Jamis Build Thread
- europa
Postby europa » Mon Oct 29, 2007 11:52 am
She's HERE
Not that I'm excited or anything
Typically, my horrid old camera doesn't do her justice, she really is a lovely colour blue with just a hint of purple.
A run over her with the ruler puts her right in there with the Europa - same top tube length, seat tube length a cm lower (which will be good actually) and a tall enough headtube and steering tube to allow me to put the bars in a half reasonable position.
Brand new frame - no sign of head stem bearings ever been fitted. A few tiny chips here and there, including the ones I added as I discovered she doesn't sit securely on the bottom bracket
Weight? 3.1 kg - feels like nothing to lift.
After postage (she had to come by FedEx in the end), she's cost me $242
Now for the build ... and decisions have been made there
- MichaelB
Postby MichaelB » Mon Oct 29, 2007 12:55 pm
I got a couple of quotes for getting a frame from the USA, and had some prices at USD $600 - for the shipping alone ?????
I'd love to know the box dimensions and weight for other possible encounters on eBay.
What was the actual postage costs charged ?
Noice blue der fella !!
- europa
Postby europa » Mon Oct 29, 2007 12:59 pm
$56 US - that's via FedEx. Originally they quoted a bit less for USPostal but the box was a bit wide and the cost went through the roof.MichaelB wrote:What was the actual postage costs charged ?
It's a lovely blue in real life.
- europa
The Cunning Plan
Postby europa » Mon Oct 29, 2007 3:17 pm
That Can Not Fail ... if I throw enough money at it.
Yes, you've seen the options.
1 - sell the Siamese into sin and finance a complete new groupset and wheelset
2 - rip what bits fit off the Trek520 which leaves me having to supply brakes and a wheelset
3 - convert her to a fixed gear touring/sportser which involves buying the impressively priced ENO hub
The one I've chosen is the cheapest ... and probably the most sensible in the short term, maybe even the long term - option 2.
The aim is to create a Gentleman's Sportster ... a relaxed bike that is fast, comfortable and able to roll off long days in the saddle while leaving the rider fit enough to drink his breakfast the next day.
The procedure
- either take the headset off the Trek520 and install that or install a new one (any thoughts on the advisability of this?)
- Nitto Noodle bars from the Trek520
- hopefully one of my stems works, if not, invest in yet another stem
- Brooks B17 and Bontrager seat post from the Trek520
- Ultegra shifters and triple crank from the Trek520
- DeoreLX rear derailleur and 105 front derailleur from the Trek520
- SRAM 11-32 cassette from the Trek520
so far, cost has been limited to headset (possible - can I reuse the old one?) and maybe a stem.
The Trek520 uses V-brakes which this frame is not set up for, so enter my Shimano600 dual pivot brakes at no cost because these were just sitting in the shed (I bought them for the Europa but they didn't have the reach)
The Trek520 wheelset is wider than I wanted and uses DeoreLX hubs, which don't fit in the Jamis, so here is where it gets expensive.
- Velocity DeepV rims. I can get them from my lbs at a reasonable price.
- Ultegra 6500 front and rear hubs from Chainreaction - this is actually cheaper than buying cartridge hubs from the lbs.
- great heap of spokes and build the wheels myself
- labour costs to sort out the mess I make of building the wheels
- Detonator 28mm tyres
So, apart from a few ancillary bits, which could still cost the earth, the conversion will be done by essentially just building a wheelset Still expensive though, but having looked at cheap wheelsets, I don't actually save a great deal and a cheap wheelset will probably have a limited life anyway, not to mention no resale value. I think I'm better building good wheels from the start. Cost is about $350.
Where does this leave the Trek520? A frame, wheelset and Avid V brakes that can all be parted and sold, hopefully quite easily (the Maverick wheels are lovely creatures) and for excessive sums of money.
So she'll be a new frame with old bits, but the bits are only about 2,500km old, kms all done by me so I know what they've gone through and how badly they've been maintained - I doubt I'll notice a month or so down the track.
