That is nothing like what mine will look like. The Powermonkey Extreme is actually a larger battery than this but it will only be used when I have the handlebar bag, so that's where it will live. I'll have the Ewerk on the down tube, close to the head tube (less obtrusive).RonK wrote:I'm fussy about these things...aesthetics are important to me.
e-Werk with auxilliary battery - no thanks...
Van Nicholas Pioneer project...
- il padrone
Re: Van Nicholas Pioneer project...
Postby il padrone » Sat Jan 28, 2012 8:49 am
- rifraf
Postby rifraf » Sat Jan 28, 2012 11:39 am
Hi IP,il padrone wrote:I'll have the Ewerk on the down tube, close to the head tube (less obtrusive).
a question regarding wiring setup.
Does your headlight wire (+-) go through your E-Werk or independent of it.
Does the headlight wire and E-Werk wires piggyback each other coming off the Son hub?
Aidan
Postby Baalzamon » Sat Jan 28, 2012 11:45 am
Way I have mine setup, I have the E-Werk cable and Light plugged into the same spade connectors.rifraf wrote:Hi IP,il padrone wrote:I'll have the Ewerk on the down tube, close to the head tube (less obtrusive).
Aidan
- il padrone
Postby il padrone » Sat Jan 28, 2012 12:07 pm
+1Baalzamon wrote:Way I have mine setup, I have the E-Werk cable and Light plugged into the same spade connectors.
I twisted the Ewerk and Supernova wires together, then fastened into the one pair of spade connectors. Since then I've seen a mate's bike that has a tricky special spade connector that divides into two, just for such a use. He would probably have got it from Cheeky Monkey Transport.
- rifraf
Postby rifraf » Sat Jan 28, 2012 12:10 pm
Good to knowBaalzamon wrote:Way I have mine setup, I have the E-Werk cable and Light plugged into the same spade connectors.rifraf wrote:Hi IP,il padrone wrote:I'll have the Ewerk on the down tube, close to the head tube (less obtrusive).
Aidan
Your headlight and E-Werk are independent of each other except where they piggyback the spade connectors
on the hub.
Safe to assume you dont run your headlight during daylight hours?
I'd have to change what is now an ingrained habit of leaving my headlight on 24/7 (not a biggie with some forethought)
- il padrone
Postby il padrone » Sat Jan 28, 2012 12:14 pm
Why not?rifraf wrote:Your headlight and E-Werk are independent of each other except where they piggyback the spade connectors
on the hub.
I've been running the headlight 24/7 for the past 10 months like this. Don't see how it could be a problem. There is enough extra output from the Schmidt to charge stuff as well as run the lights, just a bit slower. Turn the headlight off if you want maximum charging rates.
- rifraf
Postby rifraf » Sat Jan 28, 2012 12:38 pm
Good to know there is some extra charge available - I hadn't anticipated this.il padrone wrote: Why not?
I had hoped it wasn't just me enjoying the perception/illusion of greater visibility to the sometimes seemingly blind behemoths
we share the roads with.
- il padrone
Postby il padrone » Sat Jan 28, 2012 1:54 pm
Greater visibility, mucho grande!rifraf wrote:perception/illusion of greater visibility to the sometimes seemingly blind behemoths
I have been getting drivers stopping for me when they are doing a right-hand turn, 50-100m away, when I have no following traffic and I'm only doing 25kmh My theory - they think at first, that I am a motorbike.
- il padrone
Postby il padrone » Sat Jan 28, 2012 2:25 pm
It might have been two of these connectors that he was using (Schmidt connector from SJS Cycles)il padrone wrote:Since then I've seen a mate's bike that has a tricky special spade connector that divides into two, just for such a use. He would probably have got it from Cheeky Monkey Transport.
- RonK
Postby RonK » Sat Jan 28, 2012 3:37 pm
They are piggyback spade connectors, I'm using them so I can remove the charging system when I'm at home. You can get them from places like Jaycar and probably Dick Smiths, auto-electricians and auto accessories shop like Supercheap auto. I'll be soldering the joints and covering them with heat-shrink tubing.il padrone wrote:It might have been two of these connectors that he was using (Schmidt connector from SJS Cycles)il padrone wrote:Since then I've seen a mate's bike that has a tricky special spade connector that divides into two, just for such a use. He would probably have got it from Cheeky Monkey Transport.
- Aushiker
Postby Aushiker » Sat Jan 28, 2012 4:15 pm
The also come with the PedalPower+ Super-i- Cable.RonK wrote:They are piggyback spade connectors, I'm using them so I can remove the charging system when I'm at home. You can get them from places like Jaycar and probably Dick Smiths, auto-electricians and auto accessories shop like Supercheap auto. I'll be soldering the joints and covering them with heat-shrink tubing.
Aushiker.com
- RonK
Postby RonK » Sat Jan 28, 2012 5:53 pm
It looks just like this one in the Van Nicholas brochure picture.
But aarrrrgh, it's so fugly, it's revolting.
I hate kickstands - I just couldn't bear it, and had to take it off immediately.
Maybe...maybe I'll put it back on to tour when it will be hidden by a pannier. But probably I'll just use my Click Stand instead.
- il padrone
Postby il padrone » Sat Jan 28, 2012 6:18 pm
I hate kickstands.
I find practical devices that accomplish a task well to be quite the beautiful thing
- rifraf
Postby rifraf » Sat Jan 28, 2012 8:25 pm
Sometimes its just gotta be function over form.
