2012 Black Cat Awards
Re: 2012 Black Cat Awards
Postby gretaboy » Tue Jun 05, 2012 9:20 am
this time I checked the inside of the tyre and sure enough I found a bit of metal, got the tweezers and pulled it out, nice straight bit of wire
so 2 more for me, makes it 5 I think now
Postby jcjordan » Tue Jun 05, 2012 9:54 am
Sent from my HTC Sensation Z710a using Tapatalk 2
Postby steve-waters » Fri Jun 08, 2012 3:39 pm
Then my spare tube was only just long enough in the valve to get the end of my CO2 canister onto - must remember to check the valve length when buying tubes
Edit - got some really nice Schwalbe tubes 80mm valves
MTB:TWE 29er, Fox Terralogic, XT, 3T and TWE wheels
- grantw
Postby grantw » Sat Jun 09, 2012 10:51 am
Picked this up in my rear wheel on this mornings ride by _granty, on Flickr
Postby Danton » Wed Jun 13, 2012 12:05 pm
Slow flat found when leaving in the morning.
This time last year in my “Annus horribilis” I was up to 10..
Postby Ozkaban » Thu Jun 14, 2012 4:18 pm
Brought the Orbea to work instead of the Giant as the weather was nice and I felt like a spin at lunch. A nice bit of glass sliced my back tyre and embedded it in the tube. Actually wonder if the tyre is stuffed - a cut about 1cm long going across the tread towards one side. I'll check it again tonight to see how much of the cut is all the way through. Just hope it holds together heading up North Rocks Rd this afternoon.
Postby __PG__ » Mon Jun 18, 2012 9:52 am
- Strawburger
Postby Strawburger » Mon Jun 18, 2012 10:15 am
Wagga Road race, 30km in - just out of Junee and the back wheel started wobbling. Got a flat last year in the same race but a bit further in. Not a happy camper. The spare tube didn't inflate either as scratch rolled past, fortunately someone stopped and handed over their spare tube and it was a sloooooowwwww ride to the finish line.
start total = 9 +1
4000 kms (1137kms)
0x hybrid
2x racer (0/2 conti gp4000s new for 2012)
2x fixie rear (conti gp4000s - this one retired after discovering chunks out of the back from emergency stopping)
4x fixie front (kenda koncept - retired after 9400kms!)
2x pannier bike (0/2 conti gp4000s new for 2012)
New total = 10 (AT) 400kms per flat
- Mugglechops
Postby Mugglechops » Mon Jun 18, 2012 11:13 am
That's 3 in 3400kms. All on the same bike too.
- Kev365428
- Moderator
Postby Kev365428 » Tue Jun 19, 2012 12:50 pm
Came out of work last Thursday to a half inflated front tyre.
Couldn't find the cause so I pumped it back up and rode home.
By the time I got there it was starting to go soft again, so changed the tube and checked the tyre but it remains a mistery. Patched the tube and all is good.
Then, I got the bike out last night for today's commute and the rear was soft.
Found a fairy pube in the tyre.
new total 11.
Kev.
Postby Ozkaban » Thu Jun 21, 2012 8:50 pm
Another on the way home today. Slow leak. Don't know where. Stupid thing can get repaired later. Just replaced the tube for now. Flat battery in the car when I finally made it back didn't improve the mood...
Sent from my GT-I9300 using Tapatalk 2
- sturmey archer
Postby sturmey archer » Thu Jun 21, 2012 9:28 pm
1st was a nail through the tyre (fun at 7:00AM at 1.8 Degrees.... ) 2nd was after I put a 28mm tube in the 37mm tyre to replace it. Lasted about 20k before the tube started leaking from some sort of internal wear in the tyre
- birdbrain
Postby birdbrain » Tue Jun 26, 2012 4:02 pm
- Parrott
Postby Parrott » Wed Jun 27, 2012 1:13 am
Bloody 3 inch nail embedded in the back tyre and all bent where it has been hitting the rear brake and seat tube on the way through.
Total =3, all in the back tyre
Postby __PG__ » Wed Jun 27, 2012 10:51 am
After being puncture free since the first week of January I've had two in the last two weeks.
- mikesbytes
Postby mikesbytes » Thu Jun 28, 2012 1:43 pm
- mikesbytes
Postby mikesbytes » Tue Jul 03, 2012 3:33 pm
16 + 1 = 17
- twizzle
Postby twizzle » Tue Jul 03, 2012 3:34 pm
But... sucked-in MB, that's a pretty big total for the first six months.
Postby argon_18 » Wed Jul 04, 2012 10:03 am
First one was taking a threshold ramp from the road to the bike path a little fast, missing and getting a front tyre pinch flat as i jumped from the grass and back to the path
Second, this morning, noticed a little slide of the back i was taking a corner, pulled over and back wheel is flat. Whipped off the wheel, took the tube out fitted the new tube and had it back on in no time. As i was stuffing the removed tube back in the bag, noticed the screw top on the presta valve had made it's way loose and was letting air out somehow. Probably from me trying to pump it this morning prior to heading off and knocking it loose. So don't think it was a puncture. Could have just screwed it back in, given it a pump and been fine. Will know to check for next time.
Thing that pisses me off the most is, both flats and a recent broken spoke i was wearing a white long sleeve jersey and have gotten grease all over it.
- mikesbytes
Postby mikesbytes » Thu Jul 05, 2012 7:00 pm
Postby jcjordan » Thu Jul 05, 2012 7:14 pm
cut in tire while heading to breakfast with twizzle
Sent from my Transformer Prime TF201 using Tapatalk 2
- twizzle
Postby twizzle » Tue Jul 10, 2012 1:05 pm
You know, I LOVE my Pro3's as race tyres... but nothing - NOTHING - would get me to commute on them.mikesbytes wrote:I see an advert on a local mail order chain saying that Michelin Pro3race and Pro4race are virtually puncture proof. I might buy a set of each so each time I get a flat I can have a laugh
- ZepinAtor
Postby ZepinAtor » Tue Jul 10, 2012 11:28 pm
Noticed the front rim was sitting on the floor yesterday after Sundays ride.
Inspected the tyre & picked out about 10 little chunks of glass. One of them had just poked through enough & caused the tiniest little hole.
Had to use the submersed in the laundry tub method to find it.
- Strawburger
Postby Strawburger » Thu Jul 12, 2012 11:48 am
On a flyer coming home late last night, was on target for a PB when disaster struck. The Canterbury Council roads strikes again! Either a pothole, glass or a combo of both got my front tyre. Not quite sure exactly what the cause was at it was a pretty dark street. I was so close to home I decided to walk the rest and the PB evaporated (or should i say hissed out).
start total = 10 +1
4592 kms (592kms)
0x hybrid
1x fixie (1/0 conti gp4000s both new for 2012)
New total = 11 (AT) 418kms per flat
- Strawburger
Postby Strawburger » Thu Jul 12, 2012 11:52 pm
No, this is not a double post!!! On another flyer coming home late tonight. The Canterbury Council roads strikes again and it was pretty much in the same stretch of road as last night! Scraped a pothole, glass got my rear tyre. At least this time i posted the PB. On the geared bike today as i was too lazy to change the fixie this morning (feels like cheating riding with gears!)
start total = 11 +1
4626 kms (34kms)
0x hybrid
2x pannier bike (0/3 conti gp4000s new for 2012)
New total = 12 (AT) 385kms per flat