What about the fixed gear conversion? Can still be done - simply build an ENO hub into the rear DeepV rim and take off the shifters. It's not really practical for a few months anyway.
I can't wait to start spending money ... er ... building
- europa
Postby europa » Mon Oct 29, 2007 3:20 pm
The Shimano600 brakes fit nicely and will reach the wheels (I borrowed the wheels off the lad's bike to check). The grey colouring fits the frame nicely and so does the blue 'Shimano600' logo you can just see on the brake arm closest to you.
I need a better camera don't I
- MichaelB
- europa
Postby europa » Mon Oct 29, 2007 3:30 pm
That was always my first thought, but when I realised what wouldn't fit on the Jamis, I went cold on the idea. Your prompting brought it back to the surface. Thanks.MichaelB wrote:Good thing I managed to convince you to strip the Trek .....
- Birdman
- Mulger bill
Postby Mulger bill » Mon Oct 29, 2007 10:16 pm
Apart from that, it sounds like a very cunning plan my Lord. More photos!
Shaun
If I had to name that colour, methinks "Giant Blue" would be closest.
- europa
- europa
Postby europa » Tue Oct 30, 2007 11:09 am
The tension guage is really neat. There's a pin at either side of the bottom part of the guage, and one in the middle. You clamp the spoke with the two on one side of the spoke and the single on the other, and the guage measures the deflection and hence the tension in the spoke. Velly neat and easy to use ... if a bit time consuming (I checked out the wheels on the Europa with it )
I ordered a pair of Ultegra 6500 hubs from Chainreaction - yes, pricey hubs but even including postage the price is comparable with good hubs from the lbs (and the shop bloke admitted the Ultegra hubs were far better). I'm getting both for less than an Ultegra rear from the lbs so this is one place where price outweighs loyalty.
I had uncovered a source of spokes that was about half the price of buying them from the lbs ... then discovered late yesterday that he doesn't sell them with nipples and nipples cost the same as the spokes. Chainreaction sells spokes ... but only for 26" wheels. So it looks like I'll be buying spokes from the lbs at $1 a spoke and for 72 spokes
Fired up spocalc - an Excel based program for computing spoke lengths. If I was scared before, I'm terrified now, so I'll be checking the required lengths with the lbs when I order them.
I'll head down to the lbs today or tomorrow to order rims and spokes - any thoughts on whether I should wait until the hubs arrive before ordering the spokes? Just to make sure they aren't some odd size?
While I'm at the shop, I'll look at getting a new headset fitted.
Thoughts on type of spoke are appreciated too - I'm pretty sure the standard spoke from the shop is straight 14 guage.
- MichaelB
Postby MichaelB » Tue Oct 30, 2007 11:29 am
Can you wait till I get my wheels so that you can get the spokes for that at the same time ? They were meant to be posted on Friday.europa wrote:
I would wait until you get the rims & hubs to confirm, unless the shops will take them back if you stuff it up.
The tensiometer that you mention is much the same as I used to use in the RAAF to check flight control cable tensions. Very sensitive (the ones we used) and quite good.
Can you get bladed spokes from the LBS ?
- europa
Postby europa » Tue Oct 30, 2007 11:53 am
The tension guage does appear to be very sensitive.
Give them a ring about the bladed spokes - the tension guage will hande them too
I think I'm getting used to this frame staring at me without being worked on ... I WANNA RIDE IT NOW
- europa
Postby europa » Tue Oct 30, 2007 1:34 pm
Ritchie Logic Comp headset fitted
$40.45 from my lbs, supplied and fitted. Could have done it myself but they have the big tool to press the bearings in and I'd have been mucking about with stuff that only pretends to do the job.
Had a chat about rims and spokes. I'll be waiting until the hubs come in before ordering the rims, largely because his eyebrows rose when I told him they were 36 hole hubs - they can only get Ultegra in 32 holes. For a moment we shared the thought of buying 36 hole rims and then having 32 hole hubs arrive. Similarly with the spokes, we'll get the hubs and the rims and go from there.
