Jun 18, 2007 6:48 pm
- Aushiker
Postby Aushiker » Tue Jun 19, 2007 1:54 pm
Twowheels I took your advice and dropped into Repco this morning and picked up Grime Goblin Cleaner/Degreaser which is a citrus based degreaser. I got the 4 litre container for $16.00. They had a one litre product for $10.99 but the Goblin seemed a better deal, assuming of course it is any good!
So thanks for the suggestion.
Regards
Postby twowheels » Tue Jun 19, 2007 3:55 pm
- sogood
Postby sogood » Tue Jun 19, 2007 4:13 pm
- Aushiker
Postby Aushiker » Tue Jun 19, 2007 5:34 pm
Well there is nothing to suggest on the container that diluting is needed or suggested, so what criteria do you use to determine this?sogood wrote:BTW, shop by volume isn't everything when it comes to citrus degreasers. Some products needs to be diluted (eg. 1:5 to 1:10), whilst others are meant to be used straight.
Also chain cleaning is one but use. Even so paying $4.00 per litre is heaps better than $11.00 for 600 mils in my view.
Regards
Aushiker.com
- sogood
Postby sogood » Tue Jun 19, 2007 5:52 pm
I don't know which product you refer to but the fact that it doesn't require dilution suggests to me that it's used without dilution. The one I have requires dilution prior to use. In any case, it's something to be aware of when shopping and trialing different products.Aushiker wrote:Well there is nothing to suggest on the container that diluting is needed or suggested, so what criteria do you use to determine this?
- Aushiker
Postby Aushiker » Tue Jun 19, 2007 6:19 pm
See early post in this thread.sogood wrote:I don't know which product you refer to but the fact that it doesn't require dilution suggests to me that it's used without dilution.
Okay, now I see where you are coming from. Hadn't consider that. Will do if I ever use up this container.The one I have requires dilution prior to use. In any case, it's something to be aware of when shopping and trialing different products.
Regards
Aushiker.com
Postby twowheels » Tue Jun 19, 2007 6:26 pm
Lightning Products - Cleaners>
See full size photo Price: No Price
Availability: in stock
Prod. Code: 502S, 502L,502N & 502T
Grime Goblin Degreaser utilises citric instead of petroleum solvents, is non-flammable, biodegradable and is a quick break degreaser. Grime Goblin Degreaser is ideal for cleaning and degreasing engine bays, workshop floors, walls and equipment. Grime Goblin also has dozens of domestic cleaning applications like removing soap scum and body oil from showers, cooking oil and animal fat from BBQs and even emulsifying stains from carpet and upholstery.
Available in:
SIZE
Description
PRODUCT CODE
COMMENTS
750ml
High Foam Atomiser Bottle 502S
Ready to Use Formula
1lt
1lt Screw Cap Bottle 502L
4lt
4lt Clear Plastic Container 502N
20lt
20lt Plastic Barrel 502T
- sogood
Postby sogood » Tue Jun 19, 2007 6:28 pm
Huh? Where did you think I was coming from?Aushiker wrote:Okay, now I see where you are coming from. Hadn't consider that. Will do if I ever use up this container.
