Online Purchases - good and bad experiences
Re: Online Purchases - good and bad experiences
Postby Lurkin » Sat May 11, 2013 9:39 pm
I'd rather go on first hand experience, and as earlier posted, mine have been good. I'll note I also had Mavic Aksium rims put on my partners bike, similar km's/ timing, and hers are also still true.
Not really wanting to get into a 'to Mavic or not to Mavic' debate - I have already determined they should be sufficient for my requirements.
Postby boss » Sat May 11, 2013 10:36 pm
You bought cheap rims.
They went out of true relatively quickly.
Shop offered to true them at no extra cost to you. Either locally at a wheel builder of your choice, or by sending them back.
You felt this unsatisfctory as you were gunning for a new set of wheels.
Cell confirmed all that was needed was a tension adjustment to get your wheel true.
You're unhappy because you were gunning for a new set of wheels.
Reality check #1. From factory, unbuilt rims are often not 'true'. They need tension applied to roll dead straight.
Reality check #2 - it is not unheard of for a wheel to require retensioning after being ridden in.
In your case, you bought some cheap, low end, machine built wheels. Rode them for a bit, lo and behold they went out of tension quickly.
If this happened two or three times within a few weeks, yep, I'd say you deserve a new set. Currently you do not.
The only reason you may get what you want is because you've publicly bent Mark over, knowing he will bend over backwards to fix anything raised on here. I think that is questionable - you're essentially having a politely worded tantrum.
Quite honestly, if I thought you were being reasonable I would come into bat for you. But your not being reasonable.
Postby sdnelson19 » Sat May 11, 2013 11:01 pm
- MarkG
Postby MarkG » Sat May 11, 2013 11:12 pm
- sminns
Postby sminns » Sat May 11, 2013 11:28 pm
Wasn't going to get into this but I agreeboss wrote:Lets get this straight.
- ozzymac
Postby ozzymac » Sun May 12, 2013 8:28 am
And besides op also states he rode on them for 60kms on nice smooth roads, do we have such things?
And it's only his word he didn't hit a pothole or something else to cause the problem.
Sent from my GT-P5110 using Tapatalk 2
Postby Lurkin » Sun May 12, 2013 10:08 am
The rims turned up in a damaged box, and thus may have been damaged on arrival. Why should I be content with damaged goods?Lets get this straight.
Being reasonable, I decided to continue to use them as they looked ok. Then they went out of true within 60kms.
Having had a set of these rims before, I certainly did not expect them to go out of true within 60kms. There was nothing in the product description to suggest expectation otherwise. Accordingly, I have deemed the product as defective.
I then attempted to remedy the problem with Cell Bikes through detailed, clear correspondence. I have posted it all so it was clear:-
- the nature of the correspondence;
- the detail of same; and,
- the amount of time spent trying to communicate with Cell bikes.
I probably spent approx. of half an hour on each letter, quarter of an hour on each email.... at my charge out rate, they are becoming a very, very expensive set of rims.
Further, the responses from Cell Bikes ignored the fact that I did not want either pre damaged or rims that required trueing on arrival.
I was well aware of the fact that I could take them to a LBS and get them trued. I would have proceeded without contacting Cell Bikes - the ~$30 to get it trued would not have been worth pursuing if I genuinely thought that would fix the issue . I was more concerned that the rim would continue to bend out of shape in conditions where it should not - and prove to be less durable than the rims I already had. The only explanation given to me was that the riding conditions had affect the rim... which was addressed - smooth roads etc.
I wasn't 'gunning' for anything other than having rims that do not go out of shape prematurely. Note that given Cell Bikes had determined they were fine - why not accept their return for a refund???? why not use it as an opportunity to upsell to something more durable? Again, if there was actual advice given, rather than continuing to 'gun' for sending it back to me, it's likely I would have bought something else.
