Brakes on a Single Speed! Front or Rear?
Postby maccayak » Sun Feb 26, 2012 10:00 am
Geoff
- hitchhiker
Re: Brakes on a Single Speed! Front or Rear?
Postby hitchhiker » Sun Feb 26, 2012 10:09 am
Postby rkelsen » Sun Feb 26, 2012 10:35 am
Postby ejayt » Sun Feb 26, 2012 10:42 am
Postby Crittski » Sun Feb 26, 2012 10:57 am
Volagi Liscio Ultegra
- sogood
Postby sogood » Sun Feb 26, 2012 11:04 am
Stupid! The bike will be brakeless if the chain snaps. And the rider can receive inside calf skin burns.Crittski wrote:What about one in the middle??
http://manilafixedgear.blogspot.com.au/ ... -bike.html
- jimsheedy
Postby jimsheedy » Sun Feb 26, 2012 11:05 am
- mikesbytes
Postby mikesbytes » Sun Feb 26, 2012 11:25 am
Postby riddy » Sun Feb 26, 2012 1:29 pm
For the singlespeeders, as far as I can tell it is mostly out of (a) ignorance, (b) a misguided belief that all they need is the front, (c) general hipsterdom and fixie-aesthetics, or (d) (and rarely, from what I have seen) because they don't have a drilled rear brake bridge, but generally (d) falls under (c) because if you want to ride singlespeed then don't ride an undrilled track frame!
I commute on a fixed gear with a front brake. My commute is only about 3km through the Melbourne CBD, and I love riding track geometry and fixed through the city. Makes a fast, fun ride that is easy to zip around traffic (especially with 38cm bars!). I also like the absolute minimum maintenance, riding everyday all weather. With good foot retention you can stop very fast on a fixed gear with a front brake. In fact, I feel far more secure on my fixed than on my roadie when riding in the city, and especially in the wet when you have direct control to your back wheel.
But as for a front brake only singlespeed, it is pretty ridiculous in my opinion. Sure most of the braking power comes from the front, but you get control from the back. Unless you are an experience rider and know how to properly position your weight, it is very easy to throw yourself over the handlebars, especially when taking evasive action. This can also happen to a newbie riding a fixed gear, but being connected to the rear wheel means you have a lot more control (unless you don't have foot retention). And, as a city or commuting bike, it is good to stay in control!
Postby riddy » Sun Feb 26, 2012 2:00 pm
Maybe not modern track bikes, but a good 1980s-1990s steel track frame can be a whole lot of fun.mikesbytes wrote:I've ridden my track bike along a bike path and it was horrible to ride, no vertical compliance at all. Do not recommend modern track bikes be used as fixies
- gururug
Postby gururug » Sun Feb 26, 2012 2:15 pm
- PeteV
Postby PeteV » Sun Feb 26, 2012 8:57 pm
25 years ago I use to blast around a BMX track and the local streets with only a rear brake because it looked cool and you only wanted to lock up the rear for impressing your mates with skids. I've ridden single speed for commuting for the last couple of years (single speed, not fixed/track etc) and I would always have front and rear brakes on a bike. I mostly use the front to wipe off 80% of my speed and the rear helps with the remaining 20% and stops me going over the bars.
I am currently looking at building a new bike and the first thing I am researching is which brakes would be best for it!
- hartleymartin
Postby hartleymartin » Mon Feb 27, 2012 12:19 am
In the days when shearers got around by bicycle it was usual yo have a rear coaster brake only and leave off the front mudguard so you could jam your foot between the front wheel and the downtube. I tried this a few times - works quite well, but takes quick thinking and is not something you want to have to depend on!
I've also seen quite a few bicycles with a rear cable-operated brake only, but I wouldn't want to be riding real fast on one of those.
Polo bikes tend to have brakes to the rear. Not sure what the primary reason for this is, but I suspect it is to allow riders to flip their handlebars around 360 degrees. They also tend to have pretty low gears anyway - I'm lead to believe about 52 to 60 gear inches.
- sogood
Postby sogood » Mon Feb 27, 2012 12:24 am
It really doesn't matter which brake one uses at 10-15km/h...hartleymartin wrote:Generally speaking I tend to use the rear brake to control my speed and then the front to make the stop...
- gururug
Postby gururug » Mon Feb 27, 2012 12:27 am
In polo, your right hand is always holding the club, so there is little use for a brake on the right. Lots of low speed maneuvering means a rear brake is a smoother option, anyone who has done a motorbike license test knows the value of a rear brake at low speeds.hartleymartin wrote:Polo bikes tend to have brakes to the rear.
