Technical Summer Wear Shirts
- Aushiker
Postby Aushiker » Fri Dec 09, 2011 3:19 am
Okay this might be a bit left field but you never know what knowledge is out there
I have my cycling tour coming up, about two months or so of tootling along from Darwin to Perth, leaving around July. Given that this will, even at that time of the year, be pretty warm weather for a fair bit of the ride and sun protection is also important I am looking for suitable shirts to wear.
Such beasts will ideally be loose fitting, summer weight, smell resistance (can be two weeks between washes and only a couple of shirts to be worn between washes) and a reasonable degree of UV protection. Am I asking too much? I am aware of the likes of Ground Effect shirts such as the ZZ Top or the Rock Lobster but I am wondering if there are similar products in the bushwalking market place (Ground Effect's gear might be on the tight side as well ).
They don't have to be technical tees or have rear pockets either so other suggestions are appreciated.
Aushiker.com
- il padrone
Re: Technical Summer Wear Shirts
Postby il padrone » Fri Dec 09, 2011 12:36 pm
Consider merino tops like the Ground Effect Submerino, Median Strip, or similar tops from other outfitters. You are in the dry season and (at least in the southern parts of your tour) it will be coolish. I used the Submerino on the Oodnadatta Track at similar time of year and it was great - wore it for days at a stretch and no pong. A great top to wear. I've since become a real merino fanAushiker wrote:I have my cycling tour coming up, about two months or so of tootling along from Darwin to Perth, leaving around July. Given that this will, even at that time of the year, be pretty warm weather for a fair bit of the ride and sun protection is also important I am looking for suitable shirts to wear.
I can also recommend their merino socks for similar reasons - Zig Zags or Anklebiters are luxurious to wear.
Another route to take is to buy a couple of travel shirts made from wicking fabrics. I have one from Kathmandu that is exceptional to wear in hot weather - never gets damp or oppresively hot, but it does need washing as it starts to pong after 2-3 days wear
- Aushiker
Postby Aushiker » Fri Dec 09, 2011 3:57 pm
As I was out and about today I dropped into Anaconda and Kathmandu for a look. Not much at Anaconda as I pretty much expected but I did pick up a Gondwana Brumby shirt which is 50% bamboo and 50% Cotton. Was on clearance for $42 so not a big issue if it does not work out. Only down side is that it is short sleeved.
From Kathmandu I got a long sleeved short which is more "technical" in its material, if you can describe 100% nylon as technical for $70. Still over priced but it feels good on and is quite light material. It is a Kangsar which has a UPF 45 rating, long sleeved and comes with insect repellent apparently. If that works against March flies I will be very impressed indeed.
I also tried a lightweight merino long-sleeve t-shirt at Kathmandu but found it warm even in the air conditioning at the store. I might take another look at the Ground Effect options as you suggest Pete.
Both of these shirts are normal button up so not cycling shirts by any means but I will give them a try next week on a four day ride. If nothing else they will be okay bushwalking and camp shirts.
Also I suspect that they will not do well on the smell meter.
Still open to ideas as well.
Regards
Aushiker.com
- il padrone
Postby il padrone » Fri Dec 09, 2011 5:19 pm
This Kathmandu shirt is virtually the same as the one I love to use for summer cycling (short sleeves are OK for me in summer, I have a mediterranean complexion). Wore it to work today as well, so it's very versatile for meAushiker wrote:Both of these shirts are normal button up so not cycling shirts by any means but I will give them a try next week on a four day ride. If nothing else they will be okay bushwalking and camp shirts.
Where the merino really holds its own . The GE shirts are not body-hugging like some merino thermals are. Winter in outback SA they were quite comfortable, mostly worn as a single layer.Aushiker wrote:Also I suspect that they will not do well on the smell meter.
- Aushiker
Postby Aushiker » Fri Dec 09, 2011 6:14 pm
The one at Kathmandu was more of a base layer so body hugging. Just didn't feel comfortable. The looser fit would be much better I suspect. I might get a couple for later into the ride.il padrone wrote:Where the merino really holds its own . The GE shirts are not body-hugging like some merino thermals are. Winter in outback SA they were quite comfortable, mostly worn as a single layer.
Aushiker.com
Postby }SkOrPn--7 » Fri Dec 09, 2011 6:49 pm
#Garments made from lycra fabrics are light in weight.
#Comfortable and breathable.
#Lycra fabric dries very quickly.
#Lycra spandex fabric is resistant to bacteria and UV rays.
#Resistant to abrasion.
#Resistant to dry heat.
