Giant Fixed gear
Re: Giant Fixed gear
Postby Aushiker » Fri Feb 26, 2010 1:44 pm
brauluver wrote: one replied saying that giant australia would not allow mail order of ther bikes between states.
hi
That is an interesting response. I thought the Trade Practices Act specifically bans restrictions on trade across state borders. I wonder if the ACCC is aware of this.
ryan
Postby ryan » Fri Feb 26, 2010 4:45 pm
backofthebunch wrote:My 2010 bowery makes alot of noise when im pedalling, any thoughts on what is cause and how to fix?
http://www.sheldonbrown.com/creaks.html
brauluver
Postby brauluver » Fri Feb 26, 2010 8:05 pm
hi
Dunno, maybe they are just too lazy to make the effort and used a lame excuse.
backofthebunch
Postby backofthebunch » Sat Feb 27, 2010 4:24 pm
I'm thinking of putting a straight bar on my bowery, what is the clamp size? i assume you need to match the handlebar to this,
rearviewmirror
Postby rearviewmirror » Tue Mar 02, 2010 3:54 pm
backofthebunch wrote:I'm thinking of putting a straight bar on my bowery, what is the clamp size? i assume you need to match the handlebar to this,
traditional 25.4mm
trmac
Postby trmac » Wed Mar 03, 2010 8:38 pm
traditional 25.4mm
I don't have one and have never been near one, but don't they use an ahead stem. Is it not an oversize 31.8 clamp?
brauluver
Postby brauluver » Wed Mar 03, 2010 9:54 pm
traditional 25.4mm
Err...No it's as rearview stated :!:
backofthebunch
Postby backofthebunch » Sun Jul 18, 2010 11:23 am
traditional 25.4mm
well i purchased some profile air wing bullhorns that are 26mm and they're too thin!!! so either giant changed the stem in 2010 or i'm losing the plot
brauluver
Postby brauluver » Sun Jul 18, 2010 1:33 pm
traditional 25.4mm
Maybe they have changed then.I certainly had a 25.4 original bar as well as 25.4 easton risers.same clamp was fine with a 26mm as well.
backofthebunch
Postby backofthebunch » Mon Jul 19, 2010 9:26 am
pulled it apart to discover it is definately oversized 31.8mm
i want to get some air wings and i have seen them in both standard and oversize which is good.
aaron
Postby aaron » Fri Jul 30, 2010 3:20 pm
oldschoolfool wrote:The heavier the bike/rider the more difficult to skid. The lighter the bike/rider the easier to skid. Simple mechanics; friction increases with load therefore more weight = more friction = less skidding.
Not the case at all
europa
Postby europa » Sat Jul 31, 2010 1:10 am
Not the case at all
The older and grumpier the rider, the less likelihood of even attempting such foolishness.
hmm, Mulger's fear of incipient heresy are hitting rather earlier than I expected :oops:
Having said that, an explanation from both protagonists would be appreciated. :wink:
aaron
Postby aaron » Sat Jul 31, 2010 10:59 am
The more skilled the 'skidder' the easier to skid.
It has nothing to do with your weight or the weight of the bike.
It has everything to do with technique. It also has alot to do with gear inches.
backofthebunch
Postby backofthebunch » Tue Oct 12, 2010 11:46 am
2011 bowery is a steel frame for anyone interested
brauluver
Postby brauluver » Tue Oct 12, 2010 5:41 pm
backofthebunch wrote:2011 bowery is a steel frame for anyone interested
Raw finish too
rustychisel
Postby rustychisel » Tue Oct 12, 2010 6:12 pm
wow, they left the bars untaped to show how classy it is to not thread the rear brake properly, and how silly it is putting Tektro levers on pista bars? I'm unimpressed.
PS: it's only a model
backofthebunch
Postby backofthebunch » Fri Apr 08, 2011 3:36 pm
I have an aluminium bowery 2010, been putting a few km's on it and still going strong (had it for approx 18 months).
I am thinking of upgrading to a cheapish carbon fork to kill some road buzz. Given the geomitry of these, it's pretty simular to a giant roadie, i feel a road fork will be more suitable. also I will be using at least front brake, so want it to be drilled. steerer is 1 and 1/8th. anyone recomend a suitable fork?
Vivifyer
Postby Vivifyer » Sat Apr 09, 2011 1:27 am
Tektro levers on pista bars is utter trash, pointless for effective braking. pretty much the sole reason why i changed to oval cow horns on my 2009 bowery
Flickr Stream
DArt Gallery
Vivifyer
Postby Vivifyer » Tue May 10, 2011 11:12 am
collided with a car :( my Bowery is dead, and im sore.
the alex front rim is still perfectly true though... the frame is cracked and folded on its self at the head tube / top tube / down tube welds.
Flickr Stream
DArt Gallery
rustychisel
Postby rustychisel » Tue May 10, 2011 12:49 pm
that's bad news, hope someone's insurance will cover it. Not related to poor braking performance was it?
Get well soon and get back on a bike
Postby familyguy » Tue May 10, 2011 1:12 pm
As long as you're ok. You are ok, aside from being sore, right?!
'09 model? Aluminium? You can probably just get a new frame and swap parts over. Of course, you can upgrade to a complete new one now you have a decent excuse.
PS: Liking your Freo Power Station stream.
Vivifyer
Postby Vivifyer » Tue May 10, 2011 1:47 pm
due to the circumstances of the crash, Its highly unlikely any insurance would cover it. Brakes worked fine (being the bull horn type) problem was i was doing about 20km/h and i had about 3 meters to stop wasn't quite enough. all is ok with me, sore left forearm that will probably bruise up, where it hit the top of the car, and sore left quad, from running into the back of my handle bar.
considering upgrade options now. To which ive been told to look at the All City big block, - http://prollyisnotprobably.com/35455010 ... 5c61ac.jpg
Can you even get new Bowery frames on their own? hm
Flickr Stream
DArt Gallery
Vivifyer
Postby Vivifyer » Tue May 10, 2011 10:54 pm
Damage done to the frame :(
Flickr Stream
DArt Gallery
elStado
Postby elStado » Tue May 10, 2011 11:47 pm
Bummer. Glad to hear you're OK though.
Cheap Aluxx frames will do that.
Salvage what you can and rebuild with a steel frame next time. Or even with a cheap frame again. Your call.
rustychisel
Postby rustychisel » Wed May 11, 2011 10:21 am
Gaffer tape'll fix that. :D :D :D
Nah, don't be daft elStado, a high end race grade steel frame will tear apart exactly like that too, nothing to do with it being aluminium, or cheap. It's all about the quality of the front end shunt, and he's done it well. Nice 90º angle of attack.
