Descending Tips
For Roadies
Descending Tips
Postby ozstriker » Thu Nov 01, 2012 11:29 am
I had a terrible experience a few weeks ago where i was descending a very steep road (in excess of 20%) and thought i would tuck in and just cruise, and before i knew it i was sitting on 80km/hr (keeping in mind it was a rough road) i started to brake for an upcoming corner when i got the worst speed wobbles.
Everything slowed down and for a second i thought that was it, that i was hitting the deck. I managed to recover by riding it out, doing some off road and deploying my foot brakes in the gravel. I gotta say it scared the crap out of me, and i hit the same hill yesterday and i was so gun shy that i was riding the brakes all the way down, not letting myself get over 55. I actually then was getting nervous about blowing a tyre from overheating brakes.
Anyway, how the hell do the pros descend in excess of 100, any tips?
Happened to anyone else?
ozstriker
by BNA » Thu Nov 01, 2012 12:25 pm
Re: Descending Tips
Postby vander » Thu Nov 01, 2012 12:25 pm
They only do that when its a straight steep well surfaced decent. Dont worry about hitting those speeds, descend safely naturally you will get a bit faster as you get the confidence.
vander
Re: Descending Tips
Postby eeksll » Thu Nov 01, 2012 2:33 pm
if i am doing 55 with the brakes on, I am going to stop and walk down .... :shock:
eeksll
Re: Descending Tips
Postby ldrcycles » Thu Nov 01, 2012 3:14 pm
ozstriker wrote:Happened to anyone else?
Yep.
Very similar to what you described, in my case the speed was 95 and i came off the bike and collected a sharp rock. Ever since then i've been understandably very nervous going downhill, however i've found that nervousness is counter-productive. It seems to me that when i tuck down and let it rip, i'm more stable than when i sit up and try to keep the speed down, weight distribution, aerodynamics i don't know. I now just avoid very steep descents wherever possible.
Re: Descending Tips
Postby Strawburger » Thu Nov 01, 2012 4:01 pm
Stiff arms and body will make the bike handle a lot differently than if you are relaxed.
n=8 (2011 road, 2004 road, 2010 track, 2009 foldup, 1990 hybrid, 1992 indoor trainer, 2007 road now a rental, 1970's step through)
Strawburger
Re: Descending Tips
Postby Strange Rover » Thu Nov 01, 2012 5:15 pm
You just need to put weight over the front wheel...its the lack of weight that causes it to wobble. I can get my bike to do it easily just by riding no hands and slapping the stem sidways and the front wheel just wobbles like crazy...there is a youtube vid of it somewhere. But as ldrcycles says...what happens is it starts to wobble and people sit up trying to slow down and in reality it makes it worse.
Sam
Strange Rover
Re: Descending Tips
Postby Strange Rover » Thu Nov 01, 2012 5:20 pm
Here is the info..
http://www.cyclingtips.com.au/2011/03/s ... -its-head/
and the video is half way down.
I can do what he does in the video...get it to wobble...and then grab the top tube just behind the stem...and it will still continue to wobble. But if I lean forward and take weight off the seat and put it onto my hands on the top tube (which in turn puts weight onto the front wheel) the wobble stops straight away.
Sam
Strange Rover
Re: Descending Tips
Postby toolonglegs » Thu Nov 01, 2012 5:25 pm
Strange Rover wrote:You just need to put weight over the front wheel...its the lack of weight that causes it to wobble. I can get my bike to do it easily just by riding no hands and slapping the stem sidways and the front wheel just wobbles like crazy...there is a youtube vid of it somewhere. But as ldrcycles says...what happens is it starts to wobble and people sit up trying to slow down and in reality it makes it worse.
Sam
not doubting you, but on a motor bike when you get into a tank slapper you accelerate hard to lighten the front wheel. I have never had a speed wobble on a vélo but my natural reaction would be to hang my bum off the back.
Re: Descending Tips
Postby Baldy » Thu Nov 01, 2012 6:39 pm
Close your eyes on the scary bits.
Baldy
Re: Descending Tips
Postby ldrcycles » Thu Nov 01, 2012 6:42 pm
Holy heck that video is frightening! :shock:
I like this comment on that article too "we always said speed wobbles was like a dog: It could smell your fear".
Re: Descending Tips
Postby ft_critical » Thu Nov 01, 2012 7:28 pm
Sam
If I take my hands off the bars and sit up whilst decending at anything over about 50kmh both my Cinelli and Colnago start to speed wobble, so I don't know that this is the answer TLL.
ft_critical
Re: Descending Tips
Postby winstonw » Thu Nov 01, 2012 7:45 pm
Any combo of bicycle, wheels, and rider can develop wobble, and it is highly unpredictable. It is generally presumed to be dependent on weight distribution, and is more common with taller riders, and higher placed saddles.
