DT Swiss 240 Free Hub trashed
Postby RobRollin » Mon Jul 05, 2010 7:07 pm
Check out the photo. What I am looking for is, I am sure that I can purchase the free hub separately, just want confirmation.
Re: DT Swiss 240 Free Hub trashed
Postby Uncle Grumpy » Mon Jul 05, 2010 9:44 pm
Anyway, it's not trashed. The freehub mechanism still works, right? The only problem is the steel carrier on the cassette has chewed into the splines which are a softer alloy. You're producing too much torque.
Not sure off the top of my head if you can buy the freehub as a replacement. I could google it, but it's not my project. Ring the distributor, Dirt Works, on (02) 9679 8400, they'll sort you out with the good info.
Grumps
- Stonedpirate, June 2010
- MichaelB
Postby MichaelB » Tue Jul 06, 2010 8:54 am
I have a similar issue on my $100 hubset (Miche Racing Box from Wiggle) that I used for my
handbuilt wheels, but I'm 94kg and have covered 2,700km, but the damage is not as severe.
I can get a replacement freehub for 30 pounds + shipping, so will live with it until it's a major issue, but my hubs are cheapies. The DT ones are not.
I'll be watching with interest to see the outcome.
- Dave R32
Postby Dave R32 » Tue Jul 06, 2010 9:45 am
What you see there is very normal for a 8,9 or 10 speed compatible alloy free hub running a 10 Speed cassette. The splines on the 10 spd cassette are deeper which allows the cassette to move and chew into the softer alloy of the free hub.
I have seen pics and a write up on another forum of some small steel pieces which can be fitted when assembling the cassette onto the freehub and stops this from occuring. I believe they are made by American Classic, however the AC website wont work for me this morning. I will also ask the guy on the other forum for permission to post his pics here and let you know.
Dave.
PS: The freehub on my Token wheels has done the same.
- MichaelB
Postby MichaelB » Tue Jul 06, 2010 10:49 am
When you find the link, can you let me know please ?Dave R32 wrote:......
I thought I had read about this somewhere before but couldn't remember where/what
Michael B
Postby RobRollin » Tue Jul 06, 2010 4:53 pm
The part number and description:
AMCBCKA/C CASSETTE BODY CLIPS & SHIMS - 10 SPEED KIT available from Cassons
I rang Trek and the advised me that they have replacement free hubs. It is a Cycleops free hub.
Looks like I will be buying,
- toolonglegs
Postby toolonglegs » Tue Jul 06, 2010 4:57 pm
RobRollin wrote: I rang Trek and the advised me that they have replacement free hubs. It is a Cycleops free hub.
Yup they won't fair any better...I have gone thru 4 in 11,000km.
- toolonglegs
Postby toolonglegs » Tue Jul 06, 2010 5:01 pm
Postby RobRollin » Tue Jul 06, 2010 5:03 pm
On another note.....my Gravity Zero wheels, rode them for the first time last Saturday in a TT, same thing is happening.
- toolonglegs
Postby toolonglegs » Tue Jul 06, 2010 5:06 pm
Ok I am confused...this isn't a Powertap hub?...why are you getting a Cycleops freehub body for a DT Swiss hub?.RobRollin wrote:Dirt Works don't handle Cycleops anymore, as I was told I was told to ring Trek. I will have to find my paper work, I might be able to get this on warranty.
Postby RobRollin » Tue Jul 06, 2010 5:11 pm
- toolonglegs
Postby toolonglegs » Tue Jul 06, 2010 5:19 pm
Postby RobRollin » Tue Jul 06, 2010 5:21 pm
- Dave R32
Postby Dave R32 » Tue Jul 06, 2010 8:03 pm
And links to the pdf's on how to use them. Note there are different clips for different cassettes.
http://www.amclassic.com/documents/help ... ltegra.pdf
http://www.amclassic.com/documents/help ... uraAce.pdf
Hope this helps.
Dave.
- MichaelB
Postby MichaelB » Wed Jul 07, 2010 8:59 am
Fired off an email re P&A, as no pricing given on their pageRobRollin wrote:And here we go!!! Dave and Michael
Many thanks Rob and DaveR32.
Will grab a set ASAP, either from Casson's or somewhere else. I'll report back when there is some info back from Cassons
Postby alex » Wed Jul 07, 2010 10:53 am
- MichaelB
Postby MichaelB » Wed Jul 07, 2010 10:56 am
Not necessarily. The Red cassette have only 2 contact points - one at either end, and the inner end (the ironically red coloured plate) is not real thick either.alex wrote:a one piece cassette like a sram red will solve this problem also
Also probably costs a lot more
- twizzle
Postby twizzle » Wed Jul 07, 2010 10:57 am
Unless you are a daft weight-weenie, buy a steel hubs in preference to the alloy every time.
Postby alex » Wed Jul 07, 2010 12:21 pm
from 1st hand experience, the sram red cassettes do actually solve the problemMichaelB wrote:Not necessarily. The Red cassette have only 2 contact points - one at either end, and the inner end (the ironically red coloured plate) is not real thick either.alex wrote:a one piece cassette like a sram red will solve this problem also
Postby RobRollin » Wed Jul 07, 2010 12:50 pm
- MichaelB
Postby MichaelB » Wed Jul 07, 2010 2:22 pm
Just got a call from Casson's.RobRollin wrote:And here we go!!! Dave and Michael
[/img]
They don't sell to the public, hence you have to order it through the LBS (and they get it from Casson's).
There is no RRP, but the guy said that you should expect to pay around the $25 mark for the kit of tabs.
So, time to visit the LBS. Just use the code AMCBCK
And Rob, this may mean that you won't have to bother with the replacing of the freehub.
Here is a pic of my freehub damage (Miche Racing Box - 2,500km old)
Postby alchemist » Wed Jul 07, 2010 2:24 pm
No. It's not a DT Swiss hub at all, just uses a DT Swiss Rim (and maybe spokes).toolonglegs wrote:So DT Swiss hubs use Cycloeps free hubs as standard ..well there you go.
The rather than using pawls like the freehub pictured DT Swiss hubs use their "Star Ratchet" mechanism, where there are two cogs with ramps on the two adjacent faces.
- brycerider
Postby brycerider » Mon Jul 12, 2010 8:54 pm
- MichaelB
Postby MichaelB » Thu Sep 09, 2010 11:34 am
Finally came in today (took just over a week).
Total cost $18.
Postby rustychisel » Thu Sep 09, 2010 11:52 am