#Improves Circulation
Ricky
- il padrone
Postby il padrone » Fri Dec 09, 2011 8:56 pm
Note: not summer wear of course.Ground Effect wrote:Jungle Jims tights are the perfect excuse to be outside when its cold. Stretch merino keeps you toasty while their graduated compression-fit reduces muscle fatigue and aids recovery
Aushiker, you could also have a look at clothing made from bamboo . Apparently very soft, comfortable and cool in summer. Can't beat the price at $14.95 either
- Aushiker
Postby Aushiker » Sun Dec 11, 2011 12:37 am
Looks like I found the right Icebreaker products to go for. Thanks to GJ Coop for his feedback via CGOAB. He is suggesting Icebreaker GT. GT150 I assume as that is for a lightweight material for warm weather. Bivouac Outdoor a NZ company has good prices and free shipping to Australia. They also stock the Outdoor Research Sun Runner Cap which was I after for wearing under my helmet.
Aushiker.com
- Aushiker
Postby Aushiker » Sun Dec 11, 2011 12:43 am
I did pick up a shirt (SS) from Anaconda which was 50% bamboo and 50% cotton. Can voucher for the very soft claim and light weight to boot. Might see if I can get a long sleeved one.il padrone wrote:Aushiker, you could also have a look at clothing made from bamboo . Apparently very soft, comfortable and cool in summer. Can't beat the price at $14.95 either
Aushiker.com
- Aushiker
Postby Aushiker » Sun Dec 18, 2011 10:10 pm
I sort of tried your approach Ricky, in that I wore a Lycra cycling jersey under my Kathmandu shirt on my brief four day ride last week. The first day was fairly humid but the others dryer with the temps on the bike between 25 to 35 c approximately. For me the Lycra just didn't breathe that well so while I didn't get really hot, I never felt that comfortable either. May be the jersey of course. I think I will give the Icrebreaker jerseys a go.}SkOrPn--7 wrote:Andrew I wear Lycra Compression Tights/Long Sleeve Tops under my outer shirts and shorts for the following reasons that way I can wear anything of my choosing for clothing not limited in anyway so that is my touring get-up plus you don't get hot wearing it
Aushiker.com
- RonK
Postby RonK » Sun Dec 18, 2011 10:50 pm
I have the Ground Effect Road Rage, Median Strip and Manta Ray - all short-sleeved but do have their long-sleeved equivalents. These garments are aimed at the touring/mtb market so they are not tight-fitting. I ordered the largest size (XL) when I would normally order XXL bike jerseys, and find them quite long-tailed and roomy.Aushiker wrote:I am aware of the likes of Ground Effect shirts such as the ZZ Top or the Rock Lobster but I am wondering if there are similar products in the bushwalking market place (Ground Effect's gear might be on the tight side as well ).
Since you are heading north, I think the Road Rage (Rock Lobster) would be the best choice - I found the Manta Ray tends to get wet and clammy like cotton, and the Median Strip is merino and probably better suited to slightly milder climes, although I have worn it during quite warm weather in reasonable comfort. The Road Rage is light, soft fabric and wicks extremely well.
I also have both the Juggernauts and Ranchsliders, and find them great for touring with a few pairs of Underdogs for comfort.
And since these products are made in earthquake-damaged Christchurch and offer great value at the price, I'm only too happy to support the our NZ cousins.
- Aushiker
Postby Aushiker » Thu Mar 08, 2012 2:04 pm
Have narrowed down my choice to Ground Effect and more Ground Effect ... Keeping in mind riding from Darwin south starting out in July and using a Brooks England Flyer I am tossing up on the following:
Juggernaut or Supertankers ... probably will go the Juggernaut given only $10 more but thoughts form users/others? Looking for durability and not being too hot on the road ... These will be worn for up to 14 days between machine washes.
Knicks ...
The choices are:
Underdogs at $49.000
Sputniks at $79.00
Supersonics at $109.00
My preference is for at least eight panels so that knocks out the Underdogs unless there is strong support for them. Maybe the Sputniks are a good comprise? Looking at averaging around 75 km a day in the saddle. Anyone have experience with the Supersonics? Worth the extra mullah?
Thoughts?
I am staying away from bib shorts on this ride.
Aushiker.com
- il padrone
Postby il padrone » Thu Mar 08, 2012 3:49 pm
Postby Uncle Just » Thu Mar 08, 2012 3:53 pm
I have tried many shorts but probably because of my build (tallish and slim) I find few really fit me well. The juggernauts had to taken in by my wife as I "swam" in them a bit but are now ok. I like the extra length on the thigh and they don't ride up in the breeze like so many others I've tried. The zips are handy for flow through ventilation. They are well made like all their gear and are holding up well. You will be riding in a hot northern climate that others can comment on more so than me, but I would suggest taking a couple of spare underdogs to avoid wearing things for too long which may cause problems.