Fine - I wasn't aware of this, nor was I made aware of this when consulting Cell Bikes! Both of the other sets of Mavic Aksium rims I have had have certainly not required this level of fiddling. Further, if that's whats to be expected from customers, why not advertise it as so? or alternatively, why not check their shape before they are posted???Reality check #1. From factory, unbuilt rims are often not 'true'. They need tension applied to roll dead straight.
Had I have known this would be the expectation and test, I would never have bought them in the first place.If this happened two or three times within a few weeks, yep, I'd say you deserve a new set. Currently you do not.
Are you trying to suggest that I need to keep riding on them, bending them, sending them back???? It has been a right pain in the backside dealing with the so called 'couriers'. Further, as far as I'm aware, I haven't been reimbursed for the first lot of postage! I'm not going to keep incurring costs for some 'cheap' rims. I want to ride my bike, not muck around with couriers/ postage/ more damaged rubbish in the mail.
I am not publicly bending anyone over. I deliberately took all references to name out of the post to ensure exactly that - it was intended to illustrate what has happened without withholding information so other forum users can review it and come to their own conclusion - with all the facts.The only reason you may get what you want is because you've publicly bent Mark over, knowing he will bend over backwards to fix anything raised on here. I think that is questionable - you're essentially having a politely worded tantrum.
The reasons I have put it publicly are:-
(a) I have tried to get help privately, directly from Cell Bikes and found the response unsatisfactory.
(b) If the negative experiences do not get posted, then it would appear as if every trade going through Cell Bikes is perfect, and on this occasion, it has not been.
(c) what else can a consumer do? If you cannot get help directly from the supplier, and its not worth enough to litigate over, what else can you actually do??
As detailed in earlier posts, this has not been a 'out to get someone' situation. Right from the first correspondence, I would be more than happy if Cell Bikes remedied the situation with more thought than, 'let's just true them and send them back regardless of what the customer says'. I have sent a PM to Mark, and I am more than open to a resolution which is more acceptable.
Postby sdnelson19 » Sun May 12, 2013 10:19 am
Postby LM324 » Sun May 12, 2013 10:35 am
Postby greatapoc » Sun May 12, 2013 10:55 am
Wheels consist of a hub, spokes and a rim. A rim is true when all spokes are evenly tensioned. These wheels are built by machines and sometimes they get it wrong. It is quite possible for a wheel to be true but have some spokes overtensioned while others are undertensioned. Just because you have other sets of the wheel does not mean that this wheel should be perfect out of the box. Yes it is a reasonable expectation that something you purchase should work out of the box but unlike, say, a toaster that doesn't work, a wheel can be easily fixed in a matter in a minutes. Cell were absolutely correct in saying it could happen at 60km, 600km or 6000km or even never. Despite that, they offered to reimburse you the cost of a true which is all that was required. Wheels are very basic devices and they were also absolutely correct in saying short of obvious manufacturing defects (which this isn't) there is no reason to go through all this rigmarole.
I popped a tube yesterday after only having had it on the bike for a day. I suppose I should send it back because other tubes have lasted months.
Would've rejected the delivery right there.Lurkin wrote: The rims turned up in a damaged box, and thus may have been damaged on arrival. Why should I be content with damaged goods?
Except that it would fix the issue because that's how wheels workI was well aware of the fact that I could take them to a LBS and get them trued. I would have proceeded without contacting Cell Bikes - the ~$30 to get it trued would not have been worth pursuing if I genuinely thought that would fix the issue . I was more concerned that the rim would continue to bend out of shape in conditions where it should not - and prove to be less durable than the rims I already had. The only explanation given to me was that the riding conditions had affect the rim... which was addressed - smooth roads etc.
