Shifting with downtube shifters
- bychosis
Postby bychosis » Mon Jul 16, 2012 10:10 am
This being the font of knowledge for retro biking I though I might ask, other than practice, are there any tips for shifting gears with non indexed downtube shifters? Or, like this morning, do you just avoid changing gears unless absolutely necessary then take ages to make the gears run nicely. Trimming the gears seems like not a lot of fun.
Edit: should add I am reasonably comfortable with reaching down to the shifter, just not good at the shifting bit yet.
- familyguy
Re: Shifting with downtube shifters
Postby familyguy » Mon Jul 16, 2012 11:41 am
Just don't over-reach. Spokey fingers aren't fun on cold mornings.
- frailer5
Postby frailer5 » Mon Jul 16, 2012 2:54 pm
What's the setup on it? Make/model of RD? Some friction (pre-indexed) shifted better than others. Forgive me, I've just read The Good Book
I was spoiled with friction shifters. Had a SunTour VxGT, then went to a Huret Duopar, which shifted almost too well for a pre-index.
But it's amazing how quickly you will adjust to just correcting any over-shift, until you hear no chain-side-rub noise. It will become, well, like riding a bicycle.... You may even get to enjoy it.
It's amazing that, according to Berto, no-one had narrowed down the critical factor; i.e. chain-gap... the distance between the top pulley wheel and the next cog in line, particularly for downshifts (to larger ones). It had been a head-banger until that became clear. Tooth shape, variations in same, 'ramps', all that came into it, but chain gap was the 'thing'.
Postby cray- » Mon Jul 16, 2012 2:56 pm
- frailer5
Postby frailer5 » Mon Jul 16, 2012 3:05 pm
Which makes the point of how 2nd nature it is... had forgotten I did that.cray- wrote:+1 Practice. My old Nishiki has friction shifters (no indexing) and after a bit of use, gear selection becomes second nature and I rarely have to trim. You just get a feel for it, slot the gear in and then move the lever back just a smidge. I do find myself shifting less often, but I guess it depends how strong a rider you are and the type of terrain. You'll also learn to look further up the road and plan ahead as you don't want to be changing mid climb. Good luck, have fun!
edit:.... bychosis, to make you feel a bit better, this from Mr. Berto, as tripped over in this evening's chapter on How RDs Work
Feel better?...Many of today's cyclists, with less than 15 years experience, are spoiled rotten. They have never learned how to operate a friction-shifting derailleur.
When you shifted back in the good old days, you eased back on the pedaling force and then pushed the lever an appropriate distance until something happened in the back. During many shifts, the chain would ride on the destination sprocket for a bit, and then settle down into engagement. If there was a noise in the back, you moved the lever to quiet the complaining. If you were having a bad day, your companion would say "Grind me a pound while you're at it"
- bychosis
Postby bychosis » Mon Jul 16, 2012 9:23 pm
Thanks, the tip in red seemed to help on the way home this arvo.frailer5 wrote:cray- wrote:+1 Practice.... You just get a feel for it, slot the gear in and then move the lever back just a smidge....
Postby Stuey » Mon Jul 16, 2012 9:58 pm
And get the centre screw of the lever not too tight and not too loose, and well lubed.
Postby cray- » Mon Jul 16, 2012 11:32 pm
Basic logic here is that the deraileur is physically pushing the chain up/down enough to snag the next cog, so once it slots in you need back it off so that it's no longer rubbing the cage/jockey wheels/etc. and running smoothly down the middle.bychosis wrote:Thanks, the tip in red seemed to help on the way home this arvo.frailer5 wrote:cray- wrote:+1 Practice.... You just get a feel for it, slot the gear in and then move the lever back just a smidge....
That's my understanding of it anyway. I'm sure there is more than one book out there that describes the workings of a deraileur in absolutely rediculous detail, but none of them grace my coffee table.
Just keep riding, You'll get the hang of it in no time.
Postby cray- » Mon Jul 16, 2012 11:38 pm
Good tip, some adjust with a little fold out loop on the thread, unfortunately mine require an allenkey which is often the only thing I carry with me. Every now & again it will loosen itself to the point that the lever is no longer able to keep the cable tensioned. This means that the deraileur stays down at the bottom end of it's travel and you're stuck on the small cog. Not so good if you've got any kind of inclines on the way home.Stuey wrote:And get the centre screw of the lever not too tight and not too loose, and well lubed.
