Hi guys ...
So I've just received a new set wheels with DT Swiss 240 hubs, and the freehub is actually an 11 speed unit with an adapter/spacer to make it compatible with 10 speed cassettes. [Apparently this is now the norm with new DT Swiss hubs ... or so the Internet tells me anyway]
Normally with a Shimano cassette you'd install the "low spacer" first, then the first sproket set, and just continue on from there.
EG - http://www.shimano.com/media/techdocs/c ... 799947.pdf" onclick="window.open(this.href);return false;
The difficulty I'm having at the moment is that I'm not sure where this extra [DT Swiss] spacer is supposed to fit into the mix?
I'm assuming that you'd still use the regular Shimano spacer, but do I install the DT Swiss spacer first, then the regular Shimano one, or is it the other way around? Does it even make any difference?
There is a pattern cut into the top of the DT Swiss spacer, which makes me think that there is a specific order that it should be installed, but I just can't seem to find any information online to confirm one way or the other ...
Does anybody have any thoughts?
11 speed DT Swiss Hub + 10 speed spacer installation?
- DavidTomic
Postby DavidTomic » Tue Apr 09, 2013 5:27 pm
- biker jk
Re: 11 speed DT Swiss Hub + 10 speed spacer installation?
Postby biker jk » Tue Apr 09, 2013 6:43 pm
The extra cog for 11-speed means the freehub is 1.85mm longer so I would imagine you would need the standard spacer (for 10-speed) plus the 1.85mm spacer and the order shouldn't matter. This is based on using a Shimano 10-speed cassette on a Shimano 11-speed freehub. For other cassettes see the table in the article below.
http://www.slowtwitch.com/Tech/Cassette ... _3257.html
- jacks1071
Postby jacks1071 » Tue Apr 09, 2013 9:32 pm
Install both spacers before the cassette, the DT Swiss spacer and the spacer that comes with the cassette for running 10sp.
If running 9sp only use DT Swiss spacer.
If running 11sp, don't use any spacers.
Our Website is: http://www.kotavelo.com.au" onclick="window.open(this.href);return false; Find us on Facebook by searching for "Kotavelo"
Postby Arlberg » Tue Oct 14, 2014 7:28 am
Hello Jacks1071, Is it the same with the Pro Lite Bracciano wheels with the 11 speed freehub? Do I need to use the spacer that came with the wheels as well as the spacer that comes supplied with an Ultegra 10 speed cassette, ie both spacers? Which one do I mount onto the freehub first?
How wide is the spacer that comes with the Bracciano wheels?
- jacks1071
Postby jacks1071 » Wed Oct 15, 2014 12:57 am
Thanks for your question.Arlberg wrote:Hello Jacks1071, Is it the same with the Pro Lite Bracciano wheels with the 11 speed freehub? Do I need to use the spacer that came with the wheels as well as the spacer that comes supplied with an Ultegra 10 speed cassette, ie both spacers? Which one do I mount onto the freehub first?
Please use BOTH spacers, the order doesn't matter.
The spacer supplied from Pro-Lite to change 11sp freehub into 10sp freehub is 1.8mm wide.
Postby Arlberg » Wed Oct 15, 2014 6:11 am
Thanks jacks1071. Explains why my rear deraileur shifting has been playing up for the last 5 weeks despite many attempted adjustments. You may want to clarify/explain this more clearly on your website.......
- All times are UTC+11:00
