Commuting in the Dark
Re: Commuting in the Dark
Postby boss » Thu Feb 28, 2013 12:36 pm
I find it to be adequate for my riding - lots of hills, early in the morning, no streetlights. It lasts a couple of hours on the brightest setting, which is fine - earliest I'm out is 5am and it's light by 6-7am depending on time of year. Flick it onto the flashing mode to save battery after it's light enough to see.
Strictly for commuting I think the suggestion of Ayups or lights that require a separate battery pack may be overkill, both in terms of cost and complications setting up. Plenty of other bright lights that are cheaper and are all-in-one.
But personally I can see the benefit for Ayups or similar if you do riding like what I do - you can never have enough light when you're descending (or even climbing) unlit roads in the dark.
Postby warthog1 » Thu Feb 28, 2013 3:28 pm
MattyK wrote:Will add my 2c on the subject (again): If you ride anywhere near a road, bike path, or people, get a proper (cut off) beam shaped bike light. Anything else (eg round beam / flashlight) is a glaring, dazzling PITA and people will hate you. It's the equivalent of driving around in your car with your high beams on.
Philips
B&M
Supernova
etc
Yep, I am guilty of this too being a magic shine owner.
I have bought a Philips safe ride 80 from bike24 that I think you also have Matty?
Doesn't have the hot spot of the magicshine but has a beautiful broad spread beam that is well controlled and doesn't spray light everywhere. Better to see with and MUCH better for people coming the other way.
- g-boaf
Postby g-boaf » Thu Feb 28, 2013 8:51 pm
Blackburn Flea:kunalraiker wrote:Thanks g-boaf, please update this thread once you get yours.
Second impressions, it is bright for the small size and throws a fairly wide beam of light. But it's not as bright as some others, which are obviously much bigger. You can see it in comparison with the Garmin Edge 800. The button to operate it is annoying - you really have to firmly press it to make it work - and the charger mechanism from USB has a magnetic latching and appears like it might not last, on early impressions.
It is brighter than my old Bontrager Ion2 light however.
- MattyK
Postby MattyK » Thu Feb 28, 2013 9:53 pm
Yes, that's what I have and also what I came from...warthog1 wrote: Yep, I am guilty of this too being a magic shine owner.
Postby vander » Thu Feb 28, 2013 10:17 pm
However if you would rather not die then save a few 100grams, I have this light (well the 2.0 for $80) last year and I would recommend it. Biggest problem is stopping the battery from jumping around.
http://www.this link is broken/BRC-NiteSta ... ront-Light" onclick="window.open(this.href);return false;
If you want to ride safetly and be able to see properly I would recommend something similar it is over your budget and probably over your weight limit but it is worth it and really its not that expensive in the grand scheme of things.
I also have a set of the Flea lights, they are great for well lit places (for being seen) however they are not good enough in not so well lit areas. I have had them for about a year and (after <1month) needed a set replacing as they lost their charge in minutes but c r c just sent me out a new set which havent missed a beat.
Postby Michael A » Thu Feb 28, 2013 10:21 pm
http://www.lezyne.com/en/products/led-l ... rive-front" onclick="window.open(this.href);return false;
Postby kunalraiker » Thu Feb 28, 2013 10:39 pm
Michael A wrote:I just received my lezyne macro drive from Wiggle. 300L. Awesome.
Great to hear, and bl**dy light too, I wonder how this compares to ebay ones with extra battery packs promising over 1000 lumens.
The Lezyne is 300 lumens, any other ones with similar lumens but lower price ?
Postby 98octane » Thu Feb 28, 2013 10:41 pm
And now they make a 1100 lumen version...
http://www.nitelights.com.au/index.php? ... t&Itemid=1" onclick="window.open(this.href);return false;
Highly recommended.
Postby Xenon » Thu Feb 28, 2013 10:45 pm
Because I'm a nerd (in case anyone missed the recumbent reference earlier), I decided to see how 'other road user friendly' I could make my magicshine clone.MattyK wrote:Will add my 2c on the subject (again): If you ride anywhere near a road, bike path, or people, get a proper (cut off) beam shaped bike light. Anything else (eg round beam / flashlight) is a glaring, dazzling PITA and people will hate you. It's the equivalent of driving around in your car with your high beams on.
Start with a reference shot with the wide angle diffuser fitted (the light is about 500mm from the wall)
The spill light just about reaches the power board.
