Ride Quality - 20C through 22C tyres
Postby Dan » Wed Sep 26, 2012 8:06 pm
So - I'm currently on 25C rubinos/contis, but am in the process of buying a frame that really has a really tight clearance on 23Cs - I suspect I know the answer already, but is there a discernible difference in ride quality (hardness) between a 25C and these options? Commuting 25km daily, primarily bike paths.
jacks1071
Re: Ride Quality - 20C through 22C tyres
Postby jacks1071 » Wed Sep 26, 2012 10:31 pm
On a stiff frame, the difference is huge.
Our Website is: http://www.kotavelo.com.au" onclick="window.open(this.href);return false; Find us on Facebook by searching for "Kotavelo"
Postby Dan » Wed Sep 26, 2012 10:42 pm
Thanks - I've been reliably informed there's at least 3mm of clearance on a 23C in front - I'm happy with that. Can always switch out the fork if needs be.
DarrylH
Postby DarrylH » Thu Sep 27, 2012 1:00 pm
I've just read an article in an English magazine which says that 25s give better ride AND less rolling resistance to 23s at the same pressure - contrary to popular belief.
Mugglechops
Postby Mugglechops » Thu Sep 27, 2012 1:04 pm
DarrylH wrote:I've just read an article in an English magazine which says that 25s give better ride AND less rolling resistance to 23s at the same pressure - contrary to popular belief.
I read the same thing, so I run 35s :D
Postby Dan » Thu Sep 27, 2012 1:08 pm
Thanks guys - I already run 25s for that exact reason.
However, given I have next to no clearance for 23s on the new frame, discussion on the rolling resistance or otherwise of 25s seems largely irrelevant, don't you think? ;)
DarrylH
Postby DarrylH » Thu Sep 27, 2012 1:54 pm
You did say that 23s had 3mm clearance and that you could swap out the fork if necessary.
Postby Dan » Thu Sep 27, 2012 2:29 pm
Yes, I did, as well as indicating that I'm currently on 25s (and thus, most likely aware of their particular ride qualities).
I also asked specifically about the ride quality of 20C through 22C tyres - right there in the title.
Did the english article mention any of the smaller diameter tyres by any chance? Id be interested to read if so.
D
DarrylH
Postby DarrylH » Thu Sep 27, 2012 6:59 pm
No, they explained why a bigger tyre will have less rolling resistance and more comfort than a smaller tyre at the same pressure though there must be some upper limit and they did not go bigger than 25s. I raised this as most common belief is that the thinner the tyre, the less rolling resistance.
Nobody
Postby Nobody » Thu Sep 27, 2012 8:15 pm
Bigger tyres roll faster (for the same pressure) but IMHO (all things being equal) they are slower. This is due to aero and power transfer losses (thicker casing, more bob at lower pressure). However this assumes a smooth surface. As the surface gets rougher, bigger tyres (at lower pressure) get faster due to the reduction of shock/bounce. Probably why you won't see too many CX tyres in XC MTB races (where there are no tyre restrictions to my knowledge).
See the "TYRE PRESSURE" section in the link below for a better explanation.
http://www.slowtwitch.com/Tech/What_s_i ... _1034.html" onclick="window.open(this.href);return false;
Postby Dan » Thu Sep 27, 2012 8:49 pm
Learnt something new for the evening, thanks gents.
warthog1
Postby warthog1 » Fri Sep 28, 2012 12:08 am
Nobody wrote:Bigger tyres roll faster (for the same pressure) but IMHO (all things being equal) they are slower. This is due to aero and power transfer losses (thicker casing, more bob at lower pressure). However this assumes a smooth surface. As the surface gets rougher, bigger tyres (at lower pressure) get faster due to the reduction of shock/bounce. Probably why you won't see too many CX tyres in XC MTB races (where there are no tyre restrictions to my knowledge).
Good article thanks.
What you are saying about narrower being faster appears to be supported by what is being raced on. The larger 25c tyres only seem to be used where the road is rough eg Paris-Roubaix.
You don't see 25c used in tts to my knowledge, where every time gain possible is sought.
Can't fit a 25 in the rear of my S5, a 23 is already a close fit.
DarrylH
Postby DarrylH » Fri Sep 28, 2012 2:12 pm
That may be a bit out of date - in the Giro, my info is that Greenedge used 25mm Conti Competition, Rabobank 25mm Vittorias and Sky 24mm Veloflex which actually measure 24.9mm. Rims are also going wider - Zipps Firecrest 23.48mm up from 21mm, Hed and Bontrager going to 27mm, Mavic 24.2mm and Shimanos latest (used by Sky) are also up in size. A 23mm on these rims will be no more aero than a 25mm. All above courtesy of Cycling Plus.
The wider tyre does not mean a thicker casing and the point is that at the same pressure "bob"will be less on a wider tyre as there is a bigger volume of air to support the weight. A narrow tyre has more deformation at the same pressure and therefore greater rolling resistance.
Nobody
Postby Nobody » Fri Sep 28, 2012 2:41 pm
DarrylH wrote:That may be a bit out of date
What part of the logic is out of date?
