I have made the mistake in the past of connecting before resetting. First thing to do would be to check if there is a file for the activity at all. When you connect the garmin it should show up as a drive on your PC (can't confirm what happens on a mac so this may only be relevent on a PC). If you browse that drive under Garmin there is an Activities folder. Within that are all the activity files with the format of year-month-day-hour-minute-second.fit. If the file is there you may still be in luck as it may just be missing a bit of data that Garmin Connect needs but another program doesn't. It was a while ago that I did it and I can't remember exactly what worked but make sure as well as trying Garmin Connect you try the Garmin Training Centre software (the one that get's installed on your PC) and also give strava a go. One of those worked for me.silkishuge wrote:Thanks. I tried that and still could not retrieve the data. history still does not show the ride details. This is not the first time..... but I really wanted to know the data for this morning's ride.DuncanS wrote:Sounds like maybe you haven't reset after the ride. It won't appear in history until you reset, i.e. hold lap timer for 3s+
Jon
Garmin Edge 500
- sblack
Re: Garmin Edge 500
Postby sblack » Sat Jun 09, 2012 9:48 pm
- toolonglegs
Re: Garmin Edge 500
Postby toolonglegs » Sat Jun 09, 2012 9:53 pm
- sblack
Re: Garmin Edge 500
Postby sblack » Sat Jun 09, 2012 10:03 pm
- queequeg
Re: Garmin Edge 500
Postby queequeg » Tue Jun 12, 2012 11:08 pm
Tried to reload the firmware, GPS restarted and then hung during the update process. I then got "Software Missing", now the device won't power on at all. Basically, bricked
I have an updater that is supposed to resolve the "Software Missing" issue, but it assumes you can actually power the GPS up. I don't have that kind of luck, so looks like probably an RMA and sending it off. Just out of warranty too (isn't it always the case?). Can't say I wasn't warned, but I was too hopeful for the Courses feature to be fixed (it isn't!).
- Parrott
Re: Garmin Edge 500
Postby Parrott » Wed Jun 13, 2012 9:15 am
- TimW
Re: Garmin Edge 500
Postby TimW » Wed Jun 13, 2012 2:35 pm
Parrott, they are fine, and great little devices, they do the job i ask and more. I am not going anywhere near the firmware update though.TimParrott wrote:I was planning to get one of these, but reading this and a couple of other threads I am starting to think they are a POS Is it the software update that kills them or are they generally fragile?
- Parrott
Re: Garmin Edge 500
Postby Parrott » Wed Jun 13, 2012 2:58 pm
Thanks.TimW wrote:Parrott, they are fine, and great little devices, they do the job i ask and more. I am not going anywhere near the firmware update though.TimParrott wrote:I was planning to get one of these, but reading this and a couple of other threads I am starting to think they are a POS Is it the software update that kills them or are they generally fragile?
- MichaelB
Re: Garmin Edge 500
Postby MichaelB » Wed Jun 13, 2012 3:06 pm
+1 to being a great piece of kit.TimW wrote:Parrott, they are fine, and great little devices, they do the job i ask and more. I am not going anywhere near the firmware update though.TimParrott wrote:I was planning to get one of these, but reading this and a couple of other threads I am starting to think they are a POS Is it the software update that kills them or are they generally fragile?
+1 for avoiding the latest update atm.
- queequeg
Re: Garmin Edge 500
Postby queequeg » Wed Jun 13, 2012 3:07 pm
+1 Learnt my lesson - has just cost me $159 to replace my bricked unit. However, it is entirely possible that my firmware update and the issues I was having are pure coincidnece, since the firmware update was painless, error free and only took 3 minutes. The firmware does not explain why I couldn't even turn my Garmin on anymore though. Anyway, local Garmin support was excellent. Listened to my problem and said to me "if you think it is dead, we'll just swap it under our repair program". Basically, pay them $159 and send your old unit in. They send you a new one.Parrott wrote:Thanks.TimW wrote:Parrott, they are fine, and great little devices, they do the job i ask and more. I am not going anywhere near the firmware update though.TimParrott wrote:I was planning to get one of these, but reading this and a couple of other threads I am starting to think they are a POS Is it the software update that kills them or are they generally fragile?
Re: Garmin Edge 500
Postby Ozkaban » Wed Jun 13, 2012 3:15 pm
Contacted Garmin support about the screen being blank issue. Suggested a hard reset. Performed it - no difference (were we really ever expecting it to help )
I now noticed that the Heart Rate doesn't show up on the screen (either HEART RATE, or %HRR). It is recorded and showed up in the workout history though, so at least it's there... I did a ride on the weekend with my HRM and really cannot remember if the HR showed up or not, which is somewhat annoying now .
Will have to call Garmin again when I've more time at my disposal....
