New trike build started
Re: New trike build started
Postby Drifter » Sat May 09, 2009 9:14 pm
Postby Drifter » Tue May 19, 2009 9:53 pm
- hartleymartin
Postby hartleymartin » Wed May 20, 2009 11:20 pm
YAY! Sorry, its just that the past 6 months has taught me to hate derailer gears.Drifter wrote:Trial fit of 3 speed hub and adjustable bottom bracket
Postby Recycler » Thu Jun 04, 2009 7:04 am
- hazmat5765
Postby hazmat5765 » Thu Jun 04, 2009 11:11 pm
Good luck, Rob.
Postby Drifter » Fri Jun 05, 2009 5:05 pm
Robert
PS. the solid tyres feel good on the road, did a couple of Ks today. Now I just need to build up my strength a bit for those hills.
- papa
Postby papa » Thu Jun 11, 2009 1:50 pm
Began life at 86 kg, currently at 36 kg. Powered via two Milwaukee 28v cordless drill batteries. An absolute blast to ride.
Postby Drifter » Thu Jun 11, 2009 4:13 pm
I have an electric hub motor but unsure as to how to wire it up.
Robert
- lemmiwinks
Postby lemmiwinks » Fri Jun 12, 2009 11:28 am
Red is positive, black is negativeDrifter wrote:Looks good, definitely an improvement on the original.
Robert
Postby Drifter » Fri Jun 12, 2009 5:23 pm
OK , but what about the blue, white, yellow and green wires.
Robert
- papa
Postby papa » Sat Jun 13, 2009 11:16 am
http://endless-sphere.com/forums/
- raptordesigns
Postby raptordesigns » Sat Jun 13, 2009 11:40 am
If you have these wires, not a red/black, then you need a 3 phase controller. There are effectively 3 windings inside the hub motor which have to be activated in the correct sequence and only when the rotor is in the correct position relative to a whole bunch of internal magnets. So the thick set of wires are for the drive and the thin wires of similar colour are for the internal sensor that indicates where the rotor is relative to the rim. The controller uses the sensor wires to determine which winding to drive.Drifter wrote:Lemmi,
Robert
Most 3-phase controllers will work OK, but some provide better torque than others, I've found. Your local e-bike shop may be able to help you with the appropriate parts.
John R.
Postby Drifter » Sat Jun 13, 2009 11:50 am
Robert
Postby Drifter » Sat Jun 13, 2009 12:01 pm
to connect the battery but there is something missing,like a junction box ,possibly inside a headlight unit. I don't know
if is 24V or 36V and there is a plug with 9 wires that goes nowhere, possibly for sensors , lights etc. If I connect a battery,
it might even work, but I wanted to be sure before doing that.
Robert
- lemmiwinks
Postby lemmiwinks » Mon Jun 15, 2009 12:34 pm
Depends, they might go to the controller or they might go to the hall effect throttle. As mentioned, endless-sphere will shed light.Drifter wrote:Lemmi,
Robert
- papa
Postby papa » Sun Jun 28, 2009 5:42 am
http://www.varnahandcycles.com/c05.htm
