Butchering a Brooks
- WestcoastPete
Butchering a Brooks
Postby WestcoastPete » Tue Oct 30, 2012 12:20 am
So I decided to cut it; to add the Imperial cutout to the Flyer. It could end in disaster and the ruining of a very good saddle, but the saddle wasn't perfect. I wouldn't use it as it was intended to be used unless I cut it.
It turned out to be really easy. I took a template from my Imperial and used a sharp Stanley knife to make the cut. Neither of the saddles are symmetrical now that they're warn in, so neither is the cut. It's pretty bloody close though.
Whoa, what am I thinking?!?
This front of the cut was the hardest bit, but it turned out well with a bit of a shaving motion.
To prevent the saddle from flaring due to the reduced lateral tension, the Imperial is supposed to be laced. I've actually taken the laces out of my Imperial now that it has adopted the appropriate bowed shape laterally, but I need to make sure this Flyer doesn't flare out. I was hoping to get some proper leather punches for this, but they were hard to find in Darwin and I was impatient, so I got one of those cheap rotary ones. It did the job cleanly enough, but it was hard work.
And the verdict? Well, the first little ride down the street was really comfortable. It'll need a few long rides to determine if it's fixed the chafing problem, but I haven't killed the saddle. The cut looks good, nothing digs or pinches, it flexes differently, and it looks good. I'd certainly feel confident doing this again...
- hiflange
Re: Butchering a Brooks
Postby hiflange » Tue Oct 30, 2012 12:52 am
- il padrone
Postby il padrone » Tue Oct 30, 2012 9:09 pm
Postby wqlava1 » Thu Nov 01, 2012 10:42 pm
- WestcoastPete
Postby WestcoastPete » Thu Nov 01, 2012 11:27 pm
Having said that, I'm not sure if I'd get another one. GJ Coop would be a good one to consult as he's tried both on his long distance tours, although neither with the imperial cutout.
Sent from my GT-I9100 using Tapatalk 2
- il padrone
Postby il padrone » Thu Nov 01, 2012 11:51 pm
- rifraf
Postby rifraf » Fri Nov 02, 2012 2:10 pm
Postby Nobody » Fri Nov 02, 2012 3:04 pm
- rifraf
Postby rifraf » Fri Nov 02, 2012 6:21 pm
Excellent communication of the idea, process and outcome.WestcoastPete wrote:I have quite a few Brooks saddles. My first was a Brooks Flyer, which is like a B17 but sprung. It became very comfortable very quickly, and I was in love. When I was touring on it though, I developed a bit of chafing. I thought this was all part of touring and didn't put it down to the saddle. That was until I got my Brooks B17 Imperial. I love this saddle. I found myself swapping it from bike to bike, depending on what was going to be ridden most. On my last tour, I took the Imperial, and it got me thinking; what's the point in having this lovely sprung saddle if I'm just going to swap it out?
The pics really helped.
A brave experiment when you consider the costs of failure but no doubt now others can follow in your tyreprints (footsteps).
Postby zues » Fri Nov 02, 2012 9:55 pm
Do you mean you got your nuts caught in the cut-out? what were you wearing?I did an injury to my groin using a B17 Imperial while on the drops.
Postby Nobody » Fri Nov 02, 2012 10:09 pm
Um no. I believe one of the edges of the leather did some damage under the scrotum area, but closer to the body. Didn't go to the doctor to get the specifics just waited a while then rode the MTB with a very high handlebar setting until I could put pressure on that area again. Took weeks to heal. I'm just posting as a warning to others. Just in case...zues wrote:Do you mean you got your nuts caught in the cut-out? what were you wearing?Nobody wrote:I did an injury to my groin using a B17 Imperial while on the drops.
I was wearing the tighter version of boxer shorts style undies and normal shorts. Dress could have had something to do with it as there is no padding as such. Never happened before or since with other saddles and similar clothing.
Postby warthog1 » Sun Nov 04, 2012 11:04 am
+1 appreciate your honesty NobodyNobody wrote:For anyone who has their handlebars below their saddle, or has quite a forward body position on the bike (like using the drops on a road bike) I would recommend to avoid a Brooks.
Postby Nobody » Sun Nov 04, 2012 2:48 pm
Thank for that. Some shock jocks would be proud of your out-of-context quoting.warthog1 wrote:+1 appreciate your honesty NobodyNobody wrote:For anyone who has their handlebars below their saddle, or has quite a forward body position on the bike (like using the drops on a road bike) I would recommend to avoid a Brooks.
Pic courtesy of the tumbleweed section.
Somehow I don't think you'll be the first person I approach for advice on saddles. Did a bike fitter inflict that saddle angle on you, or did you do it all by yourself?
Here's how it's done if you have a Brooks.
