Headlights
Re: Headlights
Postby eeksll » Fri Jul 20, 2012 12:50 pm
- MattyK
Re: Headlights
Postby MattyK » Fri Jul 20, 2012 4:43 pm
queequeg wrote: Two sets mounted:
People give me plenty of space I get the feeling that spacing the lights out wide adds to your perceived size/weight, as opposed to just one point source or tight cluster of lights.
- Aushiker
Re: Headlights
Postby jasonc » Fri Jul 27, 2012 12:20 pm
- trailgumby
Re: Headlights
Postby trailgumby » Fri Jul 27, 2012 1:36 pm
That's not just going to zap possums, it's going to fry them
- find_bruce
- Moderator
Re: Headlights
Postby find_bruce » Fri Jul 27, 2012 2:30 pm
It would need to kill them quick as the battery is not going to last long.trailgumby wrote:That's not just going to zap possums, it's going to fry them
The site asserts they have a test certificate the University of Darmstadt showing a measured 3200 lumens. Given that it has 6 x XML emitters, and from memory 1 XML is around 550 lumens in the real world, the numbers would seem to be about right.
Battery side scares the beejeebers out of me. 8 x 18650 (ie double the magicshine size) wired up at 4S2P with a capacity of 5.8 Ah and a run time on high at 2 hours 11 minutes. They would want to be some high quality cells.
Back of the laptop calcs indicate that each XML is drawing something like 2.6 amps. That it going to be putting out some heat - better ride fast. Be nice to hear when someone has stumped up the significant amount of cash & actually received a light.
The only thing I would quibble with is made in germany claim - the Cree XMLs at the heart of it are made in china & I suspect other parts are as well.
- find_bruce
- Moderator
Re: Headlights
Postby find_bruce » Fri Jul 27, 2012 2:35 pm
Lighting up a barn said to be 170 m away
- MattyK
Re: Headlights
Postby MattyK » Fri Jul 27, 2012 2:53 pm
Yes*. Battery life is around 1.5 hours, good enough for 3 nights' commuting for me. Tends to make the indicator lamp go from green to red pretty quickly though.jasonc wrote: you running both of those off the y-cable?
* I'm now back running my 4W Niteflux Commuter light, due to the cables breaking on the batteries. The batteries themselves are fine, but somewhere near the connector socket they've cracked - you wiggle the wire and the light goes off or on.
I will rebuild the batteries at some point, shorten the cable and use a bulkhead socket inside a different housing to prevent straining the cables. I keep these batteries in my pannier so no problems about waterproofing.
** Because I'm sick of the cables breaking on these lights (never had problems with the lamps or batteries), I now have a Philips Saferide light on order. Will review when it arrives - hopefully next week.
Re: Headlights
Postby vance.heredia » Fri Jul 27, 2012 3:08 pm
It is the newer version of the Xeccon 14 (another variant of the Magicshine) review posted here http://www.bicycles.net.au/2012/07/xecc ... cle-light/
The battery is in excellent housing and the light is great.
A couple of caveats -
1) The strap mount looks and feels cheap and I'm sure I will need to revert to the O-Ring mount soon.
2) Also the in flashing mode the light is so bright and the flash is so fast that it is almost disorientating even when pointed down at the road
I usually leave fairly early in the morning as I've only just stated riding and it take around 2 hours along beach rd (melb) to get to work (docklands) or get home (chelsea). yes yes I know I'm slow, but like I've said I only just started. So being new on the roads and having to cycle in the dark, visibility was important. I've found that I can use it on medium mode and see well enough most of the time.
I'll post some pics up
- find_bruce
- Moderator
Re: Headlights
Postby find_bruce » Fri Jul 27, 2012 5:15 pm
Are there a pair of XMLs on their way as well, he asks hopefully.MattyK wrote:** Because I'm sick of the cables breaking on these lights (never had problems with the lamps or batteries), I now have a Philips Saferide light on order. Will review when it arrives - hopefully next week.
- MattyK
Re: Headlights
Postby MattyK » Fri Jul 27, 2012 10:11 pm
Haha, nah, not up for that just yet. I do have a XC-997B from dx.com that is a potential lens donor for an XML conversion though. Nice beam pattern, but way too underpowered.find_bruce wrote:Are there a pair of XMLs on their way as well, he asks hopefully.MattyK wrote:** Because I'm sick of the cables breaking on these lights (never had problems with the lamps or batteries), I now have a Philips Saferide light on order. Will review when it arrives - hopefully next week.