Why should they offer a refund on something that is a normal maintenance activity? Should a whole bike be returned because a rear derailleur needs an adjustment? Actual advice was given right at the start of your novel to go and get it trued by an LBS for free and you rejected it. Then you sent it back and they did exactly that and you refused to have it back.Note that given Cell Bikes had determined they were fine - why not accept their return for a refund???? why not use it as an opportunity to upsell to something more durable? Again, if there was actual advice given, rather than continuing to 'gun' for sending it back to me, it's likely I would have bought something else.
Seriously, this is ridiculous. You rejected all offers for help from Cell from the outset because you wanted a new set of wheels and any advice to the contrary you ignored. If anyone else had posted about this same scenario it would have been a positive experience that would go somewhat like this:The reasons I have put it publicly are:-
"I bought a set of cheap wheels from Cell which arrived in a damaged box. I chose to ride them and after 60km one of the wheels went out of shape. I contacted Cell who promptly told me to take it into my LBS and they would reimburse any costs. I was back riding within a week!"
Postby boss » Sun May 12, 2013 11:50 am
The way I see it is you've just got an incorrectly tensioned wheel. Very serviceable. The box being dinged was just a coincidence.
You trumpeted your 'experience' at the start of one of your posts... And I don't mean this in a nasty way, but its clear you are fairly new to bicycles. Half a dozen people are telling you that you're being unreasonable - isn't that telling you something?
And hey. What do you have to lose. Take th trued rim back, ride it, and if it goes wonky again... Then ask for a replacement?
No need to be a stick in the mud. Nor is their reason to tarnish a good shop (I mean, repeated references to cell fail?!?).
- CELL Bikes
Postby CELL Bikes » Sun May 12, 2013 11:57 am
Hi Lurkin, I have not received a PM in my BNA message box, or my (mark@this link is broken) inbox.Lurkin wrote:I have sent a PM to Mark, and I am more than open to a resolution which is more acceptable.
To everyone supporting us, thank you. I will always do my best to make everyone happy the best I can.
Everyone is important to us, and I do my best to maintain a good standing relationship with all of you. I see you all as my cycling mates and not just a number or a faceless customer, all of you are living, breathing 'real' people, and an oversight or slip up by us, can totally ruin things on your end, so I do my best to resolve things the best I can if any of you are unhappy.
-website mgr Mark
http://www.this link is broken/contact-us
Postby Lurkin » Sun May 12, 2013 2:12 pm
Couldn't. The receptionist at work accepted the delivery on my behalf. This will be remedied in the future, as I agree, the delivery should have been refused.Would've rejected the delivery right there.
Further agree about a damaged rims box - I will never ride on rims from a damaged box again!
If they have reimbursed same. Which I have had no confirmation or communication about after sending through my banking particulars.Sorry Lurkin but I'd have to agree with the others as well. Looking at your post it seems like you got very good service from cell bikes, they trued the wheel at no cost for you and they paid for postage as well. This should be good outcome.
Again, as posted earlier, I suspected there was more to the story due to the unexpectedly short time frame they went out of true in. I know that they could be trued! read the earlier post - I was concerned that the problem was systematic with the rim and did not want to spend time sending them back and forth proving it - although that appears to be the exact advice of the forum - there's no problem until they have been sent backwards and forwards three times to prove it.Except that it would fix the issue because that's how wheels work
I am aware of this - terminology only. I was concerned that there could be something further that has impacted the rims ability to remain true. Whether you call this bending, or going out of true, is a matter of words only.You aren't BENDING the wheel
The vague comments from Cell Bikes and and the utterly appalling, time wasting 'customer service' from Couriersplease seem to have been overlooked with the 'you're a noob, you've got the wrong end of the stick.'
As posted earlier, I posted up all of the correspondence for other forums users to determine what their conclusion on the matter is.
I think the key information in the posts received is that machine made wheels can come incorrectly tensioned and this was something I was unaware of, and was not informed of by Cell Bikes. Nor is there any mention of same in the advertising of the rims. Despite multiple contacts with Cell Bikes, I have had to post it on the internet to find it out!