Postby warthog1 » Sun Nov 04, 2012 3:33 pm
you're welcome happy to point out the obviousNobody wrote: Thank for that. Some shock jocks would be proud of your out-of-context quoting.
All by myself It looks drastically nose down in that photo I agree but it's only a couple of mm at the nose. Whether its the sloping tt or the angle the bike is leaning against the wall I don't know, either way its comfortable for a couple of hrs at least. If I had a nose up brooks on it I don't think I'd be walking today, let alone ridingNobody wrote:
Nobody wrote: Here's how it's done if you have a Brooks.
Gee those bars are low, being steel you'll be able to weld some more pipe on the steerer and get a handful more spacers in there
Failing that maybe these will help
Postby Nobody » Sun Nov 04, 2012 5:28 pm
Um, yeah. Thanks for that "helpful" advice. Not everyone is trying the relive their youth. I believe pros have a 12cm drop and LA had 9 (but he obviously didn't need to be as aero.). I have 2cm. But I have a short reach for my height and so that setup still gives me a 45 degree body angle on the hoods. Fine for what I do. If I had a Madone with a H2 fit and a 14cm head tube for my size, then I think the spacers would be less noticeable.warthog1 wrote:Gee those bars are low, being steel you'll be able to weld some more pipe on the steerer and get a handful more spacers in there
As for the ape hangers, I've got something similar on my wife's bike (cafe bars) and they make it very upright and comfortable.warthog1 wrote:Failing that maybe these will help
Postby warthog1 » Sun Nov 04, 2012 7:33 pm
My wife's bike is very upright and comfortable when I ride it too. You were correct, she has ridden it once thus far.Nobody wrote:
Postby warthog1 » Sun Nov 04, 2012 7:37 pm
It is still the only leather saddle I have ridden and yes it is comfortable. When I grow up and get a tourer I'm sure it will have a leather saddle
Got to try and catch up with the 54 year old bloke who is cleaning me up first though
- il padrone
Postby il padrone » Sun Nov 04, 2012 11:45 pm
Postby Nobody » Mon Nov 05, 2012 8:03 am
Sorry to hear it. Can't say I like being correct about that. I'd rather my wife's bike be the only one collecting dust (when I'm not riding it).warthog1 wrote:My wife's bike is very upright and comfortable when I ride it too. You were correct, she has ridden it once thus far.
You must be getting to the point now where you know you may never catch him. You obviously made the mistake before you were born of not choosing you parents more carefully.warthog1 wrote:Got to try and catch up with the 54 year old bloke who is cleaning me up first though
Postby warthog1 » Mon Nov 05, 2012 8:36 am
Yes well I'm obviously no Lance Armstrong even without the EPONobody wrote:You must be getting to the point now where you know you may never catch him. You obviously made the mistake before you were born of not choosing you parents more carefully.warthog1 wrote:Got to try and catch up with the 54 year old bloke who is cleaning me up first though
I reckon I can take him in a tt.......we dont have them here though Thats a maybe and he still has 10 years on me.
Postby warthog1 » Mon Nov 05, 2012 8:39 am
Was that you riding up Specimen Hill Rd in Golden Square yesterday? Bloke on a yellow bike who looks like you from the photos on the forum anyway.il padrone wrote:One for the ladies, the B18. Eminently comfortable I've been told
I was at work and driving the other way.
- il padrone
Postby il padrone » Mon Nov 05, 2012 10:20 am
Hmm........ Sprung!!warthog1 wrote:Was that you riding up Specimen Hill Rd in Golden Square yesterday? Bloke on a yellow bike who looks like you from the photos on the forum anyway.
Yes it was I. I was part of the group of 21 that were doing a ride out to the wineries at Marong. MBTC has a weekend base camp - staying at Central City Caravan Park and doing a series of day rides around Bendigo. We have over 50 members involved in the weekend. You would be welcome to drop over and say g'day, maybe later this arvo. They're going out to a pub for dinner tonight.
But warning - there will be many Brooks devotees
Postby warthog1 » Mon Nov 05, 2012 10:56 am
It will be nice to meet you. I'll try and get there this arvo. Night shift tonight worse luck, but a Monday night is better than a Fri or Sat nightil padrone wrote:Hmm........ Sprung!!warthog1 wrote:Was that you riding up Specimen Hill Rd in Golden Square yesterday? Bloke on a yellow bike who looks like you from the photos on the forum anyway.
I'll be on a plastic bike most likely
- il padrone
Postby il padrone » Mon Nov 05, 2012 11:17 am
Sorry, I wasn't clear about that. I'm back in Melbourne - had to work todaywarthog1 wrote:It will be nice to meet you. I'll try and get there this arvo.
If you drop in and mention you know Pete Sig I'm sure you'll get a good welcome.
Postby warthog1 » Mon Nov 05, 2012 1:00 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
