Compact V 39/53
- Apple
Compact V 39/53
Postby Apple » Mon Dec 13, 2010 1:50 pm
I have always ridden a 39/53 with 27 gears at the back.
I had to stop riding for a while due to surgery about a year ago.
I am getting older and I find that many riders younger and fitter then me, are riding compacts.
I do have lots of power and am in the process of losing weight as I am 6 kg over weight.
I am not a great spinner and I love using big gears. My cadence is moderate but slow on the hills.
Climbing a hill like akuna or bobbin head in Sydney I would be at 10 to 13km/hour on a 4km climb. Cadence would be about 54-70 depending how tired I am and how heavy.
Is it worth changing to a compact.
I am also a female
- DanielS
Re: Compact V 39/53
Postby DanielS » Mon Dec 13, 2010 2:11 pm
- philip
Re: Compact V 39/53
Postby philip » Mon Dec 13, 2010 2:12 pm
Unless you feel you need smaller gears, i.e. you're in 39/27 and you're slowing down and want to pedal faster for the same speed then there's no point. If you want to be able to click down another gear while you're climbing and you can't because you're out of gears, then go for it. Compact gearing wont magically make you climb faster if you're going to use the equivalent gear to what you're using nowApple wrote:Is it worth changing to a compact
- Apple
Re: Compact V 39/53
Postby Apple » Mon Dec 13, 2010 2:22 pm
I just don’t want to lose my 53.
It will also mean that I will need to change back to my 11/25 at the back if I get a compact. So my question is: is there much difference in compact with an 11/25 at the back, to a 39/53 and 27 group set at the back
Re: Compact V 39/53
Postby ireland57 » Mon Dec 13, 2010 7:21 pm
If you're wanting to compare the climbing gears (39/27 to 34/25) the difference is approx 6%. It is a bit of a change given that many riders can feel 2% difference in ratios and will make hills a little easier.Apple wrote:Yes I do feel like I would like an extra gear when climbing a steep hill.
If you are concerned about the loss in overall top speed it's still 6% difference obviously but a 50/11 is still a decent gear to push on flat ground.
You can get a 38 tooth chainring and an 11-28 cassette. They fit most bikes with a tweak of the rear derailleur B- screw. A 52 tooth big ring is also available so it's still a 14 tooth jump.
- sogood
Re: Compact V 39/53
Postby sogood » Mon Dec 13, 2010 7:34 pm
- ZepinAtor
Re: Compact V 39/53
Postby ZepinAtor » Mon Dec 13, 2010 7:45 pm
- open roader
Re: Compact V 39/53
Postby open roader » Mon Dec 13, 2010 8:41 pm
My recent experience but with Ultegra 53/39 vs 50/34 and using the Ultegra 11-28 casette.
I recently opted for compacts but for different reasons. I find that I perform better with a higher cadence and I was preferring rides with an ever increasing proportion of moderate longer climbs and several short nasty steep short climbs. My pre-existing 39 small front cog in combination with a large 28 tooth rear cog was not quite spinning my legs fast enough to be truly comfortable with and fast recovering from said climbs.
I also found with the 53 tooth front sproket that I was crossing the chain too often as my flat road cruising speeds were a couple of km/hr too low to really be using the centre rear cogs so I was finding that I often was using the bottom three rear cogs with the 53 front cog and crossing or was forever chaning down to 39 front and then back up to the 53 front.
The change to compacts has really advanced my climbing, keeping my legs spinning at 90-94 RPM at 14 to 15 km/hr up the really steep kicks using the 34 front in combination with the 24 and 28 tooth rear cogs. The flat road cruising is also perfect now for me, holding the large front chainring 99% of the time with no crossing issues.
As I stated before, I changed to compacts to aid keeping my cadence up, I'm a spinner not a grinder. It sounds to me like a shorter geared alternative cassette option is on the cards for you - cheaper than a full compact crankset. If your're curious and you can afford to do so, purchase a compact crankset to suit and try them both back to back on the same ride routes then choose one and sell the other as i did. I kept swapped back and forth from standard to compact three times (six crank changes) before I def. went with the compacts.
Re: Compact V 39/53
Postby ireland57 » Mon Dec 13, 2010 9:37 pm
- Apple
Re: Compact V 39/53
Postby Apple » Mon Dec 13, 2010 10:06 pm
Please,ireland57 wrote:Have you thought of a triple? It has 30/42/52 or 53 giving a decent choice of gears. It may mean changing shifters too though depending on what your bike has on it.
I dont need a triple, I had one before and never used the 30, I was spinning and not going anywhere
- Apple
Re: Compact V 39/53
Postby Apple » Mon Dec 13, 2010 10:12 pm
thanks open rider,open roader wrote:Apple,
that is a great response to my question.
I am not a spinner, I can spin but for short periods, I can push high gearing for a long time and I prefer the 53 to the 39. I do try and use the 39 more often these days but am more comfortable on the big cog.
You sound like Phil, that's what he does, spins and spins.
- breezer1
Re: Compact V 39/53
Postby breezer1 » Mon Dec 13, 2010 10:48 pm
- ZepinAtor
Re: Compact V 39/53
Postby ZepinAtor » Mon Dec 13, 2010 11:36 pm
With a comment like that I doubt you need a compact crank at all. Although there are quite a few different combo's of which the largest chainring sizes may have some benefit. The 36 x 50 or as suggested above a 38 inner ring could have some advantages.Apple wrote:Please,
If you're interested I have a compact crank you can try out & keep if you like it. I don't like compacts at all & removed this one from a CX bike. It's an FSA Gossamer with a 110 BCD & travelled less than two thousand K's. Unfortunately it's a 34/48, but you could probably source a 50 tooth big ring to give this compact thing a crack.
