Panniers, Racks and Mudguards
- KonaCommuter
Postby KonaCommuter » Wed Jan 18, 2012 6:18 pm
So I’d like to seek the forums wisdom on Panniers, racks to put ‘em on and maybe mudguards.
Advice and opinions gratefully received
- Mulger bill
Re: Panniers, Racks and Mudguards
Postby Mulger bill » Wed Jan 18, 2012 6:24 pm
No idea about racks/panniers, I'm a backpack jockey.
- Chef
Postby Chef » Wed Jan 18, 2012 7:05 pm
There are a lot of options, I have;
SKS Chromoplastic guards (good price, good fit, still look A1 after a year, and most importantly - they work!)
Tubus rack (I have the Ti version, but there are lots of options depending on your needs) - great piece of kit - very solid, good welds, and easy to fit
Ortlieb panniers; two years of daily commuting and they look as good as new; great mounting system, waterproof and several options for size and closure style
Not sure of your budget, but this lot will cost you in excess of $275 (bought online frm o/s), but worth every cent as you will get many years of reliable use from them
Hope that helps
Phil
- WestcoastPete
Postby WestcoastPete » Wed Jan 18, 2012 7:14 pm
I reckon SKS Longboards are a good idea, but they only come in 45mm so you'd need to put some pretty skinny slicks on...
- KonaCommuter
Postby KonaCommuter » Wed Jan 18, 2012 7:18 pm
Postby JBark » Thu Jan 19, 2012 2:23 pm
- WestcoastPete
Postby WestcoastPete » Thu Jan 19, 2012 2:55 pm
Sounds like a good plan JB.JBark wrote:This is some useful info, I'll be replacing my MTB with a CX bike here soon, and wanted to get some proper mudguards this time. Was hoping the SKS stuff was good, since that was my plan. Hadn't looked at the Longboards before, but they seem ideal. Especially the size, since I'll probably run 28mm slicks most of the time, but wanted something that would also fit over the stock 35mm tyres if possible.
It'd be interesting to note whether you notice much difference in the ride between the 35mm and 28mm tyres - personally I'd just stick with some good 35s...
If you're going to CX on it, beware of sticks and rocks getting stuck in the guards. The SKS fenders have a joint on the front fender that's designed to break if a stick gets stuck in there, but you don't want to be replacing it all the time. For commuting or road riding it'd be sweet as...
Postby JBark » Thu Jan 19, 2012 5:03 pm
28s are going to be Marathon Plus for my daily commuting. After running them for ~5000k last year on my MTB, don't think I'd trust another tyre, they're just so indestructible. I'm running the 1.5" on my MTB, and I think I'd like something a bit narrower for the daily ride. Plus the MPs are so damn heavy, any weight savings going to smaller size is quite a bit. I might swap on the stock 35s occasionally to do a bit of gravel riding with the missus, and would like to be able to just leave the fenders on there if I can.WestcoastPete wrote: It'd be interesting to note whether you notice much difference in the ride between the 35mm and 28mm tyres - personally I'd just stick with some good 35s...
But yeah, if I end up doing some actual CX, they'll have to come off. But in reality, I'm lazy, so it will probably spend 99.999% of its time on the Marathon Plus tyres anyway.
- MattyK
Postby MattyK » Thu Jan 19, 2012 5:07 pm
Most days I use it just as a trunk bag with the sides folded up. Big enough for a lunch box and a change of clothes with the top expanded. I can squueze a rain jacket into a side pocket.
Once a week (usually) I fold out the panniers and can fit my towel, and a pair of shoes and jeans (casual Friday). The panniers can handle my 15" laptop as well, but the fabric is fairly thin and showing some wear (pulling seams at the front corner) as a result of this heavier load - this is with 3 years of use though. One of the plastic zipper tags broke off but the zipper still works fine. The internal fabric pouch under the lid is very thin, and fraying with my keys and glasses in there. It's not rated as waterproof but it's been good enough in Melbourne weather, and there's an optional cover.
Mudguards - get 'em, end of story. I have some cheapies, but might get some Curana C-Lite guards because they look schmick.
- KonaCommuter
Postby KonaCommuter » Thu Jan 19, 2012 5:36 pm
Bought Zefal Classic mudguards. The hex screws were to long for my Kona and the front one doesn’t go onto suspension forks. Still, managed to get the back one on and we’ll see how it goes.
I came away after looking at Pannier racks none the wiser. I’m not sure if they are for me or not.
Postby teak81 » Thu Jan 19, 2012 10:27 pm
2012 Oppy a5
2011 fm 015
- csy75
Postby csy75 » Fri Jan 20, 2012 8:27 am
I did switch from 28 mm tryes to 23 maxxis's and they are much better for rolling.
