Is pushing pistons back in hard?
Postby slarv » Wed May 16, 2012 1:24 pm
I got a new set of pads for my Elixir5s. The Avid instruction manual makes it sound very easy but I am having trouble. Just leave the old pads in and use a screw driver to rock back and forth.
I think the pistons have gone back in a little bit but not enough for the disc to fit in between yet. I feel like I am applying a little bit too much pressure but I might just be hesitating. There is a slight squelching in the levers.
1. how much pressure is required?
2. how much rocking back and forth is normal?
3. is a bit of squelching normal or should it be totally silent?
4. does the squelching indicate that air is in the system and it needs to be bled?
5. would a system that needs to be bled prevent the pistons from going back in?
The bike is almost a year old. This its first new set of pads and it and it hasn't been bled before (apart from initial setup). I am planning on taking it to a bike shop for a proper service in about a month (when funds allow).
If all else fails I will attempt to loosen the bleed valve while pushing the pistons back in a bit and hope I don't have to take it for a service early.
Regards,
Slarv
- trailgumby
Re: Is pushing pistons back in hard?
Postby trailgumby » Wed May 16, 2012 1:47 pm
Otherwise, yes, just push back until they are flush with the caliper walls.
Postby rkelsen » Wed May 16, 2012 2:00 pm
Pushing pistons back in can take a fair amount of force. The top of the piston should be approximately level with the top of its bore when it is fully home.
The squelching can be ignored, unless the lever is spongy or travels all the way to the handlebar with no effort.
Dunno about rocking back and forth. I'd try to push the piston back in as squarely as possible.
No. In fact, it would be easier to push the pistons back in if the system needed to be bled.slarv wrote:would a system that needs to be bled prevent the pistons from going back in?
Postby slarv » Wed May 16, 2012 2:26 pm
Does metho count as brake cleaner?
Postby mitzikatzi » Wed May 16, 2012 2:31 pm
It does for me.slarv wrote: Does metho count as brake cleaner?
- trailgumby
Postby trailgumby » Wed May 16, 2012 3:33 pm
When I used to race R/C cars. I used metho to dissolve the fuel lubricant that always coated everything, and **carefully** blow it off with compressed air, being ultra careful to blow across shafts and bearings and **never** blowing **at** them.
Even then, I occasionally had to replace bearings, but they were cheap and readily available so there was a time/dollars trade-off that favoured the compressor.
However, with your brakes, getting rebuild kits can be problematic as some brands don't really design their calipers for servicability and the parts necessary cannot be bought. Juicys used to be fine for rebuild kits, not sure if the practice is current for the Elixir models though. But you still have to do the work yourself or you're up for bike shop labour $$$.
So unless you're prepared to strip and rebuild your brakes yourself, I'd recommend leaving compressed air alone.
- alf
Postby alf » Wed May 16, 2012 4:44 pm
http://www.jaycar.com.au/productView.asp?ID=NA1066
Fantastic to clean the rotors with as well.
Postby slarv » Wed May 16, 2012 11:37 pm
Isopropyl alcohol is another one of those nerdy supplies that is usually out of stock or no longer sold when you need it. I was at a Big W store a few weeks ago and was surprised to see it on a shelf together with a bunch of other useful supplies. They had a shelf full of Diggers brand stuff. Worth remembering for future.alf wrote:Metho should be fine but my preference is isopropyl alcohol
I cleaned things out with the metho and cotton bud.. A fair bit of gunk has come out but I still can't push the pistons all the way back in.
I put the old pads back in, credit card between the pads and squeezed the brake to push the pistons most of the way out. This gave me a good idea of what it feels like to push them back in.
I seem to have pushed them in as far as they are willing to go. However I have noticed when I push on one side, the other side comes out, and then vice versa... seems like a good indication of too much fluid in the system?
I am doing all of this while the bike is upside down, wondering if that is causing the problem? Would adjusting the reach on the levers have any effect? I don't expect either to help but it's worth a shot.
- Mulger bill
Postby Mulger bill » Thu May 17, 2012 12:50 am
Did you get a pad spacer block with the brakes? Best tool for piston retraction on the Juicys.
Postby slarv » Thu May 17, 2012 7:23 am
Mulger bill wrote:Jeez, I hope my Elixir CRs don't give me this sorta grief when it's time. The old Juicys were easy as.
Nope.. I cheaped out and got 3rd party pads from torpedo7, they didn't come with a spacer. Before you start to blame the pads, the front ones went in fine.. The rear one is being tricky.
- trailgumby
Postby trailgumby » Thu May 17, 2012 9:01 am
You can't push one in, and then the other - the free piston will come back out again as you've discovered. This behaviour is actually the system operating as intended, to apply even pressure to the pads on each side of the disc when the brake lever is squeezed.
Postby slarv » Thu May 17, 2012 9:39 am
Postby slarv » Thu May 17, 2012 10:45 pm
I know I didn't over do it because they both don't go all the way back in at the same time. The only difference is now I have enough space to fit a rotor between them.
I will invest in a bleed kit for the future but for now I think I am safe. To answer my own question. No it shouldn't be that hard to push back the pistons when they behave. Firm pressure but you don't need to force it.
Thanks for all the advice.
Postby Big_Chuck » Fri May 18, 2012 10:55 pm
This photo helped me better understand the Elixirs. http://www.pinkbike.com/photo/4397805/
More info here. http://bmorc.com/node/31889
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: Amazon [Bot], antigee
- All times are UTC+11:00
