Experience with shortening hyd brake lines & bleeding ?
- MichaelB
Postby MichaelB » Sun Jan 29, 2012 7:41 pm
Most likely place is here, so thought I'd ask.
Anyone with experience of shortening hydro brake lines and subsequent bleeding ? Any particular tips and/or tricks ?
Pretty mechanical and handy around cars, but bikes are different, so any advice will be appreciated please
Ta
Michael B
- trailgumby
Re: Experience with shortening hyd brake lines & bleeding ?
Postby trailgumby » Sun Jan 29, 2012 8:15 pm
* a bleed kit with fittings for your brand of brakes,
* compatible oil: mineral OR DOT, depending on brand. Don't confuse them or you will destroy your seals, and then yourself when they fail unexpectedly.
* a new barb + olive for eahc hose end you need to cut.
* a brake shipping block to put in place instead of the pads so they don't get contaminated by any brake fluid spillages
* brake cleaner spray and a clean shop rag to decontaminate caliper and disc if required.
Once the barb and olive are compressed onto the hose end by installation onto the master cylinder they can't be removed for re-use, which is why you need a new set. If you're on Sydney's northern beaches I can probably assist. Avid Elixirs have a reputation for being difficult, but that will be a learning experience
- MichaelB
Postby MichaelB » Sun Jan 29, 2012 10:25 pm
Is there a std place to get the nipples/barbs/olives etc ?
Is that something that the LBS can help with ?
I can get a bleed kit from Wiggle.
Will think and research a bit more and then post some more Q's.
Ta
Postby Crittski » Sun Jan 29, 2012 11:29 pm
Volagi Liscio Ultegra
- HappyHumber
Postby HappyHumber » Sun Jan 29, 2012 11:39 pm
.. in an Oprah audience?Crittski wrote:..,and they wailed like a dozen banshees.
Nah.. been procastinating about bleeding mine. Mate gave me a hand to do it about 18 months ago. Original pads were still OK at time of checking then. Need to bite the bullet and be a big boy and do it this time for myself. Time for me to brush up on Zinn and go for it...
- Mulger bill
Postby Mulger bill » Mon Jan 30, 2012 2:15 am
What is the best tool for hose cutting?
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 7:18 am
Thanks for the other advice, but re the parts required, need to source them from where ?MichaelB wrote:
Ta
- trailgumby
Postby trailgumby » Mon Jan 30, 2012 8:04 am
Cable cutters.Mulger bill wrote:Really something I should do on me MTB. Juicys bleed easy, seems Elixirs are functionally similar. *xfingers*
- trailgumby
Postby trailgumby » Mon Jan 30, 2012 8:08 am
My LBS doesn't stock them / doesn't sell them separately, so bought the last lot for my Shimanos from c r c. Before that I got some from Clarence St Cyclery's workshop.MichaelB wrote:Thanks for the other advice, but re the parts required, need to source them from where ?MichaelB wrote:
Ta
What brand are your brakes?
Postby Crittski » Mon Jan 30, 2012 10:10 am
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 10:20 am
- Jean
Postby Jean » Mon Jan 30, 2012 11:23 am
- trailgumby
Postby trailgumby » Mon Jan 30, 2012 11:36 am
TRP[/quote]MichaelB wrote:What brand are your brakes?
Wow. These guys? http://velonews.competitor.com/2011/04/ ... kes_169011
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 12:42 pm
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 3:42 pm
Here is a pic of the caliper and brake line if that helps. Is it the same as the hope ones ?
Damn, that was hard to do fro. This so called smart phone !!!!
Edit : From one of the links, it shows a banjo style fitting as having these internal bits
or is it something else ? The tes=xt in the Bike radar & Bike rumour sites mention that the Shimano bleed kit is similar (better than Avid's), but on the TRP site, there is no listing for the spare parts needed to shorten the lines.
Help ....
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 5:04 pm
- trailgumby
Postby trailgumby » Mon Jan 30, 2012 8:01 pm
You can't then get 'em off to be able to re-use them when you shorten the hose.
- MichaelB
Postby MichaelB » Mon Jan 30, 2012 9:59 pm
At least I have a picture now of what I need, so I'm miles ahead there.
Many thanks guys. Time to place an order tomorrow me thinks and take advantage of the Wiggle TDU20 code to save another few bucks
- Mulger bill
Postby Mulger bill » Mon Jan 30, 2012 11:39 pm
Shaun
Postby Crittski » Mon Jan 30, 2012 11:41 pm
- MichaelB
Postby MichaelB » Tue Jan 31, 2012 9:10 am
Not really, just want to tinker and see if the Hydro hype is true or not, so whether I need to hold out buying the Volagi until Hydro STI's come out.Crittski wrote:Wow Michael, cutting edge!
Plus I love to tinker ...
- MichaelB
Postby MichaelB » Tue Jan 31, 2012 10:21 am
Hi Michael,
I’m not sure which fittings are compatible with the TRP parabox. When ours arrived it included fittings to shorten the lines. I would assume that yours will include these as well.
Jason Woznick
Fair Wheel Bikes
Postby Crittski » Tue Jan 31, 2012 12:44 pm
- MichaelB
Postby MichaelB » Thu Feb 02, 2012 8:58 am
Ended up ordering it from Merlin Cycles in the UK, who had one in stock (somehow, as others were expecting it in mid-March), and received confirmation that it is in the post
Thanks for all the help and advice offered, and I'm sure I'll revive this thread as the time comes to do the "operation" !!!!
- MichaelB
Postby MichaelB » Mon Feb 06, 2012 1:01 pm
Having a think about it, is it (the bit highlighted) not possibel at all, or just too damn hard to make sure the parts are OK ?trailgumby wrote:Of the four brass bits in the row closest to camera in the top photo, you need 1 each of the two on the left for each hose you're going to trim. The thin edges of the brass collar (called the "olive") at far left get crimped down into the hose by the force of tightening the threaded collar into the master cylinder or banjo (depending on the brand), and this stops the next fitting, called "the barb" from coming out of teh end of the hose.
What is the hose made from ?