- bigfriendlyvegan
Postby bigfriendlyvegan » Tue Jul 17, 2012 1:20 am
While I really do like STI shifters, my commuter will probably always have DT friction shifters just for the convenience of it.
- WyvernRH
Postby WyvernRH » Tue Jul 17, 2012 8:23 am
However, as is mentioned above, you adapt quickly and after 5 mins all is smooth. Changing cleanly on gears from the 40's and 50's can be a bit of an art form tho
When you get really good you can try the 'Alpine Change' where you move both left and right levers simultaneously with the right hand to change down (in) at the front and up (out) at the back (or vice-verse).
- bychosis
Postby bychosis » Tue Jul 17, 2012 9:16 am
- koen
Postby koen » Tue Jul 17, 2012 9:32 am
Just a curious side note. One day I was complaining of this loosening on my old campag shifters and friend from Europe who was a pro many years ago said that it always happens and they just pulled the screw out and rubbed the thread around on some concrette for a while to "make it grip". This story kind of affirms the idea that as much ,as I love campag, nobody really used their imagination (in order to realise it could be better) and got to making a better shifting system for a long time. I suppose good gears really doesn't make cycling that much more fun but they do make it a bit easier for beginners.cray- wrote:Good tip, some adjust with a little fold out loop on the thread, unfortunately mine require an allenkey which is often the only thing I carry with me. Every now & again it will loosen itself to the point that the lever is no longer able to keep the cable tensioned.....Stuey wrote:And get the centre screw of the lever not too tight and not too loose, and well lubed.
- ldrcycles
Postby ldrcycles » Tue Jul 17, 2012 10:35 am
A big +1 for this, SunTour power shifters with a Cyclone derailleur is the best friction shifting i've used yet. And SunTour freewheels are MUCH smoother shifting than Shimano (Maillard is good too but not really common).WyvernRH wrote: I find that the Suntour retrofriction levers plus any Suntour gear is basically instinctive
I had a flatbar for a while with a Shimano Tourney rear derailleur, changing the Shimano levers for SunTour power shifters made an extraordinary difference.
Practice makes perfect, i would only race with STI but for just riding around i really like downtube shifters.
- marc2131
Postby marc2131 » Tue Jul 17, 2012 11:44 am
However if you do a regular commute, you'd pretty much shift to what you need before you need to. However the convenience is a luxury.
- WyvernRH
Postby WyvernRH » Tue Jul 17, 2012 11:59 am
Yes, I was told of this old trick way back and my response was 'Haven't you chaps heard of soft Loctite?'koen wrote:Just a curious side note. One day I was complaining of this loosening on my old campag shifters and friend from Europe who was a pro many years ago said that it always happens and they just pulled the screw out and rubbed the thread around on some concrette for a while to "make it grip". This story kind of affirms the idea that as much ,as I love campag, nobody really used their imagination (in order to realise it could be better) and got to making a better shifting system for a long time. I suppose good gears really doesn't make cycling that much more fun but they do make it a bit easier for beginners.
The other trick with Campag levers was to roughen up the shiny faces of the lever drum to add friction to the unit. Where I worked we used a fine grade emery paper that was on plastic film instead of paper so we could use it under water (don't ask...) If you cut a disk out of this stuff and placed it inside between the lever and the lever mount plate it added just the right amount of friction - until it wore out after a few months and had to be replaced but you got a decades worth out of one sheet
- HappyHumber
Postby HappyHumber » Tue Jul 17, 2012 12:21 pm
The throw of the older 6speed derailleur is a bit less than newer units; up past the 7 or 8 speed mark. They adjusted the wheel locknut spacings to cram more sprockets in there - but the shifting range got a bit wider to. I found this out with my 6/7 speed era Durace 7200 RD. when I went to put on in a 9speed wheel and cluster - it gave me the same problem you described. Downgraded to a later 105 RD, meant for the 9speed - and it was perfect. But I'm still using DT friction shifting on the 9speed cassette. I'm not racing. I don't care.bychosis wrote:Great info, working better already this morning. I love that you can switch up cassettes easily, although it appears my nice looking rear mech won't work with the full range of gears. I have a 7 spd cassette plus spacer on the 8/9 hub with the existing 6spd derailleur and it won't shift into the biggest cog. Limit screw backed off and the design of the derailleur will not push far enough in. Oh well, looks like concrete for breakfast.
