2010 Rainbow Ride
- RobM
2010 Rainbow Ride
Postby RobM » Sun Apr 25, 2010 9:30 pm
Map Here
One of my goals is to do this ride at the end of the year. If i keep up my training i should be okay but im worried about the climbs (especially the one at the finish line ). The area i live doesn't have that many hills so a local 100km ride for me is alot different to 100km thru the mountians.
Anyone do this ride last year? Any tips or pointers?
Rob
- goneriding
Re: 2010 Rainbow Ride
Postby goneriding » Mon Apr 26, 2010 11:14 am
The other ride to do is the River Loop with Mt Coot-tha thrown in for good measure. Somewhere between 50-60 kms with a reasonable amount of up and down. If you haven't done the River Loop before head over to La Dolce Vita in Park Rd at around 6am and go from there with the bunch. Check when you get there as there is a fast and a slow bunch.
I'd also suggest doing a couple of the participation rides that are on in Bris. Bris to Gold Coast, Brissie to Bay, etc to get used to how it all works.
Enjoy!
- Pax
Postby Pax » Mon Apr 26, 2010 1:34 pm
Hmmm...Perhaps Byron to Nth Brisbane and get that elusive 300k target ticked off??????? (yeah yeah who am I kidding )
- Pax
Postby Pax » Mon Apr 26, 2010 2:35 pm
Hey Rob, I definitely have't done this ride so someone who has might correct me here; However by the look of the elevation profile and the route description it looks like a 350m verticle gain over a 5k distance. That is a 7% climb. MT Glorious would be great training for that (as Goneriding suggests).punk_rob wrote:One of my goals is to do this ride at the end of the year. If i keep up my training i should be okay but im worried about the climbs (especially the one at the finish line ). The area i live doesn't have that many hills so a local 100km ride for me is alot different to 100km thru the mountians.
Rob
7% is pretty doable with a bit of training. However you might find that though the average is 7% it might have some peak bits at 10% or more; and that is getting steep.
It would be interesteing to hear from someone who has done this rout before or who at lease knows the climb up MT Tomewin
- elantra
Postby elantra » Mon Apr 26, 2010 11:19 pm
DON'T do it like my effort last year.punk_rob wrote:Details Here
Map Here
Rob
I did the 96 km option from Mooball (NSW) to Currumbin (Qld)
Drove down to the start with a friend, you know, up at 0.darkhundred o/clock and no breakfast.
2 and a bit hour drive, there used to be an enormous roadhouse at Mooball but it has closed.
Small servo only there now.
So started the ride after no breakfast.
Rode strongly for the first 60 km, then starting to fatigue just before Chillingham.
There i ate a big piece carrot cake with thick icing and washed down with a can of coke.
Felt sick +++ for the rest of the ride, therefore had to walk up most of the climb up Tomewin, which is actually not that bad, not as big as Mt.Nebo.
But the problem of course, is that it is at the conclusion of a hard ride.
Overall it is a great ride and i will try to do it again this year but will try to spend the night somewhere close to the start.
Oh and i will not buy the carrot cake and coke at Chillingham.
- RobM
Postby RobM » Tue Apr 27, 2010 8:10 am
As for climbs, a few questions (sorry if theyre obvious):
- is there a right direction to do the mt cootha ring road up the mountain? I only ask because someone once told me that they only go up/down one side as the other side is abit sketchy.
- what road/s do you follow for the mt nebo and glorius climbs? Ill try to look them up in bikely.
- lastly, on my normal rides i usually take a banana and some homemade energy gels with 1 bottle with gatorade to keep me going. Should i bring more if im doing climbing? Eg. Am i likely to bonk faster/harder and need to prepare for it.
Thanks guys. I cant wait to do this ride - sounds pretty scenic too. Ive also entered the Brissie to Bay and will enter the Bris to GC to get the hang of riding in large groups. Almost all of my riding is done solo otherwise (but at least i build up the mental toughness talking to myself for 3hrs haha)
- goneriding
Postby goneriding » Tue Apr 27, 2010 9:48 am
No. Either way is fine. If you are starting out I recommend the front side as it is a bit easier. That is where you turn left up the road from the gardens. The back side is where the Coot-tha Challenge is run and is avg 9% for 2.3 km's. Save that for a day when you have some climbing on your legs.
Waterworks Rd for Mt Nebo and Glorious (this follows on from Nebo unless you come from the Samford side).
It's going to hurt more. As to whether you need more, for me, no but everyone is different. I'd suggest taking a gel hit about 5 mins before the start of the climb.
The other thing is to make sure, that for the longer climbs, you get a rythym going otherwise you will blow up. For me alternating in and out of the saddle for seems to work as it changes the muscle groups being used. Watch out for the arms getting tired on steeper climbs as well. The only other thing to do is HTFU! Best of luck
- monkeymajik
Postby monkeymajik » Tue Apr 27, 2010 12:24 pm
- Brockie
Postby Brockie » Tue Apr 27, 2010 3:34 pm
- kiso
Postby kiso » Tue Apr 27, 2010 7:22 pm
I always do it anti-clockwise: up the back way and down the front way.
- Pax
Postby Pax » Tue Apr 27, 2010 7:39 pm
Yep, anti-clockwise is also recommended by Bicycle Qld.kiso wrote:You can go up Mt Coot-tha either way - as Brockie says, the back way is harder. It's recommended you don't go down the back way - it's narrow and windy and there's too much chance of collision with a car coming up - apparently a cyclist was killed a couple of years ago.