Personally I commend Van Nicholas for just how displeasing to the eye he didnt
make this and how he made the best of a bad job as its probably possible to do.
I think that that is as elegant a form as your likely to see and indeed I almost
wonder if its beefy enough to "stand" up to the rigeurs possibly to be demanded of it.
You nearly said you couldnt "stand" it
Well if you hadnt guessed, I'm now a convert to rear mounted kickstands.
Ron, yours compared to mine looks made for the job and I'd bet that given
a bit of time to get used to it, twont be long before you'll be singing its virtues
and conveniently forgotten your time "over on the Darkside".
- RonK
Postby RonK » Sat Jan 28, 2012 11:03 pm
Nah, the Click Stand is most elegant and simple: holds up my bike, scratches my back, props open my tent fly, catches brown snakes that crawl into my tent, and knocks down those fruit that I can't reach when I raid the roadside orchardsrifraf wrote:I think that that is as elegant a form as your likely to see and indeed I almost
It's so elegant you don't even notice it's there.
- il padrone
Postby il padrone » Sat Jan 28, 2012 11:18 pm
I like a stand so elegant others don't even notice it's there - I just get off the bike and the bike stands up straight away, almost by itself. No faffing about unfolding a walking stick
And when I need to take off, a quick kick and I'm riding. Simple, quick, effective for the job it's designed.
- rifraf
Postby rifraf » Sat Jan 28, 2012 11:23 pm
A bit like your E3 proRonK wrote: It's so elegant you don't even notice it's there.
Your bikes looking magnificent and I'm as envious as hell
A superb choice of frame and componentry that looks like it'll do you proud for
many years and miles to come.
I hope you've a heavy D lock to wave off the magpies.
I sure wish they Velo did those guards to suit 406 rims
- RonK
Postby RonK » Sat Jan 28, 2012 11:35 pm
But can you catch a brown snake with it?il padrone wrote:Each to their own.
- RonK
Postby RonK » Sat Jan 28, 2012 11:47 pm
We've had this conversation on one of the threads. I don't do locks - I've no wish to carry an extra kilo around. I have a light cable lock but that is all.rifraf wrote: I hope you've a heavy D lock to wave off the magpies.
If you want to keep your bike then don't let it out of your sight unless you are bloody sure about its security.
- il padrone
Postby il padrone » Sun Jan 29, 2012 12:08 am
Walk away quietlyRonK wrote:But can you catch a brown snake with it?
- rifraf
Postby rifraf » Sun Jan 29, 2012 1:08 pm
Well then maybe sharpen one end of the Clickstand to poke magpies in the eye so they dont become the beholderRonK wrote:We've had this conversation on one of the threads. I don't do locks - I've no wish to carry an extra kilo around. I have a light cable lock but that is all.rifraf wrote: I hope you've a heavy D lock to wave off the magpies.
- RonK
Postby RonK » Sun Jan 29, 2012 6:03 pm
Especially for rifraf, here are some pics of the Supernova E3.rifraf wrote: And just how good are they?
How does the E3 compare to your Ayap?
Pics or it hasnt happened
As predicted it rained all morning so still no riding. Bored, I got the soldering iron out and fitted the E3.
I don't know what it is like out on the road yet - that will have to wait until the rain stops. But looking good...
- RonK
Postby RonK » Sun Jan 29, 2012 11:05 pm
If you are going to use piggyback connectors, my tip is to fit them to the charger wiring. When not touring you can remove the charger and have the lights connected without leaving any bare terminals being exposed.il padrone wrote:Since then I've seen a mate's bike that has a tricky special spade connector that divides into two, just for such a use.
- RonK
Postby RonK » Sun Feb 05, 2012 9:56 pm
With the lights on there is a barely perceptible tingling from the dynamo hub felt through the bars at normal road speed. At speeds over 35 kph there is a distinct but not particularly intrusive vibration noticeable through the frame.
At night the E3 Pro is probably not quite as bright or penetrating as the Ayups, which have an intermediate beam. The E3 has a broader, more diffused spread of light which nonetheless provides excellent illumination of the road surface for a long way ahead. I'm not sure about the taillight, as I can't see for myself how bright it is, but in any case I will continue to use the Cateye TL-LD1000 in conjunction as a small light no matter how bright is easily lost amongst a background of vehicle taillights, and a flashing light is less easily missed. The stand light function is useful but not particularly bright and I wouldn't feel too confident I'd be seen waiting at an intersection for the lights to change. For the sake of the extra clutter of wiring on the bike frame I don't think the taillight is really worth spending the extra cash on.
- il padrone
Postby il padrone » Sun Feb 05, 2012 10:53 pm
I'm pretty sure that the E3 standlight is just as bright as the normal light in use. I don't have any concerns about it.RonK wrote:The stand light function is useful but not particularly bright and I wouldn't feel too confident I'd be seen waiting at an intersection for the lights to change. For the sake of the extra clutter of wiring on the bike frame I don't think the taillight is really worth spending the extra cash on.
"Clutter of wiring" ?? It may be worthwhile reviewing your wiring path. I ran mine along the underside of the down tube, next to and cable-tied to, the Rohloff gear cables; under the BB; following the gear cables along the underside of the chainstay; then along (cable-tied to) the Cargo rack's rear-most stay leading it up to the light's rack mount. Overall it is pretty inconspicuous to most views. It is also run in such a way that I can remove the whole lighting system in one piece by cutting the cable ties, as there are no plugs on the E3 system.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
