Accident while out for a ride yesterday
Postby auswi2 » Sun Nov 13, 2011 12:20 pm
He suffered a a broken rib and some bruising cuts and abrasions. I thank God it was not worse. It shook me up pretty good and was felling responsable for the accident all day yesterday.
Thank you to all that stopped and to help and the off duty paramedic
I say to all riders when you are in front of another rider please keep your speed consistant and if you are following or drafting then please keep at leaset a good 1/2 metre behind and always look ahead of the rider in front of you.
auswi2
- sogood
Re: Accident while out for a ride yesterday
Postby sogood » Sun Nov 13, 2011 12:33 pm
- Aushiker
Postby Aushiker » Sun Nov 13, 2011 12:52 pm
Sorry to hear about this but glad it was not worse.
Very important to call and signal when riding in groups and look ahead, not at the wheel/backside in front of you. This way you can have a sense of what is coming up.
Hope the rider heals quickly.
Aushiker.com
- il padrone
Postby il padrone » Sun Nov 13, 2011 1:01 pm
The best thing to do is to look at the shoulders of the rider in front (or just over their shoulder to be aware of what's ahead) and judge your distance from this.
- trailgumby
Postby trailgumby » Sun Nov 13, 2011 1:48 pm
- Mulger bill
Postby Mulger bill » Sun Nov 13, 2011 6:23 pm
- open roader
Postby open roader » Sun Nov 13, 2011 8:28 pm
Damn offs - only downside to cycling........auswi2 wrote: It shook me up pretty good and was felling responsable for the accident all day yesterday.
It's good that you felt moved enough to post this distress here, means you have taken note of cause and effect. However, you can only ever be held responsible for your own actions, not the actions of others. The rider behind has a duty of care to avoid rear ending the rider in front. Sure unforseen factors kick in and collisions occur and sometimes riders just zone out and BANG.......not your fault but very healthy that it shook you up and illustated the occasional pitfalls of group rides.
Best you can do is take note, be thankful you stayed rubber side down this time and follow your own plea for distance and visual awareness when drafting. I take my hat off to you, I'm too chicken to ride in a group of more than 2 - reminds me of the horrors of C grade motorcycle racing with corner cutting + drafting checking + speed = ugly ..........
Postby Sydguy » Sun Nov 13, 2011 9:06 pm
So old mate behind hits him comes off and fractures his pelvis. Very unlucky result, they were cycling in loose formation, it was dark and I gather the roads were ever so slightly wet.
Needless to say accidents happen but take care that is a nasty outcome!
JM
Postby martin_12 » Mon Nov 14, 2011 10:33 am
If you want to maintain the spacing between you and other riders in the group you have to consciously keep the pressure on the pedals as you stand and give a little extra kick to overcome the effect of your body weight moving forward. If you watch the distance between your front wheel and the wheel of the rider in front when you stand up, you can see how your bike moves when you stand.
To reduce the chances of touching wheels, I always try to ride a little to one side of the rider in front of me. Then if his wheel moves back more than I anticipate, my front wheel won't touch his back wheel.
- uncle arthur
Postby uncle arthur » Mon Nov 14, 2011 12:27 pm
A good rider can pop up out of the saddle without the bike popping backwards, and like you said, good bunch riders watch what's going on around them. It's a habit that comes with experience though,can be hard for noobies.martin_12 wrote:A very common cause of wheels touching is the rearward movement of the bike when a rider gets out of the saddle. This movement is due to conservation of momentum - cyclist's body moves forward so bike moves backward (both relative to the other riders in the group. Some cyclists make things worse by pausing their pedaling action for a fraction of a second as they stand up. I have ridden behind cyclists whose wheel moves back about one metre when they stand. Quite scary.
Hope your riding buddy recovers soon.
Postby Baldy » Mon Nov 14, 2011 1:36 pm
I did the same thing a few weeks ago, lucky to get out of it with grazes and bruising.
People are pointing out its a problem with inexperienced bunch riding and that is true. But it happens to the pros all the time, in training and during races. Not just in sprints or a 12 wide bunch either, a lapse of concentration can happen to anyone and usually when the pressure is off.
The bloke I hit felt bad too, that just tells me you are good people
- il padrone
Postby il padrone » Mon Nov 14, 2011 6:25 pm
The best trick to avoid causing this problem for those behind is easy - change up a gear before you stand up, and equally, change down when you sit down. Standing in a higher gear will propel you forwards faster, the reverse for sitting down to avoid hitting a rider in front.uncle arthur wrote:A good rider can pop up out of the saddle without the bike popping backwards, and like you said, good bunch riders watch what's going on around them. It's a habit that comes with experience though,can be hard for noobies.martin_12 wrote:A very common cause of wheels touching is the rearward movement of the bike when a rider gets out of the saddle. This movement is due to conservation of momentum - cyclist's body moves forward so bike moves backward (both relative to the other riders in the group. Some cyclists make things worse by pausing their pedaling action for a fraction of a second as they stand up. I have ridden behind cyclists whose wheel moves back about one metre when they stand. Quite scary.
- jules21
Postby jules21 » Sat Nov 26, 2011 10:47 am
Return to “Cycling Safety and Advocacy”
