Dura-Ace Di2 9070, Take that Campy EPS!
Re: Dura-Ace Di2 9070, Take that Campy EPS!
Postby Dr_Mutley » Fri Jun 01, 2012 4:53 pm
- Ross
Postby Ross » Fri Jun 01, 2012 8:48 pm
Obviously for commuters and tourers, haven't seen any in real life though. Most commuters/tourers seem more budget concious than your average roadie and don't seem to succumb to "upgraditis" as much so it would be interesting to see how many Di2 Alfine hubs are sold (either in Australia or worldwide).sblack wrote:Then why have they made Alfine Di2?Ross wrote:There wouldn't be much call for it as most of the Di2 sales would be for roadies/racer, most of whom are weight concious and therefore wouldn't contemplate a dynamo, they are more for commuters or tourers
I would of thought an OEM MTB version would of been developed before a hub version. Maybe the electronics are too fragile for MTBs.
Postby jasonc » Fri Jun 01, 2012 8:52 pm
don't worry - commuters get upgraditis too, but yes, we are more budget conscious. Currently more interested in the road bike/disc brake trend than electronic gear changes.Ross wrote:Obviously for commuters and tourers, haven't seen any in real life though. Most commuters/tourers seem more budget concious than your average roadie and don't seem to succumb to "upgraditis" as much so it would be interesting to see how many Di2 Alfine hubs are sold (either in Australia or worldwide).
- Mulger bill
Postby Mulger bill » Fri Jun 01, 2012 11:22 pm
Without doubt DR. No matter how good the gear might be, that crankset is an absolute dealbreaker for me, what's with the huge unsupported arc opposite the crank?Daccordi Rider wrote:Thisbiker jk wrote:Only if you're stuck in the 1930s Campy mindset of what a crankset should look like!!!Daccordi Rider wrote:Shimano continues to be the winner in the "we make the ugliest crank competition" Take that Shimano!!
Looks like a fully sik rim on a boganmobile
Or this
Understated and gracefull.
Honestly, no contest.
Shaun
- zozza
Postby zozza » Sat Jun 02, 2012 6:52 am
Whats with the Rear Derailleur? Looks like Shimano are using the same designers who Toyota use to shape the front bumper on a camry?
- toolonglegs
Postby toolonglegs » Sat Jun 02, 2012 7:43 am
Well you won't see it after the first lap after i get some mud on it, but it will feel good!.
Postby TDC » Sat Jun 02, 2012 1:33 pm
That was covered in the article. Has to do with where the loadings occur in the pedal stroke.Mulger bill wrote: what's with the huge unsupported arc opposite the crank?
Shaun
Big advantage of this crank is being able to use compact through to standard chain rings with the same spider.
- Parrott
Postby Parrott » Sat Jun 02, 2012 3:53 pm
Found it on the fairwheels link on the previous page, thanks. Glad it's not a styling thing and has an engineering basis behind it. Function over form, doesn't look so bad when you understand there are advantages in the design.TDC wrote:
Thanks to their continued refinement of super stiff hollow forged chainrings, Shimano could eliminate one of the spider arms and go to a 4 arm arrangement. The placement of the 4 arms aligns with the power delivery of the rider’s pedal stroke, with the gap placed at the ‘dead spot’. And the stiffer rings are able to handle the longer spans of unsupported ring. The 4 arm design does away with different spiders for compact and standard and replaces them with a proprietary bolt circle for all configurations. Chainring options will be 50/34, 52/36, 52/38, 53/39, 54/42, and 55/42.
Postby rkelsen » Sat Jun 02, 2012 4:18 pm
Is it me, or is Shimano the Microsoft of the cycling world? They want to continue dominating the market, so always have an "engineering" reason for their proprietary (and patented) designs.Parrott wrote:Glad it's not a styling thing and has an engineering basis behind it.
