Adding a front disc to a road bike !! And Now Hydro!
Re: Adding a front disc to a road bike !! And Now Hydro!
Postby Crittski » Fri Jul 20, 2012 6:49 pm
Volagi Liscio Ultegra
- MichaelB
Postby MichaelB » Sat Jul 21, 2012 11:52 am
Postby Crittski » Sat Jul 21, 2012 12:41 pm
- MichaelB
Postby MichaelB » Sat Jul 21, 2012 4:32 pm
Haven't and wont farcebook, or twatter, or rumbler or whatever other social media there is ... Just don't believe in it !!!Crittski wrote:https://www.facebook.com/volagi
does that take you there? just sign up you stick in the mud!
Just looked on their web page, and it's a Liscio with the TRP Parabox converter.
If I could buy a frameset here, that's what I'd already have !!!!
Yep, and allinternal cabling for Liscio v2
Postby Crittski » Wed Jul 25, 2012 7:04 am
As I predicted, V2 will be 135mm rear spacing, di2/eps/hydraulic hose internal routing.
- MichaelB
Postby MichaelB » Wed Jul 25, 2012 2:28 pm
Definitley is now firmly at the top of the list !!!! I'll be saving like mad, and eagerly awaiting the local launch. Meant to be around September !!!
Oh, and Salsa have released a Ti double disc road bike using the Enve carbon fork and BB7 calipers. Apart from the fork, looks like a pretty plain bike, but still another option
Postby jasonc » Wed Jul 25, 2012 3:14 pm
it's definitely a tourer rather than a road bike with regards to specs.MichaelB wrote:Oh, and Salsa have released a Ti double disc road bike using the Enve carbon fork and BB7 calipers. Apart from the fork, looks like a pretty plain bike, but still another option
- baabaa
Postby baabaa » Wed Jul 25, 2012 6:06 pm
Which what who specs? If you mean the specs for the Colossal (the new road bike) you must have a crystal ball.
Postby jasonc » Wed Jul 25, 2012 7:46 pm
http://salsacycles.com/bikes/vaya_ti/baabaa wrote:it's definitely a tourer rather than a road bike with regards to specs.
Drivetrain
Crankset Sugino XD600 Touring, 50 = 165mm, 52, 54, 55, 56 = 170mm, 57, 58, 60 = 175mm
Chainring Sugino 26-36-46T
Bottom Bracket Shimano Square Taper
Chain Shimano HG-53
Cassette Shimano XT 9-Speed, 11-34T
Front Derailleur Shimano Tiagra Triple
Rear Derailleur Shimano XT 9-Speed
- MichaelB
Postby MichaelB » Wed Jul 25, 2012 7:58 pm
Yep, I was talking about the Colassal, not the Vayabaabaa wrote:it's definitely a tourer rather than a road bike with regards to specs.
http://reviews.mtbr.com/salsa-cycles-el ... beargrease
The road specific carbon fork was developed by Enve for Salsa for 140mm rotors (with cable actuated disc brakes). The Colossal sports Hed Belgium rims (blacked out w/new graphics). The rotors are SRAM HSX Centerlock rotors. The frame is double-butted seamless 3/2.5 ti. The tubes are shaped for the chainstays and seatstays to provide a smooth ride.
Postby jasonc » Wed Jul 25, 2012 8:14 pm
that seriously looks clean.MichaelB wrote:Yep, I was talking about the Colassal, not the Vayabaabaa wrote:it's definitely a tourer rather than a road bike with regards to specs.
Postby Uncle Just » Wed Jul 25, 2012 8:37 pm
- baabaa
Postby baabaa » Wed Jul 25, 2012 8:58 pm
I have been looking at moving down from 160/160 to 160f and 140r or 140/140 for quite a while. Problem is I have three wheelsets running on two bikes and todate it has just been a bit of a bother to swap out both sets of rotors. Will now be pushing this 140 test along.
Postby Nobody » Wed Jul 25, 2012 9:33 pm
I'm more concerned with 140s not only for heat dissipation under extreme conditions (they are brakes after all) but also for the leverage problem of the brake pad as a pivot point stressing the axle/QR more. This force causes QR skewers to come loose. Rim brakes aren't a problem as the pivot point is so far away. I have not had a recent problem with my 185 disc on the road, but I have had my skewer work loose on my 160 MTB. With a 140, I'd expect the skewer to work loose fairly regularly.Uncle Just wrote:Nice clean lines. My concern is that it specs a 140 disc rotor on the front. If it is intended as a road bike with all the downhill speed that can entail, it may be undersized. I run 160f/140r on my CX and the 160 is certainly needed for fast road descents. Any thoughts?
- baabaa
Postby baabaa » Thu Jul 26, 2012 8:01 am
- queequeg
Postby queequeg » Thu Jul 26, 2012 8:25 am
I am running 160mm rotors on my CX commuter. I do some pretty quick descents and not once has my QR skewer even hinted at moving during my 7,000km of cycling on this bike. If it did, the first thing I would check for is a dodgy skewer and/or not closed tight enough.Nobody wrote:I'm more concerned with 140s not only for heat dissipation under extreme conditions (they are brakes after all) but also for the leverage problem of the brake pad as a pivot point stressing the axle/QR more. This force causes QR skewers to come loose. Rim brakes aren't a problem as the pivot point is so far away. I have not had a recent problem with my 185 disc on the road, but I have had my skewer work loose on my 160 MTB. With a 140, I'd expect the skewer to work loose fairly regularly.Uncle Just wrote:Nice clean lines. My concern is that it specs a 140 disc rotor on the front. If it is intended as a road bike with all the downhill speed that can entail, it may be undersized. I run 160f/140r on my CX and the 160 is certainly needed for fast road descents. Any thoughts?
