Cadence training on bumpy ground
- flyingporkpies
Postby flyingporkpies » Wed Nov 04, 2009 9:57 pm
I like to stay fit too but I am having trouble 'adapting' standard training plans to my terrain. Living and riding in Kalamunda, Perth, I can't go anywhere for long without going up or down. The hills are not long, a few hundred metres, usually 1 or 2 k, the longest around here is about 4 k. The gradients are pretty reasonable averaging about 5% wherever I go. My God though, if you want to know pain try Zamia and Lenori's 15%+'s at the end of a 50. I did that last week and it made me cry!
Anyway, I digress. My fitness has gone off a bit lately so I got on the oracle and adapted some different ideas to put together a little training plan.
Here it is:
MONDAY RPM/Aerobic. 90-110rpm 1x60min or 2x30mins (am/pm). HR max 140 (80% of my max).
TUESDAY Just ride the bike.
WEDNESDAY RPM/Aerobic. 90-110rpm 1x60min or 2x30mins (am/pm). HR max 140 (80% of my max).
THURSDAY STRENGTH. 10/20 intervals on every climb in a 50k ride. Go below HR 140 inbetween.
FRIDAY Just ride the bike.
SATURDAY/SUNDAY Wish I was out riding my bike.
Straight away I ran into a problem. How do I ride up a hill keeping a cadence over 90 and a heart rate under 80%? Well the answer is I can't. So I decided to let the cadence take preference. On the bumps I got in the lowest gear and was able to stay at 90+ but quite quickly my heart rate would go up and after a few hundred metres would go into the 160s even. Once crested I had to stay in low gears twiddling around for a minute or 2 before my heart rate was below 140 again and I could then continue at a decent speed and cadence. The exercise feels awkward. Should I focus on the hr or the rpm? I can go up a hill much more slowly and keep the hr down, but not at high cadence. Should I lower my cadence target when going upwards (70?) Is 90-110 too high anyway? At the end of 2 40 minute sessions I did today (am/pm) I averaged a HR of 143 and a cadence of 96. I was puffed. That's on the flattest course i can find.
So cadence training/aerobic training on bumpy ground. Any tips? Cheers, flyingporkpies
- toolonglegs
Re: Cadence training on bumpy ground
Postby toolonglegs » Wed Nov 04, 2009 10:13 pm
- Alex Simmons/RST
Postby Alex Simmons/RST » Wed Nov 04, 2009 11:33 pm
2. focus on effort level and select a gear that feels good.
- flyingporkpies
Postby flyingporkpies » Thu Nov 05, 2009 10:15 am
Effort: (MAX HR 175 REST 34)
R9 158-175 90-100% (Z5) TT's and Hill climb TT's.
R8 140-175 80-100% PB attempts.
R7 140-158 80-90% (Z4) This is the zone I tend to do most of my rides in.
R6 122-158 70-90%
R5 122-140 70-80% (Z3) Is this where I should be in training? Or is ROPE 6 ok?
R4 105-122 60-70% (Z2)
R3 <105 (Z1)
- flyingporkpies
Postby flyingporkpies » Thu Nov 05, 2009 12:22 pm
I find I really struggle to keep a high speed on flat ground. There's no more than a kilometre of flat road at a time round here and even a little head wind makes it a real effort to keep the bike moving above 30kph. Windy and flat, my weakest area. Hell, I average a higher kph on a hilly course!
How do I train to get this flat riding up to 40 and keep it there without going into the red every time? Even 35 would be nice.
flyingporkpies
- toolonglegs
Postby toolonglegs » Thu Nov 05, 2009 6:16 pm
Watts are watts...flat or hilly.Learning to pedal hard on the dowhill sections (if safe) and holding back on the up hills might be the key.
- puffdaddy
Postby puffdaddy » Thu Nov 05, 2009 9:24 pm
Interesing Where I live in NZ there are literally hills in every direction from home,Last year in The 160km Taupo ride I done well on the first 90 km which is all undulating/hilly but the most difficult was the 30 km flat ride to the finish,This year I have my speed up on the flats 35-42 km solid but my hill climbing has suffered A balance is needed,Now 3 weeks out I am doing hill work and lots of it,In the Waitakere ranges over here,I have left it all a little late,I am not going down the cadence verses h/rate verses percieved effort ,I just experiment and go with what works best for me,,Good luckflyingporkpies wrote:While I've got my 4 minutes I'll add this:
flyingporkpies
Mike ,,NZ
Bike 2011 Scott ,,all good
Genius 27 sp flat bar ,modified with aerobars etc a strange beast but love it ,,kicks ass
- flyingporkpies
Postby flyingporkpies » Fri Nov 06, 2009 10:07 pm
I also had a look at the average cadence for all my Garmin course pbs and came up with 89, but that average obviously includes lower uphill cadences.
Looking at my pbs on hill climb TTs that I have done (a lot) my optimum cadence fell between 75 and 80.
Then I rode around a bit on flat/downhills and found 93 'felt' best, not 89, not 100, not even the mythical 96.
