The swap meet thread
Postby LG » Sat Sep 17, 2011 4:53 pm
Offer
Raleigh cottered 3 spider cranks - 165mm
Solida cottered non-drive side
Cherry brake levers and calipers
Shimano dual pivot RX100 rear brake caliper
Weinmann 610 centrepull front caliper
Mafac racer front caliper
Dura Ace ex crank set 170mm
46t cottered raleigh "heron" crank set 165mm
Shimano 600 6 speed screw on freewheel (13-18tooth)
drive side shimano selecta crank and chainwheels
AVA alloy stem and steel drop bars - 22.0mm for french forks
165mm 110 BCD Sugino crank set
shimano 500 braze on front derailluer
Suntour V-T luxe rear derailluer
Rigida pro tubular rim (I think its a 36 hole)
Odd spare shimano 6200 downtube shift lever - right side only
Spinaci style bar extentions
Sachs 8 speed screw on freewheel
52 tooth alloy biopace chainring
VP beartrap pedals
1st generation dura ace black shifters
165mm stronglight 49D crank set
Campy rear wheel 126mm hub spacing (unsure of model), mavic tubular rim from memory
54cm frame - lightweight, takes a 27.0mm seat post, nicely cutout lugs, campy fork ends and dropouts. In need of paint, has some dents in the cetre of the top tube, but no bends or cracks
20 inch gold araya BMX rim on a gold high flange sunshine hub
I have some more, but will wait and see what requests others put up in this thread if it takes hold.
Wanted:
an adaptor to turn a single puegeot downtube shifter braze on into both a front & rear shifter (hope this makes sense)
Dust caps for Olimpic 64 pedals (or an idea of where I can find some)
1970's shimano 600 non-drive side crank 170mm
1st generation dura ace brake levers, front derailluer & hubs
non-drive side crank for a zues 2000 partially drilled 170mm
170mm magistroni non-drive side cottered crank
stronglight 49D outer chainring of 46-50 tooth, with 86BCD inner and 30-34 tooth chainring
32 hole dunlop special lightweight rim
decent quality 40 and 32 spoke hubs from the 1950s
shimano 6400 left (front) downtube shifter for braze on
Bugger, I know there's more stuff I'm looking for, but can't think right now. Will add to the list as things come to mind.
Re: The swap meet thread
Postby rollin » Sat Sep 17, 2011 9:13 pm
Postby LG » Sat Sep 17, 2011 9:46 pm
Postby LG » Tue Sep 27, 2011 8:06 pm
Was planning to update the original post to avoid confusion, but the edit function seems to have disappeared. Also hoping I wasn't the only member of the forum interesting in posting gear for a swapLG wrote:All items used. If of interest contact me for condition details:
Offer
AVA alloy stem and steel drop bars perfect for a peugeot build - 22.0mm for french forks
VP beartrap pedals
Wanted:
an adaptor to turn a single puegeot downtube shifter braze on into both a front & rear shifter (hope this makes sense)[b]Received thankyou very much[/b]
32 hole dunlop special lightweight rim Another forum member is also looking for some of these, if you have a pair (or more) your happy to part with, please let me know
decent quality 40 and 32 spoke hubs from the 1950s Bayliss Wiley front hub offered, looking for a matching rear
1970s campy record low flange front road hub
Suntour superbe brake callipers
Without turning this into a markplace topic, if you have something on my 'wanted' list, you'd consider selling, please let me know. My preference is for trade in the 'offer' list, but pm me if something takes your fancy.
- Ferrovelo
Postby Ferrovelo » Wed Sep 28, 2011 11:32 am
When I get some pictures I'll add them.
- Ferrovelo
Suntour supurbe cranks
- munga
Postby munga » Sun Oct 02, 2011 5:12 pm
- Ferrovelo
Postby Ferrovelo » Sun Oct 02, 2011 6:40 pm
- munga
Postby munga » Sun Oct 02, 2011 8:21 pm
when i get my act together, i'll have a few things to post up.
- frog
Postby frog » Thu Oct 06, 2011 7:05 pm
I really (really) want a reynolds tubed Peugeot frame with decent paint.
[Dreaming] Ideally it would be the black & red PE 400 with Reynolds tubing[/Dreaming]
I've seen a few lately, but none in my size/location.
Anywhere from 55-57 cm Seat tube.
Thanks!
Edit: I've made a wanted add, see my signature.
Postby LG » Sun Oct 09, 2011 8:17 pm
Will look at purchasing if you have something on my wanted list, and will then likely go to the marketplace thread with some WTS's to make up the $.
LG wrote:All items used. If of interest contact me for condition details/photos etc:
Offer
Wanted:
1st generation dura ace hubs
- munga
Postby munga » Sun Oct 09, 2011 8:52 pm
172.5mm superbe pro drive side road crank arm. anyone need it, or have its partner?munga wrote:hmm i know mine's not 170mm. it could well be 177.5 afaik, but i know for sure its not 170mm.
also have a 180mm stronglight "106" non-drive side arm
- Velo13
- nsr0772
Postby nsr0772 » Wed Oct 19, 2011 9:50 am
Will be coming down from Bathurst for the day. Have a few things to sell swap etc. If its ok I will also bring some bikes to sell, my campag 11 equipped pacer. A commuter equipped giant boulder ltd and a ladies twofold steel old style step through bike. All will be very cheap. Also have a child's seat, camelbacks, bars, tyres. Pumps, old tri bars, road and mtb bars and some other odds and sods.
I am not out to profit just wish to sell off stuff cheap to help fund my new Surly LHT. New bike is $1625 FYI.
Hope this will be OK. I'll be the fatty in the BNA cap. Come say hi.
Postby 240ZR » Wed Oct 19, 2011 6:26 pm
Nick.
- munga
Postby munga » Wed Oct 19, 2011 9:41 pm
- nsr0772
Postby nsr0772 » Thu Oct 20, 2011 5:56 am
Postby LG » Thu Oct 20, 2011 7:43 am
Wish I was in Sydney this weekend
Postby LG » Thu Dec 01, 2011 10:25 am
I'll soon be away for a couple months, but if anybody has a spare old campy downtube shifter clamp band, I'll be most appreciative (have levers and fittings, but a broken clamp). Still looking for the other things on my list.
- munga
Postby munga » Thu Dec 01, 2011 10:34 am
Postby LoveMiyata » Thu Dec 01, 2011 3:16 pm
Do you still have that 8sp Sachs freewheel?
- marc2131
Need a NOS 5 speed freewheel
Postby marc2131 » Sun Dec 11, 2011 10:45 am
Have some 2nd hand ones lying around but too old - keep slipping.
I'm in Sydney.
- Lark2004
Postby Lark2004 » Sun Dec 11, 2011 4:37 pm
I have one if you're still lookingLoveMiyata wrote:Hi LG,
Postby LoveMiyata » Sun Dec 11, 2011 5:20 pm
