This is harder...
- mikesbytes
Re: This is harder...
Postby mikesbytes » Fri Jun 04, 2010 6:10 pm
When climbing at Ken Dinnerval on Sunday it was evident how much that the 14 extra KG I was carrying in comparison to a rider well known to oprhic was affecting me. I had intended to do Ken Dinnerval (AT) 78kg, but didn't find a suitable calorie deflect window so went there with 81kg. Now there's no reason to concern myself with weight until later in the year.
- toolonglegs
Postby toolonglegs » Fri Jun 04, 2010 7:16 pm
But as long as I haven't got a giant tumor (touch wood) eating up all my calories I will take the weight lose happily.Something has to go right at the moment.
PS...I haven't got your standard garden type hernia...but I am having a scan for a femoral hernia (sometimes much smaller and more painful).I have that next thursday...then straight after I have the "doppler"?...inject a magenitc dye into me and then check that I haven't got problems with my Iliac Artery...the doctor said I can't wait till August for that one.Then MRI on the back the week after...just hope that something turns up as I am becoming more and more crippled everyday .
One big bonus of living here is that everything medical is 100% free!.
- mikesbytes
Postby mikesbytes » Fri Jun 04, 2010 7:44 pm
Postby orphic » Sun Jun 06, 2010 12:44 pm
I have been eating a lot this week. My version of a lot is probably just on maintenance... The thing is, I have felt SO much stronger when riding. For the last few months I would get to the point in the ride where my legs would hurt and they would just turn to jelly and die. This week they've been hurting but they have been feeling strong and keep pushing on. I was able to do a hard 120km ride yesterday and back it up with a moderate 70km's today and I was still feeling good at the end. Anytime I tried to do that in the past I would die about 30km's into the second days ride.
So my question is, should I stick to maintenance and get stronger or should I try and lose weight to make me faster up the hills? Hill climbing is my weakest link, but if you don't have the leg strength then you are screwed - right? I should add that I've been riding for ~12 months, and spent probably about 6 months of that training on the track and not doing much in the way of hill riding at all. I've only really increased my road km's this year.
How do you direct your calories towards building muscle, and not putting on fat? And is it remotely possible to do the two in unison? Or should I be cycling it? So many questions!
- toolonglegs
Postby toolonglegs » Sun Jun 06, 2010 3:44 pm
My reasoning is I can't ride so I can starve myself for a while so that when I hopefully ride again I will be at my goal weight and I can eat normally instead of being in deficit all the time!...after all I am going to lose the muscle anyway!...might as well lose the fat too!!!.
For you...you were obviously dieting too hard...yeah I would back it off a bit.Better to lose a couple of hundred grams a week than a kilo at your size.No wonder you ran out of energy a couple of weeks ago.
Personally I would just train hard / eat right and let your body do the rest ...that's what it does well after all!.Don't over think it too much .Not worth being a kilo or two lighter if you have no energy!.
- mikesbytes
Postby mikesbytes » Sun Jun 06, 2010 11:12 pm
There is a way that you can get stronger and loose weight and that's to have protein with a high Gi carb, zero fat within 25 minutes of exercise and then apply normal diet rules for the rest of the day. It's something that I've been meaning to do, but fail to get my act together.
BTW Orphic, how come 70k on Sunday, did you take a shortcut after your 2 flats?
Postby orphic » Mon Jun 07, 2010 10:08 am
I think that the way you are talking about would ensure glycogen stores are replenished, but not necessarily build muscle.
At the moment I'm just trying to figure out what advantage weight loss would bring. So far it's only brought weeks of turmoil as I am hungry, not performing well and frustrated.
- toolonglegs
Postby toolonglegs » Tue Jun 08, 2010 3:17 pm
Postby orphic » Tue Jun 08, 2010 4:10 pm
Body fat % is within recommended limits but closer to the upper end of the scale than the lower.
Lean body mass is normal for my height, and fat mass in kg's is under the normal range for females and heading toward the athlete range - but I am not sure that applies given how tall I am (5'4"). BF% is probably a better measure anyway. If only I was taller
I am not 100% sold on the recommendations, however.