Add a simple cowl over the top (made from a spray can lid)
Definitely better, down to the centre punches.
What happens if I add a little electrical tape over the front?
That's more like it.
So I head outside and hold the light sideways:
There is very little other light out there, 99% of what you see is from the magicshine, nice clean cutoff a little above the hot spot.
Cheap, simple and effective
Postby warthog1 » Thu Feb 28, 2013 10:46 pm
I reckon you gave me some advice in another light thread. Very happy, thanksMattyK wrote: Yes, that's what I have and also what I came from...
Postby Nobody » Fri Mar 01, 2013 12:27 am
http://www.philipsbikelight.com/" onclick="window.open(this.href);return false;warthog1 wrote:I reckon you gave me some advice in another light thread. Very happy, thanksMattyK wrote: Yes, that's what I have and also what I came from...
http://www.bike24.com/1.php?content=8;n ... duct=40657" onclick="window.open(this.href);return false;
Interesting. I might get one of these if I do a lot of night riding in the future.
For daytime being-seen use, I still believe the Ay Up lights would be preferable
as I actually want a non-cutoff light in flashing mode.
Postby warthog1 » Fri Mar 01, 2013 9:11 am
I think the Philips LED bike light is at least as good as any symmetric beam lamp that produces 1000 lumen (real lumen, not marketing lumen), for use on the road.
Conclusion
Best bike lamp I've ever seen. Almost a car headlamp. Better than any motorcycle headlamp I've seen so far. Much more light than an Edelux, much more light on the road than the Magicshine or Ktronik's dynamo powered triple XP-G.
The biggest downside of the light is the run time on high which is only ~ 2hrs. Good thing is that the light is usb rechargeable and being self contained with no ext battery, it is easily removed from the bike. I'll charge it at work if needed. The instructions say it runs for ~8hrs on low and takes ~5hrs to recharge, can't confirm any of that though.
I haven't had to run it on high yet, as it is pretty good on low and I haven't ridden in fully dark conditions. It is better on low than the photos on that test appear to indicate IME. Dont know if that is something to do with night shots on camera and our eyes perceiving light differently , I know next to nothing about photography.
I agree it would be nice to have a flashing mode, but I dont think they allow that in Germany. This light is built to comply with German laws I believe. Just run it on low during the day, but not as visible as a symetric beamed flashing light, true.
The price on bike24 includes VAT which we dont pay. It cost me ~ 92 Euro. Allow 3-4 weeks for it to arrive.
Postby kunalraiker » Fri Mar 01, 2013 9:16 am
Postby warthog1 » Fri Mar 01, 2013 9:24 am
-Our weekly grocery bill is 2-3 times that
-My car costs more to fill the tank than that.
-It's 2-3 quality bicycle tyres (GP4000s,Durano), and they wear out.
Postby Nobody » Fri Mar 01, 2013 10:31 am
Agree. To me, the main things that matter on the road/paths is how visible you are, how well you can see and how fast you can stop. Aero, weight and bling means nothing if you're invisible, miss seeing something important, or can't brake fast enough.vander wrote:I will start by saying a weight limit is ridiculous you are commuting not racing what does an extra few hundred grams mean........
However if you would rather not die then save a few 100grams...
- MattyK
Postby MattyK » Fri Mar 01, 2013 10:56 am
There is little in that prices range that has a beam cutoff.
It has very solid construction (downside = heavy). No cables/plugs to damage.
It uses its lumens very efficiently. It's a genuine (tested, proven, not theoretical) 270 lm output. Magicshines etc are in reality about 500-600, not 900-1000, and much of that is wasted by shining up where you don't need it. (I'll grant that offroad conditions are excepted, you want to see overhead branches and you aren't often on level ground.)
It doesn't blow out the foreground illumination. Making the foreground brighter makes a light appear brighter but it reduces the relative intensity of distant illumination making it harder for you to observe things at a distance.
The front lens has a "shape" which means it can be perceived with size and distance, which helps observers judge your position and movement better than an intense point source.
The run time is timer limited, but the LED readout gives you great confidence in your remaining run time; you never fear that the battery will suddenly empty, because it is timer based not voltage based. And once you go past 90 minutes (120 on the 2013 model) it goes into low power mode for another 2? hours.
