buckled rear wheel need help noob
Postby ezydeek » Mon May 06, 2013 10:46 pm
the tyre kept rubbing up against the sks mudguards so my first attempt to true the wheel seemed alright cause it stopped rubbing.
and a few days later it, the rear tyre started to rub again, tried to true it again but this made it twice as bad.
So i took it to my LBS, at first they said they would true the wheel but cause of the dent in the rim, he told me that it be better off buying a whole new so i wanted to check with you guys if it was BS or not...
so here's another dilemma my bike is a boardman hybrid team and the wheels are ritchey pro disc OCR with formula disc hubs
it would be cheaper to just buy a 700cc rim to replace but i dont have the tools to that
and i cant seem to find a rear wheel in 700cc rim with a mtb hub that can take a disc on wiggle or c r c. do i need to get a custom build wheel? any ideas?
any advice much appreciated
- Mulger bill
Re: buckled rear wheel need help noob
Postby Mulger bill » Tue May 07, 2013 9:38 am
If you can find a similar Ritchey rim then replacement is simple.
If you can't then the options are a different new rim and correct spokes built onto your existing hub or a new wheel.
Try searching for 29er wheel but make sure the width of the rim works with your frame and tyres.
- Saturnstarzz
Postby Saturnstarzz » Tue May 07, 2013 9:48 am
If the hub and spokes are fine I'd just source a rim and relace it. Id'd even send the pics to ritchey and see what they say. If they were 26" T7 has them as a set.
http://www.torpedo7.com.au/products/RTW ... lset-qr-qr" onclick="window.open(this.href);return false;
Postby ironhanglider » Tue May 07, 2013 10:11 am
Your description of making it twice as bad makes me wonder if you got your tighten/loosen directions mixed up (easy mistake to make)
If you can track down a similar rim (width, depth and with eyelets, brand is less important) then it is easy to walk the spokes across from one rim to the other.
The problem is that if the effective rim diameter (ERD) is too different you will need to get spokes of a different length. (Not forgetting that you already have spokes of two different lengths in that wheel) The real problem is that people use different ways to calculate the ERD so you can't get a reliable answer as to what the ERD of the wheel you have is v the ERD of the rim you want to get. This is why it is easier to use another rim of the same make/model, if it can be obtained separately. If you take two spokes out which are opposite to each other you can measure the ERD yourself (and then run the numbers through a spoke calculator to check their version). Some of them even have a list of rims and their ERDs plugged in so you might be able to figure it out that way.
If you can't find rims of the same depth with eyelets you would have to make do with slightly shallower rims without eyelets because they make a 2-3mm difference in ERD.
If that sounds all too hard you can just buy a new wheel which is easier and you can keep your existing one for spares or give/sell it to someone who can be bothered with the hassle.
Talk to Deon about something like these. http://www.pro-liteoz.com/store/index.p ... oductId=95.
Cameron
- queequeg
Postby queequeg » Tue May 07, 2013 2:53 pm
- find_bruce
- Moderator
Postby find_bruce » Tue May 07, 2013 3:31 pm
- windmill
- clothes line
- ceiling light
- sculpture or this or this
- clock
- mirror
- bar stool
- chair
- coffee table
- lazy susan
- or even a zoetrope
- jacks1071
Postby jacks1071 » Tue May 07, 2013 9:14 pm
Thanks Cam, the Lucca will be in stock this Friday - can ship them on Monday if anyone is interested.ironhanglider wrote:
Cameron
- Saturnstarzz
Postby Saturnstarzz » Wed May 08, 2013 7:12 pm
you forgot hula hoop http://www.hooping.org/2013/01/bikes-and-hula-hoops/" onclick="window.open(this.href);return false;find_bruce wrote:You guys are all a bit harsh, that rim has plenty of life left in that wheel. You could make aAbout the only thing I wouldn't do with it is fit it to a bike and ride it
- windmill
- clothes line
- ceiling light
- clock
- mirror
- bar stool
- chair
- coffee table
- lazy susan
Postby Mozzar » Thu May 09, 2013 12:33 pm
- biker jk
Postby biker jk » Thu May 09, 2013 3:29 pm
What method would that be and which bike shop has the tools to do it?Mozzar wrote:There is a way of fiking that wheel but would need specific tools that not all bike shops would have. most shops would recomend getting a new rim or wheel as they would have no idea of how to fix it.
Postby mick243 » Thu May 09, 2013 8:02 pm
It can't be made strong and reliable.
Get a new rim
- Mulger bill
Postby Mulger bill » Thu May 09, 2013 8:04 pm
+1 to that. Sounds like a challenging technique to learn but theres this dinged up rim in the shed I'd like to practice on.biker jk wrote:What method would that be and which bike shop has the tools to do it?Mozzar wrote:There is a way of fiking that wheel but would need specific tools that not all bike shops would have. most shops would recomend getting a new rim or wheel as they would have no idea of how to fix it.
- Saturnstarzz
Postby Saturnstarzz » Fri May 10, 2013 11:20 am
Interested to see how you would fix it and then negate metal fatigue? I was always taught with alu structures once there bent they CANT be straightened as it weakens the Alu.Mozzar wrote:There is a way of fiking that wheel but would need specific tools that not all bike shops would have. most shops would recomend getting a new rim or wheel as they would have no idea of how to fix it.
Kinda like bending a can one way and then back the other way.
Same as dropping your bike with alu bars and straightening them .
Not saying you cant fix them (mallet and some wood may straighten the rim) but just like straightened bars I wouldn't ride on ANY alu part that bent then fixed, as I value my life too much to save a few bucks.
Postby ezydeek » Sat May 11, 2013 12:28 pm
had to double check the specs but i need a rear hub in 135mm and the lucca wheels rear hub are in 130mmjacks1071 wrote:Thanks Cam, the Lucca will be in stock this Friday - can ship them on Monday if anyone is interested.ironhanglider wrote:
Cameron
Postby ezydeek » Sat May 11, 2013 1:12 pm
Saturnstarzz - probably make it the old rim into an clothes line in the garage to hang up wet gloves/jacket after the rain. love the inspiration links
In the future when i get the right tools or build em i'll attempt to swap the rims
but in the mean while i need to get my bike on the road (borrowing my cousin single speed and he wants it back)
if im looking for a new rear wheel or maybe a new set of wheels, what are the important specs i need to know before i buy them
basically i think i need a
-MTB type rear hub 135mm that can fit a 6 bolt rotor disc
-fit a 10speed cassette
-going with the old rim anything close to a 700c/622mm rim
anything else do i need to know??
- ozdavo
Postby ozdavo » Sat May 11, 2013 6:51 pm
This is a STANDARD 29er MTB wheelezydeek wrote: basically i think i need a
The only thing you need to check is the rim is not too wide.
Sent from my iThingy using Tapatalk
- bychosis
Postby bychosis » Sat May 11, 2013 7:20 pm
If the buckle has not affected the roundness (no flat spot) and only affected the side/side shape I'd probably knock the bead section back into shape, true it up and ride away. If there is a flat spot in the rim, then it's toast.
I obviously have a higher repair to failure fear tolerance than the other contributors above.
