Freeway Bike Hike - Sun 24 March 2013
Re: Freeway Bike Hike - Sun 24 March 2013
Postby donkuok » Mon Mar 25, 2013 4:22 pm
- ColinOldnCranky
Postby ColinOldnCranky » Mon Mar 25, 2013 5:05 pm
On hearsay this seems to be an issue every year.donkuok wrote:I think a lot of fast riders do not have experience riding in a group, also bad attitude. What they want is to beat their PR in Strava to compete with others. Worse still, the organiser was very inorganised. This is an epic failed event. I will not participate next year.
Were there any restrictions set on who could be in the lead of groups at the 30km and 70km rides? Or who could join packs in any way? Any guidance or restrictions at all?
I understood that in a previous year they did introduce some form of restricting the opportunuty for flat bars to mix with drops in groups for example.
I never noticed any group pile ups btw. Those I saw down were singles and could have been exhaustion for I could see. And no ambo attendances.
- kx315
Postby kx315 » Mon Mar 25, 2013 6:07 pm
The organisation at the start was pretty lackluster as the PA system had failed up until 5 mins before the start so it was a little unorganized (Jetz Fitness seemed the most organized water bottles everywhere!). There was definitely no restrictions as to what group you could join and there was some interesting combinations in the fast group to say the least including one small child that I saw.
Would I run the event again.....yes I would.
- Tornado
Postby Tornado » Mon Mar 25, 2013 6:10 pm
I think for next year as part of the receipt or other correspondence they could mention some riding tips eg. Keeping left where possible so quicker people can overtake. Releasing the groups in a better fashion will probably help a lot too. I don't think the ride was too bad, just a chain of events led to a less desirable outcome.
Postby Timbuctoo » Mon Mar 25, 2013 6:29 pm
- IncognitoMosquito
Postby IncognitoMosquito » Mon Mar 25, 2013 6:34 pm
I have written to the organisers and my concerns have been added to their discussion points for the next event. Once we understand that there are only 4 people employed by Bikeswest it is easy to see why there are so many failings in this event - not that that makes them acceptable.
My email went along the lines of the below - edited only to remove my details and those of the group I was with:
Hello,
I have just taken part in the 2013 Bike Hike and whilst I love the concept, it proved to be the single most dangerous thing I have ever done on a bike. I understand that it is not a race, but many riders are competitive animals and most of us who are serious like to ride at high speed when possible which obviously has hazards in itself.
A few of my thoughts and observations follow:
- From a pre event planning point of view I recommend that some details (which train station you might use is all that is required) should be collected at time of entry for those electing to use public transport for the event. This might make planning the number of trains/carriages better and enable a smoother start.
Secondly, the holding areas for riders at the start point need to be made larger. This should surely have been known prior to the event. It was not helped by a small number of cars parked in the holding bays. There are three parking areas at the station. Surely more than just the most southerly section could be used.
Allocation of riders to the different speed groups needs some greater consideration. There are many ways for riders to prove their ability and enable some sort of seeding to be implemented.
Closure of the roads needs to be effected promptly. The delayed start from Mandurah had significant consequences which could have proven disastrous.
Pre-event education of slower riders keeping left needs to be enhanced. This won’t be such an issue if riders are seeded and started in a more orderly fashion.
A large number of slow group riders by-passed the start arch exiting from the back of the holding bays to be in front of the fast riders
Riders should probably be released in waves of 100-200 at any one time with gaps between, particularly with the fast groups
If there is a delay starting the Mandurah riders, or any of the other start points then the subsequent shorter rides should be held for an equal length of time. The delayed Mandurah start meant that fast riders arrived at Bull Creek after families had been released. To mix 40+ kph road riders with youngsters weaving all over the freeway resulted in chaos and a lot of ill feeling between both groups. I am amazed that I didn’t see any spills at this point.
The Mount Henry Bridge expansion joint should be covered in some way. Probably a strip of insertion rubber (about 1.5mm thick) could be laid across this hazard for the event. With most of the road bikes running 19-23mm tyres this hazard came up as a big surprise to many.
There was a very dangerous narrowing of the road on the final leg from the Narrows down to the finish line. Due to the works in the area there was a fence blocking off the right hand shoulder of the freeway on ramp (being used as an off ramp here obviously). The fence came out at right angles to the bike riders and there was no warning of it being there. This may not be present next year as the works in the area change, but it highlights the importance of a pre-event risk assessment and implementation of control measures.
The area beyond the finish line was overly congested, perhaps due to the delayed start and concurrent arrival of many groups. Trying to turn every rider up Victoria Avenue clearly did not work and I feel that if the riders were taken down Riverside Drive and then into Langley Park via Plain Street there would be a lot more room for all players.