DarrylH wrote:in the Giro, my info is that Greenedge used 25mm Conti Competition, Rabobank 25mm Vittorias and Sky 24mm Veloflex which actually measure 24.9mm. Rims are also going wider - Zipps Firecrest 23.48mm up from 21mm, Hed and Bontrager going to 27mm, Mavic 24.2mm and Shimanos latest (used by Sky) are also up in size. A 23mm on these rims will be no more aero than a 25mm. All above courtesy of Cycling Plus.
I've been riding on wider touring rims for years. I use 23mm tyres but they measure 24.8mm when used with these rims.
DarrylH wrote:The wider tyre does not mean a thicker casing...
True, but once over 28mm, it usually does as the target market is different.
DarrylH wrote:and the point is that at the same pressure "bob"will be less on a wider tyre as there is a bigger volume of air to support the weight.
True. Obviously tried to simplify too much. What I overlooked writing was for the ideal pressure for each tyre, a bigger tyre should have more bob. Of course at the same pressure the bigger tyre is going to be harder, but then either the bigger is over-inflated or the smaller is under-inflated.
DarrylH wrote:A narrow tyre has more deformation at the same pressure and therefore greater rolling resistance.
True, but I just can't get my 2.35" Big Apples to go faster than my 23mm Rubino Pros. :)
Postby Dan » Fri Sep 28, 2012 2:45 pm
Can I have my thread back please?
Nobody
Postby Nobody » Fri Sep 28, 2012 2:46 pm
diggerdantheman wrote:Can I have my thread back please?
Yeah, sure. What do you want to do with it now?
Postby Dan » Fri Sep 28, 2012 2:49 pm
:D you're right, its pretty well trashed now...
Nobody
Postby Nobody » Fri Sep 28, 2012 7:30 pm
diggerdantheman wrote::D you're right, its pretty well trashed now...
Well, since it's trashed anyway... :D
warthog1 wrote:What you are saying about narrower being faster appears to be supported by what is being raced on. The larger 25c tyres only seem to be used where the road is rough eg Paris-Roubaix.
Thanks for the reply. Not being able to fit a 25 into a new S5 says a lot. If Cervelo really thought 25s were actually faster for road racing, I'm sure they would allow the space. You would think that Schwalbe would know something about tyres. They think narrow tyres are faster too.
http://www.schwalbetires.com/tech_info/ ... nce#narrow" onclick="window.open(this.href);return false;
It's funny me arguing this point as it was only a couple of years ago that I'd be arguing the opposite. I've had more time to read, think and experiment since then.
Postby toolonglegs » Fri Sep 28, 2012 7:41 pm
What is being raced on at the top level doesn't really translate to the general population... as they are all very light ( very few riders over 75kgs ) so can use the optimum tyre pressures for their weight * & they are all riding on tubular tyres which have better rolling resistance ( although running a latex tube will greatly reduce your clinchers rolling resistance ).
* Part of the advantage for bigger riders running 25's is they run lower pressures compared to what you run in 23's.
Personally I run 150 psi in front 19mm tubular, 160 psi in rear 22mm tubular on my tt bike ( much more weight over the front wheel on a tt bike ). 100-115 psi in my 23mm front clincher & 100 psi in the 25mm rear on the road bike ( 120 psi on the rear with a 23mm ). 28psi on the front 32mm & 32 psi rear on my cyclocross clinchers... would love to run much lower but need tubulars for that.
Horses for courses.
warthog1
Postby warthog1 » Sat Sep 29, 2012 12:54 am
Nobody you are on fire :lol:
warthog1
Postby warthog1 » Sat Sep 29, 2012 1:03 am
toolonglegs wrote: Personally I run 150 psi in front 19mm tubular, 160 psi in rear 22mm tubular on my tt bike.
160-180 in my 22mm tubulars on my tt bike. No idea if that is faster than a lower pressure. I tend to wonder why they build such high pressure capability into the tyres if lower is faster though.
warthog1
Postby warthog1 » Sat Sep 29, 2012 1:12 am
DarrylH wrote:That may be a bit out of date - in the Giro, my info is that Greenedge used 25mm Conti Competition, Rabobank 25mm Vittorias and Sky 24mm Veloflex .
Was that on the rougher stages, and is that the measured width or specified width of the tyre?
It's similar to the theory that clinchers are as fast as tubulars. Most of the photos of the bikes in the peleton that I see show tubulars.
I'll also reiterate my point about tt tyre widths. When I see them running 25 - 28 mm tyres on tt bikes I'll accept they are as fast.
Postby Dan » Sat Sep 29, 2012 4:44 am
Is there anyone who'd care to elaborate on how much a 22 would be in relation to a 25?
Postby toolonglegs » Sat Sep 29, 2012 4:49 am
How much what?... It will be more comfortable as you will run lower pressures in the 25mm compared to the 22mm( so it will soak up more bumps )...apart from that you won't notice any difference in speed and handling. I prefer just a 25 on the rear.
If you run a latex tube in them they are even better.
Postby Dan » Sat Sep 29, 2012 5:02 am
Ha! Crucial words missing there - how much harder is what is like to know. Outside of actually just buying them and trying it for myself.
