Raleigh Twenty
Re: Raleigh Twenty
Postby ldrcycles » Thu May 09, 2013 9:12 pm
That's scrubbing up really nicely quang! :)
Road Record Association of Australia
Re: Raleigh Twenty
Postby munga » Thu May 09, 2013 9:25 pm
paint.
thank you, thank you! try the linguini, it's fantastic!
i'll be playing the met next tuesday. 8)
Re: Raleigh Twenty
Postby QuangVuong » Thu May 09, 2013 9:51 pm
This Bright Chrome spray paint. Wasnt really expecting anything better than a matallic silver, but it turned out to be quite a nice foggy chrome. Wheels are next up for painting as well.
Re: Raleigh Twenty
Postby Dan » Fri May 10, 2013 8:03 am
Linguine, wasn't he in that movie with the rat?
Re: Raleigh Twenty
Postby ldrcycles » Fri May 10, 2013 5:51 pm
I was using some 'chrome' paint just this morning. It definitely isn't the same as chrome but if you get the surface PERFECT it looks pretty damn good.
Re: Raleigh Twenty
Postby QuangVuong » Sat May 11, 2013 12:55 pm
The Raleigh Twenty-Two Shopper done!
Polished up the levers. Bit hard to see though. Bar tape works well, and prob will just stick with that. Its comfier than the plastic grips from before.
But theres a slight issue. The housing gets caught in the front rack when turning left which makes it brake. Theres no other place to route the housing. Oh well, the brake isnt that strong so it wouldnt cause an accident.
jools
Re: Raleigh Twenty
Postby jools » Sat May 11, 2013 1:02 pm
Nice result - that looks great! The bar tape looks like a good option. Did you take it for a test ride?
jools
Re: Raleigh Twenty
Postby jools » Sat May 11, 2013 1:03 pm
Does it just need a longer cable with a bit more slack in it?
Re: Raleigh Twenty
Postby QuangVuong » Sat May 11, 2013 1:16 pm
Yeah, went up and down the street to test safety and brakes. Rear brealy does anything, and front works well enough.
As for the front housing, its super long already. Its just that the rack gets in the way. Dont think theres anyway to get around that other than removing the rack.
jools
Re: Raleigh Twenty
Postby jools » Sat May 11, 2013 1:31 pm
I haven't seen a frame mounted front rack before - my BSA 20 has a front rack but its mounted to the fork. Does the cable snag when you're riding or just when you're testing it out while standing still?
Removing the rack is probably the easiest option unless routing the cable like a centre pull down the middle gives you a bit more slack. Converting to a centre pull brake is another possibility?
Re: Raleigh Twenty
Postby QuangVuong » Sun May 12, 2013 2:18 pm
Well this was a success. Mum didn't didn't see it over the week, so it remained a secret up til today. She's happy with it, and I found out that she had a similar bike ages ago
Anyway, looks like that auto raking issue isn't too bad. I loosened the barrel adjuster anchor bolt, and that allowed the housing to flex a bit without it causin the brakes to pull in. And will be buying those leather pads soon. Or could buy some 22" alloy rims(some on eBay for only $19 per rim) and save on the price of pads.
Re: Raleigh Twenty
Postby Dan » Sun May 12, 2013 5:59 pm
Nice one! Glad you were able to keep it as a surprise. I'd get the alloy rims.
jools
Re: Raleigh Twenty
Postby jools » Mon May 13, 2013 4:45 pm
alloys sound like a good option - do you know if the twenty two had the same tyre size issue as the twenty? Different markets got different wheel sizes which meant different reach for the brakes...
Re: Raleigh Twenty
Postby QuangVuong » Mon May 13, 2013 8:42 pm
THis is the rim Im looking at
http://www.ebay.com.au/itm/170742249029 ... 1423.l2649" onclick="window.open(this.href);return false;
The tyres are 22x1.75, so Id say thats the standard size.
jools
Re: Raleigh Twenty
Postby jools » Mon May 13, 2013 10:09 pm
sounds about right if the 231.5mm wide in the subtitle refers to the radius of the rim - might be worth doublechecking the right tyre size with the seller.
The only reason I mention it is because the twenty two (like the twenty) came in two wheel sizes so the tyres were either 22 x 1.75" or 22 x 1-3/8". The ETRTO for these tyres are 47-457 and 37-501 which is about a 1" difference in diameter at the rim, so brake reach can be an issue if switching
If the bike is riding on 22 x 1.75" at the moment and that's what the alloy rims take then you shouldn't have a problem.
Re: Raleigh Twenty
Postby QuangVuong » Fri May 17, 2013 9:42 pm
Mum says new pads will do. I guess she wont be riding at anything over 20km/h, so itll be alright.
And amazing condition Twenty. If this was up a week earlier, I wouldve grabbed it.
http://www.gumtree.com.au/s-ad/concord/ ... 1019773630#" onclick="window.open(this.href);return false;
jools
Re: Raleigh Twenty
Postby jools » Sat May 18, 2013 7:22 pm
It wasn't quite as nice in the flesh as in the photos.. but it was complete and straight and the guy was negotiable so it's in my garage now while I work out what to do with it..
hartleymartin
Re: Raleigh Twenty
Postby hartleymartin » Thu Oct 16, 2014 5:02 pm
I've been absent a fair while, but I'm back on the road after getting through some serious health issues over the past few years.
My old blue folding Raleigh Twenty is going through a period of upgrades and transition. I bought the frame several years ago, but it had bent forks. Another fellow in Sydney traded a few other parts for a set of replacement forks. The one-piece handlebars and stem come from another R20, which is sitting in my garage unused and incomplete at the moment.
New SKS mudguards, new wheels with aluminium rims and a Sturmey-Archer SRC3 hub with a coaster-brake have been fitted.
Still to do:
Front Brakes, new seat-pillar, new saddle, rear carry rack, new lights, different pedals, fit 44t or 46t biopace chainring, grips and a general clean-up.
Martin Christopher Hartley
Typhoon Ken
Re: Raleigh Twenty
Postby Typhoon Ken » Thu Oct 16, 2014 6:15 pm
Cool little bike.
twowheels
Re: Raleigh Twenty
Postby twowheels » Thu Oct 16, 2014 7:16 pm
Re: Raleigh Twenty
Postby munga » Thu Oct 16, 2014 8:30 pm
welcome back, hartleymartin
hartleymartin
Re: Raleigh Twenty
Postby hartleymartin » Fri Oct 17, 2014 12:28 am
twowheels wrote:this looks in good knick
http://www.gumtree.com.au/s-ad/doncaste ... 1058905822
That's a Raleigh RSW Shopper. 16" wheels, but still a nice little bicycle.
scratchman
Re: Raleigh Twenty
Postby scratchman » Tue Oct 21, 2014 5:33 pm
munga wrote:welcome back, hartleymartin
yep, welcome back, wondered where you went, all ok now?
Phil
barefoot
Re: Raleigh Twenty
Postby barefoot » Fri Dec 05, 2014 10:40 am
Anyone shopping?
I just found this complete BSA Twenty in "original condition" for $25 in Melbourne:
http://www.gumtree.com.au/s-ad/abbotsfo ... 1063978247" onclick="window.open(this.href);return false;
Looks very similar to my one (which I really should do something with... one of these years...)
tim
kukamunga
Re: Raleigh Twenty
Postby kukamunga » Fri Mar 20, 2015 3:37 pm
The Raleigh Twenty I've had hanging' around for years now is now on fleabay View item
Almost as nice as this one I sold six or seven years ago.....
