Road Bike Lubricant ? ?
- vfrkenny
Postby vfrkenny » Mon Aug 09, 2010 11:28 am
- Mulger bill
Re: Road Bike Lubricant ? ?
Postby Mulger bill » Mon Aug 09, 2010 8:35 pm
'Nuff said!rkelsen wrote:Purple extreme!
- Cinder
Postby Cinder » Mon Aug 09, 2010 9:46 pm
- Aushiker
Postby Aushiker » Tue Aug 10, 2010 2:45 pm
Rock n Roll Gold and that is based on my cleaning regime and actual wear rates ... I did consider trying Purple Extreme but given the lack of reliable evidence I just ordered two 32 oz bottles of Gold and will continue with that.
Aushiker.com
Postby bmxbandito » Sun Aug 15, 2010 12:52 pm
Jeff
- Sepoy
Postby Sepoy » Sun Aug 15, 2010 5:04 pm
Is Rock and Roll Gold a substantial improvement over Red? I used Red for a while and wasn't tremendously impressed, but this prolink progold stuff I use at the moment only seems to last 100-150 kilometers.Aushiker wrote:Hi
- Thoglette
Postby Thoglette » Sun Aug 15, 2010 5:50 pm
I'm a wax fan. Current bottle is "squirt". Oh - see the "Search" button - use it, this has been discussed to deathvfrkenny wrote:Any suggested alternatives?
Postby handle » Mon Aug 16, 2010 8:56 am
http://sheldonbrown.com/chainclean.html
- Aushiker
Postby Aushiker » Mon Aug 16, 2010 10:23 am
HiSepoy wrote:Is Rock and Roll Gold a substantial improvement over Red? I used Red for a while and wasn't tremendously impressed, but this prolink progold stuff I use at the moment only seems to last 100-150 kilometers.Aushiker wrote:Hi
I haven't used Red so really cannot comment on the comparison but I easily get 1,000 km out of Gold with dry weather riding and around 500 km comfortably in wet months.
Aushiker.com
- brentono
Postby brentono » Mon Aug 16, 2010 12:03 pm
Perfect, love that explanation, made my day. Thankx Handle.handle wrote:The Word on chain cleaning and lubrication, from none other than the legendary Sheldon Brown.
(there's only one thing that needs to be lubed, before I put some miles on it )
And there will be the ones here that will debate, on and on, endlessly,
how they did all that, and their chain, still has a squeek, and Sheldon is wrong.
Just get out and ride it.
BrentonO
Dislaimer:That was nothing personal to you, Vfrkenny, (Singer oil would do it)
Postby stusf » Tue Aug 17, 2010 7:53 am
Postby Rhubarb » Tue Aug 17, 2010 9:53 pm
You bugger !!!handle wrote:The Word on chain cleaning and lubrication, from none other than the legendary Sheldon Brown.
I read that entire article in sheer disbelief. Right to the disclaimer at bottom.
Postby Solirossi » Tue Oct 12, 2010 4:33 pm
Postby Baldy » Tue Oct 12, 2010 5:14 pm
When that ran out a couple of months ago I grabbed a bottle of Green Oil to try. chucked it in with a bunch of other stuff I'd ordered from wiggle. Its biodegradable all natural oils and even the bottle is able to be recycled. It is a bit messier than wax lube but lasts better in the wet and is not really sticky like some of the wet weather lubes[which are great in the wet but dust/grit magnets in the dry]
Its worth a try.
- TimW
Postby TimW » Tue Oct 12, 2010 5:35 pm
I am waiting on a delivery from c r c, i ordered 3 bottles of purple extreme (AT) $13 per bottle. It's approx $25.00 here in lbs's. Reason i bought 3 was to make the postage worthwhile and i bought a park tools chain cleaner as well for 30 bucks.TimSolirossi wrote:Where do you purchase purple extreme from?
Postby Solirossi » Thu Oct 14, 2010 2:41 pm
- m@
Postby m@ » Thu Oct 14, 2010 3:40 pm
If you're in the ACT, I think Cycle Surgery has the best price in Aus.Solirossi wrote:Where do you purchase purple extreme from?
- aeroslave
Postby aeroslave » Sat Oct 16, 2010 9:41 am
Postby blue151 » Mon Oct 18, 2010 3:09 pm
Postby eeksll » Tue Oct 19, 2010 12:23 am
I thought the whole idea with rok'n'roll gold lube is no cleaning required ...
i find i need to apply about 3 times before the stuff stops turning coming out black. I dont quite squirt it on, i more drench the chain, back pedal a bit, wipe, repeat ... Is this what everyone else does? I seem to go through the stuff like water, probably used just short of 1 oz (1/4 small bottle) to clean/lube.
- Aushiker
Postby Aushiker » Tue Oct 19, 2010 1:20 am
Hieeksll wrote:aushiker and blue151, can you comment on the differences between cleaning with kero first vs not cleaning with kero?
I don't clean with kero so can't help sorry. Also I always clean my chain before reapplying the lube. Given my experience I see no reason to change that mode of operandi or test not cleaning, unless of course you are happy to pay for the chain and cassette
Regards
Aushiker.com
Postby blue151 » Tue Oct 19, 2010 4:07 pm
rock and roll is kero based (i think?) so it does clean it pretty good given that its a quick clean... but if i want to get all the grit out particularly between the links then i take off my chain and soak it a little... its definetely not necessary but only if u want a really good clean...eeksll wrote:aushiker and blue151, can you comment on the differences between cleaning with kero first vs not cleaning with kero?
90% of the time when i clean my chain.. i just rock & roll it once.... unless its really gritty then i mite use R&R twice... but if it looks like ur chain is covered in black mud then i'll degrease it first (either with kero or degreaser)
- fail
Postby fail » Tue Oct 19, 2010 11:38 pm
on a serious note; I use Purple Extreme, just got some more from c r c yesterday and a Park Tools chain cleaner.
Was at the lbs the other day when a guy comes in saying his bike shifts crap, LBS asked what lube he uses... WD40
Postby eeksll » Wed Oct 20, 2010 12:25 am
My question did not come over the way it meant to. I meant to ask the difference between cleaning the chain first with degreaser then lubing vs not degreasing first (and using the rock'n'roll lube as the cleaner).Aushiker wrote:Hieeksll wrote:aushiker and blue151, can you comment on the differences between cleaning with kero first vs not cleaning with kero?
Regards