Many say unload the saddle, load the pedals, get the bum back, squeeze the knees in against the top tube.
IME it is more likely to happen when you are banking through a long curved descent.
Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
winstonw
Re: Descending Tips
Postby toolonglegs » Thu Nov 01, 2012 8:06 pm
ft_critical wrote:
Sam
True, like I said I have never experienced it ... and I am 194cm with long legs ( saddle to peddle is 1011mm ).
I change clothes at fast descending speeds and don't seem to get it with hands off the bars either... oh well, i will count myself lucky.
Re: Descending Tips
Postby Riggsbie » Thu Nov 01, 2012 8:43 pm
It's fine with 3 wheels on a recumbent with your bum 100mm off the bitumen !
I thought you roadies were tough ;-p
Riggsbie
Re: Descending Tips
Postby ozstriker » Fri Nov 02, 2012 10:45 am
Holy smokes, that video is crazy :shock:
makes sense what they say, thanks for the link ill definitely keep it in mind
ozstriker
Re: Descending Tips
Postby 15wilsonwu » Sun Nov 04, 2012 4:15 pm
Normally, i just push both sides of the handlebar to get rid of speedwobble
I love riding, not training
15wilsonwu
Re: Descending Tips
Postby g-boaf » Tue Nov 06, 2012 11:47 am
That video is scary, and here is another good one demonstrating it:
[youtube]http://www.youtube.com/watch?v=VfngbsIUSj8&feature=player_embedded[/youtube]
I thought the poor rider was going to crash as he wobbled to the edge of the road quite quickly. I haven't had it in ages. Some reckon they experience it at 55km/h or so, I've not experienced that - not recently anyhow. The last time it did happen I ended up off the bike for a long time and with grazes and a bad back. :shock: I was new to it all then.
Perhaps I'm getting a bit better with my bike handling these days. I tend to keep my knees against the top-tube when I'm descending, unless I'm pedalling. I find it keeps things more steady.
I don't do the hands off the bars thing at high speeds however - I'm realistic about my abilities. :oops: :lol:
g-boaf
Re: Descending Tips
Postby jules21 » Mon Dec 03, 2012 10:03 am
that video above - classic scenario i reckon. it's cold, he looks like he's gripping the bars too hard (probably can't feel how hard) -> wobble.
jules21
Re: Descending Tips
Postby sogood » Mon Dec 03, 2012 3:36 pm
20% grade descent and cruising? Where did you find roads like that here in Oz?
sogood
Re: Descending Tips
Postby MREJ » Mon Dec 03, 2012 6:18 pm
Cycling Tips had a good post on descending technique. Main things I do are: hands in drops to weight front wheel; weight the outside foot on corners; look ahead to where you want to be; slow down if I have any doubts.
2010 Charge Plug, 2011 Genesis Equilibrium 20, 2012 Giant TCR Advanced SL
MREJ
Re: Descending Tips
Postby ozstriker » Wed Jan 09, 2013 5:55 pm
sogood wrote:20% grade descent and cruising? Where did you find roads like that here in Oz?
Toowoomba, there's heaps of bitumen walls to climb around here.
ozstriker
Re: Descending Tips
Postby Wal42 » Thu Jan 10, 2013 7:27 pm
Know your brakes & how fast your bike will stop safely, go practice somewhere, pick a telegraph pole or something on an open bit of road (on a slight downhill slope would be great), do gradually faster speeds & practice 'panic' stops.
Once you know how hard & fast you can stop, then you have a good skill set for descending, the trick is, just do it, over & over again, the more times you do it, the more you become comfortable with it.
I don't move my weight forward, I lift off the seat, clamp the seat with my thighs, for straights, pedals level, weighted on the outside pedals for corners.
I exceed 50kph 4 times a day, every day on my commute ride, normally most of them are over 55 usually nudging 60kph, it's like anything, the more you do it, the more comfortable you get with it.
Good descenders are usually just very comfortable & confident descending, it's an easy skill to practice & can really make you a fair whack of time gains (especially if you climb as badly as I do).
Wal42
Re: Descending Tips
Postby bosvit » Thu Jan 10, 2013 7:40 pm
Sam
My Giant Defy/American Classic 420 combo used to get the wobbles on more occasions than not descending down my own street. I can reach 70km in a tuck easy.
I found the best way to stop it was to start peddling, would settle the whole frame down and you could get on the brakes, so sort of similar to TLL's motorbike experience.
bosvit
Re: Descending Tips
Postby RunForrestRide » Mon Jan 21, 2013 12:17 pm
Can't say I'v ever had speed wobbles. Is it the conditions/speed/bike? Or combination of all?
RunForrestRide
Re: Descending Tips
Postby Mulger bill » Mon Jan 21, 2013 11:48 pm
Yes
Return to Road Biking