Believe it or not - more than happy to be informed with regard to this. Having had two sets of these rims, perfect out of the box, I had no idea that they could be tensioned incorrectly out of the box. I am surprised that there is no quality review before such products are sent out? Further, why wasn't further specific information provided, other than 'we've looked at it, trued it, and its fine'? (particularly when its evident the customer seems to have the wrong end of the stick?)
What's wrong with picking up the phone, having a twenty minute conversation, ironing out any misunderstanding and having a customer that is willing to return again and again because they have comfort that it will be sorted in the event of a problem? I know I tried to do this - and simply got the 'we'll true it and send it back to you' without further explanation.
Depends whether this is treated as a once of sale or a potentially repeated customer relationship. It takes a degree of trust to deal with an online trader, especially if you are new to cycling!Why should they offer a refund on something that is a normal maintenance activity?
You sell a customer an item once and expect them not to return - their satisfaction effectively doesn't matter because its a once off.
You sell a customer an item once and expect that they will return, or affect other people if their decision to purchase more. Immediately, customers who have problems, regardless of how much of a newbie they are, or whether they have the wrong end of the stick - have value.
Deciding only to sell to only those who know your products in and out shrinks the market considerably...
Simple - Time. Money. Opportunity cost of using a different supplier who is more interested in informing their customers about things that go wrong, communicating when they are issuing refunds/ returning rims by Aus Post /communicating with their customers to allow them to understand what has gone wrong and why the offered solution is sufficient etc.What do you have to lose.
Postby sdnelson19 » Sun May 12, 2013 2:30 pm
I think it's pretty obvious what other forum users conclusion on the matter is, yet you seem reluctant to accept it.As posted earlier, I posted up all of the correspondence for other forums users to determine what their conclusion on the matter is.
Is it really up to the retailer to pre-empt every single question regarding the manufacture of every product they list for sale online?I think the key information in the posts received is that machine made wheels can come incorrectly tensioned and this was something I was unaware of, and was not informed of by Cell Bikes. Nor is there any mention of same in the advertising of the rims
I'm certain that Mavic (one of the largest manufacturers of wheels worldwide) would have some pretty stringent quality control at the factory. I certainly would not expect any retailer to go through the exact same process before selling each wheelset from them.I had no idea that they could be tensioned incorrectly out of the box. I am surprised that there is no quality review before such products are sent out
My summary of all this: you bought some wheels, they came in a damaged box, it was someone else's fault for accepting delivery, you fitted the wheels anyway, they were fine to start with, you used them for 60km, they went out of true, cell offered to fix them for free, you weren't happy that they took so long getting back to you because they have other customers to deal with too, you asked a forum for advice (by publishing a string of emails and repeatedly call them cell fail), got a response that you really didn't want to hear.
Unfortunately you got sold (probably incredibly cheaply) a set of great wheels (have used them before myself) that turned out to have a fault from the manufacturer, the retailer offered to true them at no cost to you. There's lots of online retailers out there who would say 'bad luck' and probably 2 or 3 out of 100 wheelsets that have a spoke that isn't tensioned quite right; these things happen sometimes, and cell have gone above and beyond (as usual) to try and help solve the problem.
Postby greatapoc » Sun May 12, 2013 2:35 pm
Major props to Cell for their responses I think they've gone above and beyond what I'd expect from an online retailer. I know a few that would probably just say too bad or want you to mail it half way around the world on your dime.
Postby Lurkin » Sun May 12, 2013 2:59 pm
The general consensus seems to be to ride on them further, if they continue to go out of true, then its a manufacturing fault.
Frankly, I'm still not convinced that trueing the wheel has done anything other than put it back in shape - I am still concerned that whatever caused the rim to go out of true is still there, a partially stripped nipple some other issue etc. The rims are still in the garage.. I don't really want to use them.
However, thank you all, I have at least been given plausible explanation, other than a generic, inspecific reply.