The water stations were not clearly visible. With most riders travelling at over 30kph we need some forewarning of upcoming water stops so that riders can make their way to the appropriate side of the road if they require a drink. This led to some radical manoeuvres as riders came across the pack with little warning. Personally, I would simply scrap the water stations and make all riders become self-sufficient which isn’t all that hard for a 2 hour ride. One less thing to organise which frees volunteers for other tasks and one less hazard can only be a good thing.
The number of toilets at Mandurah was woefully inadequate. The number of riders stopping for a relief break in the first 15kms was a hazard in itself which could easily have been avoided.
The organisers responded promptly and appear genuine about fixing the problems.
At the risk of being rude, if you have anything to add to that list then i suggest that you should get in touch with the people who can try to fix them for you rather than just posting here. email address that you can use is as follows: Jana.Zivadinovic(insert at symbol here)transport.wa.gov.au
Postby wellington_street » Mon Mar 25, 2013 6:47 pm
Postby RoFlmaTiC » Mon Mar 25, 2013 8:12 pm
We did our best to keep single file and spent most of our time on the RHS emergency lane. We formed a decent group which was working well together, signalling etc and so there weren't any hairy moments. We slowed down at the section where all the kids were - some others behind us were weaving through them which wasn't great.
I got the whole ride on my gopro: http://www.youtube.com/watch?v=HALMZln8hFE" onclick="window.open(this.href);return false;
It does look like there's a little bit of weaving (particularly at the start) but when the video is replayed at normal speeds it's really not that bad.
- ColinOldnCranky
Postby ColinOldnCranky » Mon Mar 25, 2013 9:41 pm
Dan I founda pic of you at http://www.heraldsun.com.au/news/galler ... 97?page=12inline_online wrote:Had another great skate this year from Currambine. Smashed last years time by 15min so very happy.
There was plenty of space on the Currambine Hike and I saw no accidents or trouble at all.
Got my photo in Perth Now also...http://www.perthnow.com.au/news/western ... 97?page=12" onclick="window.open(this.href);return false;
I had a couple of guys on carbon racing bikes stay with me for a bit to offer moral support when my legs started to give way. Thanks guys, much appreciated.
Colin, I missed you at the finish. Not sure what time you got in but I left at about 1020hrs or so.
Hope you had a pleasant ride.
I got in at about 10:10. I got a slow start as I had a less experienced unicyclist to hold back with until he looked like he was comfortable. I was keeping an eye out for you.
Postby Bakks » Mon Mar 25, 2013 10:58 pm
I was at / close to the front of the group you joined at 6:34 (that's me going past at 8:02 - I was thinking the same thing as you). A small group of us managed to catch up to the bigger group who then tried to jump on board. By that stage there were too many people around so the pace eased off a bit. Still managed to average 44 km/h and do it in an hour and a half which I was happy with given I rode down from the city before hand.RoFlmaTiC wrote:I was one of the faster riders, me and a friend of mine completed the full hike in around an hour and a half.
Postby RoFlmaTiC » Mon Mar 25, 2013 11:19 pm
I was wondering whether anyone from BNA would feature in the video! You flew past!Bakks wrote:I was at / close to the front of the group you joined at 6:34 (that's me going past at 8:02 - I was thinking the same thing as you). A small group of us managed to catch up to the bigger group who then tried to jump on board. By that stage there were too many people around so the pace eased off a bit. Still managed to average 44 km/h and do it in an hour and a half which I was happy with given I rode down from the city before hand.RoFlmaTiC wrote:I was one of the faster riders, me and a friend of mine completed the full hike in around an hour and a half.
- Aushiker
Postby Aushiker » Tue Mar 26, 2013 1:29 am
which links through to Facebook where they have posted ...Hi guys, we recognise there were a few issues yesterday, we have identified the causes and take everyone’s...
Hi guys, we recognise there were a few issues yesterday, we have identified the causes and take everyone’s feedback very seriously. With incredible growth comes a new set of challenges which we intend to meet head on in 2014.
The Freeway Bike Hike is a community event for cyclists and riders of all abilities, ages and experiences. Above all it is a fundraising event for the Asthma Foundation of WA. This year was the most successful year ever, with over 10,000 riders who helped raise over $190,000 through fundraising; which in addition to event proceeds will go to fund vital research into Asthma.
Postby just4tehhalibut » Tue Mar 26, 2013 11:52 am
Postby Shifter » Tue Mar 26, 2013 1:48 pm
Also, does anyone know a way to see all the event day photos?