PM me if interested & I'll send them to you in Sydney. (I'm in Brisbane)
From Wiki.
In the context of road cycling, compact drivetrain typically refers to double cranksets with a smaller (usually 110mm) bolt circle diameter than the standard 130mm or Campagnolo's 135mm. As of 2006, all of the major component manufacturers such as Shimano and Campagnolo offer compact cranks in their midrange and high-end product lines. The compact crankset provides a compromise between the standard road double crankset (with 39/52 or 39/53 tooth chainrings) and the road triple (with 30/42/52 or 30/39/53 tooth chainrings). The compact crankset has two chainrings and typical ratios are 34/48, 34/50 and 36/50. This provides nearly the same lower gear ratios as a triple but without the need for a third chainring, a triple front derailleur and a long cage rear derailleur. Note that both Shimano and Campagnolo recommend and sell front derailleurs specifically designed for compact cranksets, claiming better shifting.
Compact gearing is not necessarily lower than standard gearing if cassettes with smaller sprockets (such as 11–23) are used. A high gear of 50×11 on a compact drivechain is actually slightly higher than the 53×12 of a standard set.
Compact gearing usually has a large percentage jump between the two chainrings. In balance, it may also allow small jumps in the rear by allowing a closer ratio cassette to be used, except for the 9% jump at the high end between the 11 and 12 tooth sprockets.
Re: Compact V 39/53
Postby Drunkmonkey » Tue Dec 14, 2010 12:35 am
a triple on a prince is blasphemyApple wrote:Please,ireland57 wrote:Have you thought of a triple? It has 30/42/52 or 53 giving a decent choice of gears. It may mean changing shifters too though depending on what your bike has on it.
- scotto
Re: Compact V 39/53
Postby scotto » Tue Dec 14, 2010 8:50 am
My observations are that on long hills it doesn't seem to bother me much, indeed on our bobbin head, galston gorge ride i found climbing much quicker for some reason. however on some short little steep hills I seem to get dropped a bit as i have to change down to the 39 chainring and lose momentum while the compact riders dont ?
If your managing 10-13 with cadence of 50ish, maybe a compact set will be the go.
I have a compact crankset (shimano) at home that you're more then welcome to borrow and try.
- Apple
Re: Compact V 39/53
Postby Apple » Tue Dec 14, 2010 8:54 am
Thanks Scotto,scotto wrote:Apple, IN recent months I have just gone from compact to standard. i aint much of a spinner either
My observations are that on long hills it doesnt seem to bother me much, indeed on our bobbin head, galston gorge ride i found climbing much quicker for some reason. however on some short little steep hills I seem to get dropped a bit as i have to change down to the 39 chainring and lose momentum maybe?
I have a compact crankset (shimano) at home that youre more then welcome to borrow and try.
I am going to do some hill repeats and see if I can get back up to speed. Also on those diet shakes at the moment, I am sure my weight power ratio will improve.
The thing is I am not getting any younger. I will PM you soon.
Like you it is those short steep hills I get dropped.
- Christine Tham
Re: Compact V 39/53
Postby Christine Tham » Tue Dec 14, 2010 10:00 am
Agree completely.
Actually, a triple on any road bike is blasphemy
Re: Compact V 39/53
Postby Missy24 » Tue Dec 14, 2010 10:49 am
Agree completely.
- scotto
Re: Compact V 39/53
Postby scotto » Tue Dec 14, 2010 12:31 pm
Agree completely.
here's a lovely lass riding a road triple, and making a nice job of it too !
even her knee is smiling
- number21
Re: Compact V 39/53
Postby number21 » Tue Dec 14, 2010 10:43 pm
- Apple
Re: Compact V 39/53
Postby Apple » Wed Dec 15, 2010 6:51 am
you lost me, do you mean eat meat not drink shakes?number21 wrote:Forget the diet shakes, mate of mine in Spain reckons he knows a great butcher whose cuts make power to weight concerns a thing of the past.
- scotto
Re: Compact V 39/53
Postby scotto » Wed Dec 15, 2010 7:35 am
i think he means the Astana team Purveyor of Fine MeatsApple wrote:you lost me, do you mean eat meat not drink shakes?number21 wrote:Forget the diet shakes, mate of mine in Spain reckons he knows a great butcher whose cuts make power to weight concerns a thing of the past.
- Boognoss
Re: Compact V 39/53
Postby Boognoss » Wed Dec 15, 2010 7:53 am
I did exactly this on my CX commuter (upped the 48 to a 50). Specialized Tricross Zep? Even with 48 on the front and 11 on the back I didn't spin out too much, but the 50 gives a little extra.ZepinAtor wrote:/snip Unfortunately it's a 34/48, but you could probably source a 50 tooth big ring to give this compact thing a crack.
With 11-28 cassette the gearing has higher and lower gears than my roadie with 53/39 and 12-27.
- ZepinAtor
Re: Compact V 39/53
Postby ZepinAtor » Wed Dec 15, 2010 9:58 am
Yep a Specialized Tri-cross. Hated the compact crank & fitted an FSA superlight carbon crank instead. My next issue is that a second hand race bike I recently acquired has Sram Red compact I'd like to swap with a standard Red crank. Anybody ???Boognoss wrote:I did exactly this on my CX commuter (upped the 48 to a 50). Specialized Tricross Zep? Even with 48 on the front and 11 on the back I didn't spin out too much, but the 50 gives a little extra.ZepinAtor wrote:/snip Unfortunately it's a 34/48, but you could probably source a 50 tooth big ring to give this compact thing a crack.
