Very sore perineum skin
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 1:44 pm
Do you think I should apply some on mid ride too? Does this go away with more riding (tougher skin)?
- RonK
Re: Very sore perineum skin
Postby RonK » Fri Jan 11, 2013 2:07 pm
Watch the movie "Hell on Wheels" and see how Eric Zabel's soigneur applies chamois cream to his knicks. You might be surprised.
- sogood
Postby sogood » Fri Jan 11, 2013 2:15 pm
1) Stand often.
2) Wear good quality cycling shorts/bib. It reduces the skin wear.
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 2:18 pm
I did ask on another thread about whether you should apply just the skin or to the chamois (or padded area) too. I just grab a little and rub it into my skin for a second. I guess I'll try some more!RonK wrote:Assuming of course, that your position is correct and your saddle is appropriate, are you applying enough cream to the chamois?
I'm assuming my position is correct and I got my sit bones measured (went from 132 to 143 saddle).RonK wrote:Watch the movie "Hell on Wheels" and see how Eric Zabel's soigneur applies chamois cream to his knicks. You might be surprised.
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 2:19 pm
I don't do this enough!sogood wrote:The skin will get used to it. But two items,
1) Stand often.
I mainly wear Santini bib knicks (from Prendas).sogood wrote:2) Wear good quality cycling shorts/bib. It reduces the skin wear.
- RonK
Postby RonK » Fri Jan 11, 2013 2:24 pm
And I replied and assumed you had read it (and didn't believe me). That's why I suggested you watch the movie to see how the pro's use it.stinhambo wrote:I did ask on another thread about whether you should apply just the skin or to the chamois (or padded area) too.
- sogood
Postby sogood » Fri Jan 11, 2013 2:58 pm
- greyhoundtom
Postby greyhoundtom » Fri Jan 11, 2013 3:07 pm
The weight should be carried on the sitbones with very little pressure on the perineum, and therefore the skin in that area should not be getting sore.
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 3:50 pm
Perhaps if I angle my seat forward just a smidge?
- greyhoundtom
Postby greyhoundtom » Fri Jan 11, 2013 4:11 pm
It's certainly worth a try.stinhambo wrote:It's just the edges, not the entire centre area. I thought maybe because I'm carrying a bit of fat around the legs.
That is of course assuming you wear your knicks commando without underdacks to irritate the area.
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 4:19 pm
You assume correctly! Absolutely no underwear under lycra!greyhoundtom wrote:
- InTheWoods
Postby InTheWoods » Fri Jan 11, 2013 4:47 pm
If its just the edges might the knicks be a size too big for you? I've had something similar recently and I suspect its because my knicks are now too big for me.stinhambo wrote:It's just the edges, not the entire centre area. I thought maybe because I'm carrying a bit of fat around the legs.
- RonK
Postby RonK » Fri Jan 11, 2013 4:59 pm
I dunno where you get that idea from. I regularly ride from 60 - 100 km rides and have always used chamois creme for more than 30 years of cycling. If I didn't use it, I'd almost certainly have serious saddle sores.sogood wrote:Fact is, most recreational riders riding 100 or even 150km/day have not depended on chamois cream. Unless you have massive ride volume, the most likely reason is that you don't ride enough and have not developed the endurance down there. Build it up over time. Otherwise, sore skin is trivial compared to full blown saddle sores and other neurological problems.
- RonK
Postby RonK » Fri Jan 11, 2013 5:01 pm
More likely you need to move the saddle forward so you are not sitting on the narrow part.stinhambo wrote:Perhaps if I angle my seat forward just a smidge?
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 5:33 pm
Ah yes I think I did move it back a little when I fitted the new saddle. I'll give that a go. And extra dollops of Aussie Butt Cream too!RonK wrote:More likely you need to move the saddle forward so you are not sitting on the narrow part.stinhambo wrote:Perhaps if I angle my seat forward just a smidge?
Thanks for the advice
- sogood
Postby sogood » Fri Jan 11, 2013 5:49 pm
If I didn't use the word "most" in my earlier post, then I would certainly be in your firing line.RonK wrote:I dunno where you get that idea from. I regularly ride from 60 - 100 km rides and have always used chamois creme for more than 30 years of cycling. If I didn't use it, I'd almost certainly have serious saddle sores.sogood wrote:Fact is, most recreational riders riding 100 or even 150km/day have not depended on chamois cream.
Postby macca33 » Fri Jan 11, 2013 6:16 pm
I took the two-wheels back up in late October and have done around 1500Km since - without too much trouble - however, when I went to rides over 40Km in duration, I found the shortcoming of the cheap saddle I had fitted to my bike - it caused me soreness for almost a week. Once I replaced it with a proper saddle the soreness disappeared and I'm doing 60Km+ rides no worries now. I've heard of 'butt' creams, however, have never seemed to need to use them.
Good luck with your nethers!
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 6:20 pm
- greyhoundtom
Postby greyhoundtom » Fri Jan 11, 2013 7:03 pm
Because of numbness in the perineum area I bought a Specialized Romin Saddle which is a bit cheaper than the Toupe but with the same cut out section, and it seems to have solved that problem.stinhambo wrote:I've just bought a Specialized Toupe saddle! I hope it wasn't a bad choice..
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 7:34 pm
I'll experiment with positioning first starting by sliding it forward a few mm, perhaps tilt it forward ever so slightly.greyhoundtom wrote:Because of numbness in the perineum area I bought a Specialized Romin Saddle which is a bit cheaper than the Toupe but with the same cut out section, and it seems to have solved that problem.stinhambo wrote:I've just bought a Specialized Toupe saddle! I hope it wasn't a bad choice..
- InTheWoods
Postby InTheWoods » Fri Jan 11, 2013 7:36 pm
Is it the skin that is sore or the flesh underneath? If skin, it sounds more like the fit of your knicks.stinhambo wrote:I'll experiment with positioning first starting by sliding it forward a few mm, perhaps tilt it forward ever so slightly.greyhoundtom wrote:Because of numbness in the perineum area I bought a Specialized Romin Saddle which is a bit cheaper than the Toupe but with the same cut out section, and it seems to have solved that problem.stinhambo wrote:I've just bought a Specialized Toupe saddle! I hope it wasn't a bad choice..
- Mulger bill
Postby Mulger bill » Fri Jan 11, 2013 7:57 pm
One adjustment at a time please or you'll never be sure which is the problem.stinhambo wrote:I'll experiment with positioning first starting by sliding it forward a few mm, perhaps tilt it forward ever so slightly.
Postby thearthurdog » Fri Jan 11, 2013 9:11 pm
- stinhambo
Postby stinhambo » Fri Jan 11, 2013 9:25 pm
I'll set these at forward a few mm then.Mulger bill wrote:One adjustment at a time please or you'll never be sure which is the problem.stinhambo wrote:I'll experiment with positioning first starting by sliding it forward a few mm, perhaps tilt it forward ever so slightly.
- ColinOldnCranky
Postby ColinOldnCranky » Fri Jan 11, 2013 9:53 pm
Anyway, about my second 50km I started getting discomfort in the same area and it seemed that the seat was gripping me too well so that tissue was constantly being stretched - on miillimetres but that is many thousands of times a trip.
So I put the sheepskin back on as it does have a certain amount of lateral give. Problem solved.
I have tried to do without it again and it seemed that the same thing was happening.
Perhaps you can learn from my experience and somehow break any gripiness between your seat and your nether regions.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
