Pumping tires at the petrol station... not enough PSI?
Postby anonymousmoose » Sun Nov 11, 2012 6:08 pm
One the tyres, it says 'max 75 PSI'. But when I stopped at a petrol station, I noticed their tire pumps only go up to 60 PSI.
Does this mean petrol station pumps are not high enough to pump bike tyres?
- il padrone
Re: Pumping tires at the petrol station... not enough PSI?
Postby il padrone » Sun Nov 11, 2012 6:18 pm
http://markfunkyhoward.blogspot.com.au/ ... -pump.html" onclick="window.open(this.href);return false;
You just don't need the servo's air hose. A good stand pump will easily get air into your tyres. I hardly ever use my frame pump these days.
Postby jasonc » Sun Nov 11, 2012 6:24 pm
If I took a picture of mine, it would look exactly like thatil padrone wrote:You just don't need the servo's air hose. A good stand pump will easily get air into your tyres. I hardly ever use my frame pump these days.
- il padrone
Postby il padrone » Sun Nov 11, 2012 6:27 pm
- ldrcycles
Postby ldrcycles » Sun Nov 11, 2012 7:21 pm
It is POSSIBLE (but not advisable) to use servo air hoses to pump up your tyres, but ONLY if you are careful and patient with the manually operated type, i would never risk the automatic ones you see at a lot of places now, they pump too much air too quickly and you are liable to blow your tyres off. Can be good for seating tubeless tyres though i'm told.
The last couple of days i've been replacing tyres, didn't have my track pump with me so used a mini pump instead and it might have taken me an extra 10 or 20 seconds per tyre.
Postby boss » Sun Nov 11, 2012 9:45 pm
Press flat tyre only.
Pump will spit out air, then stops to check the PSI reading. Then spit out air, then stops to check the PSI reading. And so forth.
What you do is put the hose on your valve when its spitting out air, remove before it stops. Then put it back on when it starts spitting air, then pull it off again before it stops.
I've gone up to about 75psi on mountain bike tyres / schraeder valve tubes using servo pumps with this method.
Disclaimer: do not do this with 700c presta valve tubes. Or if you do it, it's at your own risk, because I don't know what'll happen.
- Lukeyboy
Postby Lukeyboy » Sun Nov 11, 2012 10:02 pm
Postby JessicaAlba » Mon Nov 12, 2012 12:42 am
Correct. The pump pressure is capped, so that morons don't over-inflate/burst their car tyres.anonymousmoose wrote: Does this mean petrol station pumps are not high enough to pump bike tyres?
#cottonwoolsociety
2014 Scott Addict Team Issue/DA9000/Syncros RL1.1/Zipp 404/Gatorskins
Postby boss » Mon Nov 12, 2012 7:25 am
I forgot about that - petrol stations that have high flow diesel (for big trucks) usually have 100psi pumps.Lukeyboy wrote:There are a few servos in Brisbane that will still go up to 100psi. Just got to make sure you know your PSI to kPa conversions
- Aushiker
Postby Aushiker » Mon Nov 12, 2012 11:59 am
+ 1 for a pump and a Lezyne in particular and oh get one for the bike as wellil padrone wrote:You just don't need the servo's air hose. A good stand pump will easily get air into your tyres. I hardly ever use my frame pump these days.
Aushiker.com
Postby zero » Mon Nov 12, 2012 12:06 pm
I wouldn't go about doing the overfill trick, if the pump fails at or about the time you were doing it, you may have some explaining to do.
Postby boss » Mon Nov 12, 2012 12:12 pm
This is pure speculation, but... If 'protecting the masses from themselves' was the reason, they would be capped at 40, not 60psi. I've never tried it, but I don't think your car tyres will enjoy being inflated to 60psi. Willing to be stood corrected, I am not game to inflate a car tyre to 60 in order to test that theory out for myself.JessicaAlba wrote:Correct. The pump pressure is capped, so that morons don't over-inflate/burst their car tyres.anonymousmoose wrote: Does this mean petrol station pumps are not high enough to pump bike tyres?
#cottonwoolsociety
I believe the pressure is capped because the compressors aren't tough enough to go past 60+ psi regularly. I've run into more than one compressor in my travels that wasn't able to hit 45psi, even though the display would let me select 60psi.