He's quite supportive of me building the wheels, either that or very polite. He also likes my Shimano600 brakes, reckons he's got a soft spot for the old 600 gear.
Dropped in at the chemist on the way home and made the lady's day when I asked her for some nail polish ... and then held up the frame. We hunted around and got a very close match, though not quite enough purple in the blue. We agreed that matching the paint probably would have been easier in the seventies It'll be good though.
At the rate I'm chipping this frame, it'll be off to the powder coater rather than needing a crummy bottle of nail polish to touch it up
No, the paint isn't soft or brittle, just a rather frisky 'clumsy gene' I'm afraid.
Next job? Wait for the hubs to arrive. Dammit, I'm not sure I can do that one
- Birdman
- Birdman
Postby Birdman » Tue Oct 30, 2007 2:27 pm
Mitch.
Until next time...
Postby Bluerider » Tue Oct 30, 2007 2:28 pm
Man another nice rebuild coming up this means I have to get the 'ol Speedwell out for some TLC.....
Giant MTB
Hers Cell MTB
Kids Mongoose x 2 Tricycle x 1
- europa
Postby europa » Tue Oct 30, 2007 2:33 pm
The fork has a steering tube, that big tube that sticks up through the frame.
The headset is the set of bearings that mates that steering tube to the frame.
If you look on the photo, you can see a black band between the head tube and the top of the forks - that's the bearing cup at the bottom of the headset. The black band at the top of the head tube is the top bearing cup. Those bearing cups are pressed into the head tube of the frame.
A bearing cup is the race the bearings themselves run in.
The top of the forks has a bearing cup pressed onto it and a set of ball bearings (in this case they are balls fully enclosed in a cassette but they may be loose balls or balls trapped in a cage) run between the cup on the forks and the cup in the bottom of the head tube.
At the top of the head tube, a set of bearings (again a cassette in this case) runs between that cup and a cup that just slips down over the steering tube.
At this point, the whole shebang can slide up and down, because the top bearing cup on the steering tube is loose. The bike's neck (the arm the bars are bolted to) and some spacers slip over the top of the steering tube (I've got a bit of carboard tube there at the moment) - you need enough spacers so the neck (or top spacer) sticks ABOVE the steering tube ie, the whole assembly is a bit long. A top cap then sits on top of all this with a bolt through its middle that screws into a special nut inside the steering tube. When you do that bolt up, it pulls the neck and spacers down onto the headset bearings and that's how you adjust the tension and amount of free play in the whole setup - with that bolt you'll see if you look at the top of your steering. The neck is then clamped tight to the steering tube, not only to stop it flopping from side to side, but to hold the whole thing together.
Here's Sheldon Brown's take on the thing.
It's actually a lot simpler than it sounds, though probably makes more sense once you've actually pulled one apart.
- Kalgrm
Postby Kalgrm » Tue Oct 30, 2007 2:34 pm
This is the one I bought this morning. They go inside the head tube of the frame at the top and bottom of that tube (in the pic shown in the link, there is a line around the middle - that is where the two pieces are laid on top of each other for the photo.)Birdman wrote:But where does it actually go??? Is that it on the top, if so how far into the tubing does it run, and where does the handlebar clamp/stem go?
Mitch.
Graeme
- Birdman
Postby Birdman » Tue Oct 30, 2007 2:52 pm
I'm much better off when i can see pics as well so i know what i am actually looking at.
Mitch.
Until next time...
- Mulger bill
Postby Mulger bill » Tue Oct 30, 2007 8:12 pm
To the important question.... What work have you got planned for the purple unit in the background?
Shaun
- europa
- Mulger bill
Postby Mulger bill » Tue Oct 30, 2007 9:26 pm
What's the bottom line and dealer for the wheelbuild kit if I may?
Shaun
Users browsing this forum: Google Feedfetcher