- Lizzy
Postby Lizzy » Fri Jan 20, 2012 2:15 pm
- queequeg
Postby queequeg » Sat Jan 21, 2012 3:57 pm
My commuter bike:-JBark wrote:This is some useful info, I'll be replacing my MTB with a CX bike here soon, and wanted to get some proper mudguards this time. Was hoping the SKS stuff was good, since that was my plan. Hadn't looked at the Longboards before, but they seem ideal. Especially the size, since I'll probably run 28mm slicks most of the time, but wanted something that would also fit over the stock 35mm tyres if possible.
Lynskey Cooper CX (Cyclocross)
SKS Chromoplastic (P45) Mudguards
Tubus Airy Ti Pannier Rack
Ortlieb Backroller Plus Panniers
Tyres: Schwalbe Marathon Plus 700x28c (P45 guards leave enough room to run up to around 37mm for tyres)
- Aushiker
Postby Aushiker » Sun Jan 22, 2012 3:17 pm
My preference would be Tubus racks as suggested earlier on and I would add to that Ortlieb panniers. I have the Ortlieb Bike-Plus rear panniers but that is probably over kill for your needs. The cheaper Classic Rollers would probably do the trick.
With respect to mudguards I have had a mixed experiences with SKS Chromoplastic mudguards and whilst I like the set on my Surly Long Haul Trucker the set on my Kinesis Granfondo Racelight are heading to the bin, to be replaced by Crud Roadracer Mk2 mudguards.
Also you might want to verify if the Chromoplastic mudguards will actually mount to your MTB. On my mountain bike I have gone with Crud Raceguards. Mind you I am not sure how they would go with racks, at least on the rear.
Aushiker.com
Postby gdt » Mon Jan 23, 2012 1:38 am
Postby JBark » Mon Jan 23, 2012 2:58 pm
Love it, that's pretty much exactly what I'm going for, though don't have the funds for quite that nice of a bike. I'm leaning towards the Merida Cyclo Cross 4 Disc, looks to be a good choice, just hoping the 2012 model still has the rack/guard lugs on the frame like the 2011 did.queequeg wrote: My commuter bike:-
- jet-ski
Postby jet-ski » Mon Jan 23, 2012 3:07 pm
I've got Chromoplast mudguards on my surly LHT with centrepull cantis. No problems. Actually canti's are better than v's for mudguards as there's more clearance.gdt wrote:A lot of CX bikes have centrepull cantilever brakes. Compatibility with mudgards is problematic, depending very much on the height to the top of the straddle cable.
Postby malnar » Mon Jan 23, 2012 3:14 pm
At the rear there was already an old mudguard but it was too short so I extended it, again using aggie pipe and cable ties.
- DaveOZ
Postby DaveOZ » Mon Jan 23, 2012 3:17 pm
- queequeg
Postby queequeg » Tue Jan 24, 2012 12:57 pm
Might be worth having a look at the Boardman CX Bikes on Wiggle. At least one forum member has one.JBark wrote:Love it, that's pretty much exactly what I'm going for, though don't have the funds for quite that nice of a bike. I'm leaning towards the Merida Cyclo Cross 4 Disc, looks to be a good choice, just hoping the 2012 model still has the rack/guard lugs on the frame like the 2011 did.queequeg wrote: My commuter bike:-
The main issue you will have with mudguards + Discs is getting the stays to clear the calipers. The lbs was very creative with how they mounted mine, and avoided the need to bend the stays into silly shapes. The result is very nice.
- Lizzy
Postby Lizzy » Wed Mar 28, 2012 12:26 pm
My name is Lizzy and I am a compulsive accessorizer ...
- Aushiker
Postby Aushiker » Wed Mar 28, 2012 12:33 pm
Being polycarbonate they should handle that okay and shouldn't knock out of line given the use of stays. My SKS Chromoplastic mudguards survive okay on the Surly Long Haul Trucker.Lizzy wrote:... only issue I'm seeing so far is fretting about banging them against things when parking/stowing the bike.
Aushiker.com
Postby Verdigriis » Thu Mar 29, 2012 3:24 pm
Any panniers are better than no panniers (unless you don't mind a backpack) and you don't have to spend a fortune on a commuting set. I have some fairly basic Basil panniers which are a PITA to get on and off the bike, but are waterproof and carry my work gear with no problems - they're the kind that come in a set of two and just drape over the rear rack and buckle on at the top and velcro on at the bottom. I don't take them on and off the bike, but just drop another shopping bag or whatever in there for ease of carrying my gear once I get to the office.
There's no need to go for the expensive gold standard unless you have the cash and like the idea, not for commuting anyway.
- sturmey archer
Postby sturmey archer » Fri Mar 30, 2012 6:47 am
Do you have any issue with the size of the hole to get stuff in and out of that bag? I was having a look at one yesterday and it seemed a bit small relative to the bag . IanMattyK wrote:I've been reasonably happy with my Topeak MTX DXP trunkbag and matching rack. The mounting process is dead simple, a little rattle in it over bumps but doesn't bother me when riding. For convenience I think it would be hard to beat.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
