Yes, exactly so. I do,however, believe that weight is a major factor when it comes to rider perceptions on how the wheels are responding to input.Philipthelam wrote:
The issue, I think, with most first hand experiences is that lighter wheels are often more expensive, higher end wheelsets. So while the lighter wheel may feel better than a heavier wheel it is not the result of weight but a variety of other factors such as stiffness, aerodynamics, better bearings etc.
Just how much difference does lighter wheels make?
Re: Just how much difference does lighter wheels make?
Postby ball bearing » Thu Jun 20, 2013 1:53 pm
- ColinOldnCranky
Postby ColinOldnCranky » Thu Jun 20, 2013 3:01 pm
It's been forty something years since I was an engineering student but anyone proficient in calculus can prove it themselves.
Postby vosadrian » Thu Jun 20, 2013 6:07 pm
I have never ridden aero wheels to compare, but I considered buying them but decided on light weight. My reasoning was that aero was mainly of benefit when solo riding and most of my bigger riding efforts are either climbing or riding in groups. I had made the assumption that when in a group and not leading, that any bike aero benefits would be significantly reduced as you are not in the wind. Is this a valid assumption? If I suck a wheel behind someone for an hour going 40kph, will aero wheels provide much/any benefit over non aero wheels? If the situation is such that I am battling to not get dropped off a group that includes accelerations out of corners and up climbs, am I better off with lighter wheels that enable me to catch up to the wheel I am sucking quicker to save energy, or aero wheels that may provide some small benefit the whole time? I reasoned that getting back into the group was of more value than small power savings once in the group out of the wind.
Also, in terms of overall aero benefit, are wheels the best money spent. If I have a non aero regular road bike with external cables and nothing specifically aero about it, how much different do other aero considerations such as TT helmet, tighter fitting clothers, internal cables etc compared to wheels. In my case I have nothing aero. Can I achieve a better aero benefit for less money by changing something else? Would wheels make up <5% of total aero drag? However the wheel weight is a significant % of total bike weight, so I can have a large percentage weight reduction (10+%) by going from heavy to light wheels.
BTW - I am no wheel sucker generally. I pull my turn. But the bigger the group, the higher percentage of time spent out of the wind, and I am wondering which is better for that... light or aero.
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu Jun 20, 2013 7:20 pm
The moment of inertia is only a factor in rotational accelerations, and for bicycle wheels, is such a small factor as to be effectively insignificant.ColinOldnCranky wrote:For the record, on a theoretical wheel where 100% of it's mass is at the outside of the rim, the linear inertia of it in motion is exactly the same as the rotational inertia. ie. In other words a kg saved at the rim is equivalent to saving two kgs on the frame or anywhere else that is just moving in a straight line.
here, brush up on your physics:
http://www.biketechreview.com/index.php ... erformance" onclick="window.open(this.href);return false;
Postby Nobody » Thu Jun 20, 2013 10:50 pm
This might help.thecaptn wrote:I've never had anything but mid range bikes and would appreciate some opinions
In summary, wheels account for almost 10% of the total power required to race your bike and the dominant factor in wheel performance is aerodynamics. Wheel mass is a second order effect (nearly 10 times less significant) and wheel inertia is a third order effect (nearly 100 times less significant). The best wheels in terms of performance are the ones that are lightweight, aerodynamic, don’t rub brake pads and are strong enough to get you to the finish line. The problem with these high performance wheels, though, is that they sacrifice on the other two key variables important in wheel selection: durability and price. High performance wheels are neither durable nor cheap. Nothing is ever easy, is it?
Postby AndrewW » Fri Jun 21, 2013 9:04 am
Now don't even get me started on the people that think upgrading from 105 to Dura Ace will give you an extra 5km/h...