- sunho
Postby sunho » Mon May 13, 2013 9:49 am
Mark & the Cell team, Paypal is just awesome!
Order done!
Postby boss » Mon May 13, 2013 10:07 am
Well yeah, they re-dispatched the order... it was some shimano booties, castelli vest and a castelli long rain jacket.
Took the gear out on a very wet ride on the weekend.
The booties and vest were great, kept me warm... and while the jacket was a bit of a sweat bag, it kept me dry from the rain and sweating underneath it was very manageable. I was happy with it.
As one would expect, the jacket got a bit dirty with road grit and whatever. I toyed with the idea of just hosing it down, but I made my first mistake checked the care instructions - it said cold machine wash was cool. So I then proceeded to make my second mistake and throw it in the wash with my other kit.
Pull the jacket out of the wash... it was stuck to itself, and there was resistance pulling it apart. Weird. Initially I thought I'd maybe left a gel packet in the was or something, and somehow the sticky residue has made its way inside the jacket.
Nup. The waterproof coating had started peeling away. Yep, after one was.
Took some photos of the jacket and sent them to Ribble... when i was taking the photos, I discovered the Castelli logo on the front of the jacket had peeled off too!
Not really what you expect when you are paying $50 for a very, very basic sheet of waterproof nylon (with an admittedly very good fit).
Some photos... the white reflective bits are where the coating has peeled away. And that last photo is the logo peeled up.
I know this isn't Ribble's fault (at all) but it is icing on the cake for a bad experience! I'm not bitter about it, I just want to stay dry because this next week is going to be some pretty crappy weather!
- Dan
Postby Dan » Mon May 13, 2013 10:53 am
Postby boss » Mon May 13, 2013 10:55 am
Dan wrote:So, I'm thinking of buying some Aksiums. Any opinions?
- CELL Bikes
Postby CELL Bikes » Mon May 13, 2013 11:14 am
If you get them and the box is damaged, don't accept them! (or tell anyone who may receive the package this).Dan wrote:So, I'm thinking of buying some Aksiums. Any opinions?
The Aksiums are a decent basic wheel, suitable for light training or commuting, and are usually found on road bikes in the $1,000aud range.
Many of our customers ride bikes equipped with them and have no complaints.
As with anything, if you want performance, I'd suggest paying a bit more. Also regarding the reliability of some more expensive, low spoke count wheels, your weight needs to be a factor as well.
-website mgr Mark
- Dan
Postby Dan » Mon May 13, 2013 12:56 pm
- CELL Bikes
Postby CELL Bikes » Mon May 13, 2013 1:06 pm
Hi Dan, no worries, I'm not here to sell, I'd suggest you go with the lowest price if you're ever in the market for them, however just be aware of warranty issues if you buy O/S. Maybe if your LBS can do them at a good price, go with them. It's always good to support your LBS if they show you love, and their prices are competitive.Dan wrote:Thanks Mark. I'm not sure I'll ever actually be in the market for Aksiums, however if I am, I'd be more than happy to order from you guys.
I've actually paid more at an LBS in the past, because they were a great bunch of guys. But if you have kids, a mortgage, car payments, and other bills, sometimes this is hard to do.
-website mgr Mark
Postby dominicj » Mon May 13, 2013 4:09 pm
- CELL Bikes
Postby CELL Bikes » Mon May 13, 2013 4:22 pm
Yeah, in a perfect world, maybe an LBS could be just $10 more, but still offer superior sales & service. However, for Conti GP4000s', if an LBS is doing them for $109, and BikeBug, say, are doing them for $39.95, what can you do? No amount of friendly service is going to make me pay $70 more for the same tyre!dominicj wrote:Agreed, I'd like to buy from LBS if they are competitive. Unfortunately my experience is that LBS acts as if the internet doesn't exist and quotes me RRP every time I go in to check their best price.
-website mgr Mark
Users browsing this forum: Amazon [Bot]