Postby TDC » Sat Jun 02, 2012 5:39 pm
Postby jasonc » Sat Jun 02, 2012 5:49 pm
i don't remember my bike getting the sasser virus eitherTDC wrote:I think it's you. So far I haven't had to reboot any of my Shimano equipped bikes mid ride
- open roader
Postby open roader » Sat Jun 02, 2012 6:46 pm
I'm still trying to suss if the new Di2 11sp. will be retro compatible with current DA 10 speed in so far as freehub / cassettes go.... a-la-Campag......? Surely........?
Postby TDC » Sat Jun 02, 2012 6:48 pm
- open roader
Postby open roader » Sat Jun 02, 2012 7:05 pm
- HLC
Postby HLC » Sat Jun 02, 2012 10:05 pm
- Mulger bill
Postby Mulger bill » Sat Jun 02, 2012 10:31 pm
I've got twenty bucks that says NO. Make stuff backward compatible and people will buy spares not upgrades.open roader wrote:I'm still trying to suss if the new Di2 11sp. will be retro compatible with current DA 10 speed in so far as freehub / cassettes go.... a-la-Campag......? Surely........?
- Ross
Postby Ross » Sun Jun 03, 2012 7:18 am
Yes you can put 10 speed cassette on new DA wheelsopen roader wrote:Functioning aside, my 20 cents says it's a significant cosmetic improvement on the initial Di2 but still looks screams 'RoboCop'.
VeloNews wrote:Remember that you must use one of Shimano’s new wheels (or a Mavic wheel) to run the new 11-speed groups. The new wheels are, however, backwards compatible. You can run a 10-speed cassette on the newest offerings with use of a 2.85mm spacer.
VeloNews wrote:The new cogs are the same width as the 10-speed versions; they’re simply closer together. Chains, therefore, also retain the same width rollers. Only the outer plates of the chain are thinner. The outer plates are also now solid, instead of relieved like on Shimano’s current chains. Also gone is the need to orient the chain directionally.
Postby chickenlips » Sun Jun 03, 2012 7:37 am
Ok, so I've got a Mavic Ksyrium Elites (2010). Does this mean I can run a new 11 speed cassette and
new chain with my Ultegra 6700 10 speed system?
Regards to all............................
Postby TDC » Sun Jun 03, 2012 8:30 am
Postby jasonc » Sun Jun 03, 2012 10:20 am
my reading is the new wheels are 10-speed (backwards compatible), but the old wheels are not 11-speed compatible.chickenlips wrote:Ok, so I've got a Mavic Ksyrium Elites (2010). Does this mean I can run a new 11 speed cassette and
hang on - don't mavics run an extra 1mm spacer????
- Parrott
Postby Parrott » Sun Jun 03, 2012 11:46 am
- Parrott
Postby Parrott » Sun Jun 03, 2012 2:10 pm
Mine also which is a major PITAjasonc wrote:my reading is the new wheels are 10-speed (backwards compatible), but the old wheels are not 11-speed compatible.chickenlips wrote:Ok, so I've got a Mavic Ksyrium Elites (2010). Does this mean I can run a new 11 speed cassette and
My existing wheels will be useless for a new 11 speed groupo if I buy one
Postby jasonc » Sun Jun 03, 2012 3:02 pm
looks like we'll see some cheap wheels on the market with people upgrading....Parrott wrote:Mine also which is a major PITAjasonc wrote:my reading is the new wheels are 10-speed (backwards compatible), but the old wheels are not 11-speed compatible.chickenlips wrote:Ok, so I've got a Mavic Ksyrium Elites (2010). Does this mean I can run a new 11 speed cassette and
Postby Deusirae » Sun Jun 03, 2012 4:11 pm
I see nothing which lessens the appeal of Campagnolo's EPS system.biker jk wrote:Take that Campy EPS!
The posts in this thread don't seem to understand that Campagnolo EPS buyers could not care less what Shimano has done or will do. They are buying Campagnolo EPS because it has the Campagnolo imprimatur on it. Nothing else will suffice and nothing else is necessary.
Postby TDC » Sun Jun 03, 2012 5:10 pm
are you for real?Deusirae wrote:Nothing else will suffice and nothing else is necessary.