When charging the LEDs on top track the charging progress (progressively "filling up" in a pulsing pattern) so you can estimate how much charging time is remaining. The LEDs will also blink if there is a charging problem. (none of this is documented in the manual)
It has an illuminated outer ring that can be seen from all angles (even behind)
It has a simple quick release clamp.
Despite the cutoff beam there is still more than adequate spilled light to be seen from all angles. It's just that this spill light isn't blinding. So don't fear that you won't be seen (you can see cars with headlights on low beam can't you?)
Postby kunalraiker » Fri Mar 01, 2013 10:57 am
http://api.viglink.com/api/click?format ... 0959353724" onclick="window.open(this.href);return false;
- MattyK
Postby MattyK » Fri Mar 01, 2013 12:52 pm
Seriously though, that's not a meaningful question, it can't be given a straight answer. Firstly you have to appreciate that most makers (Chinese cheapies are the worst) are regularly guilty of inaccurately speccing their lumen outputs. They take the spec sheet for the emitter they use, take the number at the top of the bin range, and quote that. In the real world, the LED will likely be lower in the bin, and it will never be driven at the theoretical conditions (particularly junction temperature) that will achieve that output. Then it emits through an optics system that will further reduce the intensity. Few of these guys would use an integrating sphere to properly determine output.
And that only describes the total output, not what you do with it. If you scatter it with poor or no optics then the intensity that falls where you want it will be low, and many of the lumens will be wasted.
That's not beginning to touch on other issues such as colour rendering, or glare, or human perception issues.
Anyway, to get you back in the ballpark, I'd typically say for road and unlit bike path use that 200-300 (real) lumens, directed through efficient optics, would be adequate. More may be better, but not if it encroaches on other users.
- InTheWoods
Postby InTheWoods » Fri Mar 01, 2013 2:03 pm
I survived on about 180 real lumens for a while, but was much happier when I upgraded to about 400 real lumens. One thing is, if you are commuting at night in the rain, the lumens disappear and you want double or triple!MattyK wrote:Anyway, to get you back in the ballpark, I'd typically say for road and unlit bike path use that 200-300 (real) lumens, directed through efficient optics, would be adequate. More may be better, but not if it encroaches on other users.
I agree some of the lumen claims are ridiculous. Aside from what you said, some manufacturers don't even pick the top theoretical output of the led, they will pick a number even way higher than that - I've seen single XM-L lights advertised as 1600 lumens!
As a general guide, a Cree XM-L T6 will do 910 lumens *max* - if the junction temp is 25 degrees celcius. Once you put in a more realistic, say, 120 degrees, you get 720 lumens. Then you will lose maybe 10% from the reflector and glass.
An XM-L2 T6 bin has the same ratings, however they are rated at a junction temp of 85 degrees. At 120 degrees they are only reduced to 820 lumens, so the XM-L2 T6 will have higher output than a XM-L T6.
An XM-L2 U2 bin will be ~880 lumens at 120 degrees celcius.
Edit: The junction temperature will depend on the design and build quality of the heatsinking and thermal paths in the light, and obviously ambient temperature and airflow.
Postby kunalraiker » Mon Mar 18, 2013 11:08 am
Postby gabrielle260 » Mon Mar 18, 2013 12:14 pm
- MattyP
Postby MattyP » Mon Mar 18, 2013 2:45 pm
I ride Altona Meadows to Melb cbd & back. These lights at low beam are adequate for my commuting which involves riding before/after dawn/sunset. My commute is 30% bike path. I also use them for road rides in the dark & high beam is extraordinarily bright when needed.
The flashing mode is so fast it's fit-inducing, and I rarely use it. I use these lights to see, rather than be seen.
Only issue I have with the new lights is the cords on the light & battery are very long & have to be bunched up, somewhere. Still working on best set up.
Matt
Postby kunalraiker » Mon Mar 18, 2013 3:21 pm
Matt, What does it weigh?MattyP wrote:Bought one of these ebay Cree lights a few weeks ago, to replace a Nitelights series II set I bought in 2010. Have used them a few times over the last couple of fews & they've been a ideal replacement. Haven't used them in the wet, though the ebay ad claims '100% waterproof design'.
Matt
ebay says 118 grams which I highly doubt.
Postby drnick79 » Mon Mar 18, 2013 5:01 pm
S
Giant TCR Advanced SL0
Jamis Dakota D29 Pro
Users browsing this forum: OnTrackZeD, TrikeTragic