One, in particular, that sticks in my memory was the at the last petrol station before a major highway. I'd bet that more than one trucker had used that pump with the before mentioned 'flat tyre only' trick and over time the compressor got a little bit tired.
As above, compressors get 'tired out' and less efficient rather than catastrophically fail in a shower of fireworks. Either way, I've used the flat tyre trick fairly regularly for the last 10 years or so (however long those pumps have existed) and she's apples.zero wrote: I wouldn't go about doing the overfill trick, if the pump fails at or about the time you were doing it, you may have some explaining to do.
More risk of blowing tyre off the rim if you are a bit over excited, as when doing the overfill trick you have no idea what the psi is. Obviously it's fairly easy to manage even for a newbie by erring on the side of caution.
Live a little!
- Aushiker
Postby Aushiker » Mon Nov 12, 2012 12:22 pm
My "space saver" tyre in the Subaru Imprezza needs to be inflated to 60 PSI.jimboss wrote:This is pure speculation, but... If 'protecting the masses from themselves' was the reason, they would be capped at 40, not 60psi. I've never tried it, but I don't think your car tyres will enjoy being inflated to 60psi. Willing to be stood corrected, I am not game to inflate a car tyre to 60 in order to test that theory out for myself.
Aushiker.com
Postby boss » Mon Nov 12, 2012 12:36 pm
Corrected I stand. I wonder why that is. Discussion for another day. I still don't buy the protecting ourselves from ourselves as I'd wouldn't like to see what happens when a standard car tyre is inflated to 60psi.Aushiker wrote:My "space saver" tyre in the Subaru Imprezza needs to be inflated to 60 PSI.jimboss wrote:This is pure speculation, but... If 'protecting the masses from themselves' was the reason, they would be capped at 40, not 60psi. I've never tried it, but I don't think your car tyres will enjoy being inflated to 60psi. Willing to be stood corrected, I am not game to inflate a car tyre to 60 in order to test that theory out for myself.
Postby rkelsen » Mon Nov 12, 2012 1:31 pm
Back when you could actually get your car serviced at service stations, they'd run air compressors to power their tools. Some even had air-powered hoists. Their "customer air" was simply another line running off the compressor. Nowadays, most "service stations" only sell petrol. They don't need to run any tools, because they don't have any. So why should they run a compressor capable of 100psi if they don't need it and none of their customers require it?JessicaAlba wrote:Correct. The pump pressure is capped, so that morons don't over-inflate/burst their car tyres.
Not much, unless you drive on it.jimboss wrote:I still don't buy the protecting ourselves from ourselves as I'd wouldn't like to see what happens when a standard car tyre is inflated to 60psi.
Incidentally, those "space saver" spare tyres in cars are a stupid idea. It's simply cost-cutting for no good reason. Imagine having to drive halfway across the Nullarbor on one.
Postby jasonc » Mon Nov 12, 2012 1:45 pm
will go a bit off topic to discuss this. so i apologiserkelsen wrote:Incidentally, those "space saver" spare tyres in cars are a stupid idea. It's simply cost-cutting for no good reason. Imagine having to drive halfway across the Nullarbor on one.
the reason for them was to save weight in the car during fuel economy testing. as it weight 5kgs less (every kg helps) it may then be able to run 1 size smaller brakes etc etc saving more weight.
so it makes the car cheaper to make and show a better fuel economy for the official number..
and yes, they are a stupid idea.
- ldrcycles
Postby ldrcycles » Mon Nov 12, 2012 3:49 pm
Re tyre pressures on cars, i remember reading about a stunt bloke in the UK doing some two wheeled driving in a Triumph TR4 or something similar, and he had 90psi in the tyres for the exercise (presumably to stop them tucking under). It did say they were shot afterwards though.
Postby PB12IN » Mon Nov 12, 2012 3:57 pm
60psi wouln't blow the car tyre up but it would be a seriously hard ride.
Postby ytd » Tue Nov 13, 2012 4:45 pm
Postby wellington_street » Wed Nov 14, 2012 4:36 pm
Users browsing this forum: blizzard