Then finally I rode for an hour on one of my flattest courses. Aerobically for 45mins HR 122-140, cadence in the 50s on the steep bits and 93 on the rest. If I dropped below 85 or went over 100 I changed gear. In the last 15 mins I allowed my heart rate to go up to 158 and kept the same cadence of 93 and 70-80 on the two hilly bits in that last quarter. I went over 158 once and backed off.
The result was the fastest last quarter I had achieved on that course and more importantly it felt good.
I believe it was Cinelli who said this was a good way to pace a longer ride. 75% perspiration, last 25% power up.
So here is my revised week:
Mon R5 HR 122-140 RPM 55 up and 93 elsewhere.
Tue Mtb 20kph for as long as I have time (I'm in training for a solo 12hr)
Wed STRENGTH 10/20s/rest on hilly 1hr course
Thur PB attempt@rpm93 75% at R6 HR 122-158. 25% at R8 HR 140+
Fri Mtb 20kph for as long as I have time
(Optimum ROPE rpm 93. >100 upshift. <85 downshift. Optimum HCTT rpm 70-80. R5 aerobic optimum rpm 55.)
Sounds a little complicated, but I'll do that next week and report back. Cheers,
flyingporkpies
- nimm
Postby nimm » Sat Nov 07, 2009 4:11 pm
If I could find a safe loop where I could keep the power on then that'd be an option but over winter I found on the downhills I'd get too cold so I gave up. Should do a few exploration rides now it's warmer and see how I go.
- toolonglegs
Postby toolonglegs » Sat Nov 07, 2009 6:57 pm
- flyingporkpies
Postby flyingporkpies » Sat Nov 07, 2009 8:51 pm
Postby Ant. » Sat Nov 07, 2009 11:06 pm
If I were you, do the weekly time trials! For most (all?), there is no better way to spend your training time than redlining for an hour and beyond! Seriously.
As a sidenote, my max heart rate is probably 200, I've hit 198 in the lab once without doing a max session (but was hurting, don't get me wrong). One of the few times I wore a heart rate monitor was on a 40km TT, and sat on 186bpm the whole time, that's what... 90%?
Cervélo P3C
BT Blade
- flyingporkpies
Postby flyingporkpies » Sun Nov 08, 2009 11:50 am
My problem has always been pacing. The idea was to teach myself to hold back for a bit and ride more efficiently by picking a comfortable range of rpm and beat. One example would be a 4 lap course I do. Best lap is always the first, then I suffer for 2 and come back stronger in the 4th. In the terrible 4 lap flat TT I did last week I did 8:30 for lap one then 9:10, 9:40, 9:50 or something like that. I blew it.
- Parrott
Postby Parrott » Sun Nov 08, 2009 2:16 pm
I have a similar max, have seen 203 on the hrm. I use the HR monitor as an adjunct to the burning in my legs and percieved effort in tt's. If it drops into the 170's I dig harder, I usually average in the mid 180's. Didn't have to do that in the last tt though. Had our club pharlap in front of me in a 24k tt, average HR190, stopped looking at it after a while, had nothing left anyway.Ant. wrote: As a sidenote, my max heart rate is probably 200, I've hit 198 in the lab once without doing a max session (but was hurting, don't get me wrong). One of the few times I wore a heart rate monitor was on a 40km TT, and sat on 186bpm the whole time, that's what... 90%?
- flyingporkpies
Postby flyingporkpies » Sun Nov 15, 2009 4:20 pm
The result was positive.
I beat a pb on a short course without going too deep by keeping my heart rate down to a 90% limit and pushing the biggest gear I could at the same time at a cadence of 70-80 on the climby bits and 90-95 on the flat bits and downy bits. The first 2/3 (15 minutes) I was only 5 seconds down and felt great. The final 1/3 I went harder and came in 10 seconds up. I think I could have taken more time if I'd only gone redline in the last minute, rather than blasting up a short rise 5 minutes from the end and suffering for it.
At the end of the working week training plan I got to thinking that pacing and tempo was good for me, and pushing big gears at low cadences was not, but I didn't want to be strapped up to heart rate monitors and cadence counters all the time, so I worked out a simple count I could do which would put me in the right cadence zone, and would then use comfort as a guide to which gear to be in.
This worked really well on a 200k superhilly Audax ride I did yesterday. All I did was count 1234 quickly with each foot being 1,3 and 2,4. I'd worked out from my cadence meter on Friday that this count equated to roughly 80-95 (fairly big range but not too low or high). Once my tempo felt good I'd stop the count and ride along quite comfortably until the terrain changed again. On the hills I used another count, sounds a bit daft but distracts from the pain: 1 for sorrow 2 for joy etc, the magpie song. All this did was stop me from accelerating or dropping off by keeping the pace regular. Even on the 15% final climb I felt good. In fact that was the easiest 200 I've done and it had 4000m+ of climbing! I attribute this to comfortable pacing and thank the posters who encourged me to listen to my body.
Finally, I would also like to say a little bit of science did me no harm. It helped me work out what works best for my physiology. Without it I'd be trying to emulate Contador's mad cadence or worse trying to big chainring every hill. I would also continue to falsely believe that what works best for me is to go out full gas, accept the inevitable fade and come 'good' at the finale. That's crap and now I know it.
flyingporkpies
