New chain & grease?
- Jean
New chain & grease?
Postby Jean » Thu Sep 23, 2010 1:03 pm
While not usually inclined to buy into the 'how do I make my chain last longer' debates that go on, I am about to fit a new chain to my MTB. I did wonder if MTB riders tended to favour stripping out all the packing grease or leaving it in as many roadies do (including me). Leaving it in would seem a way to attract a lot of muck, but I thought I'd raise the matter for opinion.
Re: New chain & grease?
Postby zero » Thu Sep 23, 2010 3:00 pm
- Mulger bill
Postby Mulger bill » Thu Sep 23, 2010 8:26 pm
- trailgumby
Postby trailgumby » Thu Sep 23, 2010 9:55 pm
For road work, definitely the grease they come packed in seems to last brilliantly. I've done probably 5 or six weeks (more?) at 120km a week on hte original grease before it became noisy enough to indicate a clean was needed. That inlcuded some pretty nasty weather. Just wiped off with a rag and I was good to go again. I was a bit amazed to be honest.
For mtb ... hmmmmnnnggghh ... dunno. Current favourite is Purple Extreme. It leaves the chain residue free, yet doesn't wash out in wet rides and the crud doesn't stick to it. The problem with leaving the grease on the chain on a mtb is that it attracts HUGE amounts of sand and garbage on my local trails, which are quite sandy. Not a fan of the original packing grease in that environment. A new chain needs cleaning and re-lubing after one ride if the grease is left on. At least with the PE the grit eventually falls off or can be washed off easily if you spin your chain through under a tap.
I was using White Lightning Epic Ride, but after going so long without changing lube on the hardtail commuter, and then putting some Epic Ride on in desperation to get home last week and having it go horrid black and mucky in a single trip, I'm not going to bother finishing the bottle. PE only from now on. And since I've "rediscovered" hardtails for some of my local trails it seems like it seems like a good fit..
Postby Nobody » Fri Sep 24, 2010 12:02 am
What? I thought you loved your 5" boing armchair?trailgumby wrote:And since I've "rediscovered" hardtails for some of my local trails it seems like it seems like a good fit..
There are a number of guys on the STW forum that vacillate between FS and HT.
Postby Nobody » Fri Sep 24, 2010 12:04 am
I also use Wipperman chains but coat the outside with Finish Line Wet and wipe off. This appears to make the chain less sticky than the original grease while retaining the grease.Jean wrote:Hi,
- toolonglegs
Postby toolonglegs » Fri Sep 24, 2010 12:09 am
- Jean
Postby Jean » Fri Sep 24, 2010 9:53 am
I'm thinking I'll clean the outside of the chain thoroughly and leave the insides as they are. If it doesn't seem good after the first ride or two I'll just take it off and give it a good bottle shake in kero. I'm using Prolink lube at the moment, which I rather like after trying a few of the Rock'n'Roll types, though I'm beginning to think there is no such thing as a perfect MTB lube.
- trailgumby
Postby trailgumby » Fri Sep 24, 2010 10:02 pm
Haha! Ya busted me!Nobody wrote:What? I thought you loved your 5" boing armchair?trailgumby wrote:And since I've "rediscovered" hardtails for some of my local trails it seems like it seems like a good fit..
Yes, I really enjoyed the hardtail last Sunday on my 60km training ride. I rode it basically because I had just finished prepping the FS for the race this weekend and didn't want to have to change the chain and clean the bike AGAIN. I thought I'd give a set of Michelin tubeless I had hanging up a go as well.
It was noticeably more sketchy on the downhills than the FS, in part due to the rubber not really suiting the conditions and in part due to having only 80mm travel (fork damper needs bleeding), but it was more fun than I was expecting. The legs definitely got a workout. The trail is regarded as relatively non-technical. The main hazards are fields of babyhead rocks covering some of the downhill sides of the waterbars, loose surfaces, and sand drifts.
Aaargh the chain sounded awful after riding through the creek crossings and sandy puddles on Perimeter Track. Eventually it dropped out though.
But I'm taking the comfy armchair with me to Parkes tomorrow.
Postby Gabe » Sat Dec 11, 2010 9:43 pm
- trailgumby
Postby trailgumby » Sat Dec 11, 2010 10:35 pm
Postby mitzikatzi » Sat Dec 11, 2010 11:34 pm
- Jean
Postby Jean » Mon Dec 13, 2010 8:51 am
Postby Gabe » Mon Dec 13, 2010 5:42 pm
So you use kerosene to clean out yours then? I wasn't sure if that would work well so I used paint thinner instead, but kero would be a bit less nasty.. less nasty than petrol too, which I was also considering using.
Does the prolink lube smell much? I might try it out on my other bike, but I don't want to deal with stuff that reeks of chemicals any more than I need to. That's one of the things I like about squirt
- Jean
Postby Jean » Tue Dec 14, 2010 8:57 am
Users browsing this forum: Amazon [Bot]
