Has anyone used this torque wrench before?
- nuttzo32
Postby nuttzo32 » Sun Nov 25, 2012 6:55 pm
Seems like a good price but i was wondering what the quality is like and if anyone has used it or can recommend something else for a similar price?
Re: Has anyone used this torque wrench before?
Postby Nobody » Sun Nov 25, 2012 7:30 pm
In other words, if you want to buy cheap, don't worry about the accuracy or bother asking about it. The only way to know for sure is to get it calibrated, which will probably cost more than the initial sale.
If you don't have carbon and you are not ham-fisted, then you probably don't need it.
- nuttzo32
Postby nuttzo32 » Wed Nov 28, 2012 11:46 pm
I'm still undecided about getting one but i think i will leave it for now as i have other more important purchases to make at the moment like wet weather gear as the weather and cold is keeping me off the bike atm.
Postby usernameforme » Thu Nov 29, 2012 1:05 pm
Agree with that, I barley use my Torque wrench anymore because I know what each setting approximatley feels likeNobody wrote:If you don't have carbon and you are not ham-fisted, then you probably don't need it.
With that Torque Wrench, I have one and its accurate, Its cheap because its not a digital one and its sourced direct from manufacturor
Postby TDC » Thu Nov 29, 2012 2:11 pm
Did you get your feel for torque settings from using your torque wrench initially, or did you always know instinctively what they felt like?usernameforme wrote:Nobody wrote:I barley use my Torque wrench anymore because I know what each setting approximatley feels like
Postby usernameforme » Thu Nov 29, 2012 4:33 pm
Opinions can be divided on this topic, but I think that a good mechanic should not need a torque wrench, they should be able to 'guestimate' the torque.
- MarkG
Postby MarkG » Thu Nov 29, 2012 4:37 pm
You'd be suprised how much 4-5nm of torque is on a bolt.
Postby Baalzamon » Thu Nov 29, 2012 5:18 pm
The torque wrench in the ops post is one that is used by many a manufacturer I think, it's a dead ringer for my BBB one
Postby TDC » Thu Nov 29, 2012 6:15 pm
Cool. I have done the same thing as you. However, the guys posting about information on torque wrenches on this forum (I am being presumptuous here) I imagine are not experienced (bike) mechanics, therefore are unlikely to know what 5 nm or whatever feels like. They are ask for opinions and all they get told is "you don't need one of them, do it by feel. I have been using the force for years, so you should be able to as well."usernameforme wrote:By initially using a nice torque wrench, I still do, but if it gives a fairly wide range (like my seatpost, 2-8nm) I just do it by hand (read lazy ).
Doing things by 'feeeeel' usually requires the learning of the task and then repetitively doing the task until it can be done instinctively. Anyway, thats my take on this.
Also, that looks like the wrench I have. It seems to work fine. I dont know if it was calibrated, but it gets the bolts torqued close to the specs within the acceptable limits (I assume this last bit).
- Moderator
Postby thomashouseman » Thu Nov 29, 2012 7:02 pm
- Xplora
Postby Xplora » Thu Nov 29, 2012 8:15 pm
Screws can EASILY strip or get stuck on the thread, especially if you've been putting lube or loctite on the bolt... you use a torque wrench because it removes the guesswork. Me? I tighten the hell out of the bolts, but I wasn't the best car mechanic and I used the rattlegun without prejudice. I am not prepared to risk my Madone under such behaviour.... particularly when you are exposing the bike to the elements etc etc etc.
- JustJames
Postby JustJames » Thu Nov 29, 2012 8:55 pm
Tighten till it goes loose.
Then back a quarter turn.
http://pedallingcharm.wordpress.com/" onclick="window.open(this.href);return false;
- Alien27
Postby Alien27 » Thu Nov 29, 2012 10:29 pm
PfthhhJustJames wrote:Torque wrench? Pffffffftttt!!!
- toolonglegs
Postby toolonglegs » Thu Nov 29, 2012 10:46 pm
Postby jcjordan » Sat Dec 01, 2012 8:38 pm
I had a argument with a met who owns the my LBS and he always said he could tell exactly how tight everything should be. Put him up against a electronic torque wrench.MarkG wrote:Even mates of mine who are bike mechs don't use torque wrenches all the time, preferring to go by feel etc.
He know uses one all the time.
- Riggsbie
Postby Riggsbie » Sat Dec 01, 2012 9:25 pm
It arrived from the UK in 4 days......
- Xplora
Postby Xplora » Sun Dec 02, 2012 1:45 am
Yep, if it matters to do it up to a certain torque, you can't just make it up. CF is a bit more finicky I reckon because you can't really afford to cause structural integrity or safety issues from over or under loose bolts. Steel and Alu will at least shear and strip before cracking the tube.jcjordan wrote:He know uses one all the time.
Most bolts don't result in you eating pavement after bunnyhopping a pothole, but bike bolts can.