Postby Nobody » Thu Jul 26, 2012 8:50 am
Good for you. But if you do a search online, I'm sure you could find people who have had problems. It has been linked to somewhere in these 39 pages before.queequeg wrote:I am running 160mm rotors on my CX commuter. I do some pretty quick descents and not once has my QR skewer even hinted at moving during my 7,000km of cycling on this bike. If it did, the first thing I would check for is a dodgy skewer and/or not closed tight enough.
Postby Crittski » Thu Jul 26, 2012 9:15 am
I agree, I have never had a qr loosen on any bike I have owned. Braking forces don't loosen qr axles, a properly engaged qr can only loosen by flipping open, or by turning, neither of which braking forces enable.queequeg wrote:I am running 160mm rotors on my CX commuter. I do some pretty quick descents and not once has my QR skewer even hinted at moving during my 7,000km of cycling on this bike. If it did, the first thing I would check for is a dodgy skewer and/or not closed tight enough.Nobody wrote:I'm more concerned with 140s not only for heat dissipation under extreme conditions (they are brakes after all) but also for the leverage problem of the brake pad as a pivot point stressing the axle/QR more. This force causes QR skewers to come loose. Rim brakes aren't a problem as the pivot point is so far away. I have not had a recent problem with my 185 disc on the road, but I have had my skewer work loose on my 160 MTB. With a 140, I'd expect the skewer to work loose fairly regularly.Uncle Just wrote:Nice clean lines. My concern is that it specs a 140 disc rotor on the front. If it is intended as a road bike with all the downhill speed that can entail, it may be undersized. I run 160f/140r on my CX and the 160 is certainly needed for fast road descents. Any thoughts?
Postby Nobody » Thu Jul 26, 2012 10:08 am
http://www.ne.jp/asahi/julesandjames/ho ... k_release/
- MichaelB
Postby MichaelB » Thu Jul 26, 2012 10:25 am
I run 180/160 on my Kona (and have run 160/160) with no real issues on another bike.baabaa wrote:I like the idea of 140/ 140. Salsa have a solid background in dropbar discs ( I bought my disc la cruz in 2008)so the 140 would have been put across the slide rule many times.
For me, I wouldn't think that 140 is a good option. I'd rather have a bigger disc and have more 'reserve security' in terms of heat dissipation (as Nobody hinted at).
I think Salsa have used the 140 front is primarily that is what the ENVE fork has been designed/made for.
Volagi are sticking with 160mm, whilst Colnago seem to have opted for the 140mm front.
I'd rather have a bigger disc and be happier in the knowledge on a big hard descent rather than having to wonder. The 20g difference is not worth the worry.
- queequeg
Postby queequeg » Thu Jul 26, 2012 2:44 pm
Nobody wrote:Good for you. But if you do a search online, I'm sure you could find people who have had problems. It has been linked to somewhere in these 39 pages before.queequeg wrote:I am running 160mm rotors on my CX commuter. I do some pretty quick descents and not once has my QR skewer even hinted at moving during my 7,000km of cycling on this bike. If it did, the first thing I would check for is a dodgy skewer and/or not closed tight enough.
I am not saying it can't happen, but rather that it won't happen on a skewer that is correctly fitted. All the examples in the link of cases where the wheel has come out has been due to a loose QR (which also included bolt-ins or bolt-through....anything with a slotted dropout).
If the QR is coming loose it can be due to many factors, but high on my list would be a) not closed with sufficient force, b) poor quality QR (I have had a few of these, such as skewers where the cam is screwed onto the skewer and allows the threads to be stripped).
Postby Uncle Just » Thu Jul 26, 2012 6:05 pm
- baabaa
Postby baabaa » Thu Jul 26, 2012 7:39 pm
http://road.cc/content/news/46984-eurob ... -converter
Re rotors I just use bog standard avid cleansweeps and roundagons no problems yet and while I don’t log the ks most weeks I commute 300ks between the two bikes with discs. Find the cheapest way to replace pads and rotors is just buy new full bb7 kits.
Postby Crittski » Thu Jul 26, 2012 8:16 pm
- bosvit
Postby bosvit » Thu Jul 26, 2012 8:29 pm
As far as I am aware both 140 and 160 rotors clamp at the same place on the same hubs?
If this is the case how can a 140 place more stress on the hub than a 160? According to the physics I am aware of the bigger the disc (attached to the same hubs with the same bolt positions) the higher the torsional stress on the hubs for the same amount of braking pressure on the hand brake.
Also how does rotational force (eg braking on a rotational wheel) effect lateral force eg opening a quick release? Or is the problem that the wind up nut end (for want of a better explanation) of the quick release starts to unwind?
Not trying to be a smart arse just it not compute to my physics oriented brain
Users browsing this forum: bychosis
