BB balls and cages
BB balls and cages
Postby RetroPilot » Wed Oct 12, 2011 2:54 pm
what would happen if you put balls only, in the same diameter, in in place of the cages?
Would you need to add an extra ball or two to allow for the fact that the balls are no longer held apart a set space by the cage?
- MichaelB
Re: BB balls and cages
Postby MichaelB » Wed Oct 12, 2011 4:13 pm
Nope, but it is more hassle. Just buy std replacements. If they are captive within the cage, life is easier.RetroPilot wrote:Bottom Bracket shaft cage bearings, traditional type...
- gclark8
Postby gclark8 » Wed Oct 12, 2011 4:37 pm
George.
Postby RetroPilot » Wed Oct 12, 2011 4:38 pm
Im still looking for a cheap source of those races...see, the bearing joints can supply shotgun pellets any diameter you want, but you show them those cage races, they look puzzled, for some reason bearing shops Ive been to dont recognize them or have them..
they still must come from a major ball-bearing maker, why bearing sellers dont have them, I dont know.
I actually also wonder whether the cage contributes to shortening the life of the whole contraption.....
Postby RetroPilot » Wed Oct 12, 2011 4:41 pm
- HappyHumber
Postby HappyHumber » Wed Oct 12, 2011 6:06 pm
I pretty sure Sheldon Brown has an article on the various standard loose ball bearing sizes... he talks about the cages.
- sturmey archer
Postby sturmey archer » Wed Oct 12, 2011 6:21 pm
Having said that the standard for loose balls is pack in ans many as will fit and then take out one
Postby RetroPilot » Wed Oct 12, 2011 8:03 pm
Postby RetroPilot » Wed Oct 12, 2011 8:10 pm
In wheels, Ive noted, you are likely to encounter either caged balls or free balls..
certainly the caged balls are niftier to handle when it comes to wheels, but once Ive dismantled a BB, I doubt it makes much difference convenience wise, ive got no issue sticking the little buggers into the cup loaded with grease one by one..
Postby glennb » Wed Oct 12, 2011 9:21 pm
- HappyHumber
Postby HappyHumber » Wed Oct 12, 2011 9:51 pm
I surprised now though that someone didn't pick you on the fact shottie pellets are generally lead or some similar softer alloy?
Postby RetroPilot » Thu Oct 13, 2011 4:13 am
For my own bike, sure. Whats the rock-bottom cheapest cartridge, maybe $20?
See, Im selling cheap bikes...if BB bearing/s have failed, as they often have on 3-piece cranks though not on 1-piece ones, I have to make some kind of repair. Putting a $20 part into one, and b4 I have even done any other rectification on it Im pretty much wasting my time economically on that bike anyway..even $8 worth of cages is a large % cost-on..
- gclark8
Postby gclark8 » Thu Oct 13, 2011 7:13 am
remove old balls from cages,
clean cages with kero,
fit new balls to cage,
fit serviced cages with NEW grease,
about 50c for a BB service!
George.
- MichaelB
Postby MichaelB » Thu Oct 13, 2011 9:00 am
+ labour ....gclark8 wrote:Buy your balls by the gross,
Last time I bought a pair of BB crank bearings in cages, it was $5 for a pair.
I can't see the point of the effort to use just loose balls and the extra effort and time involved.
Postby RetroPilot » Thu Oct 13, 2011 9:01 am
See im not talking about servicing, am talking about repair /replacement of components beyond service..
- gclark8
Postby gclark8 » Thu Oct 13, 2011 9:27 am
Ball retainers 1/4†x 9 for bottom bracket racer-MTB. I sell them for $2 a pair.
George.
Postby RetroPilot » Thu Oct 13, 2011 9:32 am
the question is also an academic technical one, can you dispense with the cage altogether..
Postby glennb » Thu Oct 13, 2011 10:03 am
Cages go bad when there's no grease though, meaning odds on the spindles will be pitted, at which point you need a new BB anyway.
I picked up a 110mm sealed square-taper BB for $7 or $8 from c r c not long ago. They're probably cheaper by the dozen.
I'd be looking for a cheap source of BBs if I was in your boat.
Postby rkelsen » Thu Oct 13, 2011 10:32 am
Absolutely. In fact, I'd go as far as saying that no good mechanic could leave them in there with a clear conscience.RetroPilot wrote:the question is also an academic technical one, can you dispense with the cage altogether..
Postby RetroPilot » Fri Oct 14, 2011 1:23 pm
ill check on the el cheapo cartridges, thanks to the last two posters..
bearing store is quoting 8c each for balls if imperial sized (which I think they are, what size are they btw?) or 20c ea if metric..
at 8c it might still be practical , at 20c ea not really, at that price its well over the price of the cages that clarke mentioned.
- il padrone
Postby il padrone » Sun Oct 16, 2011 10:05 am
Struth!!!RetroPilot wrote:ok, so add two balls, which the normal number in cage is 9 by my count..so make it 11..
Go to your friendly LBS. They'll probably give you a handful of balls, enough for the whole BB for about 20c total. And they'll know what size to give you (BB and rear wheel hub bearings are 1/4")
As for the correct number, put enough balls in to fill a ring around the cup, then remove one.
- il padrone
Postby il padrone » Sun Oct 16, 2011 10:13 am
Where did you get this idea from??gclark8 wrote:it would double the wear. Cone-ball-cup as against Cone-ball-ball-cup!
When the bearings are correctly adjusted the balls should be pushed apart from one another giving only contact between the cup-ball-cone. In addition a well maintained bearing set will have a liberal dose of grease to prevent any wear.
Loose balls are always better than bearings in a cage - more balls taking the loads = less load per ball (this is particularly an issue for the headset). Also caged bearings ina headset make it that much more likely that a loose headset can become brinnelled, taking a 'set'. Caged bearings have the added disadvantage that sometimes the cage can break - in which case you have seized bearings and riding stops.
- il padrone
Postby il padrone » Sun Oct 16, 2011 10:16 am
I must admit this is my preference for BBs. Cups, loose balls and the axles to suit are pretty rare to come by these days.glennb wrote:Why are you holding out against sealed BBs? IME they work, they're cheap, and they don't need servicing.
Postby RetroPilot » Sun Oct 16, 2011 10:30 am
Ive noted that those big bastards on bikes with one-piece cranks seem almost indestructible compared to the ones on 3-piece cranks..theyve usually survived even on the daggiest old unmaintained bikes.
Ive bought a 144 pack of balls on ebay for about $8.30 inc...highly reluctant to go cap in hand to bike shops for handfulls of anything..except a bike box when I need one, I know that few of them begrudge those.
works out <6c a ball, the local bearing shop wanted 8c ea
thanks for pointing out they are same as rr wheel balls, Id wondered but figured the BBs were probably larger..that will come in handy as well..
Postby batchsaid » Wed Sep 12, 2012 10:31 pm
Was there ever consensus reached around whether ditching cages in favour of lose balls is the way to go?
Also does any one know anything about ball bearing grades? Sheldon says grade 25 is the best quality available for cycling purposes but i've seen a few sites advertising grade 10 or 5 in some sizes.