Most pro's use a single "dual control" lever mounted on the left which actuates front and rear simultaneously.
- hartleymartin
Postby hartleymartin » Mon Feb 27, 2012 3:04 pm
Believe it or not, I do ride faster than this quite often on my tourer. One thing I also noticed in Europe was that most people tended to ride much slower - at what I would call a "comfortable pace", than we do here.sogood wrote:It really doesn't matter which brake one uses at 10-15km/h...hartleymartin wrote:Generally speaking I tend to use the rear brake to control my speed and then the front to make the stop...
- landscapecadmonkey
Postby landscapecadmonkey » Wed Mar 07, 2012 1:33 am
for my other europa conversion around the lake at Ballarat, just the front, for aesthetics and 'just because'
would like the leg muscles and foresight to run no brakes... just for sh1ts and giggles, but feels far too risky at this stage.
front brake on a steel bike often seems to bend the front fork under load excessively. might be totally fine, but wouldnt like to test that flex under extreme load
- HLC
Postby HLC » Wed Mar 07, 2012 10:36 am
First I've heard of this. If I saw my steel fork bending under excessive load, I'd throw it in the bin.landscapecadmonkey wrote: front brake on a steel bike often seems to bend the front fork under load excessively. might be totally fine, but wouldnt like to test that flex under extreme load
I would expect that from a carbon fork or a bike made out of recycled coke cans (either of which I wouldn't ride if the fork was prone to flexing).
That means its time to get rid of the rust bucket kerbside frame with no structural integrity left and find a nice stiff steel track frame. No issues with mine brake or no brakes.
And FWIW if you are going to run a brake, on a fixed gear a front will suffice, SS, front is borderline ok but I'd run both. No point trying to make it look like something it's not.
Postby Kempie » Thu Mar 08, 2012 5:12 pm
I agree, I'm sure the the coefficient of friction between the tyre and the road is not that highHLC wrote:First I've heard of this. If I saw my steel fork bending under excessive load, I'd throw it in the bin.landscapecadmonkey wrote: front brake on a steel bike often seems to bend the front fork under load excessively. might be totally fine, but wouldnt like to test that flex under extreme load
Postby landscapecadmonkey » Thu Mar 08, 2012 7:11 pm
Yes, after some further riding today... with rim brakes it doesn't seem to affect the fork that much. i have another steel framed bike with disk brakes, and must have been overlaying that experience... definitely wouldnt use just the front brake only on that bike. I must just have poorer brakes on my fixed gear, as i seem to need all that the front and rear can offer while getting around town. Or perhaps its the reverse, because i have both brakes, i tend to go faster, and think about braking later than i normally would if i only had front.... or none.Kempie wrote:I agree, I'm sure the the coefficient of friction between the tyre and the road is not that highHLC wrote:First I've heard of this. If I saw my steel fork bending under excessive load, I'd throw it in the bin.landscapecadmonkey wrote: front brake on a steel bike often seems to bend the front fork under load excessively. might be totally fine, but wouldnt like to test that flex under extreme load
- HLC
Postby HLC » Fri Mar 09, 2012 12:47 am
Postby Petee » Mon Mar 12, 2012 5:01 pm
As far as i know it is only kids bikes with a front brake only?maccayak wrote:I have noticed that lots of bikes only have a front brake. Why front and not rear as I always thought rear was safer?
Geoff
All other bikes have two brakes for two reasons:
More braking power
There is no chance of the bike flipping forward with a swift stop.
- Mulger bill
Postby Mulger bill » Mon Mar 12, 2012 8:01 pm
Edited for clarityPetee wrote:Even using massive amounts of front brake only There is no chance of the bike flipping forward with a swift stop. If the rider uses their bodyweight properly.
Postby y3ntil » Tue Mar 13, 2012 12:43 am
What about us lefties eh? Also, making the brake lever on you bike pull the front or back by putting the cable into either brake. Just Front brake isn't bad either, just need to learn not to go over the bars suddenlygururug wrote:In polo, your right hand is always holding the club, so there is little use for a brake on the right. Lots of low speed maneuvering means a rear brake is a smoother option, anyone who has done a motorbike license test knows the value of a rear brake at low speeds.hartleymartin wrote:Polo bikes tend to have brakes to the rear.
Postby rkelsen » Tue Mar 13, 2012 9:17 am
HLC wrote:I reckon your headset is just loose causing your fork to flop around. Because disc-brakes shouldn't cause a fork to bend at all. The design makes it impossible.
Return to “Fixed Gear/ Single Speed”