- il padrone
Re: Headlights
Postby il padrone » Fri Jul 27, 2012 10:14 pm
"Beam me up, Scottie"find_bruce wrote:Lighting up a barn said to be 170 m away
- find_bruce
- Moderator
Re: Headlights
Postby find_bruce » Fri Jul 27, 2012 10:27 pm
i hear you- not sure I would lay out the cash on a Phillips just to immediately hack itMattyK wrote:Haha, nah, not up for that just yet. I do have a XC-997B from dx.com that is a potential lens donor for an XML conversion though. Nice beam pattern, but way too underpowered.find_bruce wrote:Are there a pair of XMLs on their way as well, he asks hopefully.
I thought you had decided the reflector hole on the dx light was too small for conversion, or have I misunderstood
- MattyK
Re: Headlights
Postby MattyK » Fri Jul 27, 2012 11:01 pm
Philips was only about $100 from bike24. Still, not going to hack it yet. I was very tempted to buy two to get a wider beam, I suspect that will be a feature it lacks.find_bruce wrote:i hear you- not sure I would lay out the cash on a Phillips just to immediately hack itMattyK wrote:Haha, nah, not up for that just yet. I do have a XC-997B from dx.com that is a potential lens donor for an XML conversion though. Nice beam pattern, but way too underpowered.find_bruce wrote:Are there a pair of XMLs on their way as well, he asks hopefully.
Th whole on the xc997 is 5mm, which is the same size as an XML so it might fit but if not the hole might be enlarged, though that might prove tricky. Cheap enough to play with though
- Aushiker
Re: Headlights
Postby Aushiker » Thu Aug 09, 2012 2:05 pm
The flagship light will offer up to 800 lumens of output and four separate lighting modes that will provide ample lighting for off-road use. It will burn for up to three hours on high and use a rechargeable battery pack that takes about two hours to charge. Fenix did not have run times for the lower settings, but like other LED lights, those will be significantly longer. The second light will offer up to 350 lumens of output.
Aushiker.com
Re: Headlights
Postby Marty Moose » Thu Aug 09, 2012 2:21 pm
- trailgumby
Re: Headlights
Postby trailgumby » Thu Aug 09, 2012 2:42 pm
News of the World wrote:Barn Stolen by Aliens from Camden Countryside
It was reported this morning that a barn was stolen from a property near the Camden River near Sydney, Australia by aliens overnight, according to local sources.
As the picture below shows, it appears the aliens have some form of advanced anti-gravity ray that is capable of lifting quite heavy structures, complete with foundations, out of the ground.
"All that was left was a large hole!" said Kylie, who declined to give her last name.
Both NASA and the Defence Signals Directorate declined to comment. ASIO stated that it does not comment on operational matters.
Peter Smith, from Ray White Real Estate, Camden, said that some of these older barns were quite sought-after as home conversion and renovation projects by tree-changers.
- find_bruce
- Moderator
Re: Headlights
Postby find_bruce » Thu Aug 09, 2012 5:01 pm
loved it, although I am still slightly confused as to how the barn got from Troutie's place in deepest darkset Yorkshire to Camden Australia.trailgumby wrote:News of the World wrote:Barn Stolen by Aliens from Camden Countryside
Re: Headlights
Postby ggevo » Tue Aug 21, 2012 6:21 am
Australian Air Express sent me an email yesterday (Monday), confirming parcel dispatched from Brisbane, arrived at Melbourne depot late yesterday. Suggest it will land on my doorstep in next 48hrs, can't complain about the service and delivery time!!!!
Re: Headlights
Postby ggevo » Tue Aug 21, 2012 5:36 pm
Re: Headlights
Postby NhiTrac » Tue Aug 21, 2012 11:28 pm
Soooooo going to get in trouble with the Director of Finance
BMC Teammachine SLR01
Re: Headlights
Postby zero » Wed Aug 22, 2012 5:30 pm
awesome!trailgumby wrote:News of the World wrote:Barn Stolen by Aliens from Camden Countryside
- MattyK
Re: Headlights
Postby MattyK » Thu Aug 23, 2012 9:57 am
Re: Headlights
Postby NhiTrac » Thu Aug 23, 2012 12:10 pm
I've been a bit sceptical with AyUps but now can see why they cost a bit more, the quality of these units are amazing. Real test is when I ride these in pitch black like most of my winter commute has been. Cant wait!
- Aushiker
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
