Causes of the blood taste on hard efforts
Postby Dr_Mutley » Fri Feb 01, 2013 2:12 am
No EPO answers please!
Many get it?
Discuss
- sogood
Re: Causes of the blood taste on hard efforts
Postby sogood » Fri Feb 01, 2013 9:39 am
Postby Dr_Mutley » Fri Feb 01, 2013 11:22 am
Postby Dr_Mutley » Fri Feb 01, 2013 11:39 am
“I launched off the ramp and cut into the first corner at full speed, with Carmichael following in a team car. I kept pushing, going right to the limit and staying there. I can tell I’m at the limit when I can taste a little bit of blood in my mouth, and that’s how I stayed, right on the edge.”
- outnabike
Postby outnabike » Fri Feb 01, 2013 11:39 am
If you heart is ok, I would think you may need to drink more? Also check out if you have those silver fillings if you have them,in your teeth some contained mercury.
Postby Jesmol » Fri Feb 01, 2013 11:40 am
Postby Dr_Mutley » Fri Feb 01, 2013 11:42 am
- RonK
Postby RonK » Fri Feb 01, 2013 11:54 am
I used to get that taste, but I don't get it any more since I finally realised what was causing it (for me anyway), and started wearing a cap under my helmet.Dr_Mutley wrote:No definite blood/metallic taste...
Simply put, there is a tiny tube that connects the eyes to the nasal cavity. Sweat runs into the eyes and drains down this tube into the back of the mouth. It has a nasty metallic taste but it's not blood. Sweat hard enough and it'll start running out the nose as well.
The cap stops sweat from running into my eyes. Bingo - no more runny nose, no more bad taste.
- outnabike
Postby outnabike » Fri Feb 01, 2013 12:19 pm
http://tridoc7.com/why-runners-taste-blood/" onclick="window.open(this.href);return false;
- sogood
Postby sogood » Fri Feb 01, 2013 12:49 pm
That article is so funny with lines like this,outnabike wrote:Some info here suggests it originates from the lungs.
Dismissed. Next.This only occurred when I exceeded my maximum heart rate
Postby Dr_Mutley » Fri Feb 01, 2013 2:26 pm
Mine is different... My nasolacrimal ducts are well blocked/plugged up...RonK wrote:I used to get that taste, but I don't get it any more since I finally realised what was causing it (for me anyway), and started wearing a cap under my helmet.Dr_Mutley wrote:No definite blood/metallic taste...
- nescius
Postby nescius » Fri Feb 01, 2013 3:34 pm
- twizzle
Postby twizzle » Fri Feb 01, 2013 3:50 pm
Postby Dr_Mutley » Fri Feb 01, 2013 5:25 pm
Common cardiopulmonary theories range from:
•pulmonary vessel congestion due to substantially increased cardiac outputs and pulmonary pressures, resulting in leakage of blood across the alveolar membrane into the smaller airways
•exercised induced (mild) pulmonary oedema
•high output pulmonary oedema as seen in thoroughbred racehorses
I can reproduce bloody/metallic taste at will on climbs by going deep into the red for long periods (ie just short of that hazy, darkening of vision phase). First thing I notice is a mild exploratory wheeze, and soon after the taste becomes quite apparent. I can also (sometimes) experience a cough post exercise, which also contains the same taste...
Seems it doesn't happen to everyone, but I'm interested to hear there's a few "athletes" on BNA who can associate that taste with high intensity activity...
- sogood
Postby sogood » Fri Feb 01, 2013 5:43 pm
- toolonglegs
Postby toolonglegs » Fri Feb 01, 2013 6:15 pm
- Redbull
Postby Redbull » Fri Feb 01, 2013 6:28 pm
You don't have a nick name like The Cannibal for nothing
Postby Dr_Mutley » Sat Feb 02, 2013 12:20 am
lolsogood wrote:Looks like I have never ridden hard enough...
Postby eveready2 » Sun Feb 03, 2013 8:24 pm
I would agree. I always thought it was to do with lactic acid. It is not very pleasant, but nothing too sinistertoolonglegs wrote:It is the gases let off by the lactic acid boiling after hard efforts.
- Spiza
Postby Spiza » Mon Feb 04, 2013 10:10 am
It also took an unusually long time for my HR to recover and I felt sick and a little light headed for about 15-20min afterwards. I Googled it both times and couldn't find a convincing answer.
Postby warthog1 » Mon Feb 04, 2013 10:37 am
I have never gone that hardDr_Mutley wrote:
I can reproduce bloody/metallic taste at will on climbs by going deep into the red for long periods (ie just short of that hazy, darkening of vision phase). ...
Nice work
- bigfriendlyvegan
Postby bigfriendlyvegan » Mon Feb 04, 2013 11:20 am
Postby gabrielle260 » Mon Feb 04, 2013 12:15 pm
- brentono
Postby brentono » Mon Feb 04, 2013 1:42 pm
especially at high temperatures, especially in the day, when there is less oxygen in the air,
at which point your metabolism is over heating and it's actually a result
of the alveoli in your lungs being overtaxed; in their hurry to transfer CO2
back out of your blood stream, some of the blood cells themselves
are pushed through the alveolar walls,
which you then breathe out as an aerosol and taste on your tongue.
I'm no Doctor, but these were my experiences. Nothing to worry about.
Push harder, push throught it. The difference between winning, and losing.
- toolonglegs
Postby toolonglegs » Mon Feb 04, 2013 7:08 pm
You would agree ...eveready2 wrote:I would agree. I always thought it was to do with lactic acid. It is not very pleasant, but nothing too sinistertoolonglegs wrote:It is the gases let off by the lactic acid boiling after hard efforts.
