Advise on 1st time going up MT Gravatt Hill
Postby auswi2 » Sat Mar 30, 2013 10:41 am
I am looking to improve my endurance and speed so tomorrow morning I will do the MT Gravatt Hill climb.
Hills are not my strong point so this is what I need to work on.
How many repeats should I be trying to do to help improve my cycling??
Should I be using my granny gear on my Merida Road Bike to get up the hill or trying to use a harder gear.
I generally use water only when riding. Would that be ok for the ride tomorrow.
Any advise would be great
Auswi2
- brett.hooker
Re: Advise on 1st time going up MT Gravatt Hill
Postby brett.hooker » Sat Mar 30, 2013 12:23 pm
Feel free to do as many repeats as your body will let you. Don't bust a muscle though; you want to be able to go back tomorrow.
Definitely use the granny gear... Better to err on the side if higher cadence than higher power. Grinding a low gear will just wear you out and not allow you to increase your hill climbing fitness.
Ps yay for the Merida!!! I changed the 11-25 that came on my Merida for a 12-27 to help with keeping my cadence up on climbing... Mt coottha and mt nebo are my local climbs, and that one little change helped a lot for me... Now I am starting to get some sort of fitness on the climbs I can choose to use the 27 or the 24 depending on the gradient and my heart rate...
Postby thearthurdog » Sat Mar 30, 2013 12:28 pm
Postby mjd » Sat Mar 30, 2013 12:31 pm
Postby Crawf » Sat Mar 30, 2013 1:10 pm
Dont be pressured to go fast by cars or to catch anyone, just sit and spin, when you come around the bend at the end and see the restaurant 'give it' some to finish off strong. Roll down for recovery. Then rinse and repeat.
You could then hit Coottha 'front' and the harder 'back'.
Postby marinmomma » Sat Mar 30, 2013 2:23 pm
The first half is def the steeper bit then it flattens out a bit so you can recover before you get to the last 300-400 meters then it kicks up again as you go around the last corner and past the cafe.
Work towards being able to do a few repeats then Coottha will start calling! Front way is easier then go the back...then there's Nebo, mt Mee, Springbrook...and before you know it the 3 peaks challenge will start calling your name
Edited to say that hills are not my strong point either and probably never will be however working on them certainly helps to improve your riding, well, that my experience anyways...I manage to get up them so I can enjoy riding back down.
Postby auswi2 » Sat Mar 30, 2013 3:01 pm
I have been riding off and on for a bout 2 years but only recently got into cycling a lot more.
I am trying to lose weight as I weigh 102kg at 5ft 11.
I doing martial arts during the week and cycling on weekends and during the week where i can fit it in.
To give you an idea of where i am at with my current fitness and training I done a 50km ride yesterday morning and it took me 2 hours and 2 mins and my average was 24.4kph
I do want to learn more about eating while out on a ride but I am not a fan of the energy gels or bars so may go with banana's etc
thanks
auswi2
Postby mjd » Sat Mar 30, 2013 4:37 pm
As for improving your riding just ride as often as you can for as long as you can. Build some endurance & then focus on other stuff.
- jacob_T
Postby jacob_T » Sun Mar 31, 2013 12:05 am
Don't stress too much about it. Just get out and try it.auswi2 wrote:Thanks for your advise.
thanks
auswi2
I wouldn't worry about gels or powerade etc. Take a banana or two and make sure you drink lots of water.
Also, make sure you take some time out at the top to have a look around, soak up the view, and remind yourself you got there with your own legs - it's a really great feeling.
Let us know how you go.
- foo on patrol
Postby foo on patrol » Sun Mar 31, 2013 6:51 am
You don't want to be running out of puff half way up the climb, so go steady for your first couple of runs until, you have figured out how you can attack it and go from there. Don't do consecutive days of hurt, you need to allow time for your muscles to repair themselves after the day of hurt.
Once you have figured out the your ability you will be able to start to lift the intensity of the climb from different points up the hill.
Foo
Postby auswi2 » Sun Mar 31, 2013 10:01 am
Am back from my 1st time going up Mt Gravatt hill. It will not be my last time great ride.
I only ended up doing it 2.5 times did not have the legs to do 3. (I know slack effort, At least it is a start. I put the bike in the easiest gear 28 and tried to stay relax all the way up whilst sitting down except for a small portion I got out of the seat.
I got up there the 1st time in 12 minutes and 13 minutes for the 2nd time. I had a good feeling when I saw the 200 metre mark before the top of the hill
The view is fantastic from the top. going down hill can be super quick if I was not braking most of the way down. I must admit that I did not push myself to my limit s for the 1st time
Thanks for all the advise. My next goal is to go up and down the hill 4 times
auswi2
Postby fluro2au » Sun Mar 31, 2013 10:52 am
For now just stick with 3 repeats MAX, until you start seeing some quicker times.
I usually on stick with 3 repeats and my current PB is 5:31
A way of improving your time up there will be to do things like this
Session 1
40sec seated, 20sec HARD (in the same gear, but really get the cadence UP), repeat this cycle
Session 2
3 x (500m hard, 1km tempo, 500m hard)
Session 3
3 x 30sec hard, 30sec tempo,repeat this cycle)
Session 4
1 x Just do 1 repeat (AT) MAX effort (test)
Session 5
1km hard, 1km tempo
1km tempo, 1km hard
500m tempo, 1km hard, 500m tempo
Session 6
1x (50sec tempo, 10 second BG out of the saddle sprint sprint)
There you go, that is 6 weeks of sessions, which is basically what I do.
