Chain tension - vertical dropouts
Postby Alistair » Tue Apr 13, 2010 4:50 pm
I'm just putting together a basic singlespeed as a training tool/commuter. I work in carlton and see so many around that i've decided to have a go myself...
Firstly, it is anti-hipster, so fashion isn't a consideration. I have got an alloy road frame that i've hacked up a bit and painted. The advantages were that it is very light, cheap and a good size.
The main issue is that it has vertical dropouts. I'm happy to run a chain tensioner from the rear derailleur hanger, but someone was trying to talk me out of that and saying something about a "magic gear calculator" or something. I've googled it and i'm not convinced that it will work, or be safe.
Am i better off sticking to plan A and running a tensioner? The plan is just to go single speed - i think fixed would be a bit trendy... If i'm better off with a tensioner, can anyone recommend one?
- boyracer
Re: Chain tension - vertical dropouts
Postby boyracer » Tue Apr 13, 2010 8:47 pm
buy my white industrie ENO eccentric hub for 130mm vertical drop out frames. make an offer.
Postby brauluver » Tue Apr 13, 2010 8:52 pm
MMMMMMM, nice clean look with less moving parts/friction, best of both worlds.boyracer wrote:or
- jaseyjase
Postby jaseyjase » Tue Apr 13, 2010 11:13 pm
thisboyracer wrote:or
Postby MiG » Tue Apr 13, 2010 11:33 pm
Postby Alistair » Wed Apr 14, 2010 7:38 am
I don't think I'm going to be coasting up hills, which is where it will make me work harder?
Postby MiG » Wed Apr 14, 2010 1:50 pm
You can mount a granny gear for hills and coast down the other side. Weak Fixed will punish you for choosing lazy gears. Plus it feels nice. Why don't you want to use fixed on the road? I commute fixed.
Postby brauluver » Wed Apr 14, 2010 2:36 pm
- familyguy
Postby familyguy » Wed Apr 14, 2010 2:43 pm
Too slack for fixed. Most roadies seem to fit neatly between every possible magic gear combo. Go the Eno and you can flip flop and keep MiG happy
Postby Alistair » Wed Apr 14, 2010 3:48 pm
I will be going with a decent gear too - the trip to work is a gradual uphill, but coming home is downhill and i don't want to be spinning out the whole way.
This is the frame anyway. I've just painted it, spent a while wetsanding and i'm pretty happy with how it is looking
- boyracer
Postby boyracer » Wed Apr 14, 2010 5:52 pm
120 clams and postage will get you one of the best hubs money can buy! It is polished alloy. Google 'White Industries ENO' . Your gunna have to buy/build a wheel anyhow. I would never run a spacer kit and jockey on a dished freewheel hub...not ideal for bullet proof commuter, especially as your a big bloke. Looks ugly too when you've spent all that time grinding and sanding to remove all extraneous crap. Hub is 32 hole flip-flop with track nuts (theft proof), meaning it is fixed one side and threaded for a BMX style freewheel on the other. I ran it fixed with a 1/8th cog/chain. This holds more lube and is stronger (and much cheaper) than 3/32 so lasts for years literally. My commuter fixed does 150 a week,rain or shine, and has been going for 2 years on its drivetrain. Def' recommend you have a go at fixed if you want to build strength/ endurance/ suplesse which is all important on those lung busting MTB climbs. This hub allows you to have both. Run a freewheel, say a 16(common) one one side and a 15 or 14 track cog on the other for your downhill run! My commute is the other way...bugger. The only problem with fixed comes when you value style over safety and go brakeless. yeah i got a brakeless track bike but i don't ride it every day. And us big lads look ridiculous in rolled up skinny jeans!
Hub hasn't seen a lot of use, was on my LOOK roadie as spare commuter!! I have since built a steel roadie for my spare bike and its 120mm spaced. I can buy new ends from WI to resize it but i have a Campy high flange wheelset on steelie and it looks just right.
Postby Alistair » Wed Apr 14, 2010 6:15 pm
- Boognoss
Postby Boognoss » Wed Apr 14, 2010 8:19 pm
Postby rustychisel » Thu Apr 15, 2010 11:33 am
Chain stretch, to put it simply. As you can see from FamilyGuy's bike the difference between good tension and poor tension is about 2mm adjustment in the dropouts... not easy sometimes. Get it right at first and within a couple of months you'll find the chain has stretched - significantly - and you need the extra adjustment. To get the right magic gear you often need a half-link in the chain, but they're often difficult to find and don't fit all chains. Thus, if you use a half link you're constricted as to choice of chains. It can work, but it's a bit fraught. The ENO obviates a lot of those difficulties, just watch out for
1) width OLN of hub and frame
2) enough cam adjustment on the frame
3) possible difficulty in running a rear brake with ENO (but I only use front brake).
Hope this helps.
Oh yeah, you can buy the Eno from US websites for less than what boyracer was originally asking, but don't tell him that For the price he's asking now, I'd be all over it like a fat kid on a custard tart.
- Boognoss
Postby Boognoss » Thu Apr 15, 2010 11:43 am
www.definitivecycles.com.au
Postby Alistair » Thu Apr 15, 2010 11:54 am
The rear brake thing is interesting too, and occurred to me as i was going to sleep last night. I have only used disks recently, and stopped riding road bikes as i was so unhappy with the crap brakes - does just the front brake stop you ok?
I didn't want a bodge anyway, and even with this i still have spent nothing on this bike. The cranks were $40, the frame $50, $25 for a can of colour/clear/sandpaper and i have bars, wheels, a fork and headset already. The only question now is whether to build a new wheel, or stick this hub into one of the cheap ones i have.
Postby rustychisel » Thu Apr 15, 2010 12:51 pm
- boyracer
Postby boyracer » Thu Apr 15, 2010 12:54 pm
US postal service used to fund a cycling team or something like that....probably from all the money they made shipping things to australia!!!rustychisel wrote:
Postby Alistair » Thu Apr 15, 2010 3:08 pm
My other concern is what kind of brake lever to use if i only had a front. I have drops, and wanted conventional aero levers. I'm not a fan of those ones near the stem... the ones i was going to use might be odd with only one though! I might have to look into it
Postby Alistair » Thu Apr 15, 2010 4:51 pm
- boyracer
Postby boyracer » Thu Apr 15, 2010 5:14 pm
Postby Alistair » Fri Apr 16, 2010 11:00 am
Another stupid question... how do you know i'm a big guy? You are right as i'm 6'4, but i don't think i have said that anywhere!boyracer wrote: I would never run a spacer kit and jockey on a dished freewheel hub...not ideal for bullet proof commuter, especially as your a big bloke.
- boyracer
Postby boyracer » Fri Apr 16, 2010 12:40 pm
Postby rustychisel » Fri Apr 16, 2010 1:04 pm
boyracer wrote:you look so peaceful when you're asleep....
Return to “Fixed Gear/ Single Speed”