- frailer5
Postby frailer5 » Tue Jul 17, 2012 2:25 pm
So True. Huret's DuoPar was the sole exception. Shimano, Campagnolo and the others must have been sweating on the slant parallelogram patent expiry. Then it was up to their marketing departments to try and conceal the copying thereof.WyvernRH wrote: I find that the Suntour retrofriction levers plus any Suntour gear is basically instinctive
Good info, bigfriendlyvegan.
Postby Stuey » Tue Jul 17, 2012 3:16 pm
Good point there. I also got used to just easing off on the chain tension while pedalling and flicking the lever for the RD and the chain would just go 'snick' between gears.bigfriendlyvegan wrote:Like the other DT friction veterans, I don't even think about it now and I can hit the right cog every time. You will also get really good at positioning your knees, pausing, shifting and pedalling again without thinking about it...
I still remember reading the Suntour 'Slant Parallellogram' owners booklet that came with the bike (I was about 13) but didn't realise it was a special system. It did work really well though. This was where I learned to adjust derailleurs, from that book and trial and error.
Postby teamex » Thu Aug 16, 2012 4:28 pm
- WyvernRH
Postby WyvernRH » Thu Aug 16, 2012 4:44 pm
Well, Indexing actually started off on downtube levers, back in the bad/good old days before brifters. As far as I know for road bikes SunTour indexing only exists in downtube levers (oh and those weird wishbone levers that fit by the brake levers). My Paino has a 7 speed Shimano 600 gear train with downtube levers. Big advantage is you can switch the indexing off if you have mechanical problems and it is only on the rear derailleur. IMHO indexing the front changer on a road bike is close on to the biggest waste of technology ever.teamex wrote:out of curiosity... is there any argument for adding indexing to the dt shifters?
Postby Big_Red » Thu Aug 16, 2012 4:52 pm
- bigfriendlyvegan
Postby bigfriendlyvegan » Thu Aug 16, 2012 6:44 pm
Agree. Friction shifters are better, in my opinion.Big_Red wrote:I'd have thought that indexing on DT shifters would be limiting as you are constrained to only using a freewheel or cassette with the sprockets a particular distance from each other. I'm considering getting a new wheelset for my old Paconi, which will result in a replacement of the suntour 6sp freewheel with a shimano 9 speed (casette) and relish the fact that it'll be just a swap of the wheels to achieve as the trimming between the gears is all manual.
- ldrcycles
Postby ldrcycles » Thu Aug 16, 2012 8:36 pm
[/quote]
Agreed. Just completely unnecessary. As for indexing on the rear though, i REALLY like indexed DT shifters, they combine the simplicity of DT shifters with the laziness of indexing . And having ridden both Shimano and SunTour, IMO SunTour indexing was MUCH nicer, had a much more positive feel to it. The Exage 400EX and 300EX that i'm very familiar with does do a good job though.
Funnily enough i did a criterium a week or so after i posted that, on my Mercier with it's friction DT shifters. Was only out of necessity but the old girl did a damn good job!ldrcycles wrote: i would only race with STI
- bigfriendlyvegan
Postby bigfriendlyvegan » Thu Aug 16, 2012 8:53 pm
Yeah, I don't know how anyone even raced before the 90s when STI was invented.ldrcycles wrote:Agreed. Just completely unnecessary. As for indexing on the rear though, i REALLY like indexed DT shifters, they combine the simplicity of DT shifters with the laziness of indexing . And having ridden both Shimano and SunTour, IMO SunTour indexing was MUCH nicer, had a much more positive feel to it. The Exage 400EX and 300EX that i'm very familiar with does do a good job though.WyvernRH wrote: IMHO indexing the front changer on a road bike is close on to the biggest waste of technology ever.
