Problem in senstitive location
- mikesbytes
Postby mikesbytes » Fri Apr 30, 2010 7:38 am
Re: Problem in senstitive location
Postby crazycanuck » Fri Apr 30, 2010 9:17 am
- s-s-a
Postby s-s-a » Fri Apr 30, 2010 9:48 am
Is the problem from Spin classes or other cycling? Are they wearing knicks or just gym pants and undies? I reckon you could get some nasty abrasion from the leg elastic on your undies in that area.
I have had the odd nasty boil in that area (only two in well over a decade of cycling, thank goodness). There are a whole heap of subcutaneous glands in that area, and it only takes one getting blocked or an ingrown hair particularly if they are keen about waxing.
I was hoping you weren't going to ask about problems in even more sensitive locations
Steph
Postby Missy24 » Fri Apr 30, 2010 9:57 am
The original saddle that I had on the Cannondale was a Fizik and although its a great saddle, more so for men than women, or someone with awesome geometry and lighteness but the saddle where it does its curve actually pressed into the right side of my butt where it actually left an abraison.
What's the actual problem? But I would just go witht he normal advice that we always give people here, less stuff between you and the seat the better, shave or wax at least 12 hours before getting back on the bike, she may want to use a Chemise cream if she's finding that its because of friction. Invest in a good quality pair of knicks.
- mikesbytes
Postby mikesbytes » Fri Apr 30, 2010 6:50 pm
If they are wearing gym tights, I'd always suggest bike shorts as a first option. How much difference is there between female and male bike shorts? The reason I ask is that many would bulk at paying for expensive female shorts/bibs.
Undies... yeh its challenging to convince some to not wear them
I need to be careful what questions I ask, I am an employee. So I have to be careful with questions relating to hair removal, so not to be seen to be asking what their 'other' hair style is. The way around this to say some get the problem from ingrown hairs and its aggravated by personal moisture.
I should point out that the seats are wide enough for all, so unless undercarriage shape is a fair way from standard then the seats will not be a significant problem. The occasional female will add a gel seat cover, but it tends to ones who bounce due to technique issues.
Sweat is significant. Despite being typically a 45 minute class you sweat one hell of a lot in those rooms.
And yes, I have been questions about an even more sensitive location
Postby TheSkyMovesSideways » Fri Apr 30, 2010 7:04 pm
There are actually two different products called "Body Glide". One is a dry stick anti-chafing product sold in sports stores, and the other (by a company called Pjur) is a silicone lubricant sold in sex stores. Of the two, I've had horrible experiences with the former, and good experiences (on the bike ) with the latter. The anti-chafing one worked ok, but left a horrible stink in my knicks after washing them! The silicone lubricant one is good because you only need a little bit of it (it's got the consistency of cooking oil), it's odourless, it's made to go in sensitive areas, and it washes out easily.crazycanuck wrote:Body Glide helps.
I've also been told that Lucas' Pawpaw Ointment is very good for both treating and preventing chafing sores.
- Apple
Postby Apple » Fri Apr 30, 2010 7:33 pm
Seriously I think they should ask one of the regular members of your class so that they compare notes and give advice by a more experienced spinner.
I mean if a guy came to a spin class with a female teacher, I doubt he would ask about his sack and nuts
Or if you are feeling confident, you could always ask them to show you the problem in order to assist
I am soooooooooooooooooo bad when I have had a glass of wine.
- fleecedog
Postby fleecedog » Fri Apr 30, 2010 7:35 pm
I don't wear shorts spinning or cycling full stop - had a pair but bibs were just far superior since they made the chamois and the shorts themselves 'hug' your legs and cushion your sensitive areas and butt whereas the shorts are more prone to moving everywhere and chafing. So I do get stared at a lot when I wear my bibs to the gym but who gives, I would never sacrifice comfort to look good on a spin bike! After all, I have retired all my bibs but my Assos ones so they do look good. I had lady who asked me how much they cost and seriously bulked at the pricetag, but it is justifiable for me since I cycle outside the spin class. But I do understand why most women would be reluctant to shell out for a pair of decent shorts/bibs, you're looking at 100ish for something you'll only wear to the gym.
And I imagine a lot of women would be wearing undies underneath the shorts. It took me a few months to get rid of them when I cycle myself and they have made me a much, much happier person in general.