Postby MyNameIsNoone » Tue Mar 26, 2013 2:37 pm
- BrownBike
- Location: Perth - Looking for a north-south route across the CBD
Postby BrownBike » Tue Mar 26, 2013 2:42 pm
I think that if people set out to race this event, or even go as fast as they can, it can only be a recipe for disappointment and danger. Perhaps next time the organisers can institute a 'race category', a bit like the City to Surf - but logistics (and entry fee) would require it to be much more expensive I guess. Anyway, had fun and keen to do it again.
Postby mnh86 » Tue Mar 26, 2013 2:57 pm
http://www.marathon-photos.com/scripts/ ... ike%20Hike" onclick="window.open(this.href);return false;
Postby Shifter » Tue Mar 26, 2013 3:19 pm
Postby mnh86 » Tue Mar 26, 2013 3:27 pm
If there is no photo found, you can click on find more photo's to see all of them and try to locate yourself that way. You can search by colour of clothing, bike etc.Shifter wrote:Yes they can. But you need to put in a bib number / name and for me and the missus nothing comes up. Hence I'd like to see 'all' of the photos.
I can't find myself on there either.
Postby eldavo » Tue Mar 26, 2013 3:39 pm
I haven't been in the previous years (or some similar version?) but considered it and paid attention to the self seeded speed brackets for groups A 40kph+/B 35-40kph/C 30-35kph and D rest of release etc.BrownBike wrote:I think that if people set out to race this event, or even go as fast as they can, it can only be a recipe for disappointment and danger. Perhaps next time the organisers can institute a 'race category', a bit like the City to Surf - but logistics (and entry fee) would require it to be much more expensive I guess. Anyway, had fun and keen to do it again.
Sounds like new organisers have lost experience of the past, and suffered additional major error of the Mandurah delay.
Fast riders riding fast ahead of slower riders isn't a problem, the average speeds people have done in groups are impressive (as a non-competitive commuter myself), and as said is a highlight attraction of having the freeway glimpse of the new world order where cars are parked at stations and bikes rule the earth =D Respect for athletes would be nice like fun-runs to get pro-am time triallers as the headline on back of Cadel Evans, Green Edge etc. to raise the charity profile.
People can ride fast responsibly, so we shouldn't tar them all with the same brush that mindless "speed kills" propaganda.
I'd rather support the "cater to all" attitude they're still carrying than close the door to settle for "too hard lowest common denominator".
Postby House85 » Tue Mar 26, 2013 3:47 pm
I dont think you are ever going to be able to stop people from going down in a pack. No one knows how to ride in a pack and one false move can send over 10+ riders. I didnt agree with the idea of letting the slow riders and children mix with the full hike participants. This was a recipe for disaster and a road bike going at 40km/hr hitting a child would of killed them!
This problem can be solved - i dont believe they should operate a mid-hike or mini-hike on the same side of perth as the full hike. The full hike should start in mandurah and the mini and mid should start north of the river. It could then be alternated each year. The delayed start times stuffed it up this year but i still dont believe it to be safe to mix road cyclists going 30+km/h with children. Especially when the children are entering the freeway on the right and have to merge to the left.
RAC are meant to be all about road safety and this event was not a safe as it could be.
Postby MyNameIsNoone » Tue Mar 26, 2013 3:50 pm
Corp Sports run the city to surf events too - same guys. I know adding a race category has a significant impact on the logistics particularly as it starts to change the insurance proposition.eldavo wrote:I haven't been in the previous years (or some similar version?) but considered it and paid attention to the self seeded speed brackets for groups A 40kph+/B 35-40kph/C 30-35kph and D rest of release etc.BrownBike wrote:I think that if people set out to race this event, or even go as fast as they can, it can only be a recipe for disappointment and danger. Perhaps next time the organisers can institute a 'race category', a bit like the City to Surf - but logistics (and entry fee) would require it to be much more expensive I guess. Anyway, had fun and keen to do it again.
House - RAC didn't organise it. They are just sponsors and would have very little to do with the logistics of it, neither would chan 9, 6 PR, Baker's delight etc.
I agree the delayed start at Mandurah caused some real issues. Especially when the PA was hurrying people out of all groups all exits as soon as the quicks got a green light. Not sure there's really room to point the finger at the sponsors though.
Postby bjohnson » Tue Mar 26, 2013 6:16 pm
They had self seeded start groups, I entered in wave 1A so should have been in the first group out after the seeded runners.
Everyone assembled in their groups in the convention centre and were supposed to be called out in order up to the start line, No call came and I noticed about 20,000 people rushing for the doors. I joined the horde and ended up starting about 5-600m from the start line next the a few walkers and some kids on razor scooters. It was the same for everyone and led to a lot of clashing between faster people interested in setting times and people who probably stopped for coffee on the way.
It was so bad that I don't plan on entering it again this year.
Postby eldavo » Tue Mar 26, 2013 7:26 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