Hope it helps
Paul
Postby macca33 » Sun Mar 31, 2013 11:10 am
Interestingly, I did 50Km yesterday, which had 1100m of climbing and was tough (for me!), but, this morning - in abhorrent conditions - I went out and took 21 seconds off my PB on the 2Km Bona Vista climb down here - and had a smidgen more left in the tank, so will crack 5:00min the next time!
cheers.
- Derny Driver
Postby Derny Driver » Mon Apr 01, 2013 5:02 pm
- Nikolai
Postby Nikolai » Mon Apr 01, 2013 7:17 pm
What's so special about this cadence? Or the gear ratios you recommend?Derny Driver wrote:Stay seated and count your cadence occasionally to make sure it is 60.
Postby thearthurdog » Mon Apr 01, 2013 7:37 pm
- Derny Driver
Postby Derny Driver » Mon Apr 01, 2013 8:58 pm
The gearing needs to get harder each week in order to overload and improve strength. 60 is the optimal cadence for strength building but not neecessarily the fsstest way up the hill. But this is a training thread. And the question was about building endurance using a hill.
Postby clydesmcdale » Tue Apr 02, 2013 11:14 am
Mt Gravatt is my local. I ride past it every day on my commute. Live about 500m from the entry to the base and can see it from the back deck at home.
At first it was a challenge for a fat bloke like me, but as I got stronger and lighter it's become easier with repitition.
Personally, I break it down into segments of 500m or so.
First 500m I like to get out of the saddle and grind up to get the heart pumping. It's the most difficult part anyway and nice to get it over with.
Second 500m I just set myself into a rythm and spin away nicely
Third 500m is a bit of a break and if in the mood i'll pick up the speed or have a rest (can even freewheel a bit near the tanks)
Last 500m lay some more power down in a tougher gear staying in the saddle to get myelf up to the summit knowing I can soon have a break.
I always also do a few laps of the roundabout at the top just to rest the heartrate and take in the view. The descent is much more enjoyable when you're not sucking in deep breaths and suffering.
Definitley giving this a go too. All makes sense to me and I think the hill suits it.fluro2au wrote: Session 1
Session 2
Session 3
Session 4
Session 5
1km hard, 1km tempo
1km tempo, 1km hard
Session 6
Postby marinmomma » Tue Apr 02, 2013 8:05 pm
Congratulations, well done! Repeats on your first run! Awesome.auswi2 wrote:Hi fellow riders.
auswi2
Postby master6 » Thu Apr 04, 2013 7:29 pm
What kind of expertise do I have? Stuff all. I have been racing for 56 years, and finished the Grafton to Inverell 7 times. Nothing special. I am an average mug.
Now you can decide whether my advice is worth considering.
My advice is:-
You are overweight, and need to remedy this before worrying about hill climbing. Climb a hill if it appears in front of you, but dont go out seeking hills.
Just ride, increasing your distances and weekly totals slowly. When you get down to 80kg, and 300km per week, get your slim self into deliberate hill climbing, seeking them out as you are now.
Get the crawling perfected before you launch into walking.
No rush.
- brett.hooker
Postby brett.hooker » Thu Apr 04, 2013 7:41 pm
- Derny Driver
Postby Derny Driver » Fri Apr 05, 2013 11:00 am
Good advice master 6 but people like you are in a minority on this forum. It seems to me that most people on here are just recreational bike riders who love riding their bikes. Your plan will turn them into a competent cyclist, possibly a racing cyclist, Im not sure the OP wants that. His personal challenge is to climb a hill. I doubt he will take your advice or mine for that matter. But its good to put it out there.master6 wrote:Auswi2, who are the people giving advice here? Have they been 102kg at 5'11"? Some probably know what they are talking about. Some possibly dont.
My advice is:-
No rush.
I can vouch for fluro, I know him personally and he is an excellent coach. He is great with the powermeter stuff which I know little about. I come from a fairly famous cycling family, my dad and his brothers rode dozens of Graftons. Whe I was a kid I remember hanging out with my dads mate Jack Griffin. http://nsw.cycling.org.au/?Page=49832" onclick="window.open(this.href);return false; My uncle, like Jack also received an OAm for services to Australian cycling.
My achievements do not equal those of my dad and his brothers but I am respected by the guys I train and thats all I care about. Im happy to share anything I have learned and I dont care if people agree with me or not.
My son is following the family tradition and looking to ride all the big Australian races. Last year he was granted special permission to ride the Goulburn to Sydney and was one of the youngest riders ever to compete in the great race. He has his eyes set on the Warrnambool and the Grafton which he plans to do next year. If you ride an 8th one maybe we will see you there.
Postby Walsh95 » Thu Apr 11, 2013 10:21 pm
Postby Venus62 » Fri Apr 12, 2013 7:50 pm
2 km almost exactly.Walsh95 wrote:Woah, how long is gravatt, I did it when I was in Bne over the hols, but it didn't seem that long
Postby BrisVegas » Sat Apr 13, 2013 10:06 am
Not my thread, but I am taking note of your advice. Cheers!master6 wrote:Auswi2, who are the people giving advice here? Have they been 102kg at 5'11"? Some probably know what they are talking about. Some possibly dont.
My advice is:-
No rush.
I'm 98kgs and 6'2" (down about 20kgs from my max). My goal is to get into the 80's, not just to look better, but being overweight is not something I want to be as I approach 40yo.. Whilst I have climbed Cootha and Nebo a few times, I think I get more benefit out of "normal" riding to get general fitness and miles in my legs. I'm focussing on my diet to get the weight off, as I'm starting to see how much easier cycling is when you're lighter.