Re: Garmin Edge 500
Postby Ozkaban » Wed Jun 13, 2012 5:43 pm
Ok, a bit of my bad. Heart rate still shows, but %hrr, etc don't display. Maybe it's a setting issue since the hard reset (no max hr or something). Will keep playing...Ozkaban wrote:Just a quick update from my experiences with the update.
Sent from my GT-I9300 using Tapatalk 2
Re: Garmin Edge 500
Postby lgbran » Sat Jun 30, 2012 10:01 am
Re: Garmin Edge 500
Postby Ozkaban » Sat Jun 30, 2012 10:42 am
Happy days
Re: Garmin Edge 500
Postby dale79 » Sat Jun 30, 2012 10:53 am
but i did what it said and deleted all files from the device before updating..
how many of you are having problems didnt delete the files?
Re: Garmin Edge 500
Postby Ozkaban » Sat Jun 30, 2012 11:37 am
I didn't see that - I just plugged it in and the web manager said to upgrade.dale79 wrote:ive got the latest firmware on mine and no problems..
By all files, do you mean *everything* or just previous activities, etc?
- bollo
Re: Garmin Edge 500
Postby bollo » Sat Jun 30, 2012 1:02 pm
2012 Merida Scultura Evo 905
Re: Garmin Edge 500
Postby Ozkaban » Sat Jun 30, 2012 1:49 pm
Re: Garmin Edge 500
Postby jasonc » Sat Jun 30, 2012 1:58 pm
+1Ozkaban wrote:By all files, do you mean *everything* or just previous activities, etc?
please answer this so i know what to do
- wombatK
Re: Garmin Edge 500
Postby wombatK » Sat Jun 30, 2012 3:00 pm
So $159 plus postage per 13 months ? Do you reckon that's merchantable quality ?queequeg wrote: +1 Learnt my lesson - has just cost me $159 to replace my bricked unit. However, it is entirely possible that my firmware update and the issues I was having are pure coincidnece, since the firmware update was painless, error free and only took 3 minutes. The firmware does not explain why I couldn't even turn my Garmin on anymore though. Anyway, local Garmin support was excellent. Listened to my problem and said to me "if you think it is dead, we'll just swap it under our repair program". Basically, pay them $159 and send your old unit in. They send you a new one.
Anyone contemplating buying one needs to factor in this "running cost" - or the perhaps lesser cost of dragging them off to a consumer claims tribunal to get a replacement under statutory warranty laws.
Wish I'd seen your post earlier - did Garmin support ask you to try the POWER/MENU/RESET simultaneous button press before sending it in ? (It's in the manual )
I only know about this trick because my Edge 500 got itself in the same unresponsive state (without any upgrades). It
also regularly corrupts files on its USB memory - have to do a chkdsk about once a month now. It also had corrupt files on its USB memory after the POWER/MENU/RESET occasion.
Re: Garmin Edge 500
Postby dale79 » Sat Jun 30, 2012 3:11 pm
all activites and all courses..jasonc wrote:+1Ozkaban wrote:By all files, do you mean *everything* or just previous activities, etc?
- queequeg
Re: Garmin Edge 500
Postby queequeg » Sat Jun 30, 2012 4:08 pm
Unit was completely dead. None of the buttons would do anything in any combination, no matter how long you held them for. Plugging into the computer would not do anything either. No device detected on the USB port, Garmin unit not charging. Even the Garmin Updater to reflash the device without it detecting a USB Mass Storage Device would not find the Unit.wombatK wrote:So $159 plus postage per 13 months ? Do you reckon that's merchantable quality ?queequeg wrote: +1 Learnt my lesson - has just cost me $159 to replace my bricked unit. However, it is entirely possible that my firmware update and the issues I was having are pure coincidnece, since the firmware update was painless, error free and only took 3 minutes. The firmware does not explain why I couldn't even turn my Garmin on anymore though. Anyway, local Garmin support was excellent. Listened to my problem and said to me "if you think it is dead, we'll just swap it under our repair program". Basically, pay them $159 and send your old unit in. They send you a new one.
The $159 swap is a bit steep considering the exact same service in the USA is $89. Still, it's cheaper than a whole new head unit.
Re: Garmin Edge 500
Postby lgbran » Sat Jun 30, 2012 6:08 pm
Re: Garmin Edge 500
Postby Ozkaban » Sat Jun 30, 2012 6:14 pm
I Google "downgrade Garmin 500 firmware 2.80" and found a couple of references to it in the Garmin forums. Someone has uploaded the old firmware to a Google docs account. Worked a treat.lgbran wrote:How do you reset to earliest version?
Re: Garmin Edge 500
Postby hosko » Sat Jun 30, 2012 6:25 pm
Re: Garmin Edge 500
Postby jasonc » Sun Jul 01, 2012 7:41 am
mine is still under warranty so I don't have much to lose....hosko wrote:2.8 seems to do everything the unit needs... don't think I will be upgrading mine anytime soon