Postby KL. » Fri Jun 21, 2013 9:43 am
Hi Nobody, good summaryNobody wrote: In summary, wheels account for almost 10% of the total power required to race your bike and the dominant factor in wheel performance is aerodynamics. Wheel mass is a second order effect (nearly 10 times less significant) and wheel inertia is a third order effect (nearly 100 times less significant). The best wheels in terms of performance are the ones that are lightweight, aerodynamic, don’t rub brake pads and are strong enough to get you to the finish line. The problem with these high performance wheels, though, is that they sacrifice on the other two key variables important in wheel selection: durability and price. High performance wheels are neither durable nor cheap. Nothing is ever easy, is it?
Hi AndrewW, no, but compared to a bad choice, the right choice of wheels canAndrewW wrote: .. Now don't even get me started on the people that think upgrading from 105 to Dura Ace will give you an extra 5km/h...
Light (< 1500g and maybe even <=1600g), aero rims and spokes, good lateral stiffness for your weight, good drive via spoke arrangement, and good hub qualities (such as Dura Ace, Record and others) are qualities that all need to be considered
thanks KL
Postby Lots of steel bikes » Fri Jun 21, 2013 11:27 am
- ColinOldnCranky
Postby ColinOldnCranky » Fri Jun 21, 2013 11:32 am
I retire in a year or so and I have been thinking of enrolling in some maths units. In the time before the term "nerd" existed I really did enjoy maths. It has been lost in a career with little need for it outside of some not-very-sophisticated stats and business maths.Alex Simmons/RST wrote:The moment of inertia is only a factor in rotational accelerations, and for bicycle wheels, is such a small factor as to be effectively insignificant.ColinOldnCranky wrote:For the record, on a theoretical wheel where 100% of it's mass is at the outside of the rim, the linear inertia of it in motion is exactly the same as the rotational inertia. ie. In other words a kg saved at the rim is equivalent to saving two kgs on the frame or anywhere else that is just moving in a straight line.
As to the authors conclusion:
It may be distanct but as to whether it is insignificant that is an opinion, no quantifiable. A lot of ridersconsider a kg on the frame as significant and spend squillions trying to rid themselves of it. So, yes, other factors may be greater. But a kg on the rims has double the effect of it beinglsewhere and if you asked the author if he would like a kg less on his frame then I suspect he would be willing to pay a significant amount to do so. And even if he isn't, many others are.So, what do all these numbers mean? It means that when evaluating wheel performance, wheel aerodynamics are the most important, distantly followed by wheel mass. Wheel inertia effects in all cases are so small that they are arguably insignificant.
Therefore for many riders inertia of the wheel is not entirely a minimal issue. At least as much as the equivalent extra mass carried elswhere. (Note: My conclusions are not about acceleration against gravity, not climbing where a kg on the wheel is the same as on anywhere else.)
Yes, other factors are more significant, aerodynamcis for instance. But cycilsts still purse the benefits of reduced weight as it is still worth pursuing.
Interestingly and all from memory) the IOC (or cycling union or whoever) used to be very strict about team pursuit bikes having weight added to the rims. That outside weighting was seen to advantage less proficient (and tired less fit) riders that were drafting with wheels almost touching. That seemed to change at the US hosted LA84 Olympics when all sorts of rulings in favour of the lowly Yanks allowed them to race with closed in wheels - so getting past the weight loading rules as well as negating rules against aerodynamic spokes. Unfortunately the Aussies with their new plastic bikes were not allowed such favourable decisions. The totally unfavoured Yanks finished up dominating track for the two weeks after which the rest of the competition adopted the same technology.
Postby ball bearing » Fri Jun 21, 2013 12:29 pm
Somehow I can't recall ever hearing anyone say they wish that their wheels were just a bit heavier.ColinOldnCranky wrote:
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri Jun 21, 2013 2:30 pm
It is precisely quantifiable, and is insignificant.ColinOldnCranky wrote:It may be distanct but as to whether it is insignificant that is an opinion, no quantifiable.
What riders might believe and what's actually real are two different things. I go with the latter.ColinOldnCranky wrote:A lot of ridersconsider a kg on the frame as significant and spend squillions trying to rid themselves of it. So, yes, other factors may be greater. But a kg on the rims has double the effect of it beinglsewhere and if you asked the author if he would like a kg less on his frame then I suspect he would be willing to pay a significant amount to do so. And even if he isn't, many others are.