Suggested calorie intake to attain ideal weight based on my resting metabolic rate (which is 1402kcal) is 1500cals with 113g of protein, 150g of carbs and 50g of fat. I been roughly following this (although striving for a few less calories) and I think the carbohydrate intake is too little. They then recommend your weekly exericise energy expenditure target - which is >2500cals for me. Problem with that is that I still don't really know the accuracy of my HRM calories burnt, and dividing the output by 2 may be under cutting and causing me dramas. Currently, when dividing it by 2, I burn approximately 3000cals per week - which is over 12hrs of riding. The orginal output would be 6000cals, or dividing by 1.33 like I have done in the past would yeild a result of 4500cals. It's a big difference.
Anyway, after doing some thinking today I decided to cycle my calories a bit. With my resting metabolic rate at 1402, my estimated daily expenditure without exercise is 1600cals. So I'm going to try to cut by 400cals M-W, 200cal on Thursday and hit maintenance for Friday-Sunday just until I feel like I have things right. It's only going to be a weekly deficit of 1400 but it's better than nothing, and if I am underestimating my HRM calories then I might find more weight drops off.
- toolonglegs
Postby toolonglegs » Tue Jun 08, 2010 4:40 pm
Don't eat any carbs after 7pm and try a 30 minute walk before bed...maybe try a protein drink before bed.
I am starving!!!....but I have to wait till I have blood test at 9! ...but weight is falling again.I am probably the lightest I have been since 2001.I am looking thin but certainly not skinny...in another 10 kilos it may be a different story!.
- puffdaddy
Postby puffdaddy » Mon Jun 14, 2010 10:30 pm
Mike
Bike 2011 Scott ,,all good
Genius 27 sp flat bar ,modified with aerobars etc a strange beast but love it ,,kicks ass
- toolonglegs
Postby toolonglegs » Mon Jun 14, 2010 10:41 pm
92.1kgs after my ride today...down from 105.5 on 29th Jan.
PS...I will be at Mount Manganui or Cambridge from the 17th of Dec till the 31st...if I get some fitness back you can show me a ride around the Coramandel
- puffdaddy
Postby puffdaddy » Mon Jun 14, 2010 10:51 pm
Mike
Postby tripstobaltimore » Mon Jan 10, 2011 5:33 pm
How is everyone else going?
Postby tripstobaltimore » Mon Jan 10, 2011 5:35 pm
- Wino
Postby Wino » Mon Jan 10, 2011 10:10 pm
11 BMC RoadRacer SL01, black
Postby tripstobaltimore » Tue Jan 11, 2011 6:55 am
I think we all are! I think I need to either look at my calories from exercise or my base rate - day off the bike yesterday (which are usually pretty hard to stick to), and ate under my allowance, but it wasn't very hard Will see if the weight goes down over the next couple of weeks....Wino wrote:but way behind what I would like. But I think I said that last year.
Postby ireland57 » Tue Jan 11, 2011 11:17 am
And..... consequently I don't get on the scales very often because I know it'll be much the same.
The last 2 months I noticed a bit of blubber sneaking up when I wasn't looking. Clothes a bit tighter, etc.....
This morning 68 kgs. Scales are obviously fooked. It's nothing to do with me losing discipline and eating more junk food.
Geez Louise!
More riding!
- ni78ck
Postby ni78ck » Tue Jan 11, 2011 12:21 pm
looks like the festive season has got the better of youireland57 wrote:I've been 65-66.5 kgs for the last 8 years mostly due to martial arts and now bike riding.
Geez Louise!
More riding!
back to eating tuna!!!
Cervelo S5 VWD - dura ace Di2
Postby ireland57 » Tue Jan 11, 2011 2:47 pm
Welll yesss! It did. Good thing too.ni78ck wrote:looks like the festive season has got the better of youireland57 wrote:I've been 65-66.5 kgs for the last 8 years mostly due to martial arts and now bike riding.
Geez Louise!
More riding!
Even though I've rarely had a drink for the last few years I gave up drinking a year ago because it interfered with riding. Broke the rule Xmas Eve though.
Now the price is to be paid. In full.
Pain is merely weakness leaving the body.
- mikesbytes
Postby mikesbytes » Tue Jan 11, 2011 6:18 pm
Postby tripstobaltimore » Tue Jan 11, 2011 10:09 pm
Lots of pro's wandering around the streets of adelaide at the moment! (not prostitutes, for the smart asses)
Postby tripstobaltimore » Tue Jan 18, 2011 1:44 pm
Postby tripstobaltimore » Fri Jan 21, 2011 8:49 am
Users browsing this forum: piledhigher2
