DIY bicycle work stand
- gregmacc
Postby gregmacc » Thu Oct 13, 2011 9:18 pm
The commercially available items are pretty expensive for what they are ... and many seem to be a compromise in one way or another ... It's one thing to be portable and/or foldable/stowable ... but if it's at the expense of strength and stability, I can't be bothered.
Greg
- drubie
Re: DIY bicycle work stand
Postby drubie » Thu Oct 13, 2011 9:23 pm
Basically, anything that gets 'em off the ground without damage will work. I am really happy with the arrangement I now have as I can work standing up and it cost me a grand total of $7.
http://www.bunnings.com.au/products_pro ... cts&page=2
- winstonw
Postby winstonw » Thu Oct 13, 2011 9:44 pm
If you need to transport multiple bikes via a rack, they also serve as a workstand
- Mulger bill
Postby Mulger bill » Fri Oct 14, 2011 12:23 am
- drubie
Postby drubie » Fri Oct 14, 2011 12:34 am
I do but I can't find it. Basically they used the plastic chopping board as a bottom bracket support (suitably carved) with the forks sitting on an extension.Mulger bill wrote:Somebody, can't remember who did a pretty good job with a sawhorse and a chopping board. Anybody remember it?
I tried to make something similar out of a cheap office chair by bending the back support out and mounting an old hub on it for the front forks, the using the bottom of the chair for the BB support, but it turned out to be worthless. I found that I needed something where the bike could be fully assembled while being worked on: some gear problems are easier to solve if you can turn the pedals with the wheel in place and the sawhorse/BB support design makes that hard.
The only real downside to hanging the frame from hooks on the top tube is that if you have cable routing underneath the tube you need to be careful how far apart the hooks are so you don't interfere with naked cables. The Sheldon Brown method (hang the bike from handlebars and behind the saddle) doesn't allow a bike to be assembled from scratch but it does avoid the problem of cable interference.
Thats why, after much stuffing around, the top tube hooks make plenty of sense if you've got room. Just hoik the bike up, fiddle to satisfaction, then ride!
- munga
Postby munga » Fri Oct 14, 2011 7:45 am
Postby AndyRevill » Fri Oct 14, 2011 10:48 am
http://www.bicycles.net.au/forums/viewt ... 0&p=378198
http://www.bicycles.net.au/forums/viewt ... 34&t=16353
Andy
Trek Domane 4.5
- Jean
Postby Jean » Fri Oct 14, 2011 12:08 pm
That was me:Mulger bill wrote:Somebody, can't remember who did a pretty good job with a sawhorse and a chopping board. Anybody remember it?
The thread is here:
http://www.bicycles.net.au/forums/viewt ... =+macgyver
I'm still using it - works a treat.
- ozdavo
Postby ozdavo » Fri Oct 14, 2011 1:23 pm
http://www.ebay.com.au/itm/160609135029 ... 955wt_1396
http://www.ebay.com.au/itm/330531986352 ... 860wt_1396
http://www.ebay.com.au/itm/Workshop-Bic ... 095wt_1396
- gregmacc
Postby gregmacc » Fri Oct 14, 2011 6:59 pm
Greg
- gregmacc
Postby gregmacc » Fri Oct 14, 2011 7:43 pm
Greg
Postby slowlearner » Sun Oct 23, 2011 10:10 pm
Mmm, love a cheap solution.Jean wrote:That was me:Mulger bill wrote:Somebody, can't remember who did a pretty good job with a sawhorse and a chopping board. Anybody remember it?
The thread is here:
- Queestce
Postby Queestce » Sun Oct 23, 2011 10:43 pm
http://camping.anaconda.com.au/search?w=bike+stand
Tk
- winstonw
Postby winstonw » Mon Oct 24, 2011 9:37 am
that's a clever design I haven't seen before.
I bought this Raleigh for $105 earlier this year, and it has been excellent. The quality is faultless, and it seems similar to the Park Tools model.
http://www.evanscycles.com/products/ral ... rk%20stand
Being able to pivot the bike is great when working under the down tube and bottom bracket, or cleaning; a limitation of a BB support stand.
Stability is surprisingly good, as is maximum height. I am 186cm and can get it high enough to mess with drive train comfortably when standing.
It folds down small enough to leave in the car.
- familyguy
Postby familyguy » Thu Oct 27, 2011 9:07 pm
That Anaconda one looks a lot like this one, dont you think?Queestce wrote:Not DIY, but along the lines of cheap stands, Anaconda have two differing models. I recently bought the more expensive one, it was a couple of hundred with the club discount - now its on sale for $130... Brilliant stand! If you did want to go down the paid route and were looking for something solid and very affordable...
Tk
Jimozdavo wrote: http://www.ebay.com.au/itm/160609135029 ... 955wt_1396
- wheels46
Postby wheels46 » Thu Oct 27, 2011 10:35 pm
Yep Aldi were selling them for 40 bucks this time last year.... They were a bargain. Not sure where Anaconda get off charging that much ??familyguy wrote:
Postby scirocco » Fri Oct 28, 2011 10:26 pm
Postby master6 » Sat Oct 29, 2011 8:17 pm
Uploaded with ImageShack.us
I made three. The first was an adaption of a go kart work stand.
Light, stable, folds flat.
- familyguy
Postby familyguy » Thu Nov 03, 2011 5:03 pm
Bought one of these, assembled last night. Seems pretty decent for $55. The KHS didnt fall off it, so it holds a reasonable amount. The Fuji will test it thoughozdavo wrote: http://www.ebay.com.au/itm/160609135029 ... 955wt_1396
- bollo
Postby bollo » Mon Feb 13, 2012 5:03 pm
i'll have a play & when i get something knocked up i'll post up a few pics
cheers Allan
2012 Merida Scultura Evo 905
- bollo
Postby bollo » Mon Feb 13, 2012 5:04 pm
munga wrote:leighthebee has a nice parktools clamp on what looks like a bench grinder pedestal. not the cheapest solution, and it doesn't have anything to do with rafters, but it's rad.
do you know where the owner bought the clamp in the quoted pic from ?
- bollo
Postby bollo » Mon Feb 13, 2012 5:25 pm
http://www.ebay.com.au/itm/Park-Tool-PR ... 20c26fed3c
Postby master6 » Mon Feb 13, 2012 5:51 pm
Allan, do you mind if we add a few features on a "wish list"?bollo wrote:hi guys , some good ideas there. not really about the cost of buying something i just enjoy to make things & i am lucky to have the means to be able to do it (& i was a boiler maker before my current job)
cheers Allan
Mine are
1. Foldable for storage
2. Transportable on caravanning trips
3. Can mount with rear wheel fitted for drive train adjustments
4. Can mount with front wheel fitted to adjust brakes and computer sensors. (no need to have both wheels fitted at same time)
5 Can fit tray under chain, to hold fluid , in order to wash chain.
- jacks1071
Postby jacks1071 » Mon Feb 13, 2012 6:17 pm
You could just loop a piece of rope around the truss and hook that over your saddle.gregmacc wrote:Hi all ... What do people do for work stands? ... I'm keen to make something ... preferably something that can be suspended somehow from the roof trusses of my workshop. I'm thinking about even using a bike specific clamp and adapting a hanger to fit. I think the most satisfactory arrangement would be with a clamp around the bike seat post (but I'm open to suggestions). There are plenty of examples out there in internet land but I've yet to see anything that really takes my fancy. Some of the clamps I've seen are particularly "agricultural" looking ... as if serious damage would eventually be done to bicycle tubing.
Greg
Users browsing this forum: blizzard
