Magic Shine
Re: Magic Shine
Postby Myddraal » Sat Jul 23, 2011 12:31 am
I've just ordered a couple of torches for cycling too after spending hours and hours reading up on all manner of things torch related; LED data sheets, drivers, hosts, drop ins, heatsinking,... - you name it. They won't be here for probably 3 or 4 weeks, but all reports indicate they can individually put the magic shines to absolute shame on high (though they can only run on high for a limited time as they're pumping out 10+W of heat) and the build quality should be a lot better.
Even though they use the same Cree XM-L T6 emitter as the 808e, they should each outclass it as well, especially for road cycling thanks to more throw and a better beam pattern from the reflectors. I'll be using them on medium so they don't burn up, but that will still be more than the MSs and for only $10 more than the 808e including four 18650 protected Li-Ion batteries, a charger and a battery case shipped.
Mounting is simple, sturdy, quick to remove/install and free with hose clamps, a rubber band bracelet and some old inner tubes.
This has benefits in being able to carry the lights with me so they aren't flogged and being useful off the bike. I can even run one of the torches off standard AAAs if I need to (not for long though, and probably not on high). It's not actually quite an ideal setup with regards to torch form factor (read heat dissipation) and batteries (life) but thanks to P60 drop ins and 18650s being the market standard it's the best you can get for your dollar at this price point.
- Xplora
Re: Magic Shine
Postby Xplora » Sat Jul 23, 2011 10:38 am
Review after the rain in Sydney for the last few days, which has been brutal at times.
The water WILL get into the connector, even if you are strategic and aim the male plug upwards, but it won't stop it working at all. I would recommend disconnecting at night to let it all dry out. Long term longevity of this setup? No idea but currently I'm not upset. It DEFINITELY got a heavy workout and you don't need to worry about it failing from one or two heavy days of rain. I still plan on mounting them permanently to the bike, it will be interesting to see it all coming together then.
- find_bruce
- Moderator
Re: Magic Shine
Postby find_bruce » Sat Jul 23, 2011 6:18 pm
Have you tried o-ring lube Xplora? A little on the male side of the connector not only makes it a bit easier to get on and off but has also sealed it well. No moisture even in heavy rain. No need to get any fancy dive light silicone lube I use hyrdoseal from Bunnings which was just a couple of bucks. Even works on the o-rings in the light head and my helmet mounted torch.Xplora wrote:Always worth remembering that a torch is useful off the bike, while a bike light isn't. Any reason for thieves to borrow your lights is a bad one!
- Leiothrix
Re: Magic Shine
Postby Leiothrix » Sun Jul 24, 2011 5:22 pm
Re: Magic Shine
Postby Myddraal » Sun Jul 24, 2011 5:41 pm
- Leiothrix
Re: Magic Shine
Postby Leiothrix » Sun Jul 24, 2011 5:56 pm
silicone grease on silicone o-rings on the other hand is not fine.
Re: Magic Shine
Postby Myddraal » Sun Jul 24, 2011 6:36 pm
The moar you know...
- Xplora
Re: Magic Shine
Postby Xplora » Tue Jul 26, 2011 8:42 am
- find_bruce
- Moderator
Re: Magic Shine
Postby find_bruce » Tue Jul 26, 2011 2:03 pm
For clarification the connection I was refering to does not appear to have a seperate o-ring - it is just moulded plastic with an interference fitLeiothrix wrote:Hydroseal is a silicone based lube isn't it? If your light has silicone o-rings it is not a good idea to use silicone lube. The lube will make the rings swell and degrade, which can reduce their water resistance and make it rather difficult to unscrew.
I have no idea if Hydroseal is a silicone based lube - there is nothing on the tube indicating one way or another. I know that the brown o-rings in my light have neither swollen nor degraded.
I would be amazed if the o-rings on a cheap chinese bike light are silicone - The lights are built down to a cost and I am betting that the brown o-rings are made from whatever is cheapest - last time I checked silcone o-rings were about 3 or 4 times the price of other materials such as ntirile.
Care to share a reference to the "manual" you are referring to. Unless I am mistaken, the o-ring in a bike light is static - once installed there is no movement between the o-ring and the parts.Myddraal wrote:Ok, checked the manual - I'm wrong. Silicon grease is "3) Sometimes ok for static applications", but definitely not 1) Fine, same for silicone oils. Other silicate compounds are mostly 2 or 3.
