Chain Reaction Bike Bag - or other recommendations?
Postby marckietan » Wed May 15, 2013 2:38 pm
I have signed up do the BUPA round the bay for the first time this year and am based in Sydney....and will probably look at flying down to Melbourne with the bike.
Has anyone used a Chain Reaction bike bag to transport their road bike? any thoughts or views? Should I just use a cardboard bag instead? did it offer good protection and what did you have to take off the bike to make it fit?
thanks
M
- jacks1071
Re: Chain Reaction Bike Bag - or other recommendations?
Postby jacks1071 » Wed May 15, 2013 11:10 pm
If you want a better solution, take a look at the ones we have:
http://www.pro-liteoz.com/store/index.p ... t&catId=11" onclick="window.open(this.href);return false;
- Aushiker
Postby Aushiker » Thu May 16, 2013 12:05 am
I have also flown with cardboard boxes. I prefer the bag where I will be doing something along the lines of what you are planning, whereas I use boxes if the return is via bike.
That said if you can keep the box for the return flight then that is by the cheapest option.
Aushiker.com
- Ross
Postby Ross » Thu May 16, 2013 7:03 am
I have used a hard case once before and found several issues.
1) it weighs 9-10kg on it's own before you put in the bike, some tools (can't have tools in carry-on luggage), maybe a track pump and some bike clothes/shoes you are up to or over 25kg. When I used a hard case to go o/s a few years back QANTAS wanted to charge me $1000 ($100 per kg) for excess luggage. That was just for the Canberra to Sydney leg.
2) It is big and awkward to store when empty, soft cases can be folded up and stored in a cupboard or under a bed
3) With a hard case the bike requires a lot more disassembly. You have to take wheels, pedals, handlebars, seat/post and sometimes even rear derailleur. So this requires more tools to be bought with you, so more weight, and more mechanical knowledge and expertise needed as well. And time to assemble/disassemble the bike. With my soft case the front wheel is the only thing that has to come off.
A friend packed his bike in a hard case last year to got o TDU and somehow he didn't pack it right and it arrived with a cracked frame. That's obviously not a fault of the case but just showing that a hard case is not the magic bullet that some make them out to be.
Postby scirocco » Thu May 16, 2013 11:22 am
Cardboard boxes are a good compromise: a bit more protection than a bag but not as heavy as a hard case. Bag or soft case, though, wrapping PVC foam tubes around the frame will do more to protect it than the container.
Postby dalai47 » Thu May 16, 2013 12:18 pm
Ended up being 19kg with bike and tools last OS trip. Just made sure the frame was covered using slit pipe lagging and reusable cable ties.
- RonK
Postby RonK » Thu May 16, 2013 1:20 pm
Postby marckietan » Thu May 16, 2013 1:57 pm
And yes, will put pipe lagging and cable ties to keep things fixed.
Do you think you have to remove the rear deraileur or do you just pull it up and attach it to the frame with ties or something similar?
Postby dalai47 » Thu May 16, 2013 2:08 pm
- RonK
Postby RonK » Thu May 16, 2013 2:30 pm
Postby jcjordan » Thu May 16, 2013 10:03 pm
- jacks1071
Postby jacks1071 » Fri May 17, 2013 9:34 pm
We've added a little weight to ours based on what I learned both selling and using the origional Polaris case. There is hard plastic rails under the case to stop it sagging, also to provide protection if you bottom it out.dalai47 wrote:I have the Polaris Bike Pod, which is an EVA case that the Pro-lite is a variation of. Only real difference looks to be weight with the Polaris is lighter at 6.7kg. All helps when trying to keep under luggage allowance limits on International flights.
There is a hard plastic insert on the bottom of the case to avoid the chain ring sawing through the case in the event you don't pack it properly, and we run wheels on the front so you can tow the case without lifting it which is a life saver for your arm.
I also had spacers made up that go on the end of the wheel skewers to support the opposite side of the case so that the case can't be crushed.
The amount of weight that adds is very little. 6.7kg on the Polaris isn't accurate, check on your scales if you like.
I was initially attracted to the Scicon style cases with the metal frame on the bottom as a little less disassembly is required. Given the amount of EVA cases I've sold to people who have that exact style of case already, I'd never use one.
As someone else said above, you are kidding yourself if you think the level of protection is the same.
Postby dalai47 » Fri May 17, 2013 10:53 pm
I went with the EVA case because I thought it was a good compromise between weight and protection. I did previously owned a Big Foot Extreme Plus case. Brilliant for protection but weighed a ton empty!
- rifraf
Postby rifraf » Sun May 19, 2013 3:42 am
Saying that, if I get on well with my new Ogre, I intend to look into getting some S&S couplers for it which should see it getting into a large suitcase (I hope) - Oh the plans of men and mice....
