Pre workout supplements and cycling
Postby Mikesbike » Fri Aug 05, 2011 9:28 pm
Re: Pre workout supplements and cycling
Postby vander » Fri Aug 05, 2011 9:43 pm
Pre workout supplements wont really work with cycling unless you are doing some sort of sprint training. As creatine only affects repetitive short burst training, unless you are doing this it wont really help except of course the amazing placebo effect. Caffeine can help in delaying the effect of fatigue but having before you start training i dont know its effectiveness but there have been tests showing that when you are fatiguing and your effort is decreasing caffeine can help bring it back to its peak. To be honest i would say mainly a waste of money unless you are doing repetitive sprints.Mikesbike wrote:Who here uses pre work out pumps with their training and racing? I use Jack3d gives you an excellent pump, beta alanine (lactic buffer), creatine monohydrates to fuel the muscles and its very high in caffine which is great for getting you going... but avoid the post ride coffee, caffine overdose is not a pleasant experience I know first hand! Does anyone else use Jack3d, how do you find it? What else do people use?
Postby Mikesbike » Fri Aug 05, 2011 10:03 pm
I use it for speed and power work so motorpacing, sprinting, and ergo sessions with a coach. I find it pretty effective as I have tried training with and without and definately notice a superior difference too great to be a placebo effect... I'm stronger, more focused and last alot longer before stamina and the lactic build up gets the better of me. I don't use it for K's because unless your sprinting and working in the high HR zones flushing blood around your body the Beta Alanine tingle doesn't go away and it drives you insane.vander wrote:Pre workout supplements wont really work with cycling unless you are doing some sort of sprint training. As creatine only affects repetitive short burst training, unless you are doing this it wont really help except of course the amazing placebo effect. Caffeine can help in delaying the effect of fatigue but having before you start training i dont know its effectiveness but there have been tests showing that when you are fatiguing and your effort is decreasing caffeine can help bring it back to its peak. To be honest i would say mainly a waste of money unless you are doing repetitive sprints.Mikesbike wrote:Who here uses pre work out pumps with their training and racing? I use Jack3d gives you an excellent pump, beta alanine (lactic buffer), creatine monohydrates to fuel the muscles and its very high in caffine which is great for getting you going... but avoid the post ride coffee, caffine overdose is not a pleasant experience I know first hand! Does anyone else use Jack3d, how do you find it? What else do people use?
Postby BarryTas » Mon Aug 08, 2011 9:29 am
Postby BarryTas » Mon Aug 08, 2011 9:30 am
Postby lethoso » Mon Aug 08, 2011 2:59 pm
I got some of those, they help me see at nightBarryTas wrote:and electro-lights
Postby BarryTas » Mon Aug 08, 2011 3:24 pm
lethoso wrote:I got some of those, they help me see at nightBarryTas wrote:and electro-lights
meh monday + Spelling = fail
Postby Stoo » Tue Aug 09, 2011 10:37 am
coffee before i ride (don't often have coffee when i ride)
just water when i ride.
2012 Argon 18 krypton
2010 Argon 18 Gallium Pro
2013 Argon 18 E-116
- ValleyForge
Postby ValleyForge » Fri Aug 12, 2011 10:34 am
90 min ride
Protein shake on return; Vit C/Vit D3/Calcium & magnesium
It's got me to a BMI of 22 and I don't get hungry until lunchtime.
- number21
Postby number21 » Fri Aug 12, 2011 11:53 am
- MarkG
Postby MarkG » Mon Aug 15, 2011 1:21 am
- winstonw
Postby winstonw » Mon Aug 15, 2011 7:49 am
My formula is as good as any commercial product and costs $0.27 for 35g.
Ingredients: maltodextrin, apple juice, cinnamon, NaCl, KCl, beta alanine, leucine, isoleucine, valine, caffeine, with jamsetta as the pectin and citric acid source.
It requires a bit of careful cooking to make it set to the right gel consistency, but recently I don't bother turning it into a gel. Just mix all ingredients, heat enough to dissolve maltodextrin, and put in a sports gel bottle.
A quicker gel is glucose syrup, honey, apple/raspberry cordial to taste, NaCl, KCl, BCAAs, beta alanine, caffeine.
Glucose syrup has shorter chain saccharides than maltodextrin, but is still longer than sucrose, so shouldn't spike blood sugar in dramatically. Combine glucose and honey and cordial, heat in microwave till warm and runny, add other ingredients. Stick in sports gel bottle, take only 100-200 Cals an hour.
After exercise, I do anything with protein and carb - jam sandwich, cheese and salad sandwich, chocolate milk.
The thing I am diligent with pre exercise is ensuring I start in fluid balance. Early morning rides mean drinking 600-1000mls before starting, essentially whatever got pee'd off overnight goes in before exercise.
Postby Jeremy » Sat Aug 20, 2011 4:17 pm
I suggest you stop using it immediately, and hope you dont get drug tested.Mikesbike wrote:Who here uses pre work out pumps with their training and racing? I use Jack3d gives you an excellent pump, beta alanine (lactic buffer), creatine monohydrates to fuel the muscles and its very high in caffine which is great for getting you going... but avoid the post ride coffee, caffine overdose is not a pleasant experience I know first hand! Does anyone else use Jack3d, how do you find it? What else do people use?
I'm assuming from your other posts, that you are a competitive cyclist?