Re: Magic Shine
Postby l45er » Tue Jul 26, 2011 2:22 pm
Just to report back - I tried this method of inverting the light (so it was mounted to the underside of the handlebars) and it did work much better.sblack wrote:I was also having this issue and recently changed to hanging it under the bar instead of sitting it on top. I did it to clear the top of the bars to temporarily put something else on top but it seams to have fixed the slipping issue so it now lives under the bars permanently.l45er wrote:Works fine, seems to slip a little bit over bumps though (gloss finish on the bars probably doesn't help).
It sort of rests on brake/shifting cables (as they route via the underside of my bars) this way but they don't seem to affect it. Thanks for the tip!
Re: Magic Shine
Postby Myddraal » Tue Jul 26, 2011 8:45 pm
http://www.parker.com/literature/ORD%20 ... ndbook.pdffind_bruce wrote:Care to share a reference to the "manual" you are referring to. Unless I am mistaken, the o-ring in a bike light is static - once installed there is no movement between the o-ring and the parts.Myddraal wrote:Ok, checked the manual - I'm wrong. Silicon grease is "3) Sometimes ok for static applications", but definitely not 1) Fine, same for silicone oils. Other silicate compounds are mostly 2 or 3.
Sometimes Ok implies don't do it unless you have to because it'll almost certainly cause issues, unless you specify a short service life for the part - which is obviously a bad thing.
- ldrcycles
Re: Magic Shine
Postby ldrcycles » Thu Aug 04, 2011 7:38 pm
Tried it for the first time this evening and OH MY GOODNESS it is incredible. On the surface it looks pretty solid and the light just blew me away, super wide beam with a large spot in the centre which gets it a fair way down the road and the sheer quantity of light is fantastic. My Cree Q5 (claimed as 240lumen) which i thought was SOO bright was completely overwhelmed. Even if this only lasts a few months it will be worth every penny as i have literally seen the light and can now appreciate a 100ish lumen light.
- Xplora
Re: Magic Shine
Postby Xplora » Thu Aug 04, 2011 9:13 pm
I've decided that you can't have too much light. The extra confidence you get from being able to see at night is worth every penny, and my eyes aren't fantastic so somewhat fuzzy eyes plus dim light makes avoiding potholes etc almost impossible, particularly if you're knackered already.
- Kenzo
Re: Magic Shine
Postby Kenzo » Fri Aug 05, 2011 10:50 am
About how long did it take for delivery? .. I am considering buying one as a gift for someone's birthday in 16 days time....ldrcycles wrote:I bought this one off ebay and it turned up yesterday. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
- MichaelB
Re: Magic Shine
Postby MichaelB » Fri Aug 05, 2011 11:39 am
Crikey, that's a good price. About $20 odd cheaper than Dealxtreme !!
Re: Magic Shine
Postby stevage1 » Fri Aug 05, 2011 7:34 pm
Is there a good middle ground at the moment? I'm really after battery life more than anything - I do a bit of cycletouring, so being able to get 10-20 hours would be great (of reduced brightness obviously ) Or do I just buy more battery packs...how much do they go for?
Re: Magic Shine
Postby stevage1 » Fri Aug 05, 2011 7:35 pm
- ldrcycles
Re: Magic Shine
Postby ldrcycles » Fri Aug 05, 2011 8:54 pm
- find_bruce
- Moderator
Re: Magic Shine
Postby find_bruce » Sat Aug 06, 2011 12:19 am
Cheaper than DX used to be, now less than US $45MichaelB wrote:Crikey, that's a good price. About $20 odd cheaper than Dealxtreme !!
- utopia
Re: Magic Shine
Postby utopia » Sat Aug 06, 2011 11:18 am
- Kenzo
Re: Magic Shine
Postby Kenzo » Sat Aug 06, 2011 11:48 am
Thanks..! Have bought one now... hopefully they deliver to me as quick as they did to you.ldrcycles wrote:Bought it on the 26-7 and got it on the 3rd, pretty quick i reckon.
- Xplora
Re: Magic Shine
Postby Xplora » Sat Aug 13, 2011 2:18 pm
Re: Magic Shine
Postby Marty Moose » Sat Aug 13, 2011 2:44 pm
Sent from my MB525 using Tapatalk
- find_bruce
- Moderator
Re: Magic Shine
Postby find_bruce » Sat Aug 13, 2011 3:02 pm
What's your wierd battery issue? I have had to resolder a few connectors in mine so may be able to help.Xplora wrote:Weird battery issue. BUT I have dropped the batteries a few times from the bike saddle to the biek rack... the jury is out just now. Take care of your batteries, bit hard to blame MagicShine for my abuse.
- Xplora
Re: Magic Shine
Postby Xplora » Sat Aug 13, 2011 6:03 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
