by 4xsama » Sat Jan 19, 2013 6:30 pm
Hi,
I am trying to setup a Bryton 40 but can't get a reading on the monitor.
Cadence and speed magnets are making the receiver flash red and green respectively but for some reason the monitor doesn't display. As I am indoors is there a GPS issue or is there alternatively a mode problem (I am in METER mode).
4xsama
by Forum Ads » Sat Jan 26, 2013 6:37 am
by ianK » Sat Jan 26, 2013 6:37 am
Are the speed and cadence sensors switched on? Check settings - sensors. Rescanning the sensors might also sort it out.
ianK
by Wal42 » Sat Jan 26, 2013 8:43 am
That's what happened with my 3 month old one before I fixed it permanently with a hammer & bought the other brand starting with G, 16 months down the track & the other one has performed virtually faultlessly. Probably not what you want to hear though.
Wal42
by 4xsama » Sun Jan 27, 2013 11:33 am
Wal42 wrote:That's what happened with my 3 month old one before I fixed it permanently with a hammer & bought the other brand starting with G, 16 months down the track & the other one has performed virtually faultlessly. Probably not what you want to hear though.
Yeah, not really. Thanks for the post though. I really like your Avatar
4xsama
by DarrylH » Sun Jan 27, 2013 12:50 pm
Don't ditch it - my Bryton 35 is now 21 months old and still has great battery life.
DarrylH
by clackers » Sun Jan 27, 2013 6:02 pm
4xsama, did you check that the sensor has been detected as Ian suggested?
You should see the speed/cadence icons on the display.
clackers
by 4xsama » Sun Jan 27, 2013 7:51 pm
clackers wrote:4xsama, did you check that the sensor has been detected as Ian suggested?
No. Is there a reboot or format function? I see the lights flick over at the appropriate times so I guess the reader reads. Whether the sender sends or displayer displays is up in the air. It's like the light are on but nobodies home.
4xsama
by clackers » Sun Jan 27, 2013 10:41 pm
Take up Ian's suggestion to Rescan. The ID of the sensor should be revealed. If not, change the battery as a first step.
clackers
by 4xsama » Mon Jan 28, 2013 6:48 pm
ianK wrote:Are the speed and cadence sensors switched on? Check settings - sensors. Rescanning the sensors might also sort it out.
Fixed. Cheers. Rescan worked. Can I load up the odo reading from my Cateye so I don't restart from 0km's.
4xsama
by clackers » Tue Jan 29, 2013 9:06 pm
4xsama wrote:ianK wrote:Are the speed and cadence sensors switched on? Check settings - sensors. Rescanning the sensors might also sort it out.
Don't think so. But could be wrong.
clackers
by beroz » Tue Jan 29, 2013 9:52 pm
Try settings, bike profile,overview, select bike 1 or bike2, odo.
Sent from my HTC One X using Tapatalk 2
beroz
by 4xsama » Thu Jan 31, 2013 8:28 pm
beroz wrote:Try settings, bike profile,overview, select bike 1 or bike2, odo.
Nope! IS it just me or does Bryton have pretty crap*y instructions.
4xsama
by clackers » Thu Jan 31, 2013 8:46 pm
4xsama wrote: IS it just me or does Bryton have pretty crap*y instructions.
They are still crappy, even by Taiwanese standards.  The Swiss Garmin documentation must surely be better!
clackers
