Nuts...
- toolonglegs
Re: Nuts...
Postby toolonglegs » Thu Jan 27, 2011 7:09 pm
Spinal surgeon is in 3 weeks...haven't made an appointment for the chronic pain doctor yet.
- twizzle
Re: Nuts...
Postby twizzle » Thu Jan 27, 2011 7:51 pm
- toolonglegs
Re: Nuts...
Postby toolonglegs » Mon Feb 21, 2011 10:51 pm
I am having 2 more Hydrocort injections right at the bottom of my spine on Thursday.Is it me or when doc's have an idea in their head it doesn't really matter what you tell them.
Anyway I don't know if it will help as I think the problem is higher...but it can't hurt,they are pretty strong so it will spread around a bit.
I am on the mend...but still am doing nothing exercise / stretching wise...funnily I could touch my toes first go while the surgeon was looking me over last Thursday.
The one thing he said was I had to lose lots of weight...I am not fat but I am a big guy,he reckons it will help a lot losing 15 kilos...no surprise there,but losing weight with no exercise is tough.
C'est la vie.
- MichaelB
Re: Nuts...
Postby MichaelB » Thu Feb 24, 2011 11:48 am
Hopefully and extended time off the bike and a chnage of scenery may get somewhere to recovering/discovering what the actual problem is, and then the holy grail of a solution.
May the force be with you !!
- toolonglegs
Re: Nuts...
Postby toolonglegs » Thu Feb 24, 2011 8:32 pm
Also turns out L5-S1 i a lot higher than I thought...good things as it means it is roughly where the worst pain is.
- ft_critical
Re: Nuts...
Postby ft_critical » Fri Feb 25, 2011 9:12 pm
I guy at work is a pretty exceptional XCtry skier, a Canadian. He had a frozen shoulder for about a year. Couldn't do anything. Physios, doctors etc. Manipulation, drugs. Nothing worked. Finally, he was recommended to an acupuncturist. He knew exactly what to do and released the ligament. Instant fix. It took a long time for the muscles to be back in shape though because he had been compensating for the ligament issue for a long time.
I had a similar experience with neck compression and acupuncture.
You have tried everything else, why not acupuncture?
- toolonglegs
Re: Nuts...
Postby toolonglegs » Fri Feb 25, 2011 10:31 pm
- ft_critical
Re: Nuts...
Postby ft_critical » Tue Mar 01, 2011 11:23 am
Chatted again about this. The guy he uses teaches Acupuncture and is located in Crows Nest. He also said during the XCCY season there is a 'sheath' that runs down the sides of his body that would tighten up. All sorts of physio manipluation failed to loosen it up. The body fights back and tightens more. However, the needle in the right place released all the tension.toolonglegs wrote:Thought about it plenty of times...can't hurt if I can find someone.
I don't have any opinion on this one way or the other, just passing it on.
- trailgumby
Re: Nuts...
Postby trailgumby » Tue Mar 01, 2011 12:35 pm
- Semar
Re: Nuts...
Postby Semar » Tue Mar 01, 2011 9:33 pm
- casual_cyclist
Re: Nuts...
Postby casual_cyclist » Thu Mar 03, 2011 4:19 pm
"that would tighten up" is the qualifiertrailgumby wrote:Why does the sheath only run down the sides of his body during the XC ski season?
It makes it sound like it doesn't tighten up when he's not XC skiing. Just goes to prove that exercise is dangerous and should never be done!
Re: Nuts...
Postby ranget@bigpond.com » Sat Mar 12, 2011 6:07 pm
- toolonglegs
Re: Nuts...
Postby toolonglegs » Sat Mar 12, 2011 8:38 pm
Over two weeks since the last injections...yes a bit of change but not a lot.
Well I am pretty much finished with everything here...maybe warmer climate and less damp will help when I am back in Oz!.
- scotto
Re: Nuts...
Postby scotto » Tue Mar 15, 2011 11:39 am
where can you buy this sheath ?trailgumby wrote:Why does the sheath only run down the sides of his body during the XC ski season?
frozen shoulders get better eventually regardless. can be 9-18months though
acupuncture shouldnt ever fix anything, but it does sometimes, and regardless of the placebo effect, if it gets the job done, works, thats fine.
- toolonglegs
Re: Nuts...
Postby toolonglegs » Wed Mar 30, 2011 8:34 am
Last Tuesday 18km
Thursday 25km
Friday 33km
Today 44km
Ok all is not great but it is a start.Not sure if the injections have started working after so long or not.But I feel pretty good.Still pretty sore around the lower T's and L1 junction...thorasiclombar?.Something like that...yup still the Syndrome des Maignes symptoms,but they are bearable on a bike and just as importantly don't get worse after the ride.The pain is very specific now at that junction with zero referred pain anywhere else which is great.I am very tight in my butt/flexors etc but will slowly work that out...after nearly a year off I will take it pretty slow.
Long way to go yet...when I can do up my shoelace easily I will be fixed!...and I know it could all go backwards in a couple of weeks if the injections are working.
So fingers crossed!.
- MichaelB
Re: Nuts...
Postby MichaelB » Wed Mar 30, 2011 9:00 am
- philip
- twizzle
Re: Nuts...
Postby twizzle » Wed Mar 30, 2011 12:52 pm
Yep - Euro-48 shoe into the backside will hurt.MichaelB wrote:Good news at last, but don't bugger it up by trying too much too soon. Remeber what Twizzle promised ....
- toolonglegs
Re: Nuts...
Postby toolonglegs » Wed Mar 30, 2011 6:23 pm
I'll ride when I feel good,won't we I don't .
Feel good after yesterday thou...that is the biggest thing,not being crippled the evening after a rollout.
- twizzle
Re: Nuts...
Postby twizzle » Wed Mar 30, 2011 6:50 pm
Just checked, make that 47's.toolonglegs wrote: You wear 48's?! .
I know, I have small feet...
When U back in Sydney?
- toolonglegs
Re: Nuts...
Postby toolonglegs » Wed Mar 30, 2011 8:09 pm
But I am now quite glad I have my retro Cinelli waiting for me...might need a bit of attention but at least I wont have to bring a bike with me .
- foo on patrol
Re: Nuts...
Postby foo on patrol » Wed Mar 30, 2011 8:34 pm
That's good news for you TLL!
Goal 6000km
- MichaelB
Re: Nuts...
Postby MichaelB » Thu Mar 31, 2011 12:06 pm
He'll have to post in the "Black balled" thread then as wellfoo on patrol wrote:You kick him with the 47s and I'll hit with the mallet to knock some sense into him as he straightens up from the kick Twizzle.
- Chuck
Re: Nuts...
Postby Chuck » Thu Mar 31, 2011 7:21 pm
foo on patrol wrote:That's good news for you TLL!
+1
- toolonglegs
Re: Nuts...
Postby toolonglegs » Thu Mar 31, 2011 9:37 pm
There is a 56km cyclosportive on Saturday thou...and most of the club is riding (in the 135km version)...might be worth a go
So yup good news...so far!.
Cheers all.
Users browsing this forum: Amazon [Bot]
- All times are UTC+11:00