A kg on the rim doesn't have double the effect.
i. Acceleration rates in cycling are small.
ii. The difference in the actual moment of inertia of wheels of a variety of masses/types when compared to the total inertial load of the bike+rider system is very very small.
No-one is saying not to pursue it, but for the majority of riding, if performance is the objective, then wheel aerodynamics trumps weight considerations by a large margin. For steep climbs then reduced weight is advantageous.ColinOldnCranky wrote: Yes, other factors are more significant, aerodynamcis for instance. But cycilsts still purse the benefits of reduced weight as it is still worth pursuing.
If you are not convinced about relative impacts of wheel aerodynamic and wheel weight during accelerations, see this example:
http://alex-cycle.blogspot.com.au/2013/ ... parts.html" onclick="window.open(this.href);return false;
The UCI have never required weight to be added to rims for team pursuit or otherwise. Disk wheels are solely an aerodynamic aid.ColinOldnCranky wrote:Interestingly and all from memory) the IOC (or cycling union or whoever) used to be very strict about team pursuit bikes having weight added to the rims. That outside weighting was seen to advantage less proficient (and tired less fit) riders that were drafting with wheels almost touching. That seemed to change at the US hosted LA84 Olympics when all sorts of rulings in favour of the lowly Yanks allowed them to race with closed in wheels - so getting past the weight loading rules as well as negating rules against aerodynamic spokes. Unfortunately the Aussies with their new plastic bikes were not allowed such favourable decisions. The totally unfavoured Yanks finished up dominating track for the two weeks after which the rest of the competition adopted the same technology.
USA team pursuit performances in 1984 were aided by blood doping run by USAC coaching staff.
USA used a rear disk with a standard spoked low profile front wheel, and aerodynamic helmets.
Aussies had standard low profile spoked rims front and rear and helmets (not sure about aero design).
Neither team had plastic bikes, they were standard steel tubed frames. USA frames may have been alu but definitely not carbon. The bars on both team's bikes were "bullhorns". There were no aerodynamic bar extensions in those days.
You might be thinking of the 1996 Atlanta Games where Australia used the "superbike", complete with the awful steerer that was a 'mare to use.
Australia won the 1984 Team Pursuit gold medal in the ride off with the USA team, largely due to the US rider who pulled his foot at the start and so they only had 3 riders for the entire 4km.
Aussies time in the final was 4:25.99
- ColinOldnCranky
Postby ColinOldnCranky » Fri Jun 21, 2013 3:25 pm
Yes, you are right - tyou won't see to many riders seeking to increase inertia or weight.ball bearing wrote:Somehow I can't recall ever hearing anyone say they wish that their wheels were just a bit heavier.ColinOldnCranky wrote:
However increased inertia was a boon for team pursuit where you only had to accelerate that weight once, then it was maintaining velocity for a long as possible but also staying as close as possible to the wheel in front. That inertia meant that riders could draft closer for a given skill level. Small changes in a riders effort at a given moment could result in wheels coming together. the extra inertia dampens that so that it takes longer to happen. Rules were in place to stop teams from adding weight to introduce that inertia. AFAIK there may still be restrictions of a similar nature, notwithstanding the LA84 olympics.
- find_bruce
- Moderator
Postby find_bruce » Fri Jun 21, 2013 3:32 pm
the gear looks to be as Alex says. Also you can see the US rider droping out right from the start.
The 1996 were not dissimilar Australian superbike
US Bike
Postby Nobody » Fri Jun 21, 2013 5:15 pm
Hi KL, sorry but it wasn't mine but the end of the link I quoted. Also didn't realize that Alex had posted the same link a few hours before. I should have read more carefully.KL. wrote:Hi Nobody, good summaryNobody wrote: In summary, wheels account for almost 10% of the total power required to race your bike and the dominant factor in wheel performance is aerodynamics. Wheel mass is a second order effect (nearly 10 times less significant) and wheel inertia is a third order effect (nearly 100 times less significant). The best wheels in terms of performance are the ones that are lightweight, aerodynamic, don’t rub brake pads and are strong enough to get you to the finish line. The problem with these high performance wheels, though, is that they sacrifice on the other two key variables important in wheel selection: durability and price. High performance wheels are neither durable nor cheap. Nothing is ever easy, is it?