The added bonus is an absolutely fantastic, fast and pretty safe descent as a reward for the hard climb up the back. JUST remember that the descent down the front ends at a T intersection & stop sign, so get on the brakes in sufficient time
Postby whichway » Mon May 03, 2010 6:41 pm
I just did the Tour de Tweed Grand Fondo which is about 136 kms of almost the same ride as the Rainbow Ride, but without the big 300m hill at the end.
Training - Do some 120km to 140km rides, with some rolling hills. I would suggest you need to do two or three rides of about that length. Do some Mt Gravatts, but Mt Cootha is better. Do Nebo at least once. So from Runcorn, ride out to Samford and back a few times, but early on a Sunday morning to avoid the Traffic. You need to do some moderately serious hill climbing before you do some of the hills around the Tweed. Be aware that at that time of the year, you might hit a headwind for the last third of the ride so practice headwinds too.
Water - Carry at least two bottles, drink one every hour. Work out what you need in them - I use half strength Endura, so I carry extra Endura to put in the bottles. You need to keep your electrolytes up to avoid cramping (which I am still working out how to do).
Finally - This is spectular country and it would be a great ride, but you need to be fit enough to do it without dieing.
Hope this helps
whichway
- RobM
Postby RobM » Tue May 04, 2010 8:28 am
I will probably do the 100km Rainbow Ride and have already done a few 80ish km ride so ill keep pushing them up until i get over 100km. And try to work in some headwind riding too.
How much food did u take for a +100km ride? Is it best not to rely on the food stations on a ride like this? Eating too much a bad thing?
rob
- elantra
Postby elantra » Tue May 04, 2010 3:06 pm
In relation to the Rainbow ride last year, i might need to be corrected but i do't recall there being any food offered at all, just water.punk_rob wrote: How much food did u take for a +100km ride? Is it best not to rely on the food stations on a ride like this? Eating too much a bad thing?
rob
However the ride did pass through a few small towns and so you can purchase nibblies in the shops along the route, specifically at Mooball, Tyalgum, and Chillingham.
However, just to labour the point, do not do what i did
Part of the problem is that the 2 shops in Chillingham actually have a lot of yummy stuff for sale.Drove down to the start with a friend, you know, up at 0.darkhundred o/clock and no breakfast.
Postby ryan » Fri May 07, 2010 4:02 pm
try magnesium tablets from your local chemist in the lead up to big rides. I haven't had a cramp since doing this but your results may vary.
This looks like a fun ride. No ready to commit but definitely considering it.
Postby dclnmurray » Mon Nov 01, 2010 12:50 pm
Sorry to resurrect an old post but is getting close to that time.
I did a ride on Saturday of 145km's so i think I am ready. The only thing is the there are a lot more hills. i still felt strong at end of ride and managed to ride up the Gaza rd/Mt Gravatt hill between 20-26kph.
As i don't know the route and the hills I have an 11-23 cassette on the bike but also have an 12-25 and 13-29 cassette I can change to. I know only I can answer the ultimate question but should I put on the 12-25 as insurance against the last hill and that i might run out of steam
Dave
Postby ryan » Mon Nov 01, 2010 3:00 pm
I would go with the 12-25, especially if you are running 53/39 up front. I would much prefer to be spinning out on the downhills than slowly grinding up Tomewin with 130km in the legs.dclnmurray wrote:Hi all
Dave
I'm working through the logistics of doing this without a car, but am keen. Have done Brisbane to Kilcoy via Nebo/Glorious/Somerset Dam and a 500km 3-day ride through Byron Bay hinterland and am feeling ok. I guess time will tell.
Anyone here signed up?
- the grid
Postby the grid » Mon Nov 01, 2010 4:47 pm
Thanks in advance.
- the grid
- elantra
Postby elantra » Tue Nov 02, 2010 10:34 am
Tomewin Hill is not steep steep steep.the grid wrote:I have got a compact crank 50/34 (i think ) with 12/23 cassette and still think I need more for the Tomewin Hill. Should I go to 12/25 or even 11/28?
Thanks in advance.
From the New South side it is only steep.
Its the sort of hill that under good conditions 34/23 would be more than adequate.
However if you have got empty legs because of a fast pace for the preceding 100+ km, then no amount of granny gear will save you from walking.
So put some thongs in your jersey would be my advice.
Sorry to be a pessimist.
- the grid
Postby the grid » Wed Nov 03, 2010 8:13 am
I have been up and back twice over Tomewin in the last two weeks and 34/23 doesn't cut it for this old man so 34/27 is my next step.
PS I live at the bottom on the QLD side so I paln to keep on doing it.
Postby dclnmurray » Wed Nov 03, 2010 2:23 pm
Dave
- elantra
Postby elantra » Wed Nov 03, 2010 3:18 pm
When i did it last year i think there was about 250 riders started at Byron Lighthouse and about 150 started at Mooball.dclnmurray wrote:Does anyone know roughly how many riders normally do this ride?
Dave
so i think there was about 400 in total.
The Mooball riders were allowed to start after the Byron peleton had gone through.
The ride is a very pleasant one but also quite challenging because of the very significant hills, and perhaps also the weather.
Not many cars for much of the route.
More cars after Chillingham, including a large number of classic Ferrari's on an outing last year
Postby whichway » Fri Nov 05, 2010 8:39 am
whichway