With regards to the male/female shorts. I don't think it's so much the chamois difference even though a lot of brands claim they make 'women specific' chamois but the fit is what's different. I will never fit into male shorts simply because it is cut differently and won't fit my hips and curves. I imagine it would be baggy and move around a lot. With my experience and shorts, always go for the more snug/skin tight size if possible. Never buy something slightly large or ill fitting.
I don't know if hair/shaving/waxing matters so much if you're just going for a one hour spin. You'd have to be pretty dumb to go spinning/riding if you've just recently shaven/waxed that area - riding would probably irritate it a lot and the cause is rather obvious? Just a thought
Postby Missy24 » Fri Apr 30, 2010 8:03 pm
Apple wrote:It may be due to them being new to spin class, that area my toughen up later.
Mike speak to a more experienced women in the class... someone whose been doing it for ages and see if they would be willing to have a chat, hard to diagnose without more info
- Apple
Postby Apple » Fri Apr 30, 2010 8:08 pm
Hey Missy, that's what I said. In my own wayMissy24 wrote: Mike speak to a more experienced women in the class... someone whose been doing it for ages and see if they would be willing to have a chat, hard to diagnose without more info
Postby Missy24 » Fri Apr 30, 2010 8:14 pm
oh yeah.... we're superApple wrote:Hey Missy, that's what I said. In my own wayMissy24 wrote: Mike speak to a more experienced women in the class... someone whose been doing it for ages and see if they would be willing to have a chat, hard to diagnose without more info
Postby vinvin » Fri Apr 30, 2010 9:00 pm
- s-s-a
Postby Robdog » Fri Apr 30, 2010 10:36 pm
Brilliant stuff, try it on literally anything and 90% of the time it will help. Chapped lips are a big one, so are cuts in places that are difficult to isolate and keep splitting open(knees, knuckles etc). I think it would work well as a lubricant in this case tooTheSkyMovesSideways wrote:I've also been told that Lucas' Pawpaw Ointment is very good for both treating and preventing chafing sores.
201x S-Works Shiv
2009 Avanti Cadent Team
- mikesbytes
Postby mikesbytes » Fri Apr 30, 2010 11:51 pm
The 2 particular woman did wear bike shorts but I'm not aware of the quality or suitability. I'm gathering for your feedback that the gender the chamois is designed for is not such an issue, but the cut is.
Generally most participants don't even buy bike shoes and use joggers in the toe straps. So directing them to Assos ain't gunna happen. Time on the bike is typically 45 minutes and some of that time is spent standing.
- Max
Postby Max » Sat May 01, 2010 5:18 am
I sooooooo was thinking of the wrong "lips" when I read that.Robdog wrote:Brilliant stuff, try it on literally anything and 90% of the time it will help. Chapped lips are a big one, so are cuts in places that are difficult to isolate and keep splitting open(knees, knuckles etc). I think it would work well as a lubricant in this case tooTheSkyMovesSideways wrote:I've also been told that Lucas' Pawpaw Ointment is very good for both treating and preventing chafing sores.
Max
Postby Missy24 » Sat May 01, 2010 7:20 am
Mike even a cheap pair of knicks should work and chemise cream, I kinda get the feeling it's a friction issue
Postby crazycanuck » Sat May 01, 2010 4:08 pm
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat May 01, 2010 4:47 pm
http://www.cyclefitcentre.com/pdf%20fin ... issues.pdf
Postby crazycanuck » Sat May 01, 2010 5:12 pm
Tell them to visit online cycling forums(here or TE) and see what info they can find. I think if i were a guy, i'd just have a cycling website list & just pass it on...Just don't tell them your user name...
Colin...so many things I could say but it would get me into trouble...
Postby Missy24 » Sat May 01, 2010 6:38 pm
Thanks Alex, we really appreciate the information.Alex Simmons/RST wrote:While not spin class related, these two items are specifically about the issues of cycle fit/positioning for women:
Postby Robdog » Sat May 01, 2010 11:10 pm
Pleased to say I'll never have *that* particular issue....Max wrote:I sooooooo was thinking of the wrong "lips" when I read that.Robdog wrote:
Max
201x S-Works Shiv
Postby orphic » Thu May 06, 2010 2:20 pm
- Apple
Postby Apple » Sat Sep 04, 2010 10:04 pm
- Mulger bill
Postby Mulger bill » Sat Sep 04, 2010 10:09 pm
I thought so, I wasn't alone. I resealed his canApple wrote:OMGosh again Hey respect, what are you, advertising. Not allowed on this forum