Postby ball bearing » Fri Jun 21, 2013 5:38 pm
Never been on a track. I'm a road-warrior one-on-one type of rider - at least I used to be. Now, I have endless hill challenges.ColinOldnCranky wrote:
Postby defy1 » Fri Jun 21, 2013 10:07 pm
Postby ironhanglider » Fri Jun 21, 2013 10:15 pm
There's always one:ColinOldnCranky wrote:Yes, you are right - tyou won't see to many riders seeking to increase inertia or weight.ball bearing wrote:Somehow I can't recall ever hearing anyone say they wish that their wheels were just a bit heavier.ColinOldnCranky wrote:
http://autobus.cyclingnews.com/news/?id ... jul19news6
I seem to recall that Moser's 1984 bike had extra weights incorporated into the rim of his revolutionary (pun intended) wheels.In his attempt, Sosenka was using a 3.2 kg wheel and 190 mm cranks, with his bike weighing a total of 9.8 kg. The reason for the heavy wheel was that although it was harder to get up to speed, it was easy to maintain it.
However in a bunch race the difference of a wheel length in acceleration might make the difference between getting into the wake of a passing rider or not and the missed opportunity could cost the race.
I'm more interested in whether there is a benefit to aero wheels in dirty air.
I ride my retro style wheels and let the bloke in front worry about being aero.
Cameron
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Jun 22, 2013 7:52 am
And is precisely why aero matters more than weight, especially when the sprint starts from speed. Taking typical differences in weight and aerodynamics between a quality low profile spoked wheel and a quality aero wheel, the aero wheel will accelerate faster and provide greater speed for the power available.ironhanglider wrote:However in a bunch race the difference of a wheel length in acceleration might make the difference between getting into the wake of a passing rider or not and the missed opportunity could cost the race.
Most definitely. Indeed not only in the single case acceleration, but in the sum total if you are able to get to the final stages of a race have done a lot less work, then the extra freshness is very important for your ability to sprint. Or if that's not your game, then your ability to generate, reach and remain with a race winning break.ironhanglider wrote:I'm more interested in whether there is a benefit to aero wheels in dirty air.
Postby pawnii » Sat Jun 22, 2013 10:51 am
2012 Scott Foil Premium
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Jun 22, 2013 12:47 pm
I don't think anyone has said that. Opening statement from my blog post linked earlier:pawnii wrote:you guys make out as if you can't get aero wheels that are light.
The issue is what do you choose when your budget is limited, because light and aero and sufficiently durable and strong for racing = expensive.A perennial favourite argument on cycling forums is the cost-benefit of choosing a wheelset with superior aerodynamics vs a wheelset that is lighter (or an aero vs a lighter frame).
It is of course a false dichotomy that one must chose only one or the other. But that does not stop people having fun arguing the merits of each, or of holding onto beliefs/myths/folklore handed down through the generations.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Jun 22, 2013 12:50 pm
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Dec 13, 2014 8:34 am
This time I used realistic power profile for a standing start acceleration and for a sprint starting from speed. I also added a scenario of a hot dog crit turn at bottom of a hill.
The sum of the parts II
Pretty much the same conclusion as before (unsurprisingly). Wheel aero trumps wheel weight, unless your racing consists of sprints from very low speeds lasting only a handful of seconds, or riding up very steep gradients.
And before anyone goes on about ignoring other factors involved with wheel choice, please read the item and the earlier one where I go through this.
Postby ozstriker » Tue Mar 10, 2015 8:41 pm
http://www.reddit.com/r/Velo/comments/2 ... ng_weight/" onclick="window.open(this.href);return false;
Which pretty much backs up what Alex is saying