Jack3D contains Geranium (1,3-Dimethylamylamine or Methylhexamine)......which is a banned substance
Postby Eberbachl » Sat Aug 20, 2011 4:43 pm
Postby Diggs » Wed Aug 31, 2011 6:43 am
I use to work for Musashi/PowerBar and spent a lot of time talking with the biochemist. Their pre-workout supp which is marketed towards bodybuilders is actually more beneficial for cyclists, kickboxers, boxers, kayakers and runners etc
Most pre workout supps help reduce the build up of lactic acid, vasodilate (expand your veins so more blood gets to your muscles), make you more mentally alert and supply amino acids to your muscles to slow the onset of fatigue.
I'm not an advocate of Musashi/PowerBar but only mention them because I've had time with the biochemist. I know many other companies make similar products which are more beneficial to us than bodybuilders but bodybuilders like the hype behind them. I would be careful of US brands as they often have ingredients that are banned in sports. I've heard good things (but haven't tried) from brands like Bodyscience, International Protein, Balance, Gen-Tec (this one I'll probably try next).
I was involved in a study at Griffith University, Gold Coast with competitive cyclists on the effects of caffeine on athletes. It was a 60 minute maximal effort once a week for 6 weeks with 15 athletes taking part. We had to eat specific food and follow strict guidlines. Blood was taken the day before the effort, 90 minutes before, 5 minutes before then straight after. The study was published and this was the result....
If the athlete abstained from caffeine for 5 days prior to the effort and took 3mg of caffeine/kg of bodyweight 60 minutes before the effort they got a 5% improvement in performance
If the athlete didn't abstain from caffeine the 5 days previous and took 3mg of caffeine/kg of bodyweight 60 minutes before the effort they got a 3% improvement in performance
So if you take that and add extras like mentioned above then bam, it's legal performance enhancing using natural substances.
I save my pre-workout supps for races or early morning hard sessions.
There's also much more sports science that can be implemented for recovery etc that will give you an edge over your competitors. It surprises me the lack of nutrition science in the sport of cycling, this is a sport that benefits greatly from close attention to these topics but it seems most are either ignorant or too lazy
- notwal
Postby notwal » Thu Sep 08, 2011 2:26 pm
Postby Kronos » Wed Jan 03, 2018 11:35 pm
It might help if you drink more water when you are using caffeine as a supplement because caffeine is a natural diuretic. It makes you piss and crap more often so you need to keep your actual fluid intake up. The cramping was most likely a direct result of dehydration.number21 wrote:Not much to add, I've had supplement salespeople try and sell me beta alanine but haven't taken the bait, although I'm more into the endurance stuff. With regards to the caffeine, I read an article by Adam Hanson where he was saying that he unknowningly bought himself gels with caffeine in them and unusually for him, cramped badly in this years Nationals road race. Hes not a coffee drinker either so effect might have been increased. I've since seen it a few times cramps related to caffeine intake.
- foo on patrol
Postby foo on patrol » Sat Jan 06, 2018 2:48 am
I find this rather confusing, because my habits don't change, if I have coffee in bulk or not!Kronos wrote:Supplements? Have a double shot of black coffee in a picolo sized cup and be merry. Most of these supplements are loaded with fillers that don't particularly do anything but sound good on the side of the can. The base ingredient is the same, and maybe taurine if you like the taste of cows testicles. Add some ginseng and guarana for good measure. Creatine just makes your muscles retain water. It's a filler, your muscles might look more defined but they are filled with water. Personally preworkout supps give me hardcore anxiety so I don't go near the stuff these days.
Foo
Goal 6000km
Postby Kronos » Sat Jan 06, 2018 2:58 pm
Postby oreo15 » Mon May 20, 2019 10:21 pm
jack3d has had a revised formula some years back, to remove the banned substance. not sure if its still as good,donna07 wrote:I dont know much about jack3d but i have been using Alpha GX7 for past 2 years. it contains huge amount of citrulline which reduced my muscle soreness as I am a marathon runner. But I must say it doesnt taste better than other supplement out there. Are you still using jack3d or something else? someone from above already replied it contains banned ingredients.
theres a boat load of pre workout supplements out there.
- ValleyForge
Postby ValleyForge » Wed May 22, 2019 12:39 pm
Nope. The cramping has nothing to do with dehydration! The cramping is from the action of the coffee increasing the motility of your intestine. For most people, coffee is a reasonable laxative. Some are quite sensitive to the effect. If you are talking about body muscle cramping, the only link might be the slight enhancement of muscle contraction with caffeine in people who are not regular coffee drinkers.foo on patrol wrote:I find this rather confusing, because my habits don't change, if I have coffee in bulk or not!Kronos wrote:Supplements? Have a double shot of black coffee in a picolo sized cup and be merry. Most of these supplements are loaded with fillers that don't particularly do anything but sound good on the side of the can. The base ingredient is the same, and maybe taurine if you like the taste of cows testicles. Add some ginseng and guarana for good measure. Creatine just makes your muscles retain water. It's a filler, your muscles might look more defined but they are filled with water. Personally preworkout supps give me hardcore anxiety so I don't go near the stuff these days.
Foo
BTW Drinking coffee will not "dehydrate" you on its own. Yes, you will probably pee a bit more, but it won't (on its own) change your hydration status to any significant degree. And if you drink extra water with your coffee, you'll pee that out too.
- ValleyForge
Postby ValleyForge » Wed May 22, 2019 12:41 pm
Who has the number plate "PEPTIDES" on his Mercedes.notwal wrote:... Then you could just seek the recommendation of you're local gym personal trainer.
I am not kidding.
- foo on patrol
Postby foo on patrol » Fri May 24, 2019 9:33 am
ValleyForge wrote:Who has the number plate "PEPTIDES" on his Mercedes.notwal wrote:... Then you could just seek the recommendation of you're local gym personal trainer.
I am not kidding.
Foo
Goal 6000km