- Aushiker
Postby Aushiker » Thu Mar 08, 2012 5:08 pm
So a pair of Juggernauts, a pair of Sputniks and a pair of Underdogs should do the trick.
Sound reasonable?
Aushiker.com
- Aushiker
Postby Aushiker » Sat Mar 10, 2012 5:29 pm
Thanks for your contributions.
Aushiker.com
Postby Meditator » Sun Mar 11, 2012 4:17 pm
I think you will find this too warm in northern Australia. I wore a polyester pjyama shirt which i'd bought for $1 in Darwin - which i don't recommend however since i got a tan through it.
I met a cyclist who had bought a fishing shirt from bcf which he recommended to me, having just ridden up from perth himself and he was happy with it. I've now bought one. Its great cause it has lots of vents in it. You won't find anything as good in a hiking shop. The price was $45. I wear mine in my tropical garden and although there's a limit to stopping the sweat from flowing it is certainly better than any cotton shirt i've used.
Its not true to say you will have to go two weeks between washes. There are creeks everywhere and you should be able to rinse them out every day. If you have a kitchen sink with you, you can even wash your gear with soap. But scrub, don't just soak cause that doesn't work at all.
You only need one pair of riding shorts/knicks for this period. You won't want to wear shorts over your knicks. Too hot. Sounds like you are buying too many clothes. Don't forget your swimmers.
Postby Meditator » Sun Mar 11, 2012 4:25 pm
- Aushiker
Postby Aushiker » Sun Mar 11, 2012 5:06 pm
Whilst I can at times do rinses in creeks or a bag I will have lengthily periods before I can do a proper wash in a washing machine with washing powder. For one section that could be 17 days when riding through the Pilbara. I will NOT use soaps etc in creeks plus in the Pilbara there is very little water and what I have is not getting wasted on washing I can assure you of that. I also don't carry a kitchen sink, in fact I don't carry soap at all.Meditator wrote:"Its not true to say you will have to go two weeks between washes. There are creeks everywhere and you should be able to rinse them out every day. If you have a kitchen sink with you, you can even wash your gear with soap. But scrub, don't just soak cause that doesn't work at all.
I will be using two pair of knicks. I have had plenty of experience of up to fourteen days between washes and have no intention of wearing one pair. As to the shorts; I prefer to wear them. I will probably have two Ground Effect riding tops, one or two Icebreaker tops (will double as sleep gear/town shirt/camp shirt if I go with the Ground Effect shirts), two pair of knicks and two shorts, maybe a third pair for in town (so I can do a machine wash of all the ride clothing and not be scaring the locals too much). To much clothing? Maybe but based on years of bushwalking and more recently cycle touring I think that will work fine for me and if not I can easily post stuff home. I have yet to still make a final decision on the button up shirts but will probably not go with them.You only need one pair of riding shorts/knicks for this period. You won't want to wear shorts over your knicks. Too hot. Sounds like you are buying too many clothes.
The Icebreaker shirts are actually very good at keeping me cool and wicking away moisture. That is based my limited testing in temps around 30 C+ so will stick with them for now and see how they pan out
Hot? Well I have riden in temps up to 50 C on the bike so I guess I have some clue as to what works for me plus I live in Perth ... and believe or not it gets hot here too.
I will not be carrying swimming shorts. My riding shorts will double for swimming shorts.
Aushiker.com
- Aushiker
Postby Aushiker » Sun Mar 11, 2012 5:16 pm
Aushiker.com
Postby J Quinton » Sun Mar 11, 2012 6:15 pm
Dont forget you can find and leg arms covers that do not warm up.
- Aushiker
Postby Aushiker » Wed May 09, 2012 1:21 pm
They also have a rougher feel to them compared to my "lycra" style roadie jerseys.
Will be interesting to see how they go on the Dreaming Tour.
Oh as an aside I also got a pair of Croc Santa Cruz Mens size 10 which weigh in at 458 grams. These will be my camp/town shoes. I have been impressed with the comfort of my Croc sandals so hopefully these will be the same. They also pack down much better than the original Crocs.
Aushiker.com
- Aushiker
Postby Aushiker » Thu May 24, 2012 2:24 pm
Aushiker.com
- KenGS
Postby KenGS » Thu May 24, 2012 3:42 pm
They'll be fine so long as I'm not riding behind youAushiker wrote:A further update. My Ground Effect Underdogs arrived in the mail today. Interesting cycling shorts. All mesh bar the chamois. Will be interesting to see how they go.
Helmets! Bells! Rego!
- Aushiker
Postby Aushiker » Thu May 24, 2012 5:45 pm
KenGS wrote:They'll be fine so long as I'm not riding behind you
Aushiker.com
